i am having trouble sending result from last WU to this server in the log file of the v7 client i am getting this repeatedly
11:47:46:WU02:FS00:Sending unit results: id:02 state:SEND error:OK project:8010 run:0 clone:2187 gen:96 core:0x15 unit:0x0000006d6953ee2d4fb43c6ade9f3e6f
11:47:46:WU02:FS00:Uploading 375.38KiB to 171.67.108.141
11:47:46:WU02:FS00:Connecting to 171.67.108.141:8080
11:48:11:WARNING:WU02:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
11:48:11:WU02:FS00:Trying to send results to collection server
11:48:11:WU02:FS00:Uploading 375.38KiB to 171.65.103.160
11:48:11:WU02:FS00:Connecting to 171.65.103.160:8080
11:48:47:ERROR:WU02:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
171.67.108.141
paulwarden
- Hardware configuration: abit an9 32x
amd 5200x2 overclocked to 3ghz
2.5gb pc 667
xfx 9600 gso
Re: 171.67.108.141
I've changed your title to reflect the work server rather than the collection server.
See viewtopic.php?f=18&t=17794 for the difference.
I've uploaded two work units to that server in the past hour without problem.
You have received credit for the work unit so it did upload but the client didn't receive acknowledgement from the work server:
Hi paul_warden (team 35947),
Your WU (P8010 R0 C2187 G96) was added to the stats database on 2012-09-24 06:09:33 for 2510 points of credit.
Try restarting the client and if that doesn't help then it was probably a server side issue and in this case it's okay to delete work/02 since you did receive credit.
paulwarden
2.5gb pc 667
xfx 9600 gso
Re: 171.67.108.141
Thank you for that it did finally send the result but is doing exactly the same thing with the next completed WU i have restarted the client several times but it makes no difference actually am wondering if it may be a router problem as it is a shared connection with 3 other computers on it
Re: 171.67.108.141
Since I'm not seeing other current reports of the problem and my client is uploading okay to that server you could restart the router and the computer to see if that helps.
If you supply the PRCG numbers for the current one I can check to make sure you've received credit for it.
paulwarden
2.5gb pc 667
xfx 9600 gso
Re: 171.67.108.141
looks like it is a router problem am unable to restart it as it is locked in the rooms of the person i am house sharing with am unable to access it to restart so have resorted to using my mobile broadband dongle for now
Re: 171.67.108.141
Where is the mains breaker for that room?
paulwarden
2.5gb pc 667
xfx 9600 gso
Re: 171.67.108.141
got it sorted now turns out my house mate had left a key for me in case router played up and i have only just found it and the letter he left for me telling me i can go into his rooms to reset router
