Folding fails with GeForce 9800 GT
Rasmon
Post by Rasmon »
The log seems to indicate an unstable system is the cause of the failure. I tried installing the latest driver, but no go. I have a GeForce 9800 GT in this system with Windows Vista 64-bit. Below is the log.
Any ideas how to fix this?
Thanks!
*********************** Log Started 2012-08-25T15:51:25Z ***********************
15:51:25:************************* Folding@home Client *************************
15:51:25:      Website: http://folding.stanford.edu/
15:51:25:    Copyright: (c) 2009-2012 Stanford University
15:51:25:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:51:25:         Args: --lifeline 6264 --command-port=36330
15:51:25:       Config: C:/ProgramData/FAHClient/config.xml
15:51:25:******************************** Build ********************************
15:51:25:      Version: 7.1.52
15:51:25:         Date: Mar 20 2012
15:51:25:         Time: 19:37:42
15:51:25:      SVN Rev: 3515
15:51:25:       Branch: fah/trunk/client
15:51:25:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
15:51:25:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
15:51:25:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
15:51:25:     Platform: win32 XP
15:51:25:         Bits: 32
15:51:25:         Mode: Release
15:51:25:******************************* System ********************************
15:51:25:          CPU: Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
15:51:25:       CPU ID: GenuineIntel Family 6 Model 15 Stepping 6
15:51:25:         CPUs: 2
15:51:25:       Memory: 4.00GiB
15:51:25:  Free Memory: 2.19GiB
15:51:25:      Threads: WINDOWS_THREADS
15:51:25:   On Battery: false
15:51:25:   UTC offset: -7
15:51:25:          PID: 6392
15:51:25:          CWD: C:/ProgramData/FAHClient
15:51:25:           OS: Windows (TM) Vista Ultimate
15:51:25:      OS Arch: AMD64
15:51:25:         GPUs: 1
15:51:25:        GPU 0: NVIDIA:1 G92 [GeForce 9800 GT]
15:51:25:         CUDA: Not detected
15:51:25:Win32 Service: false
15:51:25:***********************************************************************
15:51:25:<config>
15:51:25:  <!-- Folding Slot Configuration -->
15:51:25:  <gpu v='true'/>
15:51:25:  <smp v='false'/>
15:51:25:
15:51:25:  <!-- User Information -->
15:51:25:  <passkey v='********************************'/>
15:51:25:  <team v='111065'/>
15:51:25:  <user v='Rasmon'/>
15:51:25:
15:51:25:  <!-- Folding Slots -->
15:51:25:</config>
15:51:25:Trying to access database...
15:51:26:Successfully acquired database lock
15:51:26:Enabled folding slot 00: READY gpu:0:"G92 [GeForce 9800 GT]"
15:51:26:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
15:51:26:WU00:FS00:News: Welcome to Folding@Home
15:51:26:WU00:FS00:Assigned to work server 171.67.108.11
15:51:26:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"G92 [GeForce 9800 GT]" from 171.67.108.11
15:51:26:WU00:FS00:Connecting to 171.67.108.11:8080
15:51:26:WU00:FS00:Downloading 46.12KiB
15:51:26:WU00:FS00:Download complete
15:51:26:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:OK project:5765 run:5 clone:444 gen:2350 core:0x11 unit:0x1b50ce925038f47f092e01bc00051685
15:51:26:WU00:FS00:Starting
15:51:26:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 00 -suffix 01 -version 701 -lifeline 6392 -checkpoint 15 -gpu 0
15:51:26:WU00:FS00:Started FahCore on PID 6604
15:51:27:WU00:FS00:Core PID:6616
15:51:27:WU00:FS00:FahCore 0x11 started
15:51:28:WU00:FS00:0x11:
15:51:28:WU00:FS00:0x11:*------------------------------*
15:51:28:WU00:FS00:0x11:Folding@Home GPU Core
15:51:28:WU00:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
15:51:28:WU00:FS00:0x11:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
15:51:28:WU00:FS00:0x11:Build host: amoeba
15:51:28:WU00:FS00:0x11:Board Type: Nvidia
15:51:28:WU00:FS00:0x11:Core      :
15:51:28:WU00:FS00:0x11:Preparing to commence simulation
15:51:28:WU00:FS00:0x11:- Looking at optimizations...
