0.0.0.0 collection server for about 3-4 Wu's straight
jkljohnnyr
Hello, i have been getting the 0.0.0.0 collection server for about 3-4 Wu's straight (Roughly 4 days and 4 hours worth of time).
I Installed it using a guide on Jiggmins folding teams section of the forum on jiggmins website (I know i can't posts links after i tried to post with a link) and after looking at the end of jiggmins post i clicked on the link for the GPU folding; then followed the steps and it worked for about a week with maybe 1 wu that had the collection server of 0.0.0.0.
Specs:
- AMD A6-3650 APU with Radeon(tm) HD Graphics 2.60 GHz
- 7.49 GB usable Ram
- 64 bit os
- Not sure on what type of GPU but i can assume some one can find that out from the install guide.
Specs:
- 64 bit os
Re: 0.0.0.0 collection server for about 3-4 Wu's straight
Welcome to the folding support forum jkljohnnyr!
Please post the client's log so we can see what's going on. If you're unsure how to do that see the Welcome link.
jkljohnnyr
Which part of it are you looking for? Mine is over the cap of allowed characters.
Here is the first part of it:
And here is the last part of it:
*********************** Log Started 2012-10-12T13:14:26Z ***********************
13:14:26:************************* Folding@home Client *************************
13:14:26: Website: http://folding.stanford.edu/
13:14:26: Copyright: (c) 2009-2012 Stanford University
13:14:26: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:14:26: Args: --lifeline 3068 --command-port=36330
13:14:26: Config: C:/Users/user/AppData/Roaming/FAHClient/config.xml
13:14:26:******************************** Build ********************************
13:14:26: Version: 7.1.52
13:14:26: Date: Mar 20 2012
13:14:26: Time: 19:37:42
13:14:26: SVN Rev: 3515
13:14:26: Branch: fah/trunk/client
13:14:26: Compiler: Intel(R) C++ MSVC 1500 mode 1200
13:14:26: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
13:14:26: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
13:14:26: Platform: win32 XP
13:14:26: Bits: 32
13:14:26: Mode: Release
13:14:26:******************************* System ********************************
13:14:26: CPU: AMD A6-3650 APU with Radeon(tm) HD Graphics
13:14:26: CPU ID: AuthenticAMD Family 18 Model 1 Stepping 0
13:14:26: CPUs: 4
13:14:26: Memory: 7.49GiB
13:14:26: Free Memory: 6.11GiB
13:14:26: Threads: WINDOWS_THREADS
13:14:26: On Battery: false
13:14:26: UTC offset: -5
13:14:26: PID: 4172
13:14:26: CWD: C:/Users/user/AppData/Roaming/FAHClient
13:14:26: OS: Windows 7 Home Premium
13:14:26: OS Arch: AMD64
13:14:26: GPUs: 1
13:14:26: GPU 0: ATI:4 BeaverCreek [Radeon HD 6530D]
13:14:26: CUDA: Not detected
13:14:26:Win32 Service: false
13:14:26:***********************************************************************
13:14:26:<config>
13:14:26: <service-description v='Folding@home Client'/>
13:14:26: <service-restart v='true'/>
13:14:26: <service-restart-delay v='5000'/>
13:14:26:
13:14:26: <!-- Client Control -->
13:14:26: <cycle-rate v='4'/>
13:14:26: <cycles v='-1'/>
13:14:26: <data-directory v='.'/>
13:14:26: <disable-project-lookup v='false'/>
