For both memtestG80 and memtestCL,not able to send any results:
Running Debian Wheezy 64 bit
Internet/Network is working fine.
MemtestG80
| MemtestG80 v1.00 |
| Usage: memtestG80 [flags] [MB GPU RAM to test] [# iters] |
| Defaults: GPU 0, 128MB RAM, 50 test iterations |
| Amount of tested RAM will be rounded up to nearest 2MB |
Available flags:
--gpu N ,-g N : run test on the Nth (from 0) CUDA GPU
--license ,-l : show license terms for this build
--forcecomm, -f : DO send test results to Stanford (don't prompt)
--bancomm, -b : DO NOT send test results to Stanford (don't prompt)
--ramclock X , -r X: Specify RAM clock speed (for returned results) as X MHz
--coreclock X , -c X: Specify core/ROP clock speed (for returned results) as X MHz
Knowing the clock speeds at which your hardware runs is
very helpful. Please enter the clock speeds of the
following components (in MHz), or 0 if you do not know.
Please enter your RAM clock speed: 0
Please enter your GPU Core/ROP (non-shader) clock speed: 0
Running 2 iterations of tests over 1500 MB of GPU memory on card 0: GeForce GT 520
Running memory bandwidth test over 20 iterations of 750 MB transfers...
Estimated bandwidth 6479.48 MB/s
Test iteration 1 (GPU 0, 1500 MiB): 0 errors so far
Moving Inversions (ones and zeros): 0 errors (992 ms)
Memtest86 Walking 8-bit: 0 errors (7914 ms)
True Walking zeros (8-bit): 0 errors (3967 ms)
True Walking ones (8-bit): 0 errors (3973 ms)
Moving Inversions (random): 0 errors (992 ms)
Memtest86 Walking zeros (32-bit): 0 errors (15876 ms)
Memtest86 Walking ones (32-bit): 0 errors (15898 ms)
Random blocks: 0 errors (4159 ms)
Memtest86 Modulo-20: 0 errors (36264 ms)
Logic (one iteration): 0 errors (496 ms)
Logic (4 iterations): 0 errors (535 ms)
Logic (shared memory, one iteration): 0 errors (499 ms)
Logic (shared-memory, 4 iterations): 0 errors (776 ms)
Test iteration 2 (GPU 0, 1500 MiB): 0 errors so far
Moving Inversions (ones and zeros): 0 errors (990 ms)
Memtest86 Walking 8-bit: 0 errors (7916 ms)
True Walking zeros (8-bit): 0 errors (3972 ms)
True Walking ones (8-bit): 0 errors (3972 ms)
Moving Inversions (random): 0 errors (993 ms)
Memtest86 Walking zeros (32-bit): 0 errors (15879 ms)
Memtest86 Walking ones (32-bit): 0 errors (15899 ms)
Random blocks: 0 errors (4160 ms)
Memtest86 Modulo-20: 0 errors (36270 ms)
Logic (one iteration): 0 errors (497 ms)
Logic (shared memory, one iteration): 0 errors (495 ms)
Logic (shared-memory, 4 iterations): 0 errors (771 ms)
Final error count after 2 iterations over 1500 MiB of GPU memory: 0 errors
could not send data after three tries. Please check your network settings.
*** stack smashing detected ***: ./memtestG80 terminated
======= Backtrace: =========
/lib/x86_64-linux-gnu/libc.so.6(__fortify_fail+0x37)[0x7f1207b40f37]
/lib/x86_64-linux-gnu/libc.so.6(__fortify_fail+0x0)[0x7f1207b40f00]
./memtestG80[0x40a7d5]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xfd)[0x7f1207a72ead]
./memtestG80[0x403a89]
======= Memory map: ========
00400000-00461000 r-xp 00000000 fe:05 29363476 /home/xxxxxxxx/Downloads/memtestG80-1.1-linux64/memtestG80
00660000-00662000 rw-p 00060000 fe:05 29363476 /home/xxxxxxxx/Downloads/memtestG80-1.1-linux64/memtestG80
00914000-00a3b000 rw-p 00000000 00:00 0 [heap]
200000000-700000000 ---p 00000000 00:00 0
7f12047ec000-7f12047ff000 r-xp 00000000 fe:00 32447 /lib/x86_64-linux-gnu/libresolv-2.13.so
