ATI HD 6800 Project: 11293 (Run 8, Clone 479, Gen 21)
didcrywolf
Hardware configuration: P6T WS Professional MOBO
I7 920 CPU
ASUS ATI Radeon HD 6800 GPU
Post by didcrywolf »
Using v7.1.52 on a vista 64 machine, I have lost all ability to use my ATI radeon hd 6800 to fold as a GPU. This has been going on for a couple of days. My device driver for the GPU is 8.950.0.0
How can I get it back on track?
*********************** Log Started 2012-08-30T14:15:55Z ***********************
14:15:55:WU00:FS00:Starting
14:15:55:WU00:FS00:Running FahCore: A:\FAHClient/FAHCoreWrapper.exe A:/fahdata/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 00 -suffix 01 -version 701 -lifeline 4528 -checkpoint 4 -noassembly -gpu 0
14:15:55:WU00:FS00:Started FahCore on PID 11232
14:15:55:WU00:FS00:Core PID:10312
14:15:55:WU00:FS00:FahCore 0x16 started
14:15:56:WU00:FS00:0x16:
14:15:56:WU00:FS00:0x16:*------------------------------*
14:15:56:WU00:FS00:0x16:Folding@Home GPU Core
14:15:56:WU00:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
14:15:56:WU00:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
14:15:56:WU00:FS00:0x16:Build host: user-f6d030f24f
14:15:56:WU00:FS00:0x16:Board Type: AMD/OpenCL
14:15:56:WU00:FS00:0x16:Core      : x=16
14:15:56:WU00:FS00:0x16: Window's signal control handler registered.
14:15:56:WU00:FS00:0x16:Preparing to commence simulation
14:15:56:WU00:FS00:0x16:- User disabled assembly optimizations.
14:15:56:WU00:FS00:0x16:- Files status OK
14:15:56:WU00:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
14:15:56:WU00:FS00:0x16:- Expanded 45240 -> 171163 (decompressed 378.3 percent)
14:15:56:WU00:FS00:0x16:Called DecompressByteArray: compressed_data_size=45240 data_size=171163, decompressed_data_size=171163 diff=0
14:15:56:WU00:FS00:0x16:- Digital signature verified
14:15:56:WU00:FS00:0x16:Project: 11293 (Run 8, Clone 479, Gen 21)
14:15:56:WU00:FS00:0x16:Entering M.D.
14:15:57:WU00:FS00:0x16:Tpr hash 00/wudata_01.tpr:  2340519961 4086103580 2453196943 1728238480 4104265329
14:15:57:WU00:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
14:15:57:WU00:FS00:0x16:Client config unavailable.
14:15:58:WU00:FS00:0x16:Starting GUI Server
14:16:01:WU00:FS00:0x16:Setting checkpoint frequency: 500000
14:16:01:WU00:FS00:0x16:Completed         3 out of 50000000 steps (0%).
bollix47
Re: ATI HD 6800 Project: 11293 (Run 8, Clone 479, Gen 21)
Post by bollix47 »
Hello didcrywolf and welcome to the folding support forum.
Can you please copy and paste the config section of your log and the part after what you've already shown in the supplied log. You can see the config by clicking on the Refresh button just above the log and then scrolling up to the top of the log. Your config section will be between the system info section and the processing section of the log.
When using an ati gpu it will use a complete CPU core by itself. As a result to get the most out of your smp client you should actually decrease the number of cores from smp:8 to smp:6 (7 is known to cause problems for some projects). That way the gpu processing does not interfere with the smp processing.
When you installed v7 did you ask it to run as a service? The gpu will not run as a service. If you did then "Finish" the smp work unit and uninstall/reinstall without the service option.