13:14:26: <exec-directory v='C:\Program Files (x86)\FAHClient'/>
13:14:26: <exit-when-done v='false'/>
13:14:26: <threads v='4'/>
13:14:26:
13:14:26: <!-- Configuration -->
13:14:26: <config-rotate v='true'/>
13:14:26: <config-rotate-dir v='configs'/>
13:14:26: <config-rotate-max v='16'/>
13:14:26:
13:14:26: <!-- Debugging -->
13:14:26: <assignment-servers>
13:14:26: assign3.stanford.edu:8080 assign4.stanford.edu:80
13:14:26: </assignment-servers>
13:14:26: <capture-directory v='capture'/>
13:14:26: <capture-sockets v='false'/>
13:14:26: <debug-sockets v='false'/>
13:14:26: <exception-locations v='true'/>
13:14:26: <gpu-assignment-servers>
13:14:26: assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
13:14:26: </gpu-assignment-servers>
13:14:26: <stack-traces v='false'/>
13:14:26:
13:14:26: <!-- Error Handling -->
13:14:26: <max-slot-errors v='5'/>
13:14:26: <max-unit-errors v='5'/>
13:14:26:
13:14:26: <!-- FahCore Control -->
13:14:26: <checkpoint v='30'/>
13:14:26: <core-dir v='cores'/>
13:14:26: <core-priority v='idle'/>
13:14:26: <cpu-affinity v='false'/>
13:14:26: <cpu-usage v='100'/>
13:14:26: <no-assembly v='false'/>
13:14:26:
13:14:26: <!-- Folding Slot Configuration -->
13:14:26: <client-subtype v='STDCLI'/>
13:14:26: <client-type v='advanced'/>
13:14:26: <cpu-species v='X86_AMD'/>
13:14:26: <cpu-type v='AMD64'/>
13:14:26: <cpus v='-1'/>
13:14:26: <cuda-index v='0'/>
13:14:26: <extra-core-args v='-forceasm'/>
13:14:26: <gpu v='false'/>
13:14:26: <gpu-usage v='100'/>
13:14:26: <max-packet-size v='big'/>
13:14:26: <opencl-index v='0'/>
13:14:26: <os-species v='UNKNOWN'/>
13:14:26: <os-type v='WIN32'/>
13:14:26: <project-key v='0'/>
13:14:26: <smp v='true'/>
13:14:26:
13:14:26: <!-- Logging -->
13:14:26: <log v='log.txt'/>
13:14:26: <log-color v='false'/>
13:14:26: <log-crlf v='true'/>
13:14:26: <log-date v='false'/>
13:14:26: <log-date-periodically v='21600'/>
13:14:26: <log-debug v='true'/>
13:14:26: <log-domain v='false'/>
13:14:26: <log-header v='true'/>
13:14:26: <log-level v='true'/>
13:14:26: <log-no-info-header v='true'/>
13:14:26: <log-redirect v='false'/>
13:14:26: <log-rotate v='true'/>
13:14:26: <log-rotate-dir v='logs'/>
13:14:26: <log-rotate-max v='16'/>
13:14:26: <log-short-level v='false'/>
13:14:26: <log-simple-domains v='true'/>
13:14:26: <log-thread-id v='false'/>
13:14:26: <log-thread-prefix v='true'/>
13:14:26: <log-time v='true'/>
13:14:26: <log-to-screen v='true'/>
13:14:26: <log-truncate v='false'/>
13:14:26: <verbosity v='5'/>
13:14:26:
13:14:26: <!-- Network -->
13:14:26: <proxy v=':8080'/>
13:14:26: <proxy-enable v='false'/>
13:14:26: <proxy-pass v=''/>
13:14:26: <proxy-user v=''/>
13:14:26:
13:14:26: <!-- Process Control -->
13:14:26: <child v='false'/>
13:14:26: <daemon v='false'/>
13:14:26: <pid v='false'/>
13:14:26: <pid-file v='Folding@home Client.pid'/>
13:14:26: <respawn v='false'/>
13:14:26: <service v='false'/>
13:14:26:
13:14:26: <!-- Remote Command Server -->
13:14:26: <command-address v='0.0.0.0'/>
13:14:26: <command-allow v='127.0.0.1'/>
13:14:26: <command-allow-no-pass v='127.0.0.1'/>
