Points not being awarded - Attached Log
BYUSinger84
Post by BYUSinger84 »
I'm having an issue where it seems like everything is running just fine, but my stats are not updating like they are supposed to. I upgraded almost all of my servers this summer, but since that time I'm only getting around 9,000 points a day. I should be getting well over 60,000 as that's what I was doing before on the older hardware. Most everything is a Quad Core Xeon (socket 1155) and is plenty fast for folding. Below is my log...any help would be appriciated because I don't know what else to look at.
This is just the latest snipit:
15:52:47:WU01:FS00:0xa4:Completed 247500 out of 250000 steps  (99%)
15:53:56:WU01:FS00:0xa4:Completed 250000 out of 250000 steps  (100%)
15:53:57:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
15:53:57:WU00:FS00:Connecting to assign3.stanford.edu:8080
15:53:57:WU00:FS00:News: Welcome to Folding@Home
15:53:57:WU00:FS00:Assigned to work server 171.67.108.60
15:53:57:WU00:FS00:Requesting new work unit for slot 00: RUNNING smp:8 from 171.67.108.60
15:53:57:WU00:FS00:Connecting to 171.67.108.60:8080
15:53:58:WU00:FS00:Downloading 940.64KiB
15:53:58:WU00:FS00:Download complete
15:53:58:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:OK project:8049 run:443 clone:2 gen:58 core:0xa4 unit:0x000000506652edcc50133323aafb220f
15:54:07:WU01:FS00:0xa4:
15:54:07:WU01:FS00:0xa4:Finished Work Unit:
15:54:07:WU01:FS00:0xa4:- Reading up to 1406148 from "01/wudata_01.trr": Read 1406148
15:54:07:WU01:FS00:0xa4:trr file hash check passed.
15:54:07:WU01:FS00:0xa4:- Reading up to 851348 from "01/wudata_01.xtc": Read 851348
15:54:07:WU01:FS00:0xa4:xtc file hash check passed.
15:54:07:WU01:FS00:0xa4:edr file hash check passed.
15:54:07:WU01:FS00:0xa4:logfile size: 22866
15:54:07:WU01:FS00:0xa4:Leaving Run
15:54:11:WU01:FS00:0xa4:- Writing 2285766 bytes of core data to disk...
15:54:12:WU01:FS00:0xa4:Done: 2285254 -> 2190410 (compressed to 95.8 percent)
15:54:12:WU01:FS00:0xa4:  ... Done.
15:54:19:WU01:FS00:0xa4:- Shutting down core
15:54:19:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
15:54:20:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
15:54:20:WU01:FS00:Sending unit results: id:01 state:SEND error:OK project:8049 run:227 clone:2 gen:65 core:0xa4 unit:0x000000716652edcc50132e4336a62f4d
15:54:20:WU01:FS00:Uploading 2.09MiB to 171.67.108.60
15:54:20:WU01:FS00:Connecting to 171.67.108.60:8080
15:54:21:WU00:FS00:Starting
15:54:21:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 701 -lifeline 2564 -checkpoint 15 -np 8 -service
15:54:21:WU00:FS00:Started FahCore on PID 3924
15:54:21:WU00:FS00:Core PID:3952
15:54:21:WU00:FS00:FahCore 0xa4 started
15:54:21:WU00:FS00:0xa4:
15:54:21:WU00:FS00:0xa4:*------------------------------*
15:54:21:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
15:54:21:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
15:54:21:WU00:FS00:0xa4:Preparing to commence simulation
15:54:21:WU00:FS00:0xa4:- Looking at optimizations...
15:54:21:WU00:FS00:0xa4:- Created dyn
15:54:21:WU00:FS00:0xa4:- Files status OK
15:54:21:WU00:FS00:0xa4:- Expanded 962701 -> 2211692 (decompressed 229.7 percent)
15:54:21:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=962701 data_size=2211692, decompressed_data_size=2211692 diff=0
15:54:21:WU00:FS00:0xa4:- Digital signature verified
15:54:21:WU00:FS00:0xa4:Project: 8049 (Run 443, Clone 2, Gen 58)
15:54:21:WU00:FS00:0xa4:Assembly optimizations on if available.
15:54:21:WU00:FS00:0xa4:Entering M.D.
