13:03:37] Completed 3250000 out of 5000000 steps (65 percent)
[13:13:17] Quit 101 - NaN detected: (ener[20])
[13:13:17]
[13:13:17] Simulation instability has been encountered. The run has entered a
[13:13:17] state from which no further progress can be made.
[13:13:17] This may be the correct result of the simulation, however if you
[13:13:17] often see other project units terminating early like this
[13:13:17] too, you may wish to check the stability of your computer (issues
[13:13:17] such as high temperature, overclocking, etc.).
[13:13:17] Going to send back what have done.
[13:13:17] logfile size: 90224
[13:13:17] - Writing 90774 bytes of core data to disk...
[13:13:17] ... Done.
[13:15:17]
[13:15:17] Folding@home Core Shutdown: EARLY_UNIT_END
[13:15:17]
[13:15:21] CoreStatus = 63 (99)
[13:15:21] + Error starting Folding@Home core or unexpected system termination of core.
[13:15:26]
[13:15:26] + Processing work unit
[13:15:26] Core required: FahCore_a1.exe
[13:15:26] Core found.
[13:15:26] Working on Unit 04 [April 24 13:15:26]
[13:15:26] + Working ...
[13:15:26] - Calling 'mpiexec -channel shm -env MPICH_USE_SMP_OPTIMIZATIONS 1 -np 4 FahCore_a1.exe -dir work/ -suffix 04 -checkpoint 15 -forceasm -verbose -lifeline 3500 -version 800'
[13:15:27]
[13:15:27] *------------------------------*
[13:15:27] Folding@Home Gromacs SMP Core
[13:15:27] Version 1.76 (February 23, 2008)
[13:15:27]
[13:15:27] Preparing to commence simulation
[13:15:27] - Ensuring status. Please wait.
[13:15:27]
[13:15:27] Folding@home Core Shutdown: MISSING_WORK_FILES
[13:15:27] Finalizing output
[13:17:44] NG_WORK_FILES
[13:17:44] Finalizing output
[13:17:49] CoreStatus = 1 (1)
[13:17:49] Client-core communications error: ERROR 0x1
[13:17:49] Deleting current work unit & continuing...
[13:20:09] - Warning: Could not delete all work unit files (4): Core returned invalid code
[13:20:09] Trying to send all finished work units
[13:20:09] + No unsent completed units remaining.
Project: 3062 (Run 5, Clone 51, Gen 24) : EUE at 65%
