ATI 5670 / 12.8 drivers (fails to start)
curecompute
Post by curecompute »
Downloaded the 7.1.52 version and while a bit confusing at first, I seem to manage my way through it. I'm trying to only use the GPU (there's no motherboard GPU) but it always seems to fail after a couple of attempts. I've also disabled my firewall/security software (Outpost). The Catalyst control centre is not installed, just the 12.8 driver. Thanks.
*********************** Log Started 2012-10-01T16:24:34Z ***********************
16:24:34:************************* Folding@home Client *************************
16:24:34:      Website: http://folding.stanford.edu/
16:24:34:    Copyright: (c) 2009-2012 Stanford University
16:24:34:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:24:34:         Args: --lifeline 4208 --command-port=36330
16:24:34:       Config: E:/FAHClient/config.xml
16:24:34:******************************** Build ********************************
16:24:34:      Version: 7.1.52
16:24:34:         Date: Mar 20 2012
16:24:34:         Time: 19:37:42
16:24:34:      SVN Rev: 3515
16:24:34:       Branch: fah/trunk/client
16:24:34:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
16:24:34:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
16:24:34:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
16:24:34:     Platform: win32 XP
16:24:34:         Bits: 32
16:24:34:         Mode: Release
16:24:34:******************************* System ********************************
16:24:34:          CPU: Intel(R) Core(TM)2 Quad CPU Q9650 @ 3.00GHz
16:24:34:       CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
16:24:34:         CPUs: 4
16:24:34:       Memory: 4.00GiB
16:24:34:  Free Memory: 2.12GiB
16:24:34:      Threads: WINDOWS_THREADS
16:24:34:   On Battery: false
16:24:34:   UTC offset: 3
16:24:34:          PID: 1908
16:24:34:          CWD: E:/FAHClient
16:24:34:           OS: Windows 7 Professional
16:24:34:      OS Arch: AMD64
16:24:34:         GPUs: 1
16:24:34:        GPU 0: ATI:4 Redwood [Radeon HD 5670]
16:24:34:         CUDA: Not detected
16:24:34:Win32 Service: false
16:24:34:***********************************************************************
16:24:34:<config>
16:24:34:  <!-- Folding Slot Configuration -->
16:24:34:  <gpu v='true'/>
16:24:34:  <smp v='false'/>
16:24:34:
16:24:34:  <!-- Network -->
16:24:34:  <proxy v=':8080'/>
16:24:34:
16:24:34:  <!-- Folding Slots -->
16:24:34:  <slot id='0' type='GPU'/>
16:24:34:</config>
16:24:34:Trying to access database...
16:24:34:Successfully acquired database lock
16:24:34:Enabled folding slot 00: READY gpu:0:"Redwood [Radeon HD 5670]"
16:24:34:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
16:24:34:WU00:FS00:News: Welcome to Folding@Home
16:24:34:WU00:FS00:Assigned to work server 171.67.108.44
16:24:34:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"Redwood [Radeon HD 5670]" from 171.67.108.44
16:24:34:WU00:FS00:Connecting to 171.67.108.44:8080
16:24:35:WU00:FS00:Downloading 44.45KiB
16:24:36:WU00:FS00:Download complete
16:24:36:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:OK project:11293 run:31 clone:349 gen:29 core:0x16 unit:0x0000002e6652edbc4d94bb69f0f5e868
16:24:36:WU00:FS00:Starting
16:24:36:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" E:/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 00 -suffix 01 -version 701 -lifeline 1908 -checkpoint 15 -gpu 0
16:24:36:WU00:FS00:Started FahCore on PID 3432
16:24:36:WU00:FS00:Core PID:3664
16:24:36:WU00:FS00:FahCore 0x16 started
16:24:37:WU00:FS00:0x16:
16:24:37:WU00:FS00:0x16:*------------------------------*
16:24:37:WU00:FS00:0x16:Folding@Home GPU Core
16:24:37:WU00:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
16:24:37:WU00:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
16:24:37:WU00:FS00:0x16:Build host: user-f6d030f24f
16:24:37:WU00:FS00:0x16:Board Type: AMD/OpenCL
16:24:37:WU00:FS00:0x16:Core      : x=16
16:24:37:WU00:FS00:0x16: Window's signal control handler registered.
16:24:37:WU00:FS00:0x16:Preparing to commence simulation
16:24:37:WU00:FS00:0x16:- Looking at optimizations...
16:24:37:WU00:FS00:0x16:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
16:24:37:WU00:FS00:0x16:- Created dyn
16:24:37:WU00:FS00:0x16:- Files status OK
16:24:37:WU00:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
16:24:37:WU00:FS00:0x16:- Expanded 45001 -> 171163 (decompressed 380.3 percent)
16:24:37:WU00:FS00:0x16:Called DecompressByteArray: compressed_data_size=45001 data_size=171163, decompressed_data_size=171163 diff=0
16:24:37:WU00:FS00:0x16:- Digital signature verified
16:24:37:WU00:FS00:0x16:Project: 11293 (Run 31, Clone 349, Gen 29)
16:24:37:WU00:FS00:0x16:Assembly optimizations on if available.
16:24:37:WU00:FS00:0x16:Entering M.D.
16:24:37:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
16:24:38:WU00:FS00:0x16:Tpr hash 00/wudata_01.tpr:  2101954924 3163743669 3005302675 788089090 482901805
16:24:38:WU00:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
16:24:38:WU00:FS00:0x16:Client config unavailable.
16:24:38:WU00:FS00:0x16:Finished fah_main
16:24:38:WU00:FS00:0x16:Successful run
16:24:38:WU00:FS00:0x16:DynamicWrapper: Finished Work Unit: sleep=10000
16:24:39:WU00:FS00:0x16:Starting GUI Server
16:24:48:WU00:FS00:0x16:Reserved 0 bytes for xtc file; Cosm status=0
16:24:48:WU00:FS00:0x16:Reserved 0 0 786430464 bytes for arc file=<00/wudata_01.trr> Cosm status=0
16:24:48:WU00:FS00:0x16:Allocated 0 bytes for edr file
16:24:48:WU00:FS00:0x16:Error: could not open bedfile, but going on anyway
16:24:48:WU00:FS00:0x16:- Checksum of file (00/wudata_01.edr) read from disk doesn't match
16:24:48:WU00:FS00:0x16:edrfile file hash check failed.