7f12047ff000-7f12049fe000 ---p 00013000 fe:00 32447 /lib/x86_64-linux-gnu/libresolv-2.13.so
7f12049fe000-7f12049ff000 r--p 00012000 fe:00 32447 /lib/x86_64-linux-gnu/libresolv-2.13.so
7f12049ff000-7f1204a00000 rw-p 00013000 fe:00 32447 /lib/x86_64-linux-gnu/libresolv-2.13.so
7f1204a00000-7f1204a02000 rw-p 00000000 00:00 0
7f1204a02000-7f1204a07000 r-xp 00000000 fe:00 34968 /lib/x86_64-linux-gnu/libnss_dns-2.13.so
7f1204a07000-7f1204c06000 ---p 00005000 fe:00 34968 /lib/x86_64-linux-gnu/libnss_dns-2.13.so
7f1204c06000-7f1204c07000 r--p 00004000 fe:00 34968 /lib/x86_64-linux-gnu/libnss_dns-2.13.so
7f1204c07000-7f1204c08000 rw-p 00005000 fe:00 34968 /lib/x86_64-linux-gnu/libnss_dns-2.13.so
7f1204c08000-7f1204c0a000 r-xp 00000000 fe:00 33201 /lib/libnss_mdns4_minimal.so.2
7f1204c0a000-7f1204e09000 ---p 00002000 fe:00 33201 /lib/libnss_mdns4_minimal.so.2
7f1204e09000-7f1204e0a000 rw-p 00001000 fe:00 33201 /lib/libnss_mdns4_minimal.so.2
7f1204e0a000-7f1204e15000 r-xp 00000000 fe:00 34978 /lib/x86_64-linux-gnu/libnss_files-2.13.so
7f1204e15000-7f1205014000 ---p 0000b000 fe:00 34978 /lib/x86_64-linux-gnu/libnss_files-2.13.so
7f1205014000-7f1205015000 r--p 0000a000 fe:00 34978 /lib/x86_64-linux-gnu/libnss_files-2.13.so
7f1205015000-7f1205016000 rw-p 0000b000 fe:00 34978 /lib/x86_64-linux-gnu/libnss_files-2.13.so
7f120502b000-7f120512b000 rw-s 1d9c5b000 00:05 3867 /dev/nvidia0
7f120512b000-7f120522b000 rw-s 1da051000 00:05 3867 /dev/nvidia0
7f120522b000-7f120532b000 rw-s 1dbdc9000 00:05 3867 /dev/nvidia0
7f120532b000-7f120542b000 rw-s 00000000 00:04 15569 /dev/zero (deleted)
7f120542b000-7f120552b000 rw-s 1d9cde000 00:05 3867 /dev/nvidia0
7f120552b000-7f120562b000 rw-s 00000000 00:04 15568 /dev/zero (deleted)
7f120562b000-7f120562c000 rw-s f7f66000 00:05 3867 /dev/nvidia0
7f120562c000-7f120562d000 rw-s 1d9cc2000 00:05 3867 /dev/nvidia0
7f120562d000-7f1205a2f000 rw-s 1da2cd000 00:05 3867 /dev/nvidia0
7f1205a2f000-7f1205e31000 rw-s 213dc9000 00:05 3867 /dev/nvidia0
7f1205e31000-7f1205e32000 ---p 00000000 00:00 0
7f1205e32000-7f1206632000 rwxp 00000000 00:00 0
7f1206632000-7f1206648000 r-xp 00000000 fe:00 32545 /lib/x86_64-linux-gnu/libz.so.1.2.7
7f1206648000-7f1206847000 ---p 00016000 fe:00 32545 /lib/x86_64-linux-gnu/libz.so.1.2.7
7f1206847000-7f1206848000 r--p 00015000 fe:00 32545 /lib/x86_64-linux-gnu/libz.so.1.2.7
7f1206848000-7f1206849000 rw-p 00016000 fe:00 32545 /lib/x86_64-linux-gnu/libz.so.1.2.7
7f1206849000-7f12070f2000 r-xp 00000000 fe:02 261796 /usr/lib/x86_64-linux-gnu/libcuda.so.304.48
7f12070f2000-7f12072f1000 ---p 008a9000 fe:02 261796 /usr/lib/x86_64-linux-gnu/libcuda.so.304.48
7f12072f1000-7f1207403000 rw-p 008a8000 fe:02 261796 /usr/lib/x86_64-linux-gnu/libcuda.so.304.48
7f1207403000-7f120742c000 rw-p 00000000 00:00 0
7f120742c000-7f1207443000 r-xp 00000000 fe:00 34980 /lib/x86_64-linux-gnu/libpthread-2.13.so
7f1207443000-7f1207642000 ---p 00017000 fe:00 34980 /lib/x86_64-linux-gnu/libpthread-2.13.so
7f1207642000-7f1207643000 r--p 00016000 fe:00 34980 /lib/x86_64-linux-gnu/libpthread-2.13.so
7f1207643000-7f1207644000 rw-p 00017000 fe:00 34980 /lib/x86_64-linux-gnu/libpthread-2.13.so
7f1207644000-7f1207648000 rw-p 00000000 00:00 0
7f1207648000-7f120764a000 r-xp 00000000 fe:00 34976 /lib/x86_64-linux-gnu/libdl-2.13.so
7f120764a000-7f120784a000 ---p 00002000 fe:00 34976 /lib/x86_64-linux-gnu/libdl-2.13.so
