Project 7611 (Run 4 Clone 9 Gen 185)
Miller855
Hardware configuration: iMac 2.93 Ghz C2D 4Gb DDR3 Ram, OSX 10.6.3, Built in NVidia GeForce GT 120
iMac 2.0 Ghz C2D 2Gb DDR2 Ram, OSX 10.6.3, Built in ATI Raedon HD 2400
120 Gig PS3, 80 Gig PS3
Post by Miller855 »
it seems that for last 2 days my computer gets this "interrupted" message
I am up to 36 attempts, this is on my 2.93 ghz C2D iMac below
only my 120 gig PS3 remains
the 80 gig burnt out after 3 yrs and 1 month of 24/7 operation
an Intel i5 6400 2.70 Ghz 8 Gig ram windows 10 home, burnt out the 975GTX card here in march 2018
iMac 2.0 Ghz, C2D 2Gb DDR2 Ram, OSX 10.11.6 (El Capitan), Built in ATI Raedon HD 2400
bollix47
Re: Project 7611 (Run 4 Clone 9 Gen 185)
Post by bollix47 »
There are no results for this work unit in the database. I will mark it for followup.
Can you get a different assignment if you delete work/00 in the folding Data Directory or does it just keep giving you the same one?
Miller855
Post by Miller855 »
i will keep looking but so far i cant find it
Which version of the V7 client are you using? 7.1.52 and the previous beta moved the work folder. For these recent versions look in the system Library folder. In the Application Support folder is the FAHClient folder which contains the work and logs. If you are using an older version of V7, I would have to look up my notes at home as to where each stored the files, but most did it in the folding account's Library folder.