16:24:48:WU00:FS00:0x16:Folding@home Core Shutdown: FILE_IO_ERROR
16:24:49:WU00:FS00:FahCore returned: FILE_IO_ERROR (117 = 0x75)
16:24:49:WARNING:WU00:FS00:Fatal error, dumping
16:24:49:WU00:FS00:Sending unit results: id:00 state:SEND error:DUMPED project:11293 run:31 clone:349 gen:29 core:0x16 unit:0x0000002e6652edbc4d94bb69f0f5e868
16:24:49:WU00:FS00:Connecting to 171.67.108.44:8080
16:24:49:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
16:24:49:WU00:FS00:Server responded WORK_ACK (400)
16:24:49:WU00:FS00:Cleaning up
16:24:50:WU01:FS00:News: Welcome to Folding@Home
16:24:50:WU01:FS00:Assigned to work server 171.67.108.44
16:24:50:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"Redwood [Radeon HD 5670]" from 171.67.108.44
16:24:50:WU01:FS00:Connecting to 171.67.108.44:8080
16:24:50:WU01:FS00:Downloading 44.60KiB
16:24:51:WU01:FS00:Download complete
16:24:51:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:OK project:11293 run:8 clone:350 gen:29 core:0x16 unit:0x0000002a6652edbc4d92577a26dde82a
16:24:51:WU01:FS00:Starting
16:24:51:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" E:/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 01 -suffix 01 -version 701 -lifeline 1908 -checkpoint 15 -gpu 0
16:24:51:WU01:FS00:Started FahCore on PID 4108
16:24:52:WU01:FS00:Core PID:1628
16:24:52:WU01:FS00:FahCore 0x16 started
16:24:52:WU01:FS00:0x16:
16:24:52:WU01:FS00:0x16:*------------------------------*
16:24:52:WU01:FS00:0x16:Folding@Home GPU Core
16:24:52:WU01:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
16:24:52:WU01:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
16:24:52:WU01:FS00:0x16:Build host: user-f6d030f24f
16:24:52:WU01:FS00:0x16:Board Type: AMD/OpenCL
16:24:52:WU01:FS00:0x16:Core      : x=16
16:24:52:WU01:FS00:0x16: Window's signal control handler registered.
16:24:52:WU01:FS00:0x16:Preparing to commence simulation
16:24:52:WU01:FS00:0x16:- Looking at optimizations...
16:24:52:WU01:FS00:0x16:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
16:24:52:WU01:FS00:0x16:- Created dyn
16:24:52:WU01:FS00:0x16:- Files status OK
16:24:52:WU01:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
16:24:52:WU01:FS00:0x16:- Expanded 45162 -> 171163 (decompressed 378.9 percent)
16:24:52:WU01:FS00:0x16:Called DecompressByteArray: compressed_data_size=45162 data_size=171163, decompressed_data_size=171163 diff=0
16:24:52:WU01:FS00:0x16:- Digital signature verified
16:24:52:WU01:FS00:0x16:Project: 11293 (Run 8, Clone 350, Gen 29)
16:24:52:WU01:FS00:0x16:Assembly optimizations on if available.
16:24:52:WU01:FS00:0x16:Entering M.D.
16:24:54:WU01:FS00:0x16:Tpr hash 01/wudata_01.tpr:  1449066639 1211273945 140391033 2444071410 3452831536
16:24:54:WU01:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
16:24:54:WU01:FS00:0x16:Client config unavailable.
16:24:54:WU01:FS00:0x16:Finished fah_main
16:24:54:WU01:FS00:0x16:Successful run
16:24:54:WU01:FS00:0x16:DynamicWrapper: Finished Work Unit: sleep=10000
16:24:54:WU01:FS00:0x16:Starting GUI Server
16:25:04:WU01:FS00:0x16:Reserved 0 bytes for xtc file; Cosm status=0
16:25:04:WU01:FS00:0x16:Reserved 0 0 786430464 bytes for arc file=<01/wudata_01.trr> Cosm status=0
16:25:04:WU01:FS00:0x16:Allocated 0 bytes for edr file
16:25:04:WU01:FS00:0x16:Error: could not open bedfile, but going on anyway
16:25:04:WU01:FS00:0x16:- Checksum of file (01/wudata_01.edr) read from disk doesn't match
16:25:04:WU01:FS00:0x16:edrfile file hash check failed.
16:25:04:WU01:FS00:0x16:Folding@home Core Shutdown: FILE_IO_ERROR
16:25:04:WU01:FS00:FahCore returned: FILE_IO_ERROR (117 = 0x75)
16:25:04:WARNING:WU01:FS00:Fatal error, dumping
16:25:04:WU01:FS00:Sending unit results: id:01 state:SEND error:DUMPED project:11293 run:8 clone:350 gen:29 core:0x16 unit:0x0000002a6652edbc4d92577a26dde82a
16:25:04:WU01:FS00:Connecting to 171.67.108.44:8080
16:25:04:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
16:25:05:WU01:FS00:Server responded WORK_ACK (400)
16:25:05:WU01:FS00:Cleaning up
16:25:05:WU00:FS00:News: Welcome to Folding@Home
16:25:05:WU00:FS00:Assigned to work server 171.67.108.44
16:25:05:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"Redwood [Radeon HD 5670]" from 171.67.108.44
16:25:05:WU00:FS00:Connecting to 171.67.108.44:8080
16:25:05:WU00:FS00:Downloading 44.34KiB
16:25:07:WU00:FS00:Download complete
16:25:07:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:OK project:11293 run:11 clone:350 gen:29 core:0x16 unit:0x0000002c6652edbc4d925819e52ba892
16:25:07:WU00:FS00:Starting
16:25:07:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" E:/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 00 -suffix 01 -version 701 -lifeline 1908 -checkpoint 15 -gpu 0
16:25:07:WU00:FS00:Started FahCore on PID 2684
16:25:07:WU00:FS00:Core PID:2656
16:25:07:WU00:FS00:FahCore 0x16 started
16:25:07:WU00:FS00:0x16:
16:25:07:WU00:FS00:0x16:*------------------------------*
16:25:07:WU00:FS00:0x16:Folding@Home GPU Core
16:25:07:WU00:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
16:25:07:WU00:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
16:25:07:WU00:FS00:0x16:Build host: user-f6d030f24f
16:25:07:WU00:FS00:0x16:Board Type: AMD/OpenCL
16:25:07:WU00:FS00:0x16:Core      : x=16
16:25:07:WU00:FS00:0x16: Window's signal control handler registered.
16:25:07:WU00:FS00:0x16:Preparing to commence simulation
16:25:07:WU00:FS00:0x16:- Looking at optimizations...
16:25:07:WU00:FS00:0x16:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
16:25:07:WU00:FS00:0x16:- Created dyn
16:25:07:WU00:FS00:0x16:- Files status OK
16:25:07:WU00:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
16:25:07:WU00:FS00:0x16:- Expanded 44891 -> 171163 (decompressed 381.2 percent)
16:25:07:WU00:FS00:0x16:Called DecompressByteArray: compressed_data_size=44891 data_size=171163, decompressed_data_size=171163 diff=0
16:25:07:WU00:FS00:0x16:- Digital signature verified
16:25:07:WU00:FS00:0x16:Project: 11293 (Run 11, Clone 350, Gen 29)
16:25:07:WU00:FS00:0x16:Assembly optimizations on if available.