13:14:26: <command-deny v='0.0.0.0/0'/>
13:14:26: <command-deny-no-pass v='0.0.0.0/0'/>
13:14:26: <command-port v='36330'/>
13:14:26:
13:14:26: <!-- Slot Control -->
13:14:26: <max-shutdown-wait v='60'/>
13:14:26: <pause-on-battery v='false'/>
13:14:26: <pause-on-start v='false'/>
13:14:26:
13:14:26: <!-- User Information -->
13:14:26: <machine-id v='0'/>
13:14:26: <passkey v='********************************'/>
13:14:26: <team v='143016'/>
13:14:26: <user v='jkljohnnyr'/>
13:14:26:
13:14:26: <!-- Work Unit Control -->
13:14:26: <dump-after-deadline v='true'/>
13:14:26: <max-queue v='16'/>
13:14:26: <max-units v='0'/>
13:14:26: <next-unit-percentage v='95'/>
13:14:26:
13:14:26: <!-- Folding Slots -->
13:14:26: <slot id='0' type='SMP'>
13:14:26: <cpus v='2'/>
13:14:26: </slot>
13:14:26: <slot id='1' type='GPU'/>
13:14:26:</config>
13:14:27:Trying to access database...
13:14:27:Successfully acquired database lock
13:14:27:Enabled folding slot 00: READY smp:2
13:14:27:Enabled folding slot 01: READY gpu:0:"BeaverCreek [Radeon HD 6530D]"
13:14:27:Started thread 3 on PID 4172
13:14:27:Started thread 1 on PID 4172
13:14:27:Started thread 5 on PID 4172
13:14:27:Started thread 4 on PID 4172
13:14:27:WU01:FS00:Starting
13:14:27:Started thread 6 on PID 4172
13:14:27:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Johnathan/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 701 -lifeline 4172 -checkpoint 30 -np 2 -forceasm
13:14:27:WU01:FS00:Started FahCore on PID 4224
13:14:27:Started thread 7 on PID 4172
13:14:27:WU01:FS00:Core PID:4236
13:14:27:WU01:FS00:FahCore 0xa4 started
13:14:27:WU00:FS01:Starting
13:14:27:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Johnathan/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 00 -suffix 01 -version 701 -lifeline 4172 -checkpoint 30 -gpu 0 -forceasm
13:14:27:WU00:FS01:Started FahCore on PID 4244
13:14:27:Started thread 8 on PID 4172
13:14:27:WU00:FS01:Core PID:4260
13:14:27:WU00:FS01:FahCore 0x16 started
13:14:27:WU01:FS00:0xa4:
13:14:27:WU01:FS00:0xa4:*------------------------------*
13:14:27:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
13:14:27:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
13:14:27:WU01:FS00:0xa4:Preparing to commence simulation
13:14:27:WU01:FS00:0xa4:- Ensuring status. Please wait.
13:14:27:WU00:FS01:0x16:
13:14:27:WU00:FS01:0x16:*------------------------------*
13:14:27:WU00:FS01:0x16:Folding@Home GPU Core
13:14:27:WU00:FS01:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
13:14:27:WU00:FS01:0x16:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
13:14:27:WU00:FS01:0x16:Build host: user-f6d030f24f
13:14:27:WU00:FS01:0x16:Board Type: AMD/OpenCL
13:14:27:WU00:FS01:0x16:Core : x=16
13:14:27:WU00:FS01:0x16: Window's signal control handler registered.
13:14:27:WU00:FS01:0x16:Preparing to commence simulation
13:14:27:WU00:FS01:0x16:- Ensuring status. Please wait.
13:14:28:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
13:14:28:Started thread 9 on PID 4172
13:14:36:WU01:FS00:0xa4:- Assembly optimizations manually forced on.
13:14:36:WU01:FS00:0xa4:- Not checking prior termination.
