Project: 7610 (Run 56, Clone 0, Gen 92)
Robby_Firefox
Hardware configuration: Homebuilt Windows 10
Intel Core i7-4770 ~ started in early 2014 or 2015
32 GB RAM (up from 8 GB in 2018)
64-Bit Operating System
On 31 Mar 2020, installed a GigaByte GEFORCE GTX 1660 GPU
Post by Robby_Firefox »
Hello,
Am working with version 7.1.52 on a Windows XP platform. The night before last, I suffered some malfunction running Project: 7610 (Run 56, Clone 0, Gen 92). Anyway, the client downloaded that job Sunday afternoon around 1826 GMT, and it ran successfully until it was about 19 percent completed. Then it apparently bombed out or something went wrong somewhere (not necessarily because of 7610, but cannot rule it out totally either). A result, the entire PC became unstable with AVAST! Internet Security not working (first thought a virus/worm) and other programs not working as they should too. Rebooted the system and it seems OK now with no infection. Since this job was in the 2000 points range or so, would I get any partial credit for some of the work that was completed? From looking at the log, seems that what ever happened, it never transmitted back to you the results of what it did.
The client is also running a GPU process. Unfortunately because I have an “older” GPU processor: ATI:3 RV730 PRO [Radeon HD 4650], is is possible to disable the GPU portion of the FAH client ~ if it will not be used anymore?
Below is an attached log file showing a rather long run, starting about 0952 Z on July 21st, running continuously until 1346Z on August 6th. The 7610 job failed around 0430Z on August 6th. Did not detect the failure/issues until the next morning CDT. Sorry but there is a lot of extraneous material related to the GPU having no job to process; making it hard to tell exactly what happened. Anyway to blank out that material in future posts?
Best Wishes,
Robby - Team Firefox
*********************** Log Started 2012-07-21T09:52:11Z ***********************
09:52:11:************************* Folding@home Client *************************
09:52:11:      Website: http://folding.stanford.edu/
09:52:11:    Copyright: (c) 2009-2012 Stanford University
09:52:11:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:52:11:         Args: --lifeline 1364 --command-port=36330
09:52:11:       Config: C:/Documents and Settings/All Users/Application
09:52:11:               Data/FAHClient/config.xml
09:52:11:******************************** Build ********************************
09:52:11:      Version: 7.1.52
09:52:11:         Date: Mar 20 2012
09:52:11:         Time: 19:37:42
09:52:11:      SVN Rev: 3515
09:52:11:       Branch: fah/trunk/client
09:52:11:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
09:52:11:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
09:52:11:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
09:52:11:     Platform: win32 XP
09:52:11:         Bits: 32
09:52:11:         Mode: Release
09:52:11:******************************* System ********************************
09:52:11:          CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 4200+
09:52:11:       CPU ID: AuthenticAMD Family 15 Model 75 Stepping 2
09:52:11:         CPUs: 2
09:52:11:       Memory: 3.00GiB
09:52:11:  Free Memory: 1.90GiB
09:52:11:      Threads: WINDOWS_THREADS
09:52:11:   On Battery: false
09:52:11:   UTC offset: -5
09:52:11:          PID: 476
09:52:11:          CWD: C:/Documents and Settings/All Users/Application Data/FAHClient
09:52:11:           OS: Microsoft Windows XP Service Pack 3
09:52:11:      OS Arch: X86
09:52:11:         GPUs: 1
09:52:11:        GPU 0: ATI:3 RV730 PRO [Radeon HD 4650]
09:52:11:         CUDA: Not detected
09:52:11:Win32 Service: false
09:52:11:***********************************************************************
09:52:12:<config>
09:52:12:  <!-- Folding Slot Configuration -->
09:52:12:  <client-type v='advanced'/>
09:52:12:  <gpu v='true'/>
09:52:12:
09:52:12:  <!-- Network -->
09:52:12:  <proxy v=':8080'/>
09:52:12:
09:52:12:  <!-- User Information -->
09:52:12:  <passkey v='********************************'/>
09:52:12:  <team v='39299'/>
09:52:12:  <user v='Robby'/>
09:52:12:
09:52:12:  <!-- Folding Slots -->
09:52:12:  <slot id='0' type='GPU'/>
09:52:12:  <slot id='1' type='SMP'/>
09:52:12:</config>
09:52:12:Trying to access database...