16:25:07:WU00:FS00:0x16:Entering M.D.
16:25:09:WU00:FS00:0x16:Tpr hash 00/wudata_01.tpr:  1896690871 3810589076 352688575 1319069493 1717392945
16:25:09:WU00:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
16:25:09:WU00:FS00:0x16:Client config unavailable.
16:25:09:WU00:FS00:0x16:Finished fah_main
16:25:09:WU00:FS00:0x16:Successful run
16:25:09:WU00:FS00:0x16:DynamicWrapper: Finished Work Unit: sleep=10000
16:25:09:WU00:FS00:0x16:Starting GUI Server
16:25:19:WU00:FS00:0x16:Reserved 0 bytes for xtc file; Cosm status=0
16:25:19:WU00:FS00:0x16:Reserved 0 0 786430464 bytes for arc file=<00/wudata_01.trr> Cosm status=0
16:25:19:WU00:FS00:0x16:Allocated 0 bytes for edr file
16:25:19:WU00:FS00:0x16:Error: could not open bedfile, but going on anyway
16:25:19:WU00:FS00:0x16:- Checksum of file (00/wudata_01.edr) read from disk doesn't match
16:25:19:WU00:FS00:0x16:edrfile file hash check failed.
16:25:19:WU00:FS00:0x16:Folding@home Core Shutdown: FILE_IO_ERROR
16:25:19:WU00:FS00:FahCore returned: FILE_IO_ERROR (117 = 0x75)
16:25:19:WARNING:WU00:FS00:Fatal error, dumping
16:25:19:WU00:FS00:Sending unit results: id:00 state:SEND error:DUMPED project:11293 run:11 clone:350 gen:29 core:0x16 unit:0x0000002c6652edbc4d925819e52ba892
16:25:19:WU00:FS00:Connecting to 171.67.108.44:8080
16:25:20:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
16:25:20:WU00:FS00:Server responded WORK_ACK (400)
16:25:20:WU00:FS00:Cleaning up
16:25:20:WU01:FS00:News: Welcome to Folding@Home
16:25:20:WU01:FS00:Assigned to work server 171.67.108.44
16:25:20:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"Redwood [Radeon HD 5670]" from 171.67.108.44
16:25:20:WU01:FS00:Connecting to 171.67.108.44:8080
16:25:21:WU01:FS00:Downloading 44.55KiB
16:25:22:WU01:FS00:Download complete
16:25:22:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:OK project:11293 run:1 clone:352 gen:29 core:0x16 unit:0x000000306652edbc4d92560dadf9c767
16:25:22:WU01:FS00:Starting
16:25:22:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" E:/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 01 -suffix 01 -version 701 -lifeline 1908 -checkpoint 15 -gpu 0
16:25:22:WU01:FS00:Started FahCore on PID 1768
16:25:22:WU01:FS00:Core PID:892
16:25:22:WU01:FS00:FahCore 0x16 started
16:25:22:WU01:FS00:0x16:
16:25:22:WU01:FS00:0x16:*------------------------------*
16:25:22:WU01:FS00:0x16:Folding@Home GPU Core
16:25:22:WU01:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
16:25:22:WU01:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
16:25:22:WU01:FS00:0x16:Build host: user-f6d030f24f
16:25:23:WU01:FS00:0x16:Board Type: AMD/OpenCL
16:25:23:WU01:FS00:0x16:Core      : x=16
16:25:23:WU01:FS00:0x16: Window's signal control handler registered.
16:25:23:WU01:FS00:0x16:Preparing to commence simulation
16:25:23:WU01:FS00:0x16:- Looking at optimizations...
16:25:23:WU01:FS00:0x16:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
16:25:23:WU01:FS00:0x16:- Created dyn
16:25:23:WU01:FS00:0x16:- Files status OK
16:25:23:WU01:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
16:25:23:WU01:FS00:0x16:- Expanded 45111 -> 171163 (decompressed 379.4 percent)
16:25:23:WU01:FS00:0x16:Called DecompressByteArray: compressed_data_size=45111 data_size=171163, decompressed_data_size=171163 diff=0
16:25:23:WU01:FS00:0x16:- Digital signature verified
16:25:23:WU01:FS00:0x16:Project: 11293 (Run 1, Clone 352, Gen 29)
16:25:23:WU01:FS00:0x16:Assembly optimizations on if available.
16:25:23:WU01:FS00:0x16:Entering M.D.
16:25:24:WU01:FS00:0x16:Tpr hash 01/wudata_01.tpr:  397920639 1087026068 1295977669 112400954 285539810
16:25:24:WU01:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
16:25:24:WU01:FS00:0x16:Client config unavailable.
16:25:24:WU01:FS00:0x16:Finished fah_main
16:25:24:WU01:FS00:0x16:Successful run
16:25:24:WU01:FS00:0x16:DynamicWrapper: Finished Work Unit: sleep=10000
16:25:24:WU01:FS00:0x16:Starting GUI Server
16:25:34:WU01:FS00:0x16:Reserved 0 bytes for xtc file; Cosm status=0
16:25:34:WU01:FS00:0x16:Reserved 0 0 786430464 bytes for arc file=<01/wudata_01.trr> Cosm status=0
16:25:34:WU01:FS00:0x16:Allocated 0 bytes for edr file
16:25:34:WU01:FS00:0x16:Error: could not open bedfile, but going on anyway
16:25:34:WU01:FS00:0x16:- Checksum of file (01/wudata_01.edr) read from disk doesn't match
16:25:34:WU01:FS00:0x16:edrfile file hash check failed.