13:14:36:WU01:FS00:0xa4:- Expanded 51930 -> 195796 (decompressed 377.0 percent)
13:14:36:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=51930 data_size=195796, decompressed_data_size=195796 diff=0
13:14:36:WU01:FS00:0xa4:- Digital signature verified
13:14:36:WU01:FS00:0xa4:Project: 7019 (Run 0, Clone 20, Gen 45)
13:14:36:WU01:FS00:0xa4:Assembly optimizations on if available.
13:14:36:WU01:FS00:0xa4:Entering M.D.
13:14:37:WU00:FS01:0x16:- Assembly optimizations manually forced on.
13:14:37:WU00:FS01:0x16:- Not checking prior termination.
13:14:37:WU00:FS01:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
13:14:37:WU00:FS01:0x16:- Expanded 45056 -> 171163 (decompressed 379.8 percent)
13:14:37:WU00:FS01:0x16:Called DecompressByteArray: compressed_data_size=45056 data_size=171163, decompressed_data_size=171163 diff=0
13:14:37:WU00:FS01:0x16:- Digital signature verified
13:14:37:WU00:FS01:0x16:Project: 11293 (Run 15, Clone 283, Gen 32)
13:14:37:WU00:FS01:0x16:Assembly optimizations on if available.
13:14:37:WU00:FS01:0x16:Entering M.D.
13:14:39:WU00:FS01:0x16:Will resume from checkpoint file 00/wudata_01.ckp
13:14:39:WU00:FS01:0x16:Tpr hash 00/wudata_01.tpr: 385401384 3025942514 873259732 854069790 4098227664
13:14:39:WU00:FS01:0x16:Working on ALZHEIMER DISEASE AMYLOID
13:14:39:WU00:FS01:0x16:Client config unavailable.
13:14:39:WU00:FS01:0x16:Starting GUI Server
13:14:42:WU01:FS00:0xa4:Using Gromacs checkpoints
13:14:42:WU01:FS00:0xa4:Mapping NT from 2 to 2
13:14:43:WU00:FS01:0x16:Resuming from checkpoint
13:14:43:WU00:FS01:0x16:fcCheckPointResume: retreived and current tpr file hash:
13:14:43:WU00:FS01:0x16: 0 385401384 385401384
13:14:43:WU00:FS01:0x16: 1 3025942514 3025942514
13:14:43:WU00:FS01:0x16: 2 873259732 873259732
13:14:43:WU00:FS01:0x16: 3 854069790 854069790
13:14:43:WU00:FS01:0x16: 4 4098227664 4098227664
13:14:43:WU00:FS01:0x16:fcCheckPointResume: file hashes same.
13:14:43:WU00:FS01:0x16:fcCheckPointResume: state restored.
13:14:43:WU00:FS01:0x16:fcCheckPointResume: name 00/wudata_01.log Verified 00/wudata_01.log
13:14:43:WU00:FS01:0x16:fcCheckPointResume: name 00/wudata_01.trr Verified 00/wudata_01.trr
13:14:43:WU01:FS00:0xa4:Resuming from checkpoint
13:14:43:WU01:FS00:0xa4:Verified 01/wudata_01.log
13:14:43:WU00:FS01:0x16:fcCheckPointResume: name 00/wudata_01.xtc Verified 00/wudata_01.xtc
13:14:43:WU00:FS01:0x16:fcCheckPointResume: name 00/wudata_01.edr Verified 00/wudata_01.edr
13:14:43:WU00:FS01:0x16:fcCheckPointResume: state restored 2
13:14:43:WU00:FS01:0x16:Resumed from checkpointCode: Select all
19:06:49:WU02:FS01:0x16:*------------------------------*
19:06:49:WU02:FS01:0x16:Folding@Home GPU Core
19:06:49:WU02:FS01:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
19:06:49:WU02:FS01:0x16:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
19:06:49:WU02:FS01:0x16:Build host: user-f6d030f24f
19:06:49:WU02:FS01:0x16:Board Type: AMD/OpenCL
19:06:49:WU02:FS01:0x16:Core : x=16
19:06:49:WU02:FS01:0x16: Window's signal control handler registered.