09:52:12:Successfully acquired database lock
09:52:12:Enabled folding slot 00: READY gpu:0:"RV730 PRO [Radeon HD 4650]"
09:52:12:Enabled folding slot 01: READY smp:2
09:52:12:WU01:FS01:Starting
09:52:12:WU01:FS01:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/All Users/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 01 -suffix 01 -version 701 -lifeline 476 -checkpoint 15 -np 2
09:52:14:WU01:FS01:Started FahCore on PID 4400
09:52:14:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
09:52:17:WU01:FS01:Core PID:4644
09:52:17:WU01:FS01:FahCore 0xa4 started
09:52:18:WU01:FS01:0xa4:
09:52:18:WU01:FS01:0xa4:*------------------------------*
09:52:18:WU01:FS01:0xa4:Folding@Home Gromacs GB Core
09:52:18:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
09:52:18:WU01:FS01:0xa4:Preparing to commence simulation
09:52:18:WU01:FS01:0xa4:- Looking at optimizations...
09:52:18:WU01:FS01:0xa4:- Files status OK
09:52:18:WU01:FS01:0xa4:- Expanded 546908 -> 1326096 (decompressed 242.4 percent)
09:52:18:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=546908 data_size=1326096, decompressed_data_size=1326096 diff=0
09:52:18:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
09:52:18:WU01:FS01:0xa4:- Digital signature verified
09:52:18:WU01:FS01:0xa4:Project: 8014 (Run 2, Clone 266, Gen 54)
09:52:18:WU01:FS01:0xa4:Assembly optimizations on if available.
09:52:18:WU01:FS01:0xa4:Entering M.D.
09:52:19:WU00:FS00:News: Welcome to Folding@Home
09:52:19:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
09:52:19:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
09:52:19:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
09:52:19:ERROR:WU00:FS00:Exception: Could not get an assignment
09:52:25:WU01:FS01:0xa4:Using Gromacs checkpoints
09:52:26:WU01:FS01:0xa4:Mapping NT from 2 to 2
09:52:31:WU01:FS01:0xa4:Resuming from checkpoint
09:52:31:WU01:FS01:0xa4:Verified 01/wudata_01.log
09:52:31:WU01:FS01:0xa4:Verified 01/wudata_01.trr
09:52:32:WU01:FS01:0xa4:Verified 01/wudata_01.xtc
09:52:32:WU01:FS01:0xa4:Verified 01/wudata_01.edr
09:52:32:WU01:FS01:0xa4:Completed 84940 out of 250000 steps  (33%)
09:52:46:WU01:FS01:0xa4:Completed 85000 out of 250000 steps  (34%)
09:53:19:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
09:53:19:WU00:FS00:News: Welcome to Folding@Home
09:53:19:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
09:53:19:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
09:53:19:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
09:53:19:ERROR:WU00:FS00:Exception: Could not get an assignment
09:54:56:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
09:54:56:WU00:FS00:News: Welcome to Folding@Home
09:54:56:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
09:54:56:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
09:54:57:WU00:FS00:News: Welcome to Folding@Home
09:54:57:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
09:54:57:ERROR:WU00:FS00:Exception: Could not get an assignment
09:57:33:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
09:57:34:WU00:FS00:News: Welcome to Folding@Home
09:57:34:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
09:57:34:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
09:57:34:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
09:57:34:ERROR:WU00:FS00:Exception: Could not get an assignment
09:59:21:WU01:FS01:0xa4:Completed 87500 out of 250000 steps  (35%)
10:01:48:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
10:01:48:WU00:FS00:News: Welcome to Folding@Home
10:01:48:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
10:01:48:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
10:01:48:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
10:01:48:ERROR:WU00:FS00:Exception: Could not get an assignment
10:04:31:WU01:FS01:0xa4:Completed 90000 out of 250000 steps  (36%)