didcrywolf
I7 920 CPU
14:15:55:<config>
14:15:55:  <service-description v='Folding@home Client'/>
14:15:55:  <service-restart v='true'/>
14:15:55:  <service-restart-delay v='5000'/>
14:15:55:
14:15:55:  <!-- Client Control -->
14:15:55:  <cycle-rate v='4'/>
14:15:55:  <cycles v='-1'/>
14:15:55:  <data-directory v='.'/>
14:15:55:  <disable-project-lookup v='false'/>
14:15:55:  <exec-directory v='A:\FAHClient'/>
14:15:55:  <exit-when-done v='false'/>
14:15:55:  <threads v='4'/>
14:15:55:
14:15:55:  <!-- Configuration -->
14:15:55:  <config-rotate v='true'/>
14:15:55:  <config-rotate-dir v='configs'/>
14:15:55:  <config-rotate-max v='16'/>
14:15:55:
14:15:55:  <!-- Debugging -->
14:15:55:  <assignment-servers>
14:15:55:    assign3.stanford.edu:8080 assign4.stanford.edu:80
14:15:55:  </assignment-servers>
14:15:55:  <capture-directory v='capture'/>
14:15:55:  <capture-sockets v='false'/>
14:15:55:  <debug-sockets v='false'/>
14:15:55:  <exception-locations v='true'/>
14:15:55:  <gpu-assignment-servers>
14:15:55:    assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
14:15:55:  </gpu-assignment-servers>
14:15:55:  <stack-traces v='false'/>
14:15:55:
14:15:55:  <!-- Error Handling -->
14:15:55:  <max-slot-errors v='5'/>
14:15:55:  <max-unit-errors v='5'/>
14:15:55:
14:15:55:  <!-- FahCore Control -->
14:15:55:  <checkpoint v='4'/>
14:15:55:  <core-dir v='cores'/>
14:15:55:  <core-priority v='low'/>
14:15:55:  <cpu-affinity v='true'/>
14:15:55:  <cpu-usage v='100'/>
14:15:55:  <no-assembly v='true'/>
14:15:55:
14:15:55:  <!-- Folding Slot Configuration -->
14:15:55:  <client-subtype v='STDCLI'/>
14:15:55:  <client-type v='normal'/>
14:15:55:  <cpu-species v='X86_PENTIUM_II'/>
14:15:55:  <cpu-type v='AMD64'/>
14:15:55:  <cpus v='-1'/>
14:15:55:  <cuda-index v='0'/>
14:15:55:  <gpu v='true'/>
14:15:55:  <gpu-usage v='100'/>
14:15:55:  <max-packet-size v='normal'/>
14:15:55:  <opencl-index v='0'/>
14:15:55:  <os-species v='UNKNOWN'/>
14:15:55:  <os-type v='WIN32'/>
14:15:55:  <project-key v='0'/>
14:15:55:  <smp v='true'/>
14:15:55:
14:15:55:  <!-- Logging -->
14:15:55:  <log v='log.txt'/>
14:15:55:  <log-color v='false'/>
14:15:55:  <log-crlf v='true'/>
14:15:55:  <log-date v='false'/>
14:15:55:  <log-date-periodically v='21600'/>
14:15:55:  <log-debug v='true'/>
14:15:55:  <log-domain v='false'/>
14:15:55:  <log-header v='true'/>
14:15:55:  <log-level v='true'/>
14:15:55:  <log-no-info-header v='true'/>
14:15:55:  <log-redirect v='false'/>
14:15:55:  <log-rotate v='true'/>
14:15:55:  <log-rotate-dir v='logs'/>
14:15:55:  <log-rotate-max v='16'/>
14:15:55:  <log-short-level v='false'/>
14:15:55:  <log-simple-domains v='true'/>
14:15:55:  <log-thread-id v='false'/>
14:15:55:  <log-thread-prefix v='true'/>
14:15:55:  <log-time v='true'/>
14:15:55:  <log-to-screen v='true'/>
14:15:55:  <log-truncate v='false'/>
14:15:55:  <verbosity v='5'/>
14:15:55:
14:15:55:  <!-- Network -->
14:15:55:  <proxy v=':8080'/>
14:15:55:  <proxy-enable v='false'/>
14:15:55:  <proxy-pass v=''/>
14:15:55:  <proxy-user v=''/>
14:15:55:
14:15:55:  <!-- Process Control -->
14:15:55:  <child v='false'/>
14:15:55:  <daemon v='false'/>
14:15:55:  <pid v='false'/>
14:15:55:  <pid-file v='Folding@home Client.pid'/>
14:15:55:  <respawn v='false'/>
14:15:55:  <service v='false'/>
14:15:55:
14:15:55:  <!-- Remote Command Server -->
14:15:55:  <command-address v='0.0.0.0'/>
14:15:55:  <command-allow v='127.0.0.1'/>
14:15:55:  <command-allow-no-pass v='127.0.0.1'/>
14:15:55:  <command-deny v='0.0.0.0/0'/>
14:15:55:  <command-deny-no-pass v='0.0.0.0/0'/>
14:15:55:  <command-port v='36330'/>
14:15:55:
14:15:55:  <!-- Slot Control -->
14:15:55:  <max-shutdown-wait v='60'/>
14:15:55:  <pause-on-battery v='false'/>
14:15:55:  <pause-on-start v='false'/>
14:15:55:
14:15:55:  <!-- User Information -->
14:15:55:  <machine-id v='0'/>
14:15:55:  <passkey v='********************************'/>
14:15:55:  <team v='34025'/>
14:15:55:  <user v='I7_'/>
14:15:55:
14:15:55:  <!-- Work Unit Control -->
14:15:55:  <dump-after-deadline v='true'/>
14:15:55:  <max-queue v='16'/>
14:15:55:  <max-units v='0'/>
14:15:55:  <next-unit-percentage v='99'/>
14:15:55:
14:15:55:  <!-- Folding Slots -->
14:15:55:  <slot id='0' type='GPU'/>
14:15:55:  <slot id='2' type='SMP'>
14:15:55:  </slot>
14:15:55:</config>
14:15:55:Trying to access database...
