Asus HD7750 Not Supported
Son_of_Man
My GPU is an Asus HD7750, device ID 1002 - 683F. It is not recognized by the FAH software. Any help would be appreciated. Thanks. : )
P5-133XL
Machine #2:
Machine 3:
Re: Asus HD7750 Not Supported
Try downloading the current white-list GPUs.txt and placing it in the Data Directory (Start->All Programs->FAHClient->Data Directory). Then re-start the client so it reads the file when it initializes.
Son_of_Man
Pont_ERPE=mc²
Hi, i have a different pb.
12.6 package installed but FAH display that:
what's happend ?
GPU-z detect all and Einstein@Home works fine.
i've tryed catalyst 12.8, then 12.4, and now 12.6
*********************** Log Started 2012-09-04T21:02:14Z ***********************
21:02:14:************************* Folding@home Client *************************
21:02:14: Website: http://folding.stanford.edu/
21:02:14: Copyright: (c) 2009-2012 Stanford University
21:02:14: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:02:14: Args: --lifeline 2460 --command-port=36330
21:02:14: Config: H:/Foldingathome/config.xml
21:02:14:******************************** Build ********************************
21:02:14: Version: 7.1.52
21:02:14: Date: Mar 20 2012
21:02:14: Time: 19:37:42
21:02:14: SVN Rev: 3515
21:02:14: Branch: fah/trunk/client
21:02:14: Compiler: Intel(R) C++ MSVC 1500 mode 1200
21:02:14: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
21:02:14: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
21:02:14: Platform: win32 XP
21:02:14: Bits: 32
21:02:14: Mode: Release
21:02:14:******************************* System ********************************
21:02:14: CPU: Intel(R) Core(TM) i5-2400S CPU @ 2.50GHz
21:02:14: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
21:02:14: CPUs: 4
21:02:14: Memory: 7.98GiB
21:02:14: Free Memory: 6.04GiB
21:02:14: Threads: WINDOWS_THREADS
21:02:14: On Battery: false
21:02:14: UTC offset: 2
21:02:14: PID: 4908
21:02:14: CWD: H:/Foldingathome
21:02:14: OS: Windows (TM) Vista Business
21:02:14: OS Arch: AMD64
21:02:14: GPUs: 1
21:02:14: GPU 0: ATI:4 R575A [AMD Radeon HD7700 Series]
21:02:14: CUDA: Not detected
21:02:14:Win32 Service: false
21:02:14:***********************************************************************
21:02:14:<config>
21:02:14: <!-- Folding Slot Configuration -->
21:02:14: <gpu v='true'/>
21:02:14: <smp v='false'/>
21:02:14:
21:02:14: <!-- User Information -->
21:02:14: <passkey v='********************************'/>
21:02:14: <team v='51'/>
21:02:14: <user v='Einstein-Rosen-Podolsky'/>
21:02:14:
21:02:14: <!-- Folding Slots -->
21:02:14:</config>
21:02:14:[b]Trying to access database...
21:02:15:Successfully acquired database lock
21:02:15:Enabled folding slot 00: READY gpu:0:"R575A [AMD Radeon HD7700 Series] "
21:02:16:WU00:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah
21:02:16:WU00:FS00:Connecting to www.stanford.edu:80
21:02:16:ERROR:WU00:FS00:Exception: Failed to read stream
21:02:16:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
21:03:16:WU00:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah
21:03:16:WU00:FS00:Connecting to www.stanford.edu:80
21:03:16:ERROR:WU00:FS00:Exception: Failed to read stream
21:04:53:WU00:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah
21:04:53:WU00:FS00:Connecting to www.stanford.edu:80
21:04:53:ERROR:WU00:FS00:Exception: [u]Failed to read stream[/u][/b]
P5-133XL
Machine #2:
Machine 3:
Do you have IPv6 running in your network stack? If so, try Prefer IPv4 over IPv6 button. The current clients don't like IPv6 and Microsoft defaults to IPv6 if given a choice. So preferring IPv4 works better currently. Repeatedly failing to DL a core is a likely symptom.
Pont_ERPE=mc²
i have believed disabled IPv6 !!
now it's disable, it's works!
thanks -_-
thanks -_-