19:06:49:WU02:FS01:0x16:Preparing to commence simulation
19:06:49:WU02:FS01:0x16:- Assembly optimizations manually forced on.
19:06:49:WU02:FS01:0x16:- Not checking prior termination.
19:06:49:WU02:FS01:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
19:06:49:WU02:FS01:0x16:- Expanded 45117 -> 171163 (decompressed 379.3 percent)
19:06:49:WU02:FS01:0x16:Called DecompressByteArray: compressed_data_size=45117 data_size=171163, decompressed_data_size=171163 diff=0
19:06:49:WU02:FS01:0x16:- Digital signature verified
19:06:49:WU02:FS01:0x16:Project: 11293 (Run 19, Clone 345, Gen 33)
19:06:49:WU02:FS01:0x16:Assembly optimizations on if available.
19:06:49:WU02:FS01:0x16:Entering M.D.
19:06:51:WU02:FS01:0x16:Tpr hash 02/wudata_01.tpr: 1058594420 3808631250 2452186751 3288793623 3484945488
19:06:51:WU02:FS01:0x16:Working on ALZHEIMER DISEASE AMYLOID
19:06:51:WU02:FS01:0x16:Client config unavailable.
19:06:51:WU02:FS01:0x16:Starting GUI Server
19:06:54:WU01:FS01:Upload 23.69%
19:06:55:WU02:FS01:0x16:Setting checkpoint frequency: 500000
19:06:55:WU02:FS01:0x16:Completed 3 out of 50000000 steps (0%).
19:07:00:WU01:FS01:Upload 52.66%
19:07:06:WU01:FS01:Upload 81.62%
19:07:10:WU01:FS01:Upload complete
19:07:10:WU01:FS01:Server responded WORK_ACK (400)
19:07:10:WU01:FS01:Final credit estimate, 1835.00 points
19:07:10:WU01:FS01:Cleaning up
19:09:14:WU00:FS00:0xa4:Completed 1820000 out of 2000000 steps (91%)
19:19:48:WU02:FS01:0x16:Completed 500000 out of 50000000 steps (1%).
19:29:15:WU00:FS00:0xa4:Completed 1840000 out of 2000000 steps (92%)
19:34:05:WU02:FS01:0x16:Completed 1000000 out of 50000000 steps (2%).
19:48:24:WU02:FS01:0x16:Completed 1500000 out of 50000000 steps (3%).
19:49:17:WU00:FS00:0xa4:Completed 1860000 out of 2000000 steps (93%)
20:02:50:WU02:FS01:0x16:Completed 2000000 out of 50000000 steps (4%).
20:09:39:WU00:FS00:0xa4:Completed 1880000 out of 2000000 steps (94%)
20:17:14:WU02:FS01:0x16:Completed 2500000 out of 50000000 steps (5%).
20:29:48:WU00:FS00:0xa4:Completed 1900000 out of 2000000 steps (95%)
20:29:49:WU01:FS00:Connecting to assign3.stanford.edu:8080
20:29:50:WU01:FS00:News: Welcome to Folding@Home
20:29:50:WU01:FS00:Assigned to work server 171.64.65.104
20:29:50:WU01:FS00:Requesting new work unit for slot 00: RUNNING smp:2 from 171.64.65.104
20:29:50:WU01:FS00:Connecting to 171.64.65.104:8080
20:29:51:WU01:FS00:Downloading 330.33KiB
20:29:55:WU01:FS00:Download complete
20:29:55:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:OK project:7610 run:532 clone:1 gen:27 core:0xa4 unit:0x00000029664f2dd04de6d49b6f6b1eb4
20:31:36:WU02:FS01:0x16:Completed 3000000 out of 50000000 steps (6%).
