returning to folding, problems with 680?
nuttcase21
Hardware configuration: Rig 1: Asus P5E-VM HDMI mobo
Xeon X3350 @ 3.4 gigs
4 gigs of gskill pc2-8500 ram
ATI 3870 vid card
74 gig Raptor HDD
Vista Ultimate 64 bit
Custom water cooling in a Lian pc-350 case
Post by nuttcase21 »
i just started folding again and i'm having a few issues. first of all i'm running the latest v7 and my cpu is folding fine (3930k, 12 cores all @ 100%) but my gpu isn't folding a thing. i downloaded the latest GPUs.txt file and installed it in the data folder. started the client and like i said, i get the cpu to fold, but nothing for the gpu. looked on the forums here and found the device id needs changed for the 680. so i closed the client, changed the 680's device id line in the GPUs.txt file, saved it, and then restarted the client and still nothing. looking at the "folding slots" window in the client shows that the gpu is running, but the device name is still GF114, not the GK104 i changed it to. any suggestions? here's the log:
*********************** Log Started 2012-10-03T17:59:22Z ***********************
17:59:22:************************* Folding@home Client *************************
17:59:22:      Website: http://folding.stanford.edu/
17:59:22:    Copyright: (c) 2009-2012 Stanford University
17:59:22:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:59:22:         Args: --lifeline 21620 --command-port=36330
17:59:22:       Config: C:/Users/Jay/AppData/Roaming/FAHClient/config.xml
17:59:22:******************************** Build ********************************
17:59:22:      Version: 7.1.52
17:59:22:         Date: Mar 20 2012
17:59:22:         Time: 19:37:42
17:59:22:      SVN Rev: 3515
17:59:22:       Branch: fah/trunk/client
17:59:22:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
17:59:22:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
17:59:22:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
17:59:22:     Platform: win32 XP
17:59:22:         Bits: 32
17:59:22:         Mode: Release
17:59:22:******************************* System ********************************
17:59:22:          CPU: Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz
17:59:22:       CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
17:59:22:         CPUs: 12
17:59:22:       Memory: 15.98GiB
17:59:22:  Free Memory: 13.25GiB
17:59:22:      Threads: WINDOWS_THREADS
17:59:22:   On Battery: false
17:59:22:   UTC offset: -5
17:59:22:          PID: 22748
17:59:22:          CWD: C:/Users/Jay/AppData/Roaming/FAHClient
17:59:22:           OS: Windows 7 Ultimate
17:59:22:      OS Arch: AMD64
17:59:22:         GPUs: 1
17:59:22:        GPU 0: FERMI:1 GF114 [GeForce GTX 680]
17:59:22:         CUDA: 3.0
17:59:22:  CUDA Driver: 5000
17:59:22:Win32 Service: false
17:59:22:***********************************************************************
17:59:22:<config>
17:59:22:  <!-- Folding Slot Configuration -->
17:59:22:  <gpu v='true'/>
17:59:22:
17:59:22:  <!-- Network -->
17:59:22:  <proxy v=':8080'/>
17:59:22:
17:59:22:  <!-- User Information -->
17:59:22:  <passkey v='********************************'/>
17:59:22:  <team v='11314'/>
17:59:22:  <user v='nuttcase21'/>
17:59:22:
17:59:22:  <!-- Folding Slots -->
17:59:22:  <slot id='0' type='GPU'/>
17:59:22:  <slot id='1' type='SMP'/>
17:59:22:</config>
17:59:22:Trying to access database...
17:59:22:Successfully acquired database lock
17:59:22:Enabled folding slot 00: READY gpu:0:"GF114 [GeForce GTX 680]"
17:59:22:Enabled folding slot 01: READY smp:12
17:59:22:WU00:FS00:Starting
17:59:22:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Jay/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 00 -suffix 01 -version 701 -lifeline 22748 -checkpoint 15 -gpu 0
17:59:22:WU00:FS00:Started FahCore on PID 22108
17:59:22:WU00:FS00:Core PID:23048
17:59:22:WU00:FS00:FahCore 0x15 started
17:59:22:WU01:FS01:Starting
17:59:22:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Jay/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 701 -lifeline 22748 -checkpoint 15 -np 12
17:59:23:WU01:FS01:Started FahCore on PID 23272
17:59:23:WU01:FS01:Core PID:22180
17:59:23:WU01:FS01:FahCore 0xa4 started
17:59:23:WU00:FS00:0x15:
17:59:23:WU00:FS00:0x15:*------------------------------*
17:59:23:WU00:FS00:0x15:Folding@Home GPU Core
17:59:23:WU00:FS00:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
17:59:23:WU00:FS00:0x15:Build host             SimbiosNvdWin7
17:59:23:WU00:FS00:0x15:Board Type             NVIDIA/CUDA
17:59:23:WU00:FS00:0x15:Core                   15
17:59:23:WU00:FS00:0x15:Window's signal control handler registered.
17:59:23:WU00:FS00:0x15:Preparing to commence simulation
17:59:23:WU00:FS00:0x15:- Looking at optimizations...