16:25:34:WU01:FS00:0x16:Folding@home Core Shutdown: FILE_IO_ERROR
16:25:34:WU01:FS00:FahCore returned: FILE_IO_ERROR (117 = 0x75)
16:25:34:WARNING:WU01:FS00:Fatal error, dumping
16:25:35:WU01:FS00:Sending unit results: id:01 state:SEND error:DUMPED project:11293 run:1 clone:352 gen:29 core:0x16 unit:0x000000306652edbc4d92560dadf9c767
16:25:35:WU01:FS00:Connecting to 171.67.108.44:8080
16:25:35:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
16:25:35:WU01:FS00:Server responded WORK_ACK (400)
16:25:35:WU01:FS00:Cleaning up
16:25:35:WU00:FS00:News: Welcome to Folding@Home
16:25:35:WU00:FS00:Assigned to work server 171.67.108.44
16:25:35:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"Redwood [Radeon HD 5670]" from 171.67.108.44
16:25:35:WU00:FS00:Connecting to 171.67.108.44:8080
16:25:36:WU00:FS00:Downloading 44.45KiB
16:25:37:WU00:FS00:Download complete
16:25:37:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:OK project:11293 run:25 clone:352 gen:29 core:0x16 unit:0x0000002a6652edbc4d94ba183b4f608f
16:25:37:WU00:FS00:Starting
16:25:37:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" E:/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 00 -suffix 01 -version 701 -lifeline 1908 -checkpoint 15 -gpu 0
16:25:37:WU00:FS00:Started FahCore on PID 4936
16:25:37:WU00:FS00:Core PID:4980
16:25:37:WU00:FS00:FahCore 0x16 started
16:25:38:WU00:FS00:0x16:
16:25:38:WU00:FS00:0x16:*------------------------------*
16:25:38:WU00:FS00:0x16:Folding@Home GPU Core
16:25:38:WU00:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
16:25:38:WU00:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
16:25:38:WU00:FS00:0x16:Build host: user-f6d030f24f
16:25:38:WU00:FS00:0x16:Board Type: AMD/OpenCL
16:25:38:WU00:FS00:0x16:Core      : x=16
16:25:38:WU00:FS00:0x16: Window's signal control handler registered.
16:25:38:WU00:FS00:0x16:Preparing to commence simulation
16:25:38:WU00:FS00:0x16:- Looking at optimizations...
16:25:38:WU00:FS00:0x16:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
16:25:38:WU00:FS00:0x16:- Created dyn
16:25:38:WU00:FS00:0x16:- Files status OK
16:25:38:WU00:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
16:25:38:WU00:FS00:0x16:- Expanded 45007 -> 171163 (decompressed 380.3 percent)
16:25:38:WU00:FS00:0x16:Called DecompressByteArray: compressed_data_size=45007 data_size=171163, decompressed_data_size=171163 diff=0
16:25:38:WU00:FS00:0x16:- Digital signature verified
16:25:38:WU00:FS00:0x16:Project: 11293 (Run 25, Clone 352, Gen 29)
16:25:38:WU00:FS00:0x16:Assembly optimizations on if available.
16:25:38:WU00:FS00:0x16:Entering M.D.
16:25:39:WU00:FS00:0x16:Tpr hash 00/wudata_01.tpr:  3589788722 1125947451 1529469444 4053279597 1036583956
16:25:39:WU00:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
16:25:39:WU00:FS00:0x16:Client config unavailable.
16:25:39:WU00:FS00:0x16:Finished fah_main
16:25:39:WU00:FS00:0x16:Successful run
16:25:39:WU00:FS00:0x16:DynamicWrapper: Finished Work Unit: sleep=10000
16:25:40:WU00:FS00:0x16:Starting GUI Server
16:25:49:WU00:FS00:0x16:Reserved 0 bytes for xtc file; Cosm status=0
16:25:49:WU00:FS00:0x16:Reserved 0 0 786430464 bytes for arc file=<00/wudata_01.trr> Cosm status=0
16:25:49:WU00:FS00:0x16:Allocated 0 bytes for edr file
16:25:49:WU00:FS00:0x16:Error: could not open bedfile, but going on anyway
16:25:49:WU00:FS00:0x16:- Checksum of file (00/wudata_01.edr) read from disk doesn't match
16:25:49:WU00:FS00:0x16:edrfile file hash check failed.
16:25:49:WU00:FS00:0x16:Folding@home Core Shutdown: FILE_IO_ERROR
16:25:50:WU00:FS00:FahCore returned: FILE_IO_ERROR (117 = 0x75)
16:25:50:WARNING:WU00:FS00:Fatal error, dumping
16:25:50:WU00:FS00:Sending unit results: id:00 state:SEND error:DUMPED project:11293 run:25 clone:352 gen:29 core:0x16 unit:0x0000002a6652edbc4d94ba183b4f608f
16:25:50:WU00:FS00:Connecting to 171.67.108.44:8080
16:25:50:WU00:FS00:Server responded WORK_ACK (400)
16:25:51:WU00:FS00:Cleaning up
16:26:57:Server connection id=1 ended
16:26:57:Lost lifeline PID 4208, exiting
16:26:58:Clean exit
Re: ATI 5670 / 12.8 drivers (fails to start)
As I recall, AMD no longer supports OpenCL on WinXP. Without that you can't fold on your Radeon 5670. The last version of the Catalyst drivers that included OpenCL for XP are from last year. I looked, but could not find the posts describing that right away. I think the last version that includes OpenCL support for XP is 11.10.
I don't think XP is the problem.
As a test, drill down to c:\amd\support\12-8...\Packages\Apps\OpenCL and run the OpenCL.msi installer there. Does it install, or say that it is already installed?
curecompute
Thanks a lot - it did install. I also had to reinstall FAH and now everything seems ok. :)
Swell. 8-)
curecompute
I had to reinstall FAH because it got stuck on "Connecting..." when I opened it, but now it looks like this is permanent (local/connecting/127.0.0.1:36330). It only goes away with a FAH reinstall.
curecompute
Oh ok, found the answer. I confused the Autostart option, too - thought it was boot-related.
curecompute
I'm back at this, because it won't work for me any more. I uninstalled, deleted all folders, reinstalled (autostart enabled as recommended) and use only a cpu slot. It worked once, but after that all I'm getting is Connecting: inactive. In case this is again an AMD issue (although I disabled gpu folding), I looked again for the OpenCL.msi installer. However, there isn't one in the 13.4 driver package. Is the AMD-APP-SDK-v2.8.1.0-Windows-64 package, the same thing?
This is yesterday's log, it doesn't seem to write a new one now.