15:51:28:WU00:FS00:0x11:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
15:51:28:WU00:FS00:0x11:- Created dyn
15:51:28:WU00:FS00:0x11:- Files status OK
15:51:28:WU00:FS00:0x11:- Expanded 46718 -> 252912 (decompressed 541.3 percent)
15:51:28:WU00:FS00:0x11:Called DecompressByteArray: compressed_data_size=46718 data_size=252912, decompressed_data_size=252912 diff=0
15:51:28:WU00:FS00:0x11:- Digital signature verified
15:51:28:WU00:FS00:0x11:Project: 5765 (Run 5, Clone 444, Gen 2350)
15:51:28:WU00:FS00:0x11:Assembly optimizations on if available.
15:51:28:WU00:FS00:0x11:Entering M.D.
15:51:28:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
15:51:33:WU00:FS00:0x11:Tpr hash 00/wudata_01.tpr:  3941581733 2426766863 2013796002 799118588 2013224589
15:51:33:WU00:FS00:0x11:Calling fah_main args: 14 usage=100
15:51:33:WU00:FS00:0x11:mdrun_gpu returned
15:51:33:WU00:FS00:0x11:Going to send back what have done -- stepsTotalG=0
15:51:33:WU00:FS00:0x11:Work fraction=0.0000 steps=0.
15:51:37:WU00:FS00:0x11:logfile size=0 infoLength=0 edr=0 trr=25
15:51:37:WU00:FS00:0x11:+ Opened results file
15:51:37:WU00:FS00:0x11:- Writing 635 bytes of core data to disk...
15:51:37:WU00:FS00:0x11:Done: 123 -> 121 (compressed to 98.3 percent)
15:51:37:WU00:FS00:0x11:  ... Done.
15:51:37:WU00:FS00:0x11:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
15:51:37:WU00:FS00:0x11:Folding@home Core Shutdown: UNSTABLE_MACHINE
15:51:38:WU00:FS00:FahCore returned: UNSTABLE_MACHINE (122 = 0x7a)
15:51:38:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:5765 run:5 clone:444 gen:2350 core:0x11 unit:0x1b50ce925038f47f092e01bc00051685
15:51:38:WU00:FS00:Uploading 633B to 171.67.108.11
15:51:38:WU00:FS00:Connecting to 171.67.108.11:8080
15:51:38:WU00:FS00:Upload complete
15:51:38:WU00:FS00:Server responded WORK_ACK (400)
15:51:38:WU00:FS00:Cleaning up
15:51:38:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
15:51:38:WU01:FS00:News: Welcome to Folding@Home
15:51:38:WU01:FS00:Assigned to work server 171.67.108.11
15:51:38:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"G92 [GeForce 9800 GT]" from 171.67.108.11
15:51:38:WU01:FS00:Connecting to 171.67.108.11:8080
15:51:38:WU01:FS00:Downloading 44.88KiB
15:51:38:WU01:FS00:Download complete
15:51:38:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:OK project:5771 run:6 clone:63 gen:4081 core:0x11 unit:0x29710e985038f48b0ff1003f0006168b
15:51:39:WU01:FS00:Starting
15:51:39:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 01 -suffix 01 -version 701 -lifeline 6392 -checkpoint 15 -gpu 0
15:51:39:WU01:FS00:Started FahCore on PID 6912
15:51:39:WU01:FS00:Core PID:6924
15:51:39:WU01:FS00:FahCore 0x11 started
15:51:39:WU01:FS00:0x11:
15:51:39:WU01:FS00:0x11:*------------------------------*
15:51:39:WU01:FS00:0x11:Folding@Home GPU Core
15:51:39:WU01:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
15:51:39:WU01:FS00:0x11:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
15:51:39:WU01:FS00:0x11:Build host: amoeba
15:51:39:WU01:FS00:0x11:Board Type: Nvidia
15:51:39:WU01:FS00:0x11:Core      :
15:51:39:WU01:FS00:0x11:Preparing to commence simulation
15:51:39:WU01:FS00:0x11:- Looking at optimizations...