20:45:58:WU02:FS01:0x16:Completed 3500000 out of 50000000 steps (7%).
20:49:56:WU00:FS00:0xa4:Completed 1920000 out of 2000000 steps (96%)
21:00:20:WU02:FS01:0x16:Completed 4000000 out of 50000000 steps (8%).
21:10:01:WU00:FS00:0xa4:Completed 1940000 out of 2000000 steps (97%)
21:14:42:WU02:FS01:0x16:Completed 4500000 out of 50000000 steps (9%).
21:29:04:WU02:FS01:0x16:Completed 5000000 out of 50000000 steps (10%).
21:30:10:WU00:FS00:0xa4:Completed 1960000 out of 2000000 steps (98%)
21:43:27:WU02:FS01:0x16:Completed 5500000 out of 50000000 steps (11%).
******************************** Date: 18/10/12 ********************************
21:50:13:WU00:FS00:0xa4:Completed 1980000 out of 2000000 steps (99%)
21:57:49:WU02:FS01:0x16:Completed 6000000 out of 50000000 steps (12%).
22:10:11:WU00:FS00:0xa4:Completed 2000000 out of 2000000 steps (100%)
22:10:11:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
22:10:21:WU00:FS00:0xa4:
22:10:21:WU00:FS00:0xa4:Finished Work Unit:
22:10:21:WU00:FS00:0xa4:- Reading up to 488544 from "00/wudata_01.trr": Read 488544
22:10:21:WU00:FS00:0xa4:trr file hash check passed.
22:10:21:WU00:FS00:0xa4:- Reading up to 58084 from "00/wudata_01.xtc": Read 58084
22:10:21:WU00:FS00:0xa4:xtc file hash check passed.
22:10:21:WU00:FS00:0xa4:edr file hash check passed.
22:10:21:WU00:FS00:0xa4:logfile size: 40328
22:10:21:WU00:FS00:0xa4:Leaving Run
22:10:23:WU00:FS00:0xa4:- Writing 610872 bytes of core data to disk...
22:10:24:WU00:FS00:0xa4:Done: 610360 -> 548490 (compressed to 89.8 percent)
22:10:24:WU00:FS00:0xa4: ... Done.
22:10:25:WU00:FS00:0xa4:- Shutting down core
22:10:25:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
22:10:25:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:10:25:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:7611 run:2 clone:37 gen:232 core:0xa4 unit:0x0000015b664f2dd04df0f55a367ba418
22:10:25:WU00:FS00:Uploading 536.13KiB to 171.64.65.104
22:10:25:WU00:FS00:Connecting to 171.64.65.104:8080
22:10:25:WU01:FS00:Starting
22:10:25:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Johnathan/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 701 -lifeline 4172 -checkpoint 30 -np 2 -forceasm
22:10:25:WU01:FS00:Started FahCore on PID 5388
22:10:25:Started thread 24 on PID 4172
22:10:25:WU01:FS00:Core PID:5172
22:10:25:WU01:FS00:FahCore 0xa4 started
22:10:26:WU01:FS00:0xa4:
22:10:26:WU01:FS00:0xa4:*------------------------------*
22:10:26:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
22:10:26:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
22:10:26:WU01:FS00:0xa4:Preparing to commence simulation
22:10:26:WU01:FS00:0xa4:- Assembly optimizations manually forced on.
22:10:26:WU01:FS00:0xa4:- Not checking prior termination.
22:10:26:WU01:FS00:0xa4:- Expanded 337742 -> 644556 (decompressed 190.8 percent)
22:10:26:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=337742 data_size=644556, decompressed_data_size=644556 diff=0
22:10:26:WU01:FS00:0xa4:- Digital signature verified
22:10:26:WU01:FS00:0xa4:Project: 7610 (Run 532, Clone 1, Gen 27)
22:10:26:WU01:FS00:0xa4:Assembly optimizations on if available.
