New Encountering A Problem
Packman1422
Post by Packman1422 »
I am new to F@H. I have been running it for a few weeks with no issues, but the last few days I have run into an issue. I cannot get F@H to process, and I am lost! Help please, and I apologize for my ignorance lol. :D
Re: New Encountering A Problem
Please post some information about your system such as which OS, and which version of the F@H client you are running. That may be easiest if you post the beginning section of your folding log file, and a section that shows the client not processing. If you enclose the log file between Code tags selected from the top of the Full Editor, that will place the entries in a scrollable box that makes it easier to read.
And welcome to the Folding Forum.
Packman1422
Joe_H wrote:Please post some information about your system such as which OS, and which version of the F@H client you are running. That may be easiest if you post the beginning section of your folding log file, and a section that shows the client not processing. If you enclose the log file between Code tags selected from the top of the Full Editor, that will place the entries in a scrollable box that makes it easier to read.
*********************** Log Started 2012-10-15T03:29:36Z ***********************
03:29:36:************************* Folding@home Client *************************
03:29:36:      Website: http://folding.stanford.edu/
03:29:36:    Copyright: (c) 2009-2012 Stanford University
03:29:36:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:29:36:         Args: --lifeline 7828 --command-port=36330
03:29:36:       Config: C:/Users/Joshua/AppData/Roaming/FAHClient/config.xml
03:29:36:******************************** Build ********************************
03:29:36:      Version: 7.1.52
03:29:36:         Date: Mar 20 2012
03:29:36:         Time: 19:37:42
03:29:36:      SVN Rev: 3515
03:29:36:       Branch: fah/trunk/client
03:29:36:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
03:29:36:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
03:29:36:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
03:29:36:     Platform: win32 XP
03:29:36:         Bits: 32
03:29:36:         Mode: Release
03:29:36:******************************* System ********************************
03:29:36:          CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 4000+
03:29:36:       CPU ID: AuthenticAMD Family 15 Model 107 Stepping 1
03:29:36:         CPUs: 2
03:29:36:       Memory: 1.94GiB
03:29:36:  Free Memory: 539.98MiB
03:29:36:      Threads: WINDOWS_THREADS
03:29:36:   On Battery: false
03:29:36:   UTC offset: -5
03:29:36:          PID: 2760
03:29:36:          CWD: C:/Users/Joshua/AppData/Roaming/FAHClient
03:29:36:           OS: Windows 7 Home Premium Service Pack 1
03:29:36:      OS Arch: X86
03:29:36:         GPUs: 0
03:29:36:         CUDA: Not detected
03:29:36:Win32 Service: false
03:29:36:***********************************************************************
03:29:37:<config>
03:29:37:  <!-- Folding Slot Configuration -->
03:29:37:  <gpu v='true'/>
03:29:37:
03:29:37:  <!-- Network -->
03:29:37:  <proxy v=':8080'/>
03:29:37:
03:29:37:  <!-- User Information -->
03:29:37:  <team v='222543'/>
03:29:37:  <user v='Joshua'/>
03:29:37:
03:29:37:  <!-- Folding Slots -->
03:29:37:  <slot id='0' type='SMP'>
03:29:37:    <cpus v='-1'/>
03:29:37:  </slot>
03:29:37:</config>
03:29:37:Trying to access database...
03:29:37:Successfully acquired database lock
03:29:37:Enabled folding slot 00: READY smp:2
03:29:37:WU00:FS00:Starting
03:29:37:WU00:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:/Users/Joshua/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 701 -lifeline 2760 -checkpoint 15 -np 2
03:29:38:WU00:FS00:Started FahCore on PID 7504
03:29:40:WU00:FS00:Core PID:5860
03:29:40:WU00:FS00:FahCore 0xa4 started
03:29:41:WU00:FS00:0xa4:
03:29:41:WU00:FS00:0xa4:*------------------------------*
03:29:41:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
03:29:41:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
03:29:41:WU00:FS00:0xa4:Preparing to commence simulation
03:29:41:WU00:FS00:0xa4:- Looking at optimizations...
03:29:41:WU00:FS00:0xa4:- Files status OK
03:29:41:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
03:29:41:WU00:FS00:0xa4:- Expanded 688269 -> 1533008 (decompressed 222.7 percent)
03:29:41:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=688269 data_size=1533008, decompressed_data_size=1533008 diff=0
03:29:41:WU00:FS00:0xa4:- Digital signature verified
03:29:41:WU00:FS00:0xa4:Project: 8056 (Run 81, Clone 24, Gen 1)
03:29:41:WU00:FS00:0xa4:Assembly optimizations on if available.
03:29:41:WU00:FS00:0xa4:Entering M.D.
03:29:47:WU00:FS00:0xa4:Mapping NT from 2 to 2
03:29:49:WU00:FS00:0xa4:Completed 0 out of 500000 steps  (0%)
Your configuration looks okay from what I can see in the log. You have a WU that looks like it has started for now. Could you post portions of an older log that shows your machine not processing?
Packman1422
I got it working again.
