Project: 8049 (Run 514, Clone 2, Gen 26) - BAD_WORK_UNIT
Fahrenheit451
Hardware configuration: System 1:
CPU: Intel Core 2 Duo E6850, 3000 MHz (9 x 333)
Mainboard: Gigabyte P35-DS3P v1.1
RAM: 2 GB (2x1024 MB DDR2 Dual-Channel, DRAM frequency 400 MHz)
OS: Windows Vista Ultimate, 32 bit, Service Pack 2
HD: Samsung HD501LJ (500 GB)
PSU: BeQuiet Straight Power E8 CM 580W
Case: CoolerMaster Cosmos 1000
GPU: NVIDIA GeForce 8800 GTS 512, XFX Pine Group
GFX driver version: 285.62
The card runs at stock speed: GPU 648 MHz, Memory 972 Mhz, Shader 1620 MHz
System 2:
CPU: Intel i7 2600 (Sandy Bridge) @ 3400 MHz (4C/8T)
Mainboard: Asus P8H67-M-Pro
RAM: 8GB (2x4 GB DDR3, 1333 MHz, Kingston)
OS: Windows 7 Ultimate, 64bit
HD: Samsung HD103SJ (1TB)
PSU: BeQuiet Straight Power E8 CM 580 W
Case: Corsair Obsidian 800D with H100 water cooling
GPU: i7 2600 IGP (not for folding) / Gigabyte GTX 560 Ti OC 1GB
Post by Fahrenheit451 »
Hi guys,
according to the log it is a bad WU:
*********************** Log Started 2012-09-07T13:44:02Z ***********************
00:41:59:WU02:FS00:0xa4:Completed 247500 out of 250000 steps  (99%)
00:42:36:WU02:FS00:0xa4:Completed 250000 out of 250000 steps  (100%)
00:42:36:WU02:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
00:42:37:WU01:FS00:Connecting to assign3.stanford.edu:8080
00:42:38:WU01:FS00:News: Welcome to Folding@Home
00:42:38:WU01:FS00:Assigned to work server 171.67.108.60
00:42:38:WU01:FS00:Requesting new work unit for slot 00: RUNNING smp:8 from 171.67.108.60
00:42:38:WU01:FS00:Connecting to 171.67.108.60:8080
00:42:39:WU01:FS00:Downloading 58.11KiB
00:42:40:WU01:FS00:Download complete
00:42:40:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:OK project:8049 run:514 clone:2 gen:26 core:0xa4 unit:0x000000346652edcc501334bf69d36407
00:42:46:WU02:FS00:0xa4:
00:42:46:WU02:FS00:0xa4:Finished Work Unit:
00:42:46:WU02:FS00:0xa4:- Reading up to 588732 from "02/wudata_01.trr": Read 588732
00:42:46:WU02:FS00:0xa4:trr file hash check passed.
00:42:46:WU02:FS00:0xa4:- Reading up to 352200 from "02/wudata_01.xtc": Read 352200
00:42:46:WU02:FS00:0xa4:xtc file hash check passed.
00:42:46:WU02:FS00:0xa4:edr file hash check passed.
00:42:46:WU02:FS00:0xa4:logfile size: 23235
00:42:46:WU02:FS00:0xa4:Leaving Run
00:42:47:WU02:FS00:0xa4:- Writing 969755 bytes of core data to disk...
00:42:47:WU02:FS00:0xa4:Done: 969243 -> 922127 (compressed to 95.1 percent)
00:42:47:WU02:FS00:0xa4:  ... Done.
00:42:48:WU02:FS00:0xa4:- Shutting down core
00:42:48:WU02:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
00:42:48:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:42:48:WU02:FS00:Sending unit results: id:02 state:SEND error:OK project:8051 run:98 clone:3 gen:14 core:0xa4 unit:0x000000146652edcb503b7e483a03b390
00:42:48:WU02:FS00:Uploading 901.01KiB to 171.67.108.59
00:42:48:WU02:FS00:Connecting to 171.67.108.59:8080
00:42:48:WU01:FS00:Starting
00:42:48:WU01:FS00:Running FahCore: D:\FAHClient_V7/FAHCoreWrapper.exe C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 701 -lifeline 5796 -checkpoint 15 -np 8
00:42:48:WU01:FS00:Started FahCore on PID 3896
00:42:48:WU01:FS00:Core PID:5644
00:42:48:WU01:FS00:FahCore 0xa4 started
00:42:49:WU01:FS00:0xa4:
00:42:49:WU01:FS00:0xa4:*------------------------------*
00:42:49:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
00:42:49:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
00:42:49:WU01:FS00:0xa4:Preparing to commence simulation
00:42:49:WU01:FS00:0xa4:- Looking at optimizations...