7f120784a000-7f120784b000 r--p 00002000 fe:00 34976 /lib/x86_64-linux-gnu/libdl-2.13.so
7f120784b000-7f120784c000 rw-p 00003000 fe:00 34976 /lib/x86_64-linux-gnu/libdl-2.13.so
7f120784c000-7f1207853000 r-xp 00000000 fe:00 34982 /lib/x86_64-linux-gnu/librt-2.13.so
7f1207853000-7f1207a52000 ---p 00007000 fe:00 34982 /lib/x86_64-linux-gnu/librt-2.13.so
7f1207a52000-7f1207a53000 r--p 00006000 fe:00 34982 /lib/x86_64-linux-gnu/librt-2.13.so
7f1207a53000-7f1207a54000 rw-p 00007000 fe:00 34982 /lib/x86_64-linux-gnu/librt-2.13.so
7f1207a54000-7f1207bd1000 r-xp 00000000 fe:00 32443 /lib/x86_64-linux-gnu/libc-2.13.so
7f1207bd1000-7f1207dd1000 ---p 0017d000 fe:00 32443 /lib/x86_64-linux-gnu/libc-2.13.so
7f1207dd1000-7f1207dd5000 r--p 0017d000 fe:00 32443 /lib/x86_64-linux-gnu/libc-2.13.so
7f1207dd5000-7f1207dd6000 rw-p 00181000 fe:00 32443 /lib/x86_64-linux-gnu/libc-2.13.so
7f1207dd6000-7f1207ddb000 rw-p 00000000 00:00 0
7f1207ddb000-7f1207df0000 r-xp 00000000 fe:00 32858 /lib/x86_64-linux-gnu/libgcc_s.so.1
7f1207df0000-7f1207ff0000 ---p 00015000 fe:00 32858 /lib/x86_64-linux-gnu/libgcc_s.so.1
7f1207ff0000-7f1207ff1000 rw-p 00015000 fe:00 32858 /lib/x86_64-linux-gnu/libgcc_s.so.1
7f1207ff1000-7f1208072000 r-xp 00000000 fe:00 34969 /lib/x86_64-linux-gnu/libm-2.13.so
7f1208072000-7f1208271000 ---p 00081000 fe:00 34969 /lib/x86_64-linux-gnu/libm-2.13.so
7f1208271000-7f1208272000 r--p 00080000 fe:00 34969 /lib/x86_64-linux-gnu/libm-2.13.so
7f1208272000-7f1208273000 rw-p 00081000 fe:00 34969 /lib/x86_64-linux-gnu/libm-2.13.so
7f1208273000-7f120835b000 r-xp 00000000 fe:02 271206 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.17
7f120835b000-7f120855b000 ---p 000e8000 fe:02 271206 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.17
7f120855b000-7f1208563000 r--p 000e8000 fe:02 271206 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.17
7f1208563000-7f1208565000 rw-p 000f0000 fe:02 271206 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.17
7f1208565000-7f120857a000 rw-p 00000000 00:00 0
7f120857a000-7f12085d5000 r-xp 00000000 fe:02 261828 /usr/lib/x86_64-linux-gnu/libcudart.so.4.2.9
7f12085d5000-7f12087d5000 ---p 0005b000 fe:02 261828 /usr/lib/x86_64-linux-gnu/libcudart.so.4.2.9
7f12087d5000-7f12087d6000 r--p 0005b000 fe:02 261828 /usr/lib/x86_64-linux-gnu/libcudart.so.4.2.9
7f12087d6000-7f12087d7000 rw-p 0005c000 fe:02 261828 /usr/lib/x86_64-linux-gnu/libcudart.so.4.2.9
7f12087d7000-7f12087d8000 rw-p 00000000 00:00 0
7f12087d8000-7f12087f8000 r-xp 00000000 fe:00 34984 /lib/x86_64-linux-gnu/ld-2.13.so
7f12088b7000-7f12088d8000 rw-p 00000000 00:00 0
7f12088d8000-7f12089d8000 rw-s 00000000 00:04 15564 /dev/zero (deleted)
7f12089d8000-7f12089d9000 r--s fd009000 00:05 3867 /dev/nvidia0
7f12089d9000-7f12089e0000 rw-p 00000000 00:00 0
7f12089f1000-7f12089f2000 rw-s f7f65000 00:05 3867 /dev/nvidia0
7f12089f2000-7f12089f3000 rw-s 1daa1b000 00:05 3867 /dev/nvidia0
7f12089f3000-7f12089f7000 rw-p 00000000 00:00 0
7f12089f7000-7f12089f8000 r--p 0001f000 fe:00 34984 /lib/x86_64-linux-gnu/ld-2.13.so
7f12089f8000-7f12089f9000 rw-p 00020000 fe:00 34984 /lib/x86_64-linux-gnu/ld-2.13.so
7f12089f9000-7f12089fa000 rw-p 00000000 00:00 0
7fff0cc5c000-7fff0cc7c000 rwxp 00000000 00:00 0 [stack]
7fff0cc7c000-7fff0cc7d000 rw-p 00000000 00:00 0
7fff0cd46000-7fff0cd47000 r-xp 00000000 00:00 0 [vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall]
