cuda
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
Re: cuda
Welcome to the forum ihatesnow,
What exactly do you mean? Do you want to fold on your GPU, are you adding another GPU and want to use it, is your GPU unrecognized, etc?
We'd be happy to help but personally I don't quite understand your question.
-Jesse V.
Big Lake, Alaska. Hahaha
-Jesse V.
Re: cuda
Run the V7 client installer again. It will add the GPU slot automatically, while keeping current setup.
Jesse_V
CPU: i7-6700k
Re: cuda
That will work. If you need to add a GPU slot, here's a method that doesn't involve the installer: 1) using the drop-down menu in the upper right-hand corner, change V7's mode to Advanced, 2) press the Configure button, 3) Go to the Slots tab and hit the Add button, 4) select the GPU option and click Add, 5) hit Save.7im wrote:Run the V7 client installer again. It will add the GPU slot automatically, while keeping current setup.
Either way.
The V7 installer should automatically try to set up a GPU slot. Did it? If not, I think we need more information.
Dark Pulse
- Hardware configuration: System 1:
Core i7 2600K (Sandy Bridge, Overclocked up to 4.3 GHz)
GeForce GTX 690
System 2 (Arriving soon!):
Core i7 3820QM (Ivy Bridge, OC TBD)
GeForce GTX 680M - Location: Buffalo, NY, USA
Re: cuda
If for some reason the GPU slot still isn't detected, or is detected but doesn't seem to "work," you may need to update GPUs.txt.
What GPU do you have?