14:15:55:Successfully acquired database lock
14:15:55:Enabled folding slot 00: READY gpu:0:"Barts XT [ATI Radeon HD 6800 Series]"
14:15:55:Enabled folding slot 02: READY smp:8
14:15:55:Started thread 3 on PID 4528
14:15:55:Started thread 1 on PID 4528
14:15:55:Started thread 6 on PID 4528
14:15:55:Started thread 5 on PID 4528
14:15:55:Started thread 4 on PID 4528
14:15:55:Started thread 7 on PID 4528
14:15:55:WU01:FS02:Starting
14:15:55:WU01:FS02:Running FahCore: A:\FAHClient/FAHCoreWrapper.exe A:/fahdata/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 701 -lifeline 4528 -checkpoint 4 -noassembly -np 8
14:15:55:WU01:FS02:Started FahCore on PID 11228
14:15:55:Started thread 8 on PID 4528
14:15:55:WU01:FS02:Core PID:4756
14:15:55:WU01:FS02:FahCore 0xa4 started
14:15:56:WU01:FS02:0xa4:
14:15:56:WU01:FS02:0xa4:*------------------------------*
14:15:56:WU01:FS02:0xa4:Folding@Home Gromacs GB Core
14:15:56:WU01:FS02:0xa4:Version 2.27 (Dec. 15, 2010)
14:15:56:WU01:FS02:0xa4:Preparing to commence simulation
14:15:56:WU01:FS02:0xa4:- User disabled assembly optimizations.
14:15:56:WU01:FS02:0xa4:- Files status OK
14:15:56:WU01:FS02:0xa4:- Expanded 572372 -> 1689464 (decompressed 295.1 percent)
14:15:56:WU01:FS02:0xa4:Called DecompressByteArray: compressed_data_size=572372 data_size=1689464, decompressed_data_size=1689464 diff=0
14:15:56:WU01:FS02:0xa4:- Digital signature verified
14:15:56:WU01:FS02:0xa4:Project: 8051 (Run 190, Clone 8, Gen 6)
14:15:56:WU01:FS02:0xa4:Entering M.D.
14:15:58:Started thread 9 on PID 4528
14:15:58:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
14:16:01:WU01:FS02:0xa4:Using Gromacs checkpoints
14:16:02:WU01:FS02:0xa4:Mapping NT from 8 to 8
14:17:40:WU01:FS02:0xa4:Resuming from checkpoint
14:17:40:WU01:FS02:0xa4:Verified 01/wudata_01.log
14:17:40:WU01:FS02:0xa4:Verified 01/wudata_01.trr
14:17:40:WU01:FS02:0xa4:Verified 01/wudata_01.xtc
14:17:40:WU01:FS02:0xa4:Verified 01/wudata_01.edr
14:17:41:WARNING:WU01:FS02:Detected clock skew, adjusting time estimates
14:17:41:WU01:FS02:0xa4:Completed 19240 out of 250000 steps  (7%)
14:19:48:WU01:FS02:0xa4:Completed 20000 out of 250000 steps  (8%)
14:23:17:WU01:FS02:0xa4:Completed 22500 out of 250000 steps  (9%)
14:26:13:WU01:FS02:0xa4:Completed 25000 out of 250000 steps  (10%)
14:29:04:WU01:FS02:0xa4:Completed 27500 out of 250000 steps  (11%)
14:32:19:WU01:FS02:0xa4:Completed 30000 out of 250000 steps  (12%)
14:35:45:WU01:FS02:0xa4:Completed 32500 out of 250000 steps  (13%)
14:46:24:WU01:FS02:0xa4:Completed 35000 out of 250000 steps  (14%)
14:58:08:Saving configuration to config.xml
14:58:08:<config>
14:58:08:  <!-- FahCore Control -->
14:58:08:  <checkpoint v='4'/>
14:58:08:  <core-priority v='low'/>
14:58:08:
14:58:08:  <!-- Folding Slot Configuration -->
14:58:08:  <gpu v='true'/>
14:58:08:
14:58:08:  <!-- Logging -->
14:58:08:  <verbosity v='5'/>
14:58:08:
14:58:08:  <!-- Network -->
14:58:08:  <proxy v=':8080'/>
14:58:08:
14:58:08:  <!-- User Information -->
14:58:08:  <passkey v='********************************'/>
14:58:08:  <team v='34025'/>
14:58:08:  <user v='I7_'/>
14:58:08:
14:58:08:  <!-- Folding Slots -->
14:58:08:  <slot id='0' type='GPU'/>
14:58:08:  <slot id='2' type='SMP'>
14:58:08:    <cpus v='-1'/>
14:58:08:  </slot>
14:58:08:</config>
15:01:15:WU01:FS02:0xa4:Completed 37500 out of 250000 steps  (15%)
15:05:19:WU01:FS02:0xa4:Completed 40000 out of 250000 steps  (16%)
15:10:00:WU01:FS02:0xa4:Completed 42500 out of 250000 steps  (17%)
15:14:37:WU01:FS02:0xa4:Completed 45000 out of 250000 steps  (18%)
15:22:13:WU01:FS02:0xa4:Completed 47500 out of 250000 steps  (19%)
15:26:52:WU01:FS02:0xa4:Completed 50000 out of 250000 steps  (20%)
15:30:15:WU01:FS02:0xa4:Completed 52500 out of 250000 steps  (21%)