22:10:26:WU01:FS00:0xa4:Entering M.D.
22:10:30:WU00:FS00:Upload complete
22:10:30:WU00:FS00:Server responded WORK_ACK (400)
22:10:30:WU00:FS00:Final credit estimate, 4314.00 points
22:10:30:WU00:FS00:Cleaning up
22:10:31:WU01:FS00:0xa4:Mapping NT from 2 to 2
22:10:32:WU01:FS00:0xa4:Completed 0 out of 2000000 steps (0%)
22:12:11:WU02:FS01:0x16:Completed 6500000 out of 50000000 steps (13%).
22:26:33:WU02:FS01:0x16:Completed 7000000 out of 50000000 steps (14%).
22:31:38:WU01:FS00:0xa4:Completed 20000 out of 2000000 steps (1%)
22:40:55:WU02:FS01:0x16:Completed 7500000 out of 50000000 steps (15%).
22:52:40:WU01:FS00:0xa4:Completed 40000 out of 2000000 steps (2%)
22:55:17:WU02:FS01:0x16:Completed 8000000 out of 50000000 steps (16%).
23:09:39:WU02:FS01:0x16:Completed 8500000 out of 50000000 steps (17%).
23:13:43:WU01:FS00:0xa4:Completed 60000 out of 2000000 steps (3%)
23:19:35:WU02:FS01:Downloading project 11293 description
23:19:35:WU02:FS01:Connecting to fah-web.stanford.edu:80
23:19:35:WU02:FS01:Project 11293 description downloaded successfully
23:24:01:WU02:FS01:0x16:Completed 9000000 out of 50000000 steps (18%).
23:34:43:WU01:FS00:0xa4:Completed 80000 out of 2000000 steps (4%)
23:38:24:WU02:FS01:0x16:Completed 9500000 out of 50000000 steps (19%).
P5-133XL
Machine #2:
Machine 3:
What you supplied, while being very useful background information, does not show any attempt at the sending of any WU to any server which is your issue.
Incidentally, You may find that SMP:3 would produce more points than SMP:2 on your quad core processor. To my knowledge WU's do not have an issue with SMP:3 so it should be safe even though it is not even.
If your topic refers to: 13:14:28:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1 it has nothing to do with a collection server. It is the connection between FAHControl and FAHClient.
I would change that next-unit-percentage to 99 or 100 but other than that it looks good. Using 95 you're downloading the next SMP WU over an hour before it's actually getting processed which will delay the project and lessen your bonus points.
jkljohnnyr
Here is what you may be looking for:
I have been getting points to these Wu's that are going to the 0.0.0.0 server which is odd to me. Is that suppose to happen?
EDIT:
Ok, so what it says in the expert view for the collection server isn't the real collection server.
17:53:39:WU02:FS01:Connecting to assign-GPU.stanford.edu:80
17:53:39:WU02:FS01:News: Welcome to Folding@Home
17:53:39:WU02:FS01:Assigned to work server 171.67.108.44
17:53:39:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:"BeaverCreek [Radeon HD 6530D]" from 171.67.108.44
17:53:39:WU02:FS01:Connecting to 171.67.108.44:8080
17:53:40:WU02:FS01:Downloading 44.56KiB
17:53:40:WU02:FS01:Download complete
17:53:40:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:OK project:11293 run:19 clone:345 gen:33 core:0x16 unit:0x0000003a6652edbc4d94b8c5c96fb15d
18:07:56:WU01:FS01:0x16:Completed 48000000 out of 50000000 steps (96%).
18:09:03:WU00:FS00:0xa4:Completed 1760000 out of 2000000 steps (88%)
18:22:15:WU01:FS01:0x16:Completed 48500000 out of 50000000 steps (97%).
18:29:06:WU00:FS00:0xa4:Completed 1780000 out of 2000000 steps (89%)
18:36:34:WU01:FS01:0x16:Completed 49000000 out of 50000000 steps (98%).