Aborted
MemtestCL
| MemtestCL v1.00 |
| Usage: memtestCL [flags] [MB GPU RAM to test] [# iters] |
Available flags:
--platform N ,-p N : run test on the Nth (from 0) OpenCL platform
--gpu N ,-g N : run test on the Nth (from 0) OpenCL device
on selected platform
--ramclock X , -r X : Specify RAM clock speed (for returned results) as X MHz
--coreclock X , -c X : Specify core/ROP clock speed (for returned results) as X MHz
Available OpenCL platforms:
0: AMD Accelerated Parallel Processing (SELECTED)
Available OpenCL devices on selected platform:
0: AMD Athlon(tm) II X4 640 Processor (SELECTED)
Running 2 iterations of tests over 1500 MB of memory on device 0: AMD Athlon(tm) II X4 640 Processor
Estimated bandwidth 6454.39 MB/s
Test iteration 1 on 1500 MiB of memory on device 0 (AMD Athlon(tm) II X4 640 Processor): 0 errors so far
Moving Inversions (ones and zeros): 0 errors (1136 ms)
Moving Inversions (random): 0 errors (1141 ms)
Memtest86 Walking 8-bit: 0 errors (9059 ms)
True Walking zeros (8-bit): 0 errors (4554 ms)
True Walking ones (8-bit): 0 errors (4640 ms)
Memtest86 Walking zeros (32-bit): 0 errors (18779 ms)
Memtest86 Walking ones (32-bit): 0 errors (18181 ms)
Random blocks: 0 errors (3877 ms)
Memtest86 Modulo-20: 0 errors (269217 ms)
Logic (one iteration): 0 errors (581 ms)
Logic (4 iterations): 0 errors (574 ms)
Logic (local memory, one iteration): 0 errors (579 ms)
Logic (local memory, 4 iterations): 0 errors (575 ms)
Test iteration 2 on 1500 MiB of memory on device 0 (AMD Athlon(tm) II X4 640 Processor): 0 errors so far
Moving Inversions (ones and zeros): 0 errors (1182 ms)
Moving Inversions (random): 0 errors (1235 ms)
Memtest86 Walking 8-bit: 0 errors (9312 ms)
True Walking zeros (8-bit): 0 errors (4460 ms)
True Walking ones (8-bit): 0 errors (4517 ms)
Memtest86 Walking zeros (32-bit): 0 errors (18370 ms)
Memtest86 Walking ones (32-bit): 0 errors (18109 ms)
Random blocks: 0 errors (3961 ms)
Memtest86 Modulo-20: 0 errors (267582 ms)
Logic (one iteration): 0 errors (573 ms)
Logic (4 iterations): 0 errors (568 ms)
Logic (local memory, one iteration): 0 errors (561 ms)
Logic (local memory, 4 iterations): 0 errors (565 ms)
Test summary:
2 iterations over 1500 MiB of memory on device AMD Athlon(tm) II X4 640 Processor
Moving inversions (ones and zeros): 0 failed iterations
(0 total incorrect bits)
Memtest86 walking 8-bit: 0 failed iterations
True walking zeros (8-bit): 0 failed iterations
True walking ones (8-bit): 0 failed iterations
Moving inversions (random): 0 failed iterations
True walking zeros (32-bit): 0 failed iterations
True walking ones (32-bit): 0 failed iterations
Random blocks: 0 failed iterations
Memtest86 Modulo-20: 0 failed iterations
Integer logic: 0 failed iterations
Integer logic (4 loops): 0 failed iterations
Integer logic (local memory): 0 failed iterations
Integer logic (4 loops, local memory): 0 failed iterations
Final error count: 0 errors
Press <enter> to quit.
Uploading data...could not send data after three tries. Please check your network settings.
Thanks.
Mike
memtestG80/memtestCL - not able to send results
mdberrisford
P5-133XL
Machine #2:
Machine 3:
Re: memtestG80/memtestCL - not able to send results
Originally the developers that made these products were collecting data on memory failures. It's been several years and I don't think they are any more. It is still useful to the end user though.