10:08:39:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
10:08:39:WU00:FS00:News: Welcome to Folding@Home
10:08:39:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
10:08:39:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
10:08:39:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
10:08:39:ERROR:WU00:FS00:Exception: Could not get an assignment
10:09:30:WU01:FS01:0xa4:Completed 92500 out of 250000 steps  (37%)
10:14:27:WU01:FS01:0xa4:Completed 95000 out of 250000 steps  (38%)
10:19:21:WU01:FS01:0xa4:Completed 97500 out of 250000 steps  (39%)
10:19:45:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
10:19:45:WU00:FS00:News: Welcome to Folding@Home
10:19:45:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
10:19:45:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
10:19:45:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
10:19:45:ERROR:WU00:FS00:Exception: Could not get an assignment
10:24:15:WU01:FS01:0xa4:Completed 100000 out of 250000 steps  (40%)
10:29:09:WU01:FS01:0xa4:Completed 102500 out of 250000 steps  (41%)
10:34:02:WU01:FS01:0xa4:Completed 105000 out of 250000 steps  (42%)
10:37:41:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
10:37:42:WU00:FS00:News: Welcome to Folding@Home
10:37:42:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
10:37:42:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
10:37:42:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
10:37:42:ERROR:WU00:FS00:Exception: Could not get an assignment
10:38:56:WU01:FS01:0xa4:Completed 107500 out of 250000 steps  (43%)
10:43:49:WU01:FS01:0xa4:Completed 110000 out of 250000 steps  (44%)
10:48:44:WU01:FS01:0xa4:Completed 112500 out of 250000 steps  (45%)
10:53:47:WU01:FS01:0xa4:Completed 115000 out of 250000 steps  (46%)
10:58:41:WU01:FS01:0xa4:Completed 117500 out of 250000 steps  (47%)
11:03:36:WU01:FS01:0xa4:Completed 120000 out of 250000 steps  (48%)
11:06:43:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
11:06:44:WU00:FS00:News: Welcome to Folding@Home
11:06:44:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
11:06:44:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
11:06:44:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
11:06:44:ERROR:WU00:FS00:Exception: Could not get an assignment
11:08:31:WU01:FS01:0xa4:Completed 122500 out of 250000 steps  (49%)
11:13:26:WU01:FS01:0xa4:Completed 125000 out of 250000 steps  (50%)
11:18:35:WU01:FS01:0xa4:Completed 127500 out of 250000 steps  (51%)
11:23:29:WU01:FS01:0xa4:Completed 130000 out of 250000 steps  (52%)
11:28:22:WU01:FS01:0xa4:Completed 132500 out of 250000 steps  (53%)
11:33:16:WU01:FS01:0xa4:Completed 135000 out of 250000 steps  (54%)
11:38:17:WU01:FS01:0xa4:Completed 137500 out of 250000 steps  (55%)
11:43:08:WU01:FS01:0xa4:Completed 140000 out of 250000 steps  (56%)
11:48:00:WU01:FS01:0xa4:Completed 142500 out of 250000 steps  (57%)
11:53:09:WU01:FS01:0xa4:Completed 145000 out of 250000 steps  (58%)
11:53:42:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
11:53:43:WU00:FS00:News: Welcome to Folding@Home
11:53:43:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
11:53:43:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
11:53:43:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
11:53:43:ERROR:WU00:FS00:Exception: Could not get an assignment
11:58:01:WU01:FS01:0xa4:Completed 147500 out of 250000 steps  (59%)
12:02:54:WU01:FS01:0xa4:Completed 150000 out of 250000 steps  (60%)
12:07:44:WU01:FS01:0xa4:Completed 152500 out of 250000 steps  (61%)
12:12:35:WU01:FS01:0xa4:Completed 155000 out of 250000 steps  (62%)
12:17:37:WU01:FS01:0xa4:Completed 157500 out of 250000 steps  (63%)
12:22:28:WU01:FS01:0xa4:Completed 160000 out of 250000 steps  (64%)
12:27:20:WU01:FS01:0xa4:Completed 162500 out of 250000 steps  (65%)
12:32:11:WU01:FS01:0xa4:Completed 165000 out of 250000 steps  (66%)