15:54:23:WU01:FS00:Upload complete
15:54:23:WU01:FS00:Server responded WORK_ACK (400)
15:54:23:WU01:FS00:Final credit estimate, 1761.00 points
15:54:23:WU01:FS00:Cleaning up
15:54:27:WU00:FS00:0xa4:Mapping NT from 8 to 8
15:54:28:WU00:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
15:55:37:WU00:FS00:0xa4:Completed 2500 out of 250000 steps  (1%)
15:56:46:WU00:FS00:0xa4:Completed 5000 out of 250000 steps  (2%)
15:57:56:WU00:FS00:0xa4:Completed 7500 out of 250000 steps  (3%)
P5-133XL
Machine #2:
Machine 3:
Re: Points not being awarded - Attached Log
Post by P5-133XL »
Hi BYUSinger84 (team 33),
Your WU (P8049 R227 C2 G65) was added to the stats database on 2012-09-22 09:07:19 for 223.41 points of credit.
Your WU (P8049 R443 C2 G58) was added to the stats database on 2012-09-22 11:07:15 for 223.41 points of credit.
You are getting base points + 10% for these A4's. Do you have a passkey configured? To get bonus points, you need to have a Passkey and successfully complete SMP 10 WU's maintaining an 80% successfully completed ratio.
BYUSinger84
I do have a passkey. I've used it for a long time and I did verify it already. My history shows that I was pushing over 1.5 million points a month. Now I'm lucky to get about 40K...
bollix47
Post by bollix47 »
Unfortunately you have fallen below the 80% requirement necessary to receive the QRB.
Your history shows a current rate of 74% with 4486 bonus completed but 1540 bonus expired.
I can't tell you when those failures occurred but with that many work units it's probably faster for you to get a new passkey (requires a different e-mail address) than to get from 74% back to 80%.
Your current returns appear to have been returned before the preferred deadline so perhaps the failures are not recent. You could check your logs as far back as possible but there might not be any error indication if the failures were caused by missing the deadline. Looking at your 3rd party stats the fall below 80% appears to have occurred around mid to late August so I'm not sure how many logs you would have available before then but v7 does keep a few in the logs directory.
BYUSinger84
What 3rd party stats page did you go to, to see those %?
bollix47
Post by bollix47 »
The % of bonus qualified returns is only available to moderators, site admins and PG.
As to when you fell below 80% I looked at kakao stats: http://kakaostats.com/usum.php?u=1320719
It looks like August 29th was the date you fell below 80% and there would have been more failures since then in order for the % to drop to 74.
I realize you have a number of clients running but if one of them is constantly failing the only way I know to find out which one is to check the logs. That should be done before you get a new passkey, otherwise it may get disqualified very quickly too.
BYUSinger84
How do I get a new passkey once I find out what's going on? I think the server I've been having issues with was the server that I've since decommissioned. I'll check the logs just to be sure. Thanks for all your help and answers. They have been extremely helpful.
bollix47
Post by bollix47 »
You can get a new passkey via http://folding.stanford.edu/English/FAQ-passkey
Make sure you use the same user name but a different email address, otherwise you'll get the same unqualified passkey that you're now using.
BYUSinger84
And if I want to continue to use the same e-mail/key, I just need to make sure that the uploads are ok and then eventually when I hit 80% again, everything should just start working agian?
Yes. That is my recommendation.
bollix47
Post by bollix47 »
Correct but with your current stats that would take considerably longer than qualifying a new passkey. The choice is of course yours but having to do hundreds of work units to reach 80% or do 10 with a new passkey ...
BYUSinger84
gotcha...I just hate having to use a different e-mail but oh well...if I change my passkey right now, will it take effect with my current work units or do I need to wait for new ones to be assigned?
bollix47
Post by bollix47 »
New ones. The same passkey must be present when downloading and uploading.
I did a rough calculation using your current stats and you would have to successfully complete ~1500 work units to get your percentage back to 80.
It will apply with the next WU's done. Changing the passkey in the middle of processing a WU will keep it from getting bonus, but you are not getting that anyways now. Once 10 WU's have been completed successfully with the new passkey you will get the QRB as long as you maintain at least a 80% completion rate.
BYUSinger84
Great. Thanks for all your help.
