Project 3064
toaster8
Hardware configuration: Model Name: Mac Pro
Model Identifier: MacPro3,1
Processor Name: Quad-Core Intel Xeon
Processor Speed: 2.8 GHz
Number Of Processors: 2
Total Number Of Cores: 8
L2 Cache (per processor): 12 MB
Memory: 4 GB
Bus Speed: 1.6 GHz
Project 3064
Post by toaster8 »
Protein: p3064_lambda5_2003Extra SSE boost OK.
This project comes up as worth 1753 points and yet takes twice as long to run as a project 2605 worth 1760 points. Increase is warning me that it may not complete in time as it takes 44 hours at 38pph. It will definetly not make it for the preferred time. I am running an 8-core macpro and most other wu's complete no problem. I am guessing that there is either a problem with this project, it was given too low of a point score or my machine just does not like this one.
zorzyk
Hardware configuration: abit IP35 PRO,
Q6600/B3 3042 MHz (9*338) / CPU VCore 1.3550V,
DDR2 4x1GB: Corsair Twin2X DDR2 800MHz CL4-4-4-12 DHX @ 845 MHz CL4-4-4-12 / 2.2V
Re: Project 3064
Post by zorzyk »
toaster8 wrote:Protein: p3064_lambda5_2003Extra SSE boost OK.
I don't know MacPro with 8 cores, but on Q6600/XP I get the following results (depending on CPU speed):
Project 3064 - 1 x SMP:
Q6600 @ 2.93 GHz     16h 00min   2629 PPD   164 PPH    9:36 TPF
Q6600 @ 3.18 GHz     14h 47min   2846 PPD   193 PPH    8:52 TPF
I can't compare to 2605 because I didn't fold it.
How are your results comparing to other people who fold on MacPro/8 cores?
Re: Project 3064
zorzyk wrote:I can't compare to 2605 because I didn't fold it.
You can compare with the 2653 ... they fold at the same speed but 2605 is linux only ;)
zorzyk
Re: Project 3064
Post by zorzyk »
toTOW wrote:You can compare with the 2653 ... they fold at the same speed but 2605 is linux only ;)
OK :)
Project 3064 gets almost exactly the same results as 2653, but 2653 folds slightly quicker (1-2 seconds quicker per frame).
Re: Project 3064
Yes 30xx are generally a little bit slower than 26xx used to ;)
toaster8
Memory: 4 GB
Bus Speed: 1.6 GHz
Re: Project 3064
Post by toaster8 »
Slightly slower I could handle but this is less than half the speed. Is this normal?
zorzyk
Re: Project 3064
Post by zorzyk »
In my opinion two times slower is not normal. MacPro 8 cores is built on double Xeon quad core 2.8MHz basis.
Two times slower means that your 3064 is utilizing 2 cores instead of four. How do you run your SMP client?
Re: Project 3064
zorzyk wrote:In my opinion two times slower is not normal. MacPro 8 cores is built on double Xeon quad core 2.8MHz basis.
Nobody is talking about the cache size and how the caches are shared between the various CPU-cores, compared to the same information on the benchmark machine. These can be much more important than the simple number of CPU-cores on your hardware. Tightly coupled CPUs are vastly superior to ones with a much slower data rate between CPUs . . . on specific WUs. On other WUs, it's not so important.
FAH will use whatever resources you provide, and one of the drawbacks of any benchmarking system is that when your hardware is different than the benchmark machine, any of the differences might be important, not just one single number.
I have a double-Xeon machine, and the data rate between the cores that share cache is vastly faster than the data rate between cores that are on different chips. In some cases it acts like a quad, and in other cases it acts much like a pair of independent dual processors.
Outback_Jon
Hardware configuration: Asus A8N-SLI Premium
Opteron 165 @ 2.5GHz (vCore 1.5v)
2 GB GSkill PC4000 @ 228MHz
Windows XP SP2
8800GT
Re: Project 3064
Post by Outback_Jon »
Guess I'm about a month late to this thread, but I just recently got a p3064 on my dual-core Opteron @ 2.5GHz. My PPD is good, but I'm not going to make the preferred deadline. This one is going to take a bit over 2 days, even if I don't use my computer for anything else. And the deadline is 1.8 days.
EDIT: p3065 gives similar results. I'll make the final deadline, but not the preferred.
Currently Folding as: Outback_Jon - Team 32
PhenomIIx4 965 @ 3.8GHz on an MSI NF980-G65 & GTX70