12:37:05:WU01:FS01:0xa4:Completed 167500 out of 250000 steps  (67%)
12:41:59:WU01:FS01:0xa4:Completed 170000 out of 250000 steps  (68%)
12:46:51:WU01:FS01:0xa4:Completed 172500 out of 250000 steps  (69%)
12:51:51:WU01:FS01:0xa4:Completed 175000 out of 250000 steps  (70%)
12:56:44:WU01:FS01:0xa4:Completed 177500 out of 250000 steps  (71%)
13:01:36:WU01:FS01:0xa4:Completed 180000 out of 250000 steps  (72%)
13:06:26:WU01:FS01:0xa4:Completed 182500 out of 250000 steps  (73%)
13:09:43:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
13:09:44:WU00:FS00:News: Welcome to Folding@Home
13:09:44:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
13:09:44:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
13:09:44:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
13:09:44:ERROR:WU00:FS00:Exception: Could not get an assignment
13:11:16:WU01:FS01:0xa4:Completed 185000 out of 250000 steps  (74%)
13:16:07:WU01:FS01:0xa4:Completed 187500 out of 250000 steps  (75%)
13:21:11:WU01:FS01:0xa4:Completed 190000 out of 250000 steps  (76%)
13:26:02:WU01:FS01:0xa4:Completed 192500 out of 250000 steps  (77%)
13:30:53:WU01:FS01:0xa4:Completed 195000 out of 250000 steps  (78%)
13:35:44:WU01:FS01:0xa4:Completed 197500 out of 250000 steps  (79%)
13:40:35:WU01:FS01:0xa4:Completed 200000 out of 250000 steps  (80%)
13:45:26:WU01:FS01:0xa4:Completed 202500 out of 250000 steps  (81%)
13:50:17:WU01:FS01:0xa4:Completed 205000 out of 250000 steps  (82%)
13:55:17:WU01:FS01:0xa4:Completed 207500 out of 250000 steps  (83%)
14:00:08:WU01:FS01:0xa4:Completed 210000 out of 250000 steps  (84%)
14:04:59:WU01:FS01:0xa4:Completed 212500 out of 250000 steps  (85%)
14:09:51:WU01:FS01:0xa4:Completed 215000 out of 250000 steps  (86%)
14:14:43:WU01:FS01:0xa4:Completed 217500 out of 250000 steps  (87%)
14:19:34:WU01:FS01:0xa4:Completed 220000 out of 250000 steps  (88%)
14:24:24:WU01:FS01:0xa4:Completed 222500 out of 250000 steps  (89%)
14:29:14:WU01:FS01:0xa4:Completed 225000 out of 250000 steps  (90%)
14:34:05:WU01:FS01:0xa4:Completed 227500 out of 250000 steps  (91%)
14:38:56:WU01:FS01:0xa4:Completed 230000 out of 250000 steps  (92%)
14:43:49:WU01:FS01:0xa4:Completed 232500 out of 250000 steps  (93%)
14:48:41:WU01:FS01:0xa4:Completed 235000 out of 250000 steps  (94%)
14:53:41:WU01:FS01:0xa4:Completed 237500 out of 250000 steps  (95%)
14:58:50:WU01:FS01:0xa4:Completed 240000 out of 250000 steps  (96%)
15:03:42:WU01:FS01:0xa4:Completed 242500 out of 250000 steps  (97%)
15:08:33:WU01:FS01:0xa4:Completed 245000 out of 250000 steps  (98%)
15:12:43:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
15:12:43:WU00:FS00:News: Welcome to Folding@Home
15:12:43:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
15:12:43:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
15:12:44:WU00:FS00:News: Welcome to Folding@Home
15:12:44:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
15:12:44:ERROR:WU00:FS00:Exception: Could not get an assignment
15:13:25:WU01:FS01:0xa4:Completed 247500 out of 250000 steps  (99%)
15:18:16:WU01:FS01:0xa4:Completed 250000 out of 250000 steps  (100%)
15:18:17:WU01:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
15:18:17:WU02:FS01:Connecting to assign3.stanford.edu:8080
15:18:17:WU02:FS01:News: Welcome to Folding@Home
15:18:17:WU02:FS01:Assigned to work server 171.67.108.58
15:18:17:WU02:FS01:Requesting new work unit for slot 01: RUNNING smp:2 from 171.67.108.58
15:18:17:WU02:FS01:Connecting to 171.67.108.58:8080
15:18:18:WU02:FS01:Downloading 534.51KiB
15:18:19:WU02:FS01:Download complete
15:18:19:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:OK project:8014 run:3 clone:423 gen:24 core:0xa4 unit:0x000000256652edca4f9b05bc17cb3bbc
15:18:27:WU01:FS01:0xa4:
15:18:27:WU01:FS01:0xa4:Finished Work Unit:
15:18:27:WU01:FS01:0xa4:- Reading up to 769164 from "01/wudata_01.trr": Read 769164
15:18:27:WU01:FS01:0xa4:trr file hash check passed.