*********************** Log Started 2013-08-22T20:56:22Z ***********************
20:56:22:************************* Folding@home Client *************************
20:56:22:      Website: http://folding.stanford.edu/
20:56:22:    Copyright: (c) 2009-2013 Stanford University
20:56:22:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:56:22:         Args: --open-web-control
20:56:22:       Config: <none>
20:56:22:******************************** Build ********************************
20:56:22:      Version: 7.3.6
20:56:22:         Date: Feb 18 2013
20:56:22:         Time: 15:25:17
20:56:22:      SVN Rev: 3923
20:56:22:       Branch: fah/trunk/client
20:56:22:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
20:56:22:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
20:56:22:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
20:56:22:     Platform: win32 XP
20:56:22:         Bits: 32
20:56:22:         Mode: Release
20:56:22:******************************* System ********************************
20:56:22:          CPU: Intel(R) Core(TM)2 Quad CPU Q9650 @ 3.00GHz
20:56:22:       CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
20:56:22:         CPUs: 4
20:56:22:       Memory: 4.00GiB
20:56:22:  Free Memory: 1.80GiB
20:56:22:      Threads: WINDOWS_THREADS
20:56:22:  Has Battery: false
20:56:22:   On Battery: false
20:56:22:   UTC offset: 3
20:56:22:          PID: 6764
20:56:22:          CWD: C:/Users/Alex/AppData/Roaming/FAHClient
20:56:22:           OS: Windows 8 Pro
20:56:22:      OS Arch: AMD64
20:56:22:         GPUs: 1
20:56:22:        GPU 0: ATI:4 Redwood [Radeon HD 5670]
20:56:22:         CUDA: Not detected
20:56:22:Win32 Service: false
20:56:22:***********************************************************************
20:56:22:<config>
20:56:22:  <!-- Folding Slots -->
20:56:22:</config>
20:56:22:Connecting to assign-GPU.stanford.edu:80
20:57:34:Connecting to assign-GPU.stanford.edu:8080
20:57:35:Read GPUs.txt
20:57:35:Trying to access database...
20:57:36:Successfully acquired database lock
20:57:36:Enabled folding slot 00: PAUSED gpu:0:Redwood [Radeon HD 5670] (not configured)
20:57:36:Enabled folding slot 01: PAUSED cpu:3 (not configured)
20:57:40:3:127.0.0.1:New Web connection
20:58:46:Saving configuration to config.xml
20:58:46:<config>
20:58:46:  <!-- Folding Core -->
20:58:46:  <no-assembly v='true'/>
20:58:46:
20:58:46:  <!-- Network -->
20:58:46:  <proxy v=':8080'/>
20:58:46:
20:58:46:  <!-- User Information -->
20:58:46:  <passkey v='********************************'/>
20:58:46:  <team v='*****'/>
20:58:46:  <user v='*******'/>
20:58:46:
20:58:46:  <!-- Folding Slots -->
20:58:46:  <slot id='1' type='CPU'/>
20:58:46:</config>
20:58:46:Set client configured
20:58:46:WU00:FS01:Connecting to assign3.stanford.edu:8080
20:58:47:WU00:FS01:Connecting to assign3.stanford.edu:8080
20:58:48:WU00:FS01:News: Welcome to Folding@Home
20:58:48:WU00:FS01:Assigned to work server 171.67.108.35
20:58:48:WU00:FS01:Requesting new work unit for slot 01: READY cpu:3 from 171.67.108.35
20:58:48:WU00:FS01:Connecting to 171.67.108.35:8080
20:58:50:WU00:FS01:Downloading 1002.36KiB
20:58:53:WU00:FS01:Download complete
20:58:53:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8702 run:64 clone:17 gen:13 core:0xa4 unit:0x000000166652edb35196edc957b9c802
20:58:54:WU00:FS01:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
20:58:54:WU00:FS01:Connecting to www.stanford.edu:80
20:58:54:WU00:FS01:FahCore a4: Downloading 2.89MiB
20:59:00:WU00:FS01:FahCore a4: 19.48%
20:59:06:WU00:FS01:FahCore a4: 38.96%
20:59:12:WU00:FS01:FahCore a4: 62.76%
20:59:18:WU00:FS01:FahCore a4: 86.57%
20:59:21:WU00:FS01:FahCore a4: Download complete
20:59:21:WU00:FS01:Valid core signature
20:59:22:WU00:FS01:Unpacked 9.59MiB to cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe
20:59:22:WU00:FS01:Starting
20:59:22:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Alex/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 703 -lifeline 6764 -checkpoint 15 -noassembly -np 3
20:59:22:WU00:FS01:Started FahCore on PID 6832
20:59:22:WU00:FS01:Core PID:6844
20:59:22:WU00:FS01:FahCore 0xa4 started
20:59:22:WU00:FS01:0xa4:
20:59:22:WU00:FS01:0xa4:*------------------------------*
20:59:22:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
20:59:22:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
20:59:22:WU00:FS01:0xa4:Preparing to commence simulation
20:59:22:WU00:FS01:0xa4:- User disabled assembly optimizations.
20:59:22:WU00:FS01:0xa4:- Created dyn
20:59:22:WU00:FS01:0xa4:- Files status OK
20:59:22:WU00:FS01:0xa4:- Expanded 1025901 -> 2544640 (decompressed 248.0 percent)
20:59:22:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=1025901 data_size=2544640, decompressed_data_size=2544640 diff=0
20:59:22:WU00:FS01:0xa4:- Digital signature verified
20:59:22:WU00:FS01:0xa4:Project: 8702 (Run 64, Clone 17, Gen 13)
20:59:22:WU00:FS01:0xa4:Entering M.D.
20:59:28:WU00:FS01:0xa4:Mapping NT from 3 to 3
20:59:29:WU00:FS01:0xa4:Completed 0 out of 250000 steps  (0%)
21:01:35:Saving configuration to config.xml
21:01:35:<config>
21:01:35:  <!-- Network -->
21:01:35:  <proxy v=':8080'/>
21:01:35:
21:01:35:  <!-- User Information -->
21:01:35:  <passkey v='********************************'/>
21:01:35:  <team v='*****'/>
21:01:35:  <user v='*******'/>
21:01:35:
21:01:35:  <!-- Folding Slots -->
21:01:35:  <slot id='1' type='CPU'/>
21:01:35:</config>
21:02:55:WARNING:Exception: 9:127.0.0.1: Send error: 10053: An established connection was aborted by the software in your host machine.
