attemting to get work packet
tommy_ber
Post by tommy_ber »
i think it always had say attemting to get work... but worked fine eny ways... myby i am wrong but now it stuck sinz months and i havent understand before now.
worked fine even if it says core not running all the time. sorry my english i am from sweden.
pleas help
Re: attemting to get work packet
Hello tommy_ber, welcome to the folding forum.
Please make sure you are running an SMP client v6.34 or newer. GPU client v6.41 or newer.
Tell us more about your setup, and post the log file contents.
tommy_ber
Post by tommy_ber »
[08:25:49] Gpu type=1 species=3.
[08:25:49] - Connecting to assignment server
[08:25:52] + No appropriate work server was available; will try again in a bit.
[08:25:52] + Couldn't get work instructions.
[08:25:52] - Attempt #21 to get work failed, and no other work to do.
Waiting before retry.
[09:13:54] + Attempting to get work packet
[09:13:54] Gpu type=1 species=3.
[09:13:54] - Connecting to assignment server
[09:13:56] + No appropriate work server was available; will try again in a bit.
[09:13:56] + Couldn't get work instructions.
[09:13:56] - Attempt #22 to get work failed, and no other work to do.
[10:01:56] + Attempting to get work packet
[10:01:56] Gpu type=1 species=3.
[10:01:56] - Connecting to assignment server
[10:01:58] + No appropriate work server was available; will try again in a bit.
[10:01:58] + Couldn't get work instructions.
[10:01:58] - Attempt #23 to get work failed, and no other work to do.
bollix47
Post by bollix47 »
What make and model of GPU?
What version of Windows?
You can see the version of v6 that you're using by looking at the top of the log (FAHlog.txt). Copy and paste the first 20 lines of the log.
Type 1 Species 3 in the log indicates a 4xxx series ATI GPU.
This older GPU went end of life more than a year ago. Work units finally ran out a month or two ago.
Here is the original EOL announcement from 2011 03 15: http://folding.typepad.com/news/2011/03 ... -gpus.html
You will want to shut down that GPU client. Folding on your CPU client should continue uninterrupted.
tommy_ber
Post by tommy_ber »
i hav now installed 7.1.52 an it says local online running
download 0.00 %
running 0.0%
never eny problem in 2-3 yers so wat am i going too do. in this klient i can not find eny log file
tommy_ber
Post by tommy_ber »
okey how do i shut down gpu client?
bollix47
Post by bollix47 »
Configure > Slots > Click on the GPU slot > Remove > Save
tommy_ber
Post by tommy_ber »
i dont get this at all can i not run this .
Windows: V6 GPU2 (ATI 2xxx - 5xxx; nVidia) clients
Windows XP/2003/Vista/7 GPU2 System tray client (installer msi)
pleas give me a link too somthing that work whit my computer set up. only cpu klient if thats the only opurtunity
spm stands for cpu client?
i
tommy_ber
Post by tommy_ber »
this Configure > Slots > Click on the GPU slot > Remove > Save dos not even exist in that folding program i was running :s
bollix47
Post by bollix47 »
If you're running as a Novice (top right of FAHControl screen) click on the down arrow and change to Advanced or Expert. Then try the procedure again.
SMP is used for computers that have multiple cores/threads.
If you want us to suggest a client and slot type to use on your computer setup how about telling us something about your computer setup like your cpu type.
All the required info is in the System Info at the top(Refresh and scroll up) of the log.
tommy_ber
Post by tommy_ber »
now i run folding at home 7.1.52 ..... dos it alway start whit demo protein? then i dont now befor that is don in 6 hours
so i gues i whait and se, and come back if it is the same problem or as i asked give me a link to somthing that worke (mayby only cpu client) . this whit GPU slot > Remove > Save dident help me ... never sean that chose in the program
tommy_ber
Post by tommy_ber »
okey i tray Advanced or Expert. and come back
tommy_ber
Post by tommy_ber »
here is a log tell me if it's fine or any problem.
14:17:38:      Website: http://folding.stanford.edu/
14:17:38:    Copyright: (c) 2009-2012 Stanford University
14:17:38:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:17:38:         Args: --lifeline 2076 --command-port=36330
14:17:38:       Config: C:/Users/tergryt/AppData/Roaming/FAHClient/config.xml
14:17:38:******************************** Build ********************************
14:17:38:      Version: 7.1.52
14:17:38:         Date: Mar 20 2012
14:17:38:         Time: 19:37:42
14:17:38:      SVN Rev: 3515
14:17:38:       Branch: fah/trunk/client
14:17:38:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
14:17:38:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
14:17:38:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
14:17:38:     Platform: win32 XP
14:17:38:         Bits: 32
14:17:38:         Mode: Release
14:17:38:******************************* System ********************************
14:17:38:          CPU: AMD FX(tm)-4100 Quad-Core Processor
14:17:38:       CPU ID: AuthenticAMD Family 21 Model 1 Stepping 2
14:17:38:         CPUs: 4
14:17:38:       Memory: 7.98GiB
14:17:38:  Free Memory: 5.86GiB
14:17:38:      Threads: WINDOWS_THREADS
14:17:38:   On Battery: false
14:17:38:   UTC offset: 2
14:17:38:          PID: 3592
14:17:38:          CWD: C:/Users/tergryt/AppData/Roaming/FAHClient
14:17:38:           OS: Windows 7 Ultimate
14:17:38:      OS Arch: AMD64
14:17:38:         GPUs: 1
14:17:38:        GPU 0: ATI:3 RV770 [Radeon HD 4850]
14:17:38:         CUDA: Not detected
14:17:38:Win32 Service: false
14:17:38:***********************************************************************
14:17:39:<config>
14:17:39:  <!-- User Information -->
14:17:39:  <team v='37451'/>
14:17:39:  <user v='tommy_ber_bommy'/>
14:17:39:
14:17:39:  <!-- Folding Slots -->
14:17:39:</config>
14:17:39:Trying to access database...