15:18:27:WU01:FS01:0xa4:- Reading up to 456364 from "01/wudata_01.xtc": Read 456364
15:18:27:WU01:FS01:0xa4:xtc file hash check passed.
15:18:27:WU01:FS01:0xa4:edr file hash check passed.
15:18:27:WU01:FS01:0xa4:logfile size: 24815
15:18:27:WU01:FS01:0xa4:Leaving Run
15:18:27:WU01:FS01:0xa4:- Writing 1255747 bytes of core data to disk...
15:18:27:WU01:FS01:0xa4:Done: 1255235 -> 1193531 (compressed to 95.0 percent)
15:18:27:WU01:FS01:0xa4:  ... Done.
15:18:28:WU01:FS01:0xa4:- Shutting down core
15:18:28:WU01:FS01:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
15:18:28:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
15:18:28:WU01:FS01:Sending unit results: id:01 state:SEND error:OK project:8014 run:2 clone:266 gen:54 core:0xa4 unit:0x000000546652edca4f9b04de05ba5e26
15:18:28:WU01:FS01:Uploading 1.14MiB to 171.67.108.58
15:18:28:WU01:FS01:Connecting to 171.67.108.58:8080
15:18:28:WU02:FS01:Starting
15:18:28:WU02:FS01:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/All Users/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 02 -suffix 01 -version 701 -lifeline 476 -checkpoint 15 -np 2
15:18:28:WU02:FS01:Started FahCore on PID 3856
15:18:29:WU02:FS01:Core PID:2932
15:18:29:WU02:FS01:FahCore 0xa4 started
15:18:29:WU02:FS01:0xa4:
15:18:29:WU02:FS01:0xa4:*------------------------------*
15:18:29:WU02:FS01:0xa4:Folding@Home Gromacs GB Core
15:18:29:WU02:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
15:18:29:WU02:FS01:0xa4:Preparing to commence simulation
15:18:29:WU02:FS01:0xa4:- Looking at optimizations...
15:18:29:WU02:FS01:0xa4:- Created dyn
15:18:29:WU02:FS01:0xa4:- Files status OK
15:18:29:WU02:FS01:0xa4:- Expanded 546824 -> 1326096 (decompressed 242.5 percent)
15:18:29:WU02:FS01:0xa4:Called DecompressByteArray: compressed_data_size=546824 data_size=1326096, decompressed_data_size=1326096 diff=0
15:18:29:WU02:FS01:0xa4:- Digital signature verified
15:18:29:WU02:FS01:0xa4:Project: 8014 (Run 3, Clone 423, Gen 24)
15:18:29:WU02:FS01:0xa4:Assembly optimizations on if available.
15:18:29:WU02:FS01:0xa4:Entering M.D.
15:18:32:WU01:FS01:Upload complete
15:18:32:WU01:FS01:Server responded WORK_ACK (400)
15:18:32:WU01:FS01:Final credit estimate, 331.00 points
15:18:32:WU01:FS01:Cleaning up
15:18:35:WU02:FS01:0xa4:Mapping NT from 2 to 2
15:18:35:WU02:FS01:0xa4:Completed 0 out of 250000 steps  (0%)
15:23:13:WU02:FS01:0xa4:Completed 2500 out of 250000 steps  (1%)
15:27:51:WU02:FS01:0xa4:Completed 5000 out of 250000 steps  (2%)
15:32:28:WU02:FS01:0xa4:Completed 7500 out of 250000 steps  (3%)
15:37:06:WU02:FS01:0xa4:Completed 10000 out of 250000 steps  (4%)
15:41:44:WU02:FS01:0xa4:Completed 12500 out of 250000 steps  (5%)
15:46:22:WU02:FS01:0xa4:Completed 15000 out of 250000 steps  (6%)
15:51:00:WU02:FS01:0xa4:Completed 17500 out of 250000 steps  (7%)
******************************** Date: 21/07/12 ********************************
!!! DELETED !!!