20:54:38:Adding folding slot 00: PAUSED gpu:0:Redwood [Radeon HD 5670] (waiting for idle)
20:54:38:Saving configuration to config.xml
20:54:38:<config>
20:54:38:  <!-- Network -->
20:54:38:  <proxy v=':8080'/>
20:54:38:
20:54:38:  <!-- User Information -->
20:54:38:  <passkey v='********************************'/>
20:54:38:  <team v='*****'/>
20:54:38:  <user v='*******'/>
20:54:38:
20:54:38:  <!-- Folding Slots -->
20:54:38:  <slot id='1' type='CPU'/>
20:54:38:  <slot id='0' type='GPU'/>
20:54:38:</config>
20:55:08:WU00:FS01:0xa4:Completed 2500 out of 250000 steps  (1%)
20:56:01:FS01:Shutting core down
20:56:01:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
20:57:05:Saving configuration to config.xml
20:57:05:<config>
20:57:05:  <!-- Folding Core -->
20:57:05:  <no-assembly v='true'/>
20:57:05:
20:57:05:  <!-- Folding Slot Configuration -->
20:57:05:  <power v='OFF'/>
20:57:05:
20:57:05:  <!-- Network -->
20:57:05:  <proxy v=':8080'/>
20:57:05:
20:57:05:  <!-- User Information -->
20:57:05:  <passkey v='********************************'/>
20:57:05:  <team v='*****'/>
20:57:05:  <user v='*******'/>
20:57:05:
20:57:05:  <!-- Folding Slots -->
20:57:05:  <slot id='1' type='CPU'/>
20:57:05:  <slot id='0' type='GPU'/>
20:57:05:</config>
20:57:42:Saving configuration to config.xml
20:57:42:<config>
20:57:42:  <!-- Folding Core -->
20:57:42:  <no-assembly v='true'/>
20:57:42:
20:57:42:  <!-- Folding Slot Configuration -->
20:57:42:  <power v='OFF'/>
20:57:42:
20:57:42:  <!-- Network -->
20:57:42:  <proxy v=':8080'/>
20:57:42:
20:57:42:  <!-- User Information -->
20:57:42:  <passkey v='********************************'/>
20:57:42:  <team v='*****'/>
20:57:42:  <user v='*******'/>
20:57:42:
20:57:42:  <!-- Folding Slots -->
20:57:42:  <slot id='0' type='GPU'/>
20:57:42:</config>
20:57:42:WARNING:WU00:Slot ID 1 no longer exists and there are no other matching slots, dumping
20:57:42:WU00:Sending unit results: id:00 state:SEND error:DUMPED project:8702 run:64 clone:17 gen:13 core:0xa4 unit:0x000000166652edb35196edc957b9c802
20:57:42:WU00:Connecting to 171.67.108.35:8080
20:57:43:WU00:Server responded WORK_ACK (400)
20:57:43:WU00:Cleaning up
20:58:23:Adding folding slot 01: READY cpu:3
20:58:23:Saving configuration to config.xml
20:58:23:<config>
20:58:23:  <!-- Folding Core -->
20:58:23:  <no-assembly v='true'/>
20:58:23:
20:58:23:  <!-- Folding Slot Configuration -->
20:58:23:  <power v='MEDIUM'/>
20:58:23:
20:58:23:  <!-- Network -->
20:58:23:  <proxy v=':8080'/>
20:58:23:
20:58:23:  <!-- User Information -->
20:58:23:  <passkey v='********************************'/>
20:58:23:  <team v='*****'/>
20:58:23:  <user v='*******'/>
20:58:23:
20:58:23:  <!-- Folding Slots -->
20:58:23:  <slot id='1' type='CPU'>
20:58:23:    <cpus v='-1'/>
20:58:23:  </slot>
20:58:23:</config>
20:58:23:WU00:FS01:Connecting to assign3.stanford.edu:8080
20:58:24:WU00:FS01:News: Welcome to Folding@Home
20:58:24:WU00:FS01:Assigned to work server 171.67.108.35
20:58:24:WU00:FS01:Requesting new work unit for slot 01: READY cpu:3 from 171.67.108.35
20:58:24:WU00:FS01:Connecting to 171.67.108.35:8080
20:58:26:WU00:FS01:Downloading 1001.75KiB
20:58:29:WU00:FS01:Download complete
20:58:30:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8702 run:22 clone:33 gen:113 core:0xa4 unit:0x000000986652edb35196eb31493c1ae9
20:58:30:WU00:FS01:Starting
20:58:30:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Alex/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 703 -lifeline 6764 -checkpoint 15 -noassembly -np 3
20:58:31:WU00:FS01:Started FahCore on PID 3980
20:58:32:WU00:FS01:Core PID:3176
20:58:32:WU00:FS01:FahCore 0xa4 started
20:58:33:WU00:FS01:0xa4:
20:58:33:WU00:FS01:0xa4:*------------------------------*
20:58:33:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
20:58:33:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
20:58:33:WU00:FS01:0xa4:Preparing to commence simulation
20:58:33:WU00:FS01:0xa4:- User disabled assembly optimizations.
20:58:33:WU00:FS01:0xa4:- Created dyn
20:58:33:WU00:FS01:0xa4:- Files status OK
20:58:33:WU00:FS01:0xa4:- Expanded 1025279 -> 2544640 (decompressed 248.1 percent)
20:58:33:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=1025279 data_size=2544640, decompressed_data_size=2544640 diff=0
20:58:33:WU00:FS01:0xa4:- Digital signature verified
20:58:33:WU00:FS01:0xa4:Project: 8702 (Run 22, Clone 33, Gen 113)
20:58:33:WU00:FS01:0xa4:Entering M.D.
20:58:39:WU00:FS01:0xa4:Mapping NT from 3 to 3
20:58:39:WU00:FS01:0xa4:Completed 0 out of 250000 steps  (0%)
20:58:56:FS01:Shutting core down
20:59:03:WU00:FS01:0xa4:Client no longer detected. Shutting down core
20:59:03:WU00:FS01:0xa4:Folding@home Core Shutdown: CLIENT_DIED
20:59:03:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
20:59:03:WU00:FS01:Starting
20:59:03:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Alex/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 703 -lifeline 6764 -checkpoint 15 -noassembly -np 3
20:59:04:WU00:FS01:Started FahCore on PID 32
20:59:04:WU00:FS01:Core PID:180
20:59:04:WU00:FS01:FahCore 0xa4 started
20:59:04:WU00:FS01:0xa4:
20:59:04:WU00:FS01:0xa4:*------------------------------*
20:59:05:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
20:59:05:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
20:59:05:WU00:FS01:0xa4:Preparing to commence simulation
20:59:05:WU00:FS01:0xa4:- User disabled assembly optimizations.
20:59:05:WU00:FS01:0xa4:- Files status OK
20:59:05:WU00:FS01:0xa4:- Expanded 1025279 -> 2544640 (decompressed 248.1 percent)
20:59:05:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=1025279 data_size=2544640, decompressed_data_size=2544640 diff=0
20:59:05:WU00:FS01:0xa4:- Digital signature verified
20:59:05:WU00:FS01:0xa4:Project: 8702 (Run 22, Clone 33, Gen 113)
20:59:05:WU00:FS01:0xa4:Entering M.D.
20:59:10:WU00:FS01:0xa4:Mapping NT from 3 to 3
20:59:11:41:127.0.0.1:New Web connection
20:59:11:WU00:FS01:0xa4:Completed 0 out of 250000 steps  (0%)
20:59:23:FS01:Shutting core down
20:59:24:WU00:FS01:0xa4:Client no longer detected. Shutting down core
20:59:24:WU00:FS01:0xa4:Folding@home Core Shutdown: CLIENT_DIED
20:59:25:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
20:59:35:WARNING:Exception: 46:127.0.0.1: Send error: 10053: An established connection was aborted by the software in your host machine.