18:49:09:WU00:FS00:0xa4:Completed 1800000 out of 2000000 steps (90%)
18:50:52:WU01:FS01:0x16:Completed 49500000 out of 50000000 steps (99%).
19:05:11:WU01:FS01:0x16:Completed 50000000 out of 50000000 steps (100%).
19:06:36:WU01:FS01:0x16:Finished fah_main
19:06:36:WU01:FS01:0x16:Successful run
19:06:36:WU01:FS01:0x16:DynamicWrapper: Finished Work Unit: sleep=10000
19:06:46:WU01:FS01:0x16:Reserved 2446912 bytes for xtc file; Cosm status=0
19:06:46:WU01:FS01:0x16:Allocated 2446912 bytes for xtc file
19:06:46:WU01:FS01:0x16:- Reading up to 2446912 from "01/wudata_01.xtc": Read 2446912
19:06:46:WU01:FS01:0x16:Read 2446912 bytes from xtc file; available packet space=783983552
19:06:46:WU01:FS01:0x16:xtc file hash check passed.
19:06:46:WU01:FS01:0x16:Reserved 75840 75840 783983552 bytes for arc file=<01/wudata_01.trr> Cosm status=0
19:06:46:WU01:FS01:0x16:Allocated 75840 bytes for arc file
19:06:46:WU01:FS01:0x16:- Reading up to 75840 from "01/wudata_01.trr": Read 75840
19:06:46:WU01:FS01:0x16:Read 75840 bytes from arc file; available packet space=783907712
19:06:46:WU01:FS01:0x16:trr file hash check passed.
19:06:46:WU01:FS01:0x16:Allocated 544 bytes for edr file
19:06:46:WU01:FS01:0x16:Read bedfile
19:06:46:WU01:FS01:0x16:edr file hash check passed.
19:06:46:WU01:FS01:0x16:Allocated 120006 bytes for logfile
19:06:46:WU01:FS01:0x16:Read logfile
19:06:46:WU01:FS01:0x16:GuardedRun: success in DynamicWrapper
19:06:46:WU01:FS01:0x16:GuardedRun: done
19:06:46:WU01:FS01:0x16:Run: GuardedRun completed.
19:06:46:WU01:FS01:0x16:+ Opened results file
19:06:46:WU01:FS01:0x16:- Writing 2643814 bytes of core data to disk...
19:06:47:WU01:FS01:0x16:Done: 2643302 -> 2488745 (compressed to 94.1 percent)
19:06:47:WU01:FS01:0x16: ... Done.
19:06:47:WU01:FS01:0x16:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
19:06:48:WU01:FS01:0x16:Shutting down core
19:06:48:WU01:FS01:0x16:Folding@home Core Shutdown: FINISHED_UNIT
19:06:48:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
19:06:48:WU01:FS01:Sending unit results: id:01 state:SEND error:OK project:11293 run:28 clone:393 gen:33 core:0x16 unit:0x000000396652edbc4d94babec5cded28
19:06:48:WU01:FS01:Uploading 2.37MiB to 171.67.108.44
19:06:48:WU01:FS01:Connecting to 171.67.108.44:8080
19:06:49:WU02:FS01:Starting
19:06:49:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Johnathan/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 701 -lifeline 4172 -checkpoint 30 -gpu 0 -forceasm
19:06:49:WU02:FS01:Started FahCore on PID 5516
19:06:49:Started thread 23 on PID 4172
19:06:49:WU02:FS01:Core PID:1864
19:06:49:WU02:FS01:FahCore 0x16 started
19:06:49:WU02:FS01:0x16:EDIT:
The WU is returned to the work server that it came from. Some projects do have an alternate collection server in case there's a problem with the work server, but others may not have a collection server set and they show 0.0.0.0 in the GUI but rest assured your work units are returning to the work server.
jkljohnnyr