15:51:39:WU01:FS00:0x11:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
15:51:39:WU01:FS00:0x11:- Created dyn
15:51:39:WU01:FS00:0x11:- Files status OK
15:51:39:WU01:FS00:0x11:- Expanded 45447 -> 251112 (decompressed 552.5 percent)
15:51:39:WU01:FS00:0x11:Called DecompressByteArray: compressed_data_size=45447 data_size=251112, decompressed_data_size=251112 diff=0
15:51:39:WU01:FS00:0x11:- Digital signature verified
15:51:39:WU01:FS00:0x11:Project: 5771 (Run 6, Clone 63, Gen 4081)
15:51:39:WU01:FS00:0x11:Assembly optimizations on if available.
15:51:39:WU01:FS00:0x11:Entering M.D.
15:51:45:WU01:FS00:0x11:Tpr hash 01/wudata_01.tpr:  976700529 319890704 2982657010 1607892756 102483489
15:51:45:WU01:FS00:0x11:Calling fah_main args: 14 usage=100
15:51:45:WU01:FS00:0x11:mdrun_gpu returned
15:51:45:WU01:FS00:0x11:Going to send back what have done -- stepsTotalG=0
15:51:45:WU01:FS00:0x11:Work fraction=0.0000 steps=0.
15:51:49:WU01:FS00:0x11:logfile size=0 infoLength=0 edr=0 trr=25
15:51:49:WU01:FS00:0x11:+ Opened results file
15:51:49:WU01:FS00:0x11:- Writing 635 bytes of core data to disk...
15:51:49:WU01:FS00:0x11:Done: 123 -> 120 (compressed to 97.5 percent)
15:51:49:WU01:FS00:0x11:  ... Done.
15:51:49:WU01:FS00:0x11:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
15:51:49:WU01:FS00:0x11:Folding@home Core Shutdown: UNSTABLE_MACHINE
15:51:49:WU01:FS00:FahCore returned: UNSTABLE_MACHINE (122 = 0x7a)
15:51:49:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:5771 run:6 clone:63 gen:4081 core:0x11 unit:0x29710e985038f48b0ff1003f0006168b
15:51:49:WU01:FS00:Uploading 632B to 171.67.108.11
15:51:49:WU01:FS00:Connecting to 171.67.108.11:8080
15:51:49:WU01:FS00:Upload complete
15:51:49:WU01:FS00:Server responded WORK_ACK (400)
15:51:50:WU01:FS00:Cleaning up
15:51:50:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
15:51:50:WU00:FS00:News: Welcome to Folding@Home
15:51:50:WU00:FS00:Assigned to work server 171.67.108.11
15:51:50:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"G92 [GeForce 9800 GT]" from 171.67.108.11
15:51:50:WU00:FS00:Connecting to 171.67.108.11:8080
15:51:50:WU00:FS00:Downloading 46.13KiB
15:51:50:WU00:FS00:Download complete
15:51:50:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:OK project:5765 run:7 clone:93 gen:1667 core:0x11 unit:0x718d56e25038f4970683005d00071685
15:51:50:WU00:FS00:Starting
15:51:50:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 00 -suffix 01 -version 701 -lifeline 6392 -checkpoint 15 -gpu 0
15:51:50:WU00:FS00:Started FahCore on PID 2884
15:51:50:WU00:FS00:Core PID:1584
15:51:50:WU00:FS00:FahCore 0x11 started
15:51:51:WU00:FS00:0x11:
15:51:51:WU00:FS00:0x11:*------------------------------*
15:51:51:WU00:FS00:0x11:Folding@Home GPU Core
15:51:51:WU00:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
15:51:51:WU00:FS00:0x11:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
15:51:51:WU00:FS00:0x11:Build host: amoeba
15:51:51:WU00:FS00:0x11:Board Type: Nvidia
15:51:51:WU00:FS00:0x11:Core      :
15:51:51:WU00:FS00:0x11:Preparing to commence simulation
15:51:51:WU00:FS00:0x11:- Looking at optimizations...