15:35:40:WU01:FS02:0xa4:Completed 55000 out of 250000 steps  (22%)
15:49:52:WU01:FS02:0xa4:Completed 57500 out of 250000 steps  (23%)
P5-133XL
Machine #2:
Machine 3:
Post by P5-133XL »
My guess is that you need to do some fiddling with the open_cl index on your GPU slot (try 0 or 1 rather than -1) or the GPU index (try 0 or 1 rather than -1). You may have to do a trial and error process of every combination to get it all aligned and working again. You have one GPU that can't fold and one that can and whenever I have done either a driver upgrade or a client upgrade I have found that the order of GPU's can change if there are multiples. The -1 value is for auto-detecting and I don't think that is working for you. So I think you will have to manually choose. Unfortunately I can't predict if either value will be a 0, or a 1
bollix47
Post by bollix47 »
Try P5's suggestion and if using gpu-index = 0 or 1 still doesn't cause the gpu to start processing the following may be helpful.
Make the changes I referred to in my earlier post. If the gpu still doesn't start processing after changing to smp:6 and doing the uninstall/reinstall without using the service option come back and let us know.
You're using priority=low and it looks to me that both are set to low but if that's just on the smp slot it would mean that the gpu is getting little or no cpu resources which it needs to load and unload data. Please ensure that either both are set to low or the gpu is set to low and the smp is set to idle. My personal preference is to set them both to low. If just the smp is set to low and the gpu is set idle then the gpu will never get the cpu cycles it needs, especially if using smp:8.
I noticed you're using a checkpoint of 4. This is quite low and could cause corruption if you have a power interruption. The recommended 15 minutes works well and some people use the full 30 minutes to minimize the change of corruption. Corruption can occur if the power outage occurs during the writing of the checkpoint.
Longer check point settings also improves performance, as long as you do not stop and start the client often.
didcrywolf
I7 920 CPU
Big kaboom on PC reboot Now nothing will happen...
How do you do a command line clean up? do I have to launch an app through cmd.exe?
My other option is that I have a new SSD that I want to use to do a clean install. How do I avoid having ANYTHING left over? Is is better to use a new user name too?
RIP v7...
bollix47
Post by bollix47 »
Start>FAHClient>Uninstall ... should clean it up.
From your pic it looks like there is something set wrong. When the client is running on a local computer the Name under Clients should say local and the address should say 127.0.0.1:36330.
Use the following guide to reinstall:
http://folding.stanford.edu/English/WinGuide#ntoc6
Additional info:
https://fah-web.stanford.edu/projects/F ... de#Windows
Using a new user name shouldn't be necessary.
Is there a reason for not allowing the installer to use the default location rather than a new SSD?
didcrywolf
I7 920 CPU
To answer the first question, I am never going to have anything BUT SSDs (the future of HDDs is grim as are all things spinning inside my next build!) so any new OS, APPs and data will be on SSDs as for media it's going to the cloud...
So I did install a new OS W7 ultimate. on the SSD ,loaded v7.1.52. and besides reducing SMP to 6 and removing my second GPU (ATI HD 3600 with no work) as suggested, the program has been plugging fine. The GPU has been running quite faster than the CPU by a magnitude of 5x.
I can only thank you, cross my fingers that nothing else happens...
GONE FISHING for the long weekend!
Merci from Montreal!