00:42:49:WU01:FS00:0xa4:- Created dyn
00:42:49:WU01:FS00:0xa4:- Files status OK
00:42:49:WU01:FS00:0xa4:- Expanded 58990 -> 2209820 (decompressed 3746.0 percent)
00:42:49:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=58990 data_size=2209820, decompressed_data_size=2209820 diff=0
00:42:49:WU01:FS00:0xa4:- Digital signature verified
00:42:49:WU01:FS00:0xa4:Project: 8049 (Run 514, Clone 2, Gen 26)
00:42:49:WU01:FS00:0xa4:Assembly optimizations on if available.
00:42:49:WU01:FS00:0xa4:Entering M.D.
00:42:54:WU02:FS00:Upload 42.62%
00:42:54:WU01:FS00:0xa4:Mapping NT from 8 to 8
00:42:54:WU01:FS00:0xa4:mdrun returned 255
00:42:54:WU01:FS00:0xa4:Going to send back what have done -- stepsTotalG=250000
00:42:54:WU01:FS00:0xa4:Work fraction=0.0000 steps=250000.
00:42:58:WU01:FS00:0xa4:logfile size=6836 infoLength=6836 edr=0 trr=25
00:42:58:WU01:FS00:0xa4:logfile size: 6836 info=6836 bed=0 hdr=25
00:42:58:WU01:FS00:0xa4:- Writing 7374 bytes of core data to disk...
00:42:58:WU01:FS00:0xa4:Done: 6862 -> 2448 (compressed to 35.6 percent)
00:42:58:WU01:FS00:0xa4:  ... Done.
00:42:59:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:42:59:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:8049 run:514 clone:2 gen:26 core:0xa4 unit:0x000000346652edcc501334bf69d36407
00:42:59:WU01:FS00:Uploading 2.89KiB to 171.67.108.60
00:42:59:WU01:FS00:Connecting to 171.67.108.60:8080
00:42:59:WU03:FS00:Connecting to assign3.stanford.edu:8080
00:42:59:WU01:FS00:Upload complete
00:42:59:WU01:FS00:Server responded WORK_ACK (400)
00:42:59:WU01:FS00:Cleaning up
00:43:00:WU03:FS00:News: Welcome to Folding@Home
00:43:00:WU03:FS00:Assigned to work server 171.67.108.60
00:43:00:WU03:FS00:Requesting new work unit for slot 00: READY smp:8 from 171.67.108.60
00:43:00:WU03:FS00:Connecting to 171.67.108.60:8080
00:43:00:WU02:FS00:Upload 85.24%
00:43:01:WU03:FS00:Downloading 946.96KiB
00:43:03:WU02:FS00:Upload complete
00:43:03:WU02:FS00:Server responded WORK_ACK (400)
00:43:03:WU02:FS00:Final credit estimate, 644.00 points
00:43:03:WU02:FS00:Cleaning up
00:43:04:WU03:FS00:Download complete
00:43:04:WU03:FS00:Received Unit: id:03 state:DOWNLOAD error:OK project:8049 run:67 clone:5 gen:24 core:0xa4 unit:0x000000216652edcc50132aad128caf49
00:43:04:WU03:FS00:Starting
00:43:04:WU03:FS00:Running FahCore: D:\FAHClient_V7/FAHCoreWrapper.exe C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 03 -suffix 01 -version 701 -lifeline 5796 -checkpoint 15 -np 8
bollix47
Re: Project: 8049 (Run 514, Clone 2, Gen 26) - BAD_WORK_UNIT
Post by bollix47 »
Thank you for the report.
There are numerous entries with 0 points in the database.
I've marked this one as bad:
The WU (P8049,R514,C2,G26) has been reported as a bad WU. Note that the list of reported WUs are stopped daily at 8am pacific time.