15:51:51:WU00:FS00:0x11:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
15:51:51:WU00:FS00:0x11:- Created dyn
15:51:51:WU00:FS00:0x11:- Files status OK
15:51:51:WU00:FS00:0x11:- Expanded 46721 -> 252912 (decompressed 541.3 percent)
15:51:51:WU00:FS00:0x11:Called DecompressByteArray: compressed_data_size=46721 data_size=252912, decompressed_data_size=252912 diff=0
15:51:51:WU00:FS00:0x11:- Digital signature verified
15:51:51:WU00:FS00:0x11:Project: 5765 (Run 7, Clone 93, Gen 1667)
15:51:51:WU00:FS00:0x11:Assembly optimizations on if available.
15:51:51:WU00:FS00:0x11:Entering M.D.
15:51:56:WU00:FS00:0x11:Tpr hash 00/wudata_01.tpr:  1113695450 2330777904 2252710322 94204691 2952804159
15:51:56:WU00:FS00:0x11:Calling fah_main args: 14 usage=100
15:51:56:WU00:FS00:0x11:mdrun_gpu returned
15:51:56:WU00:FS00:0x11:Going to send back what have done -- stepsTotalG=0
15:51:56:WU00:FS00:0x11:Work fraction=0.0000 steps=0.
15:52:00:WU00:FS00:0x11:logfile size=0 infoLength=0 edr=0 trr=25
15:52:00:WU00:FS00:0x11:+ Opened results file
15:52:00:WU00:FS00:0x11:- Writing 635 bytes of core data to disk...
15:52:00:WU00:FS00:0x11:Done: 123 -> 121 (compressed to 98.3 percent)
15:52:00:WU00:FS00:0x11:  ... Done.
15:52:00:WU00:FS00:0x11:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
15:52:01:WU00:FS00:0x11:
15:52:01:WU00:FS00:0x11:Folding@home Core Shutdown: UNSTABLE_MACHINE
15:52:01:WU00:FS00:FahCore returned: UNSTABLE_MACHINE (122 = 0x7a)
15:52:01:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:5765 run:7 clone:93 gen:1667 core:0x11 unit:0x718d56e25038f4970683005d00071685
15:52:01:WU00:FS00:Uploading 633B to 171.67.108.11
15:52:01:WU00:FS00:Connecting to 171.67.108.11:8080
15:52:01:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
15:52:01:WU00:FS00:Upload complete
15:52:01:WU00:FS00:Server responded WORK_ACK (400)
15:52:01:WU00:FS00:Cleaning up
15:52:01:WU01:FS00:News: Welcome to Folding@Home
15:52:01:WU01:FS00:Assigned to work server 171.67.108.11
15:52:01:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"G92 [GeForce 9800 GT]" from 171.67.108.11
15:52:01:WU01:FS00:Connecting to 171.67.108.11:8080
15:52:02:WU01:FS00:Downloading 46.14KiB
15:52:02:WU01:FS00:Download complete
15:52:02:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:OK project:5768 run:13 clone:216 gen:1023 core:0x11 unit:0x0b64b3d85038f4a203ff00d8000d1688
15:52:02:WU01:FS00:Starting
15:52:02:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 01 -suffix 01 -version 701 -lifeline 6392 -checkpoint 15 -gpu 0
15:52:02:WU01:FS00:Started FahCore on PID 6300
15:52:02:WU01:FS00:Core PID:1712
15:52:02:WU01:FS00:FahCore 0x11 started
15:52:02:WU01:FS00:0x11:
15:52:02:WU01:FS00:0x11:*------------------------------*
15:52:02:WU01:FS00:0x11:Folding@Home GPU Core
15:52:02:WU01:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
15:52:02:WU01:FS00:0x11:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
15:52:02:WU01:FS00:0x11:Build host: amoeba
15:52:02:WU01:FS00:0x11:Board Type: Nvidia
15:52:02:WU01:FS00:0x11:Core      :
15:52:02:WU01:FS00:0x11:Preparing to commence simulation
15:52:02:WU01:FS00:0x11:- Looking at optimizations...