21:00:03:WU00:FS01:Starting
21:00:03:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Alex/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 703 -lifeline 6764 -checkpoint 15 -noassembly -np 3
21:00:05:WU00:FS01:Started FahCore on PID 3576
21:00:05:WU00:FS01:Core PID:2372
21:00:05:WU00:FS01:FahCore 0xa4 started
21:00:05:WU00:FS01:0xa4:
21:00:05:WU00:FS01:0xa4:*------------------------------*
21:00:05:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
21:00:05:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
21:00:05:WU00:FS01:0xa4:Preparing to commence simulation
21:00:05:WU00:FS01:0xa4:- User disabled assembly optimizations.
21:00:05:WU00:FS01:0xa4:- Files status OK
21:00:05:WU00:FS01:0xa4:- Expanded 1025279 -> 2544640 (decompressed 248.1 percent)
21:00:05:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=1025279 data_size=2544640, decompressed_data_size=2544640 diff=0
21:00:05:WU00:FS01:0xa4:- Digital signature verified
21:00:05:WU00:FS01:0xa4:Project: 8702 (Run 22, Clone 33, Gen 113)
21:00:05:WU00:FS01:0xa4:Entering M.D.
21:00:11:WU00:FS01:0xa4:Mapping NT from 3 to 3
21:00:11:WU00:FS01:0xa4:Completed 0 out of 250000 steps  (0%)
21:02:51:Saving configuration to config.xml
21:02:51:<config>
21:02:51:  <!-- Folding Core -->
21:02:51:  <no-assembly v='true'/>
21:02:51:
21:02:51:  <!-- Network -->
21:02:51:  <proxy v=':8080'/>
21:02:51:
21:02:51:  <!-- User Information -->
21:02:51:  <passkey v='********************************'/>
21:02:51:  <team v='*****'/>
21:02:51:  <user v='*******'/>
21:02:51:
21:02:51:  <!-- Folding Slots -->
21:02:51:  <slot id='1' type='CPU'>
21:02:51:    <cpus v='-1'/>
21:02:51:  </slot>
21:02:51:</config>
21:02:51:WARNING:WU00:FS01:Detected clock skew (2 mins 34 secs), adjusting time estimates
21:02:52:WARNING:Exception: 54:127.0.0.1: Send error: 10053: An established connection was aborted by the software in your host machine.
21:02:53:57:127.0.0.1:New Web connection
21:03:31:WARNING:Exception: 67:127.0.0.1: Send error: 10053: An established connection was aborted by the software in your host machine.
21:03:36:WARNING:Exception: 62:127.0.0.1: Send error: 10053: An established connection was aborted by the software in your host machine.
21:05:17:WU00:FS01:0xa4:Completed 2500 out of 250000 steps  (1%)
21:10:25:WU00:FS01:0xa4:Completed 5000 out of 250000 steps  (2%)
21:12:10:WARNING:WU00:FS01:FahCore crashed with Windows unhandled exception code 0xUNKNOWN_ENUM, searching for this code online may provide more information
21:12:10:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (1073807364 = 0x40010004)
21:12:10:WU00:FS01:Starting
21:12:10:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Alex/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 703 -lifeline 6764 -checkpoint 15 -noassembly -np 3
21:12:12:WU00:FS01:Started FahCore on PID 6304
21:12:12:WU00:FS01:Core PID:3664
21:12:12:WU00:FS01:FahCore 0xa4 started
21:12:12:WU00:FS01:0xa4:
21:12:12:WU00:FS01:0xa4:*------------------------------*
21:12:12:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
21:12:12:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
21:12:12:WU00:FS01:0xa4:Preparing to commence simulation
21:12:12:WU00:FS01:0xa4:- Ensuring status. Please wait.
It does not appear to be related to the GPU driver or the related OpenCL package. But it is hard to figure out what is wrong here with all of the configuration changes, deletion of the CPU (SMP) slot in the middle and other such modifications. There is a point in the log where a GPU slot was added, did you initiate that yourself or did it auto-configure one to add? If you do not want a GPU slot at all, set the parameter gpu to false.
In addition, there is no need for the no-assembly parameter to be set differently from the default. Beyond that, is the FAHClient process still running? You should be able to see it running in Task Manager.
I also didn't see a power setting in the log. Have you tried changing it to full again?
curecompute
Thanks for the replies. Yes, I added the GPU slot at some point, and then deleted it. Anyway I think solved it, it was a case of a shortcut mix-up. I believe I was opening FAHControl.exe and that's why it wouldn't start folding. Sorted it out now, sorry for the confusion.
Problem was that you also deleted the CPU slot at the same time as shown in the log:
20:57:05:<config>
20:57:05:
20:57:05:
20:57:05:
20:57:05:
20:57:05:</config>
20:57:42:<config>
20:57:42:
20:57:42:
20:57:42:
20:57:42:
20:57:42:</config>
That caused the WU to be dumped since there was no longer a CPU slot for it to be folded on.
Perhaps the problem is <power v='OFF'/>
vip00
Post by vip00 »
I'm having a similar problem, perhaps my log can be helpful? This is on a HD7950 with a moderate overclock. It does not appear to even be starting to fold though, so stability of the overclock isn't an issue (yet).
*********************** Log Started 2013-08-25T00:10:34Z ***********************
00:10:34:************************* Folding@home Client *************************
00:10:34:      Website: http://folding.stanford.edu/
00:10:34:    Copyright: (c) 2009-2013 Stanford University
00:10:34:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:10:34:         Args:
00:10:34:       Config: C:/Users/Vlad/AppData/Roaming/FAHClient/config.xml
00:10:34:******************************** Build ********************************
00:10:34:      Version: 7.3.6
00:10:34:         Date: Feb 18 2013
00:10:34:         Time: 15:25:17
00:10:34:      SVN Rev: 3923
00:10:34:       Branch: fah/trunk/client
00:10:34:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
00:10:34:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
00:10:34:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
00:10:34:     Platform: win32 XP
00:10:34:         Bits: 32
00:10:34:         Mode: Release
00:10:34:******************************* System ********************************
00:10:34:          CPU: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
00:10:34:       CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
00:10:34:         CPUs: 4
00:10:34:       Memory: 15.88GiB
00:10:34:  Free Memory: 14.14GiB
00:10:34:      Threads: WINDOWS_THREADS
00:10:34:  Has Battery: false
00:10:34:   On Battery: false
00:10:34:   UTC offset: -4
00:10:34:          PID: 3656
00:10:34:          CWD: C:/Users/Vlad/AppData/Roaming/FAHClient
00:10:34:           OS: Windows 7 Ultimate
00:10:34:      OS Arch: AMD64
00:10:34:         GPUs: 1
00:10:34:        GPU 0: ATI:5 Tahiti PRO [Radeon HD 7950]
00:10:34:         CUDA: Not detected
00:10:34:Win32 Service: false
00:10:34:***********************************************************************
00:10:34:<config>
00:10:34:  <!-- Folding Slot Configuration -->
00:10:34:  <power v='full'/>
00:10:34:
00:10:34:  <!-- User Information -->
00:10:34:  <team v='49191'/>
00:10:34:  <user v='vpresnyak'/>
00:10:34:
00:10:34:  <!-- Folding Slots -->
00:10:34:  <slot id='0' type='GPU'/>
00:10:34:  <slot id='1' type='CPU'/>
00:10:34:</config>
00:10:34:Trying to access database...
