171.67.108.44
Judas
171.67.108.44
Post by Judas »
all machines with gpus are getting this from multiple locations... started around 3am this morning..
*********************** Log Started 2012-08-22T19:07:10Z ***********************
19:07:11:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
19:07:11:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
19:07:11:ERROR:WU01:FS00:Exception: Could not get an assignment
19:07:11:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
19:07:13:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.44:80: No connection could be made because the target machine actively refused it.
19:07:14:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
19:07:14:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
19:07:15:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
19:07:15:ERROR:WU01:FS00:Exception: Could not get an assignment
19:07:15:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
19:07:17:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
19:07:18:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.44:80: No connection could be made because the target machine actively refused it.
19:07:20:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
19:07:21:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
19:08:11:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
19:08:12:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
19:08:12:ERROR:WU01:FS00:Exception: Could not get an assignment
19:08:17:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
19:08:19:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.44:80: No connection could be made because the target machine actively refused it.
19:08:20:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
19:08:21:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
19:09:49:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
19:09:49:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
19:09:49:ERROR:WU01:FS00:Exception: Could not get an assignment
19:09:55:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
19:09:56:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.44:80: No connection could be made because the target machine actively refused it.
19:09:57:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
19:09:59:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
bollix47
Re: 171.67.108.44
Post by bollix47 »
Thanks for the report.
108.26 is a collection server and has not worked for a long time.
108.44 is in reject mode and has been reported:
viewtopic.php?p=222842#p222842
I'm going to change your title so that it just reflects the actual problem server.
See the sticky "Troubleshooting Server Connectivity Issues (Do This First)" at the top of this forum.
Re: 171.67.108.44
Server is now listed as accepting connections, so you should be able to upload any completed work and get a new assignment.
Judas
Re: 171.67.108.44
Post by Judas »
yup looks like it's progressing as it should be now... thanks