15:52:02:WU01:FS00:0x11:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
15:52:02:WU01:FS00:0x11:- Created dyn
15:52:02:WU01:FS00:0x11:- Files status OK
15:52:02:WU01:FS00:0x11:- Expanded 46731 -> 252912 (decompressed 541.2 percent)
15:52:02:WU01:FS00:0x11:Called DecompressByteArray: compressed_data_size=46731 data_size=252912, decompressed_data_size=252912 diff=0
15:52:02:WU01:FS00:0x11:- Digital signature verified
15:52:02:WU01:FS00:0x11:Project: 5768 (Run 13, Clone 216, Gen 1023)
15:52:02:WU01:FS00:0x11:Assembly optimizations on if available.
15:52:02:WU01:FS00:0x11:Entering M.D.
15:52:08:WU01:FS00:0x11:Tpr hash 01/wudata_01.tpr:  1686998715 317859561 990602419 3143626078 3712734281
15:52:08:WU01:FS00:0x11:Calling fah_main args: 14 usage=100
15:52:08:WU01:FS00:0x11:mdrun_gpu returned
15:52:08:WU01:FS00:0x11:Going to send back what have done -- stepsTotalG=0
15:52:08:WU01:FS00:0x11:Work fraction=0.0000 steps=0.
15:52:12:WU01:FS00:0x11:logfile size=0 infoLength=0 edr=0 trr=25
15:52:12:WU01:FS00:0x11:+ Opened results file
15:52:12:WU01:FS00:0x11:- Writing 635 bytes of core data to disk...
15:52:12:WU01:FS00:0x11:Done: 123 -> 120 (compressed to 97.5 percent)
15:52:12:WU01:FS00:0x11:  ... Done.
15:52:12:WU01:FS00:0x11:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
15:52:13:WU01:FS00:0x11:
15:52:13:WU01:FS00:0x11:Folding@home Core Shutdown: UNSTABLE_MACHINE
15:52:13:WU01:FS00:FahCore returned: UNSTABLE_MACHINE (122 = 0x7a)
15:52:13:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:5768 run:13 clone:216 gen:1023 core:0x11 unit:0x0b64b3d85038f4a203ff00d8000d1688
15:52:13:WU01:FS00:Uploading 632B to 171.67.108.11
15:52:13:WU01:FS00:Connecting to 171.67.108.11:8080
15:52:13:WU01:FS00:Upload complete
15:52:13:WU01:FS00:Server responded WORK_ACK (400)
15:52:13:WU01:FS00:Cleaning up
15:52:14:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
15:52:14:WU00:FS00:News: Welcome to Folding@Home
15:52:14:WU00:FS00:Assigned to work server 171.67.108.11
15:52:14:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"G92 [GeForce 9800 GT]" from 171.67.108.11
15:52:14:WU00:FS00:Connecting to 171.67.108.11:8080
15:52:14:WU00:FS00:Downloading 44.90KiB
15:52:14:WU00:FS00:Download complete
15:52:14:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:OK project:5770 run:6 clone:390 gen:2014 core:0x11 unit:0x71ba38fc5038f4af07de01860006168a
15:52:14:WU00:FS00:Starting
15:52:14:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 00 -suffix 01 -version 701 -lifeline 6392 -checkpoint 15 -gpu 0
15:52:14:WU00:FS00:Started FahCore on PID 6520
15:52:14:WU00:FS00:Core PID:4936
15:52:14:WU00:FS00:FahCore 0x11 started
15:52:15:WU00:FS00:0x11:
15:52:15:WU00:FS00:0x11:*------------------------------*
15:52:15:WU00:FS00:0x11:Folding@Home GPU Core
15:52:15:WU00:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
15:52:15:WU00:FS00:0x11:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
15:52:15:WU00:FS00:0x11:Build host: amoeba
15:52:15:WU00:FS00:0x11:Board Type: Nvidia
15:52:15:WU00:FS00:0x11:Core      :
15:52:15:WU00:FS00:0x11:Preparing to commence simulation
15:52:15:WU00:FS00:0x11:- Looking at optimizations...