00:10:35:Successfully acquired database lock
00:10:35:Enabled folding slot 00: READY gpu:0:Tahiti PRO [Radeon HD 7950]
00:10:35:Enabled folding slot 01: READY cpu:3
00:10:35:WU01:FS00:Starting
00:10:35:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Vlad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 01 -suffix 01 -version 703 -lifeline 3656 -checkpoint 15 -gpu 0 -gpu-vendor ati
00:10:35:WU01:FS00:Started FahCore on PID 3040
00:10:35:WU01:FS00:Core PID:1064
00:10:35:WU01:FS00:FahCore 0x16 started
00:10:35:WU00:FS01:Starting
00:10:35:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Vlad/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 703 -lifeline 3656 -checkpoint 15 -np 3
00:10:35:WU00:FS01:Started FahCore on PID 3592
00:10:35:WU00:FS01:Core PID:4112
00:10:35:WU00:FS01:FahCore 0xa4 started
00:10:35:WU01:FS00:0x16:
00:10:35:WU01:FS00:0x16:*------------------------------*
00:10:35:WU01:FS00:0x16:Folding@Home GPU Core
00:10:35:WU01:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
00:10:35:WU01:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
00:10:35:WU01:FS00:0x16:Build host: user-f6d030f24f
00:10:35:WU01:FS00:0x16:Board Type: AMD/OpenCL
00:10:35:WU01:FS00:0x16:Core      : x=16
00:10:35:WU01:FS00:0x16: Window's signal control handler registered.
00:10:35:WU01:FS00:0x16:Preparing to commence simulation
00:10:35:WU01:FS00:0x16:- Ensuring status. Please wait.
00:10:36:WU00:FS01:0xa4:
00:10:36:WU00:FS01:0xa4:*------------------------------*
00:10:36:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
00:10:36:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
00:10:36:WU00:FS01:0xa4:Preparing to commence simulation
00:10:36:WU00:FS01:0xa4:- Ensuring status. Please wait.
00:10:45:WU01:FS00:0x16:- Looking at optimizations...
00:10:45:WU01:FS00:0x16:- Working with standard loops on this execution.
00:10:45:WU01:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
00:10:45:WU01:FS00:0x16:- Expanded 45149 -> 171163 (decompressed 379.1 percent)
00:10:45:WU01:FS00:0x16:Called DecompressByteArray: compressed_data_size=45149 data_size=171163, decompressed_data_size=171163 diff=0
00:10:45:WU01:FS00:0x16:- Digital signature verified
00:10:45:WU01:FS00:0x16:Project: 11293 (Run 23, Clone 240, Gen 45)
00:10:45:WU01:FS00:0x16:Entering M.D.
00:10:45:WU00:FS01:0xa4:- Looking at optimizations...
00:10:45:WU00:FS01:0xa4:- Working with standard loops on this execution.
00:10:45:WU00:FS01:0xa4:- Previous termination of core was improper.
00:10:45:WU00:FS01:0xa4:- Going to use standard loops.
00:10:45:WU00:FS01:0xa4:- Files status OK
00:10:45:WU00:FS01:0xa4:- Expanded 1025332 -> 2544640 (decompressed 248.1 percent)
00:10:45:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=1025332 data_size=2544640, decompressed_data_size=2544640 diff=0
00:10:45:WU00:FS01:0xa4:- Digital signature verified
00:10:45:WU00:FS01:0xa4:Project: 8702 (Run 38, Clone 19, Gen 23)
00:10:45:WU00:FS01:0xa4:Entering M.D.
00:10:47:WU01:FS00:0x16:Tpr hash 01/wudata_01.tpr:  3211540151 3096628684 37576934 2593584280 4079083162
00:10:47:WU01:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
00:10:47:WU01:FS00:0x16:Client config unavailable.
00:10:47:WU01:FS00:0x16:Starting GUI Server
00:10:51:WU00:FS01:0xa4:Using Gromacs checkpoints
00:10:51:WU00:FS01:0xa4:Mapping NT from 3 to 3
00:10:51:WU00:FS01:0xa4:Resuming from checkpoint
00:10:51:WU00:FS01:0xa4:Verified 00/wudata_01.log
00:10:51:WU00:FS01:0xa4:Verified 00/wudata_01.trr
00:10:51:WU00:FS01:0xa4:Verified 00/wudata_01.xtc
00:10:51:WU00:FS01:0xa4:Verified 00/wudata_01.edr
00:10:51:WU00:FS01:0xa4:Completed 30830 out of 250000 steps  (12%)
00:12:25:WU00:FS01:0xa4:Completed 32500 out of 250000 steps  (13%)
00:14:41:WU00:FS01:0xa4:Completed 35000 out of 250000 steps  (14%)
00:16:38:WU00:FS01:0xa4:Completed 37500 out of 250000 steps  (15%)
00:18:36:WU00:FS01:0xa4:Completed 40000 out of 250000 steps  (16%)
00:20:33:WU00:FS01:0xa4:Completed 42500 out of 250000 steps  (17%)
00:22:30:WU00:FS01:0xa4:Completed 45000 out of 250000 steps  (18%)
00:24:27:WU00:FS01:0xa4:Completed 47500 out of 250000 steps  (19%)
00:26:24:WU00:FS01:0xa4:Completed 50000 out of 250000 steps  (20%)
00:28:25:WU00:FS01:0xa4:Completed 52500 out of 250000 steps  (21%)
00:30:26:WU00:FS01:0xa4:Completed 55000 out of 250000 steps  (22%)
00:32:27:WU00:FS01:0xa4:Completed 57500 out of 250000 steps  (23%)
Interestingly, it appears to load the CPU portion normally (ie I have 25% CPU utilization going to FahCore_16.exe), but there is no load on the graphics card and project makes no progress.
vip00 -> Are you using driver version 12.8 or not? If it is a different one, can you please tell us what it is?