17:59:23:WU00:FS00:0x15:- Files status OK
17:59:23:WU00:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
17:59:23:WU00:FS00:0x15:- Expanded 126474 -> 507182 (decompressed 401.0 percent)
17:59:23:WU01:FS01:0xa4:
17:59:23:WU00:FS00:0x15:Called DecompressByteArray: compressed_data_size=126474 data_size=507182, decompressed_data_size=507182 diff=0
17:59:23:WU01:FS01:0xa4:*------------------------------*
17:59:23:WU00:FS00:0x15:- Digital signature verified
17:59:23:WU01:FS01:0xa4:Folding@Home Gromacs GB Core
17:59:23:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
17:59:23:WU00:FS00:0x15:Project: 7626 (Run 201, Clone 0, Gen 29)
17:59:23:WU01:FS01:0xa4:Preparing to commence simulation
17:59:23:WU00:FS00:0x15:Assembly optimizations on if available.
17:59:23:WU01:FS01:0xa4:- Looking at optimizations...
17:59:23:WU00:FS00:0x15:Entering M.D.
17:59:23:WU01:FS01:0xa4:- Files status OK
17:59:23:WU01:FS01:0xa4:- Expanded 963067 -> 2211116 (decompressed 229.5 percent)
17:59:23:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=963067 data_size=2211116, decompressed_data_size=2211116 diff=0
17:59:23:WU01:FS01:0xa4:- Digital signature verified
17:59:23:WU01:FS01:0xa4:Project: 8049 (Run 501, Clone 16, Gen 23)
17:59:23:WU01:FS01:0xa4:Assembly optimizations on if available.
17:59:23:WU01:FS01:0xa4:Entering M.D.
17:59:25:WU00:FS00:0x15:Tpr hash 00/wudata_01.tpr:  3225335712 998962500 612323984 1239580999 504153450
17:59:25:WU00:FS00:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
17:59:25:WU00:FS00:0x15:Working on Protein
17:59:25:WU00:FS00:0x15:Client config unavailable.
17:59:25:WU00:FS00:0x15:Starting GUI Server
17:59:26:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
17:59:29:WU01:FS01:0xa4:Using Gromacs checkpoints
17:59:29:WU01:FS01:0xa4:Mapping NT from 12 to 12
17:59:35:WU01:FS01:0xa4:Resuming from checkpoint
17:59:35:WU01:FS01:0xa4:Verified 01/wudata_01.log
17:59:35:WU01:FS01:0xa4:Verified 01/wudata_01.trr
17:59:35:WU01:FS01:0xa4:Verified 01/wudata_01.xtc
17:59:35:WU01:FS01:0xa4:Verified 01/wudata_01.edr
18:00:23:WU01:FS01:0xa4:Completed 24580 out of 250000 steps  (9%)
18:00:34:Server connection id=2 on 0.0.0.0:36330 from 127.0.0.1
18:00:35:WARNING:WU01:FS01:Detected clock skew, adjusting time estimates
18:00:35:Server connection id=1 ended
18:00:59:WU01:FS01:0xa4:Completed 25000 out of 250000 steps  (10%)
18:02:11:WU01:FS01:0xa4:Completed 27500 out of 250000 steps  (11%)
18:03:21:WU01:FS01:0xa4:Completed 30000 out of 250000 steps  (12%)
18:03:32:Server connection id=3 on 0.0.0.0:36330 from 127.0.0.1
18:03:35:Server connection id=2 ended
18:08:18:WU01:FS01:0xa4:Completed 32500 out of 250000 steps  (13%)
Zagen30
Re: returning to folding, problems with 680?
Post by Zagen30 »
bollix47
Post by bollix47 »
The system doesn't work that way. The device ids have to be added to the GPUs.txt file that's on the server. Please post the ids here as explained in viewtopic.php?f=83&t=21205 .
nuttcase21
ATI 3870 vid card
74 gig Raptor HDD
i figured some of it out after i posted the thread. i now understand that the gpus.txt file needs to be copied and pasted into the data folder, but also, the servers file needs to be updated as well. thats why it's still showing GF114 in the id line for the client (its getting that info from the server). i ended up using the beta command and it's working now, but i'm assuming at a slower ppd until the server gets straightened out, am i correct?
nuttcase21 wrote:i figured some of it out after i posted the thread. i now understand that the gpus.txt file needs to be copied and pasted into the data folder, but also, the servers file needs to be updated as well. thats why it's still showing GF114 in the id line for the client (its getting that info from the server). i ended up using the beta command and it's working now, but i'm assuming at a slower ppd until the server gets straightened out, am i correct?
The new beta V7.2.9 eliminates the need to manually copy/paste GPUs.txt but the server file still needs to be updated.
The beta command is a temporary work-around so plan on discontinuing that practice unless you plan to actively participate in beta testing. I'm sure you'll hear about the change when it happens. PPD should not change either way.