15:52:15:WU00:FS00:0x11:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
15:52:15:WU00:FS00:0x11:- Created dyn
15:52:15:WU00:FS00:0x11:- Files status OK
15:52:15:WU00:FS00:0x11:- Expanded 45468 -> 251112 (decompressed 552.2 percent)
15:52:15:WU00:FS00:0x11:Called DecompressByteArray: compressed_data_size=45468 data_size=251112, decompressed_data_size=251112 diff=0
15:52:15:WU00:FS00:0x11:- Digital signature verified
15:52:15:WU00:FS00:0x11:Project: 5770 (Run 6, Clone 390, Gen 2014)
15:52:15:WU00:FS00:0x11:Assembly optimizations on if available.
15:52:15:WU00:FS00:0x11:Entering M.D.
15:52:21:WU00:FS00:0x11:Tpr hash 00/wudata_01.tpr:  269560385 609513194 1401176806 356818751 3470812285
15:52:21:WU00:FS00:0x11:Calling fah_main args: 14 usage=100
15:52:21:WU00:FS00:0x11:mdrun_gpu returned
15:52:21:WU00:FS00:0x11:Going to send back what have done -- stepsTotalG=0
15:52:21:WU00:FS00:0x11:Work fraction=0.0000 steps=0.
15:52:24:WU00:FS00:0x11:logfile size=0 infoLength=0 edr=0 trr=25
15:52:24:WU00:FS00:0x11:+ Opened results file
15:52:24:WU00:FS00:0x11:- Writing 635 bytes of core data to disk...
15:52:24:WU00:FS00:0x11:Done: 123 -> 121 (compressed to 98.3 percent)
15:52:24:WU00:FS00:0x11:  ... Done.
15:52:24:WU00:FS00:0x11:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
15:52:25:WU00:FS00:FahCore returned: UNSTABLE_MACHINE (122 = 0x7a)
15:52:25:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:5770 run:6 clone:390 gen:2014 core:0x11 unit:0x71ba38fc5038f4af07de01860006168a
15:52:25:WU00:FS00:Uploading 633B to 171.67.108.11
15:52:25:WU00:FS00:Connecting to 171.67.108.11:8080
15:52:25:WU00:FS00:Upload complete
15:52:25:WU00:FS00:Server responded WORK_ACK (400)
15:52:25:WU00:FS00:Cleaning up
kiore
Re: Folding fails with GeForce 9800 GT
Post by kiore »
Were you folding OK on this card before? Unstable machine errors are frequently caused by heat/overclocking.
If overclocked reduce to stock, check the fan is working and what the temps are, on a 9800GT on a unit like that my old ones used to go up to the low 70c's.
I would check these things first. You may have gone into a 24hr shut down as well due to failing so often so you will need to reboot and watch for this again.. If it continues stop it for now no use wasting all these units.
No CUDA, no folding.
Would you happen to be using Remote Desktop to access PC? Try VNC instead.
kiore
Post by kiore »
I noticed that no cuda thing, so this is related to using remote desktop? Must file that under useful stuff to remember .
Rasmon
Post by Rasmon »
7im, you nailed it. I was using Remote Desktop to update the system. I rebooted and went to the system console and it works fine. Thanks!!