14:17:39:Successfully acquired database lock
14:17:39:Enabled folding slot 00: READY smp:4
14:17:39:WU00:FS00:Connecting to assign3.stanford.edu:8080
14:17:40:WU00:FS00:Connecting to assign3.stanford.edu:8080
14:17:40:WU00:FS00:News: Welcome to Folding@Home
14:17:40:WU00:FS00:Assigned to work server 171.67.108.58
14:17:40:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.58
14:17:40:WU00:FS00:Connecting to 171.67.108.58:8080
14:17:41:WU00:FS00:Downloading 532.27KiB
14:17:42:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
14:17:44:WU00:FS00:Download complete
14:17:44:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:OK project:8001 run:70 clone:82 gen:45 core:0xa4 unit:0x000000426652edca4ededd93ad0bcf5a
14:17:44:WU00:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
14:17:44:WU00:FS00:Connecting to http://www.stanford.edu:80
14:17:45:WU00:FS00:FahCore a4: Downloading 2.89MiB
14:17:51:WU00:FS00:FahCore a4: 23.81%
14:17:57:WU00:FS00:FahCore a4: 51.94%
14:18:03:WU00:FS00:FahCore a4: 77.91%
14:18:07:WU00:FS00:FahCore a4: Download complete
14:18:07:WU00:FS00:Valid core signature
14:18:08:WU00:FS00:Unpacked 9.59MiB to cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe
14:18:08:WU00:FS00:Starting
14:18:08:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/tergryt/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 701 -lifeline 3592 -checkpoint 15 -np 4
14:18:08:WU00:FS00:Started FahCore on PID 2044
14:18:08:WU00:FS00:Core PID:1400
14:18:08:WU00:FS00:FahCore 0xa4 started
14:18:08:WU00:FS00:Downloading project 8001 description
14:18:08:WU00:FS00:Connecting to fah-web.stanford.edu:80
14:18:08:WU00:FS00:0xa4:
14:18:08:WU00:FS00:0xa4:*------------------------------*
14:18:08:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
14:18:08:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
14:18:08:WU00:FS00:0xa4:Preparing to commence simulation
14:18:08:WU00:FS00:0xa4:- Looking at optimizations...
14:18:08:WU00:FS00:0xa4:- Created dyn
14:18:08:WU00:FS00:0xa4:- Files status OK
14:18:08:WU00:FS00:0xa4:- Expanded 544531 -> 1305024 (decompressed 239.6 percent)
14:18:08:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=544531 data_size=1305024, decompressed_data_size=1305024 diff=0
14:18:08:WU00:FS00:0xa4:- Digital signature verified
14:18:08:WU00:FS00:0xa4:Project: 8001 (Run 70, Clone 82, Gen 45)
14:18:08:WU00:FS00:0xa4:Assembly optimizations on if available.
14:18:08:WU00:FS00:0xa4:Entering M.D.
14:18:09:WU00:FS00:Project 8001 description downloaded successfully
14:18:14:WU00:FS00:0xa4:Mapping NT from 4 to 4
14:18:38:Server connection id=2 on 0.0.0.0:36330 from 127.0.0.1
14:29:07:WU00:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
14:32:02:WU00:FS00:0xa4:Completed 2500 out of 250000 steps  (1%)
14:34:43:WU00:FS00:0xa4:Completed 5000 out of 250000 steps  (2%)
14:38:09:WU00:FS00:0xa4:Completed 7500 out of 250000 steps  (3%)
14:41:00:WU00:FS00:0xa4:Completed 10000 out of 250000 steps  (4%)
14:43:47:WU00:FS00:0xa4:Completed 12500 out of 250000 steps  (5%)
14:46:36:WU00:FS00:0xa4:Completed 15000 out of 250000 steps  (6%)
14:49:36:WU00:FS00:0xa4:Completed 17500 out of 250000 steps  (7%)
bollix47
Post by bollix47 »
Log looks good.
As 7im already stated your GPU is no longer supported but you are using SMP:4 and for your setup that is your best option for now.