Jonas98
Post by Jonas98 »
I have this problem as well running a new, clean installation of V7.2.9, windows version. I have been using the beta command to run my two 680s as Fermi for quite some time without problems but this shouldn't be necessary any more, I understand? However, after cleaning up previous installations and starting from scratch FAHClient insists that I have two "NVIDIA:2 GF114 [GeForce GTX 680]" in my system.
The Windows Device Manager identifies the cards as "PCI\VEN_10DE&DEV_1180" and GPUs.txt says "0x10de:0x1180:2:3:GK104 [GeForce GTX 680]" and still, when I run "FAHClient.exe --lspci" it says:
0x10de:0x0e0a:NVIDIA Corporation:High Definition Audio-styrenhet
0x10de:0x1180:NVIDIA Corporation:GF114 [GeForce GTX 680]
I've been searching for any possible remnants of previous installations that may mess this up but can't find any. I don't understand why my cards would be identified as GF114.
Ideas, anybody?
When you installed 7.2.9, did you retain the setup and data from a previous install? There has been reports of similar problems after an update to install 7.2.9 that required deleting the slot and recreating it for the GPU. Also delete your local copy of GPUs.txt to cause a new download to be certain the current one is there.
Jonas98
Post by Jonas98 »
Thanks for helping, Joe!
After I first got this problem I uninstalled everything FAH and checked that all the files and directories were gone. Then I scanned the hard drive for GPUs.txt and even for any file on the whole drive containing the string "GF114", including the registry. Nothing. Installed again, started, and checked the new downloaded GPUs.txt which looked fine. Still FAHClient insisted on my card being Fermi.
I must have missed something but I have run out of things to try. Except formatting the hard drive, I guess, but I'm not that frustrated. Yet.
n_w95482
Hardware configuration: CPU: Ryzen 7 5800X3D
GPU: Radeon RX 6700 XT, Radeon RX 6900 XT
Post by n_w95482 »
My 680 (EVGA Superclocked+) is also being detected as GF114. I'm using 7.2.9 and just deleted GPUs.txt followed by a client restart. Having said that, it appears to be folding fine (and generating a TON of PPD).
I'm on a new Windows 8 x64 install, using the 310.70 drivers.
Folding since December 2003. In memory of my mother, who lost her battle with cancer.
That's difficult to understand since
1) The current version on the server says 0x10de:0x1180:2:3:GK104 [GeForce GTX 680]
2) V7.2.9 should automatically download the latest version.
3) Maybe you have more that one copy of GPUs.txt. If you find a copy that says GF104, feel free to manually replace that copy with the one I linked in item 1.
n_w95482
Post by n_w95482 »
My copy says GK104, and I only have one copy. Everywhere I've looked in the client and GPU slot log references GF114 for the video card though. Perhaps a bug in the client?
bollix47
Post by bollix47 »
There was a typo in GPUs.txt back in early November but that was fixed.
Try the following:
1. Pause your slots and Quit FAHControl
2. If you normally start FAHClient before FAHControl you will have a FAHClient dos-like screen ... ctrl-c to end it.
3. Click on Start>All Programs>FAHClient>Data Directory
4. Right click on GPUs or GPUs.txt and select delete
5. Start up folding in your usual way
If it doesn't show GK104 in the log after doing the above the only other suggestion I've seen is to Finish the GPU slot and Remove and Add it back. That may be your solution. Perhaps when you first added your GPU slot you had the file with the typo and your GPU was initially identified as a GF114 and even updating the file might not 'fix' that without removing the slot and adding it back.
Perhaps your copy of GPUs.txt is not located in the proper place. As bollix47 has said, there was a typo in an earlier version of GPUs.txt and it did say GF114.
Stop FAHClient as suggested above. Restart FAHClient using the shortcut that the FAH installer put in All_Programs, creating the DOS-like window. Allow it to run long enough to confirm whether it says GK or GF. Type CTRL-C to stop FAHClient but do not close the DOS window. Type dir and confirm that GPUs.txt is present. Note the date of the file.
Type more<GPUs.txt which will display the file, one page at a time. (Press space to advance to the next page.) On or near page 68, you'll find the 680. (They're in order by the 0x10de:0x1180 part.)
Delete the file with del GPUs.txt. Restart FAHClient using the same shortcut.
n_w95482
Post by n_w95482 »
I installed Windows on my PC on December 10th, with a fresh install of F@H at that time. I just deleted GPUs.txt a second time and watched it get recreated, the client still lists GF114. I'm not too concerned about it as it's folding fine for me. I opened the file and verified that the card is listed in there (0x10de:0x1180:2:3:GK104 [GeForce GTX 680]).
Dark_n_Beyond
Post by Dark_n_Beyond »
I have the same issue, client lists GF114. However, I've been having nothing but problems the last few weeks, and I wonder if this is somehow related? Seems that some projects fold fine, others come up with "unstable machine" and/or early end. I really don't think it's my hardware, because I just spent a week running benchmarks and had no issues at all (all very good scores in fact). I thought maybe it was updating the driver when 310.70 became WHQL, but to try and narrow it down I just did a fresh install of Windows today and used the driver I was using before. I'm kind of at my wits end here.