******************************** Date: 05/08/12 ********************************
05:53:51:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
05:53:55:WU00:FS00:News: Welcome to Folding@Home
05:53:55:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
05:53:55:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
05:53:55:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
05:53:55:ERROR:WU00:FS00:Exception: Could not get an assignment
06:25:35:WU02:FS01:0xa4:Completed 1520000 out of 2000000 steps  (76%)
06:55:27:WU02:FS01:0xa4:Completed 1540000 out of 2000000 steps  (77%)
07:25:36:WU02:FS01:0xa4:Completed 1560000 out of 2000000 steps  (78%)
07:55:25:WU02:FS01:0xa4:Completed 1580000 out of 2000000 steps  (79%)
08:25:04:WU02:FS01:0xa4:Completed 1600000 out of 2000000 steps  (80%)
08:55:09:WU02:FS01:0xa4:Completed 1620000 out of 2000000 steps  (81%)
09:25:15:WU02:FS01:0xa4:Completed 1640000 out of 2000000 steps  (82%)
09:55:07:WU02:FS01:0xa4:Completed 1660000 out of 2000000 steps  (83%)
10:24:52:WU02:FS01:0xa4:Completed 1680000 out of 2000000 steps  (84%)
10:54:46:WU02:FS01:0xa4:Completed 1700000 out of 2000000 steps  (85%)
11:24:44:WU02:FS01:0xa4:Completed 1720000 out of 2000000 steps  (86%)
11:53:51:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
11:53:53:WU00:FS00:News: Welcome to Folding@Home
11:53:53:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
11:53:53:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
11:53:53:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
11:53:53:ERROR:WU00:FS00:Exception: Could not get an assignment
11:54:36:WU02:FS01:0xa4:Completed 1740000 out of 2000000 steps  (87%)
12:24:21:WU02:FS01:0xa4:Completed 1760000 out of 2000000 steps  (88%)
12:54:14:WU02:FS01:0xa4:Completed 1780000 out of 2000000 steps  (89%)
13:24:23:WU02:FS01:0xa4:Completed 1800000 out of 2000000 steps  (90%)
13:54:28:WU02:FS01:0xa4:Completed 1820000 out of 2000000 steps  (91%)
14:24:37:WU02:FS01:0xa4:Completed 1840000 out of 2000000 steps  (92%)
14:55:33:WU02:FS01:0xa4:Completed 1860000 out of 2000000 steps  (93%)
15:26:28:WU02:FS01:0xa4:Completed 1880000 out of 2000000 steps  (94%)
15:56:15:WU02:FS01:0xa4:Completed 1900000 out of 2000000 steps  (95%)
16:26:20:WU02:FS01:0xa4:Completed 1920000 out of 2000000 steps  (96%)
16:56:43:WU02:FS01:0xa4:Completed 1940000 out of 2000000 steps  (97%)
17:26:34:WU02:FS01:0xa4:Completed 1960000 out of 2000000 steps  (98%)
17:53:52:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
17:53:53:WU00:FS00:News: Welcome to Folding@Home
17:53:53:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
17:53:53:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
17:53:53:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
17:53:53:ERROR:WU00:FS00:Exception: Could not get an assignment
17:56:29:WU02:FS01:0xa4:Completed 1980000 out of 2000000 steps  (99%)
17:56:30:WU01:FS01:Connecting to assign3.stanford.edu:8080
17:56:30:WU01:FS01:News: Welcome to Folding@Home
17:56:30:WU01:FS01:Assigned to work server 171.64.65.104
17:56:30:WU01:FS01:Requesting new work unit for slot 01: RUNNING smp:2 from 171.64.65.104
17:56:30:WU01:FS01:Connecting to 171.64.65.104:8080
17:56:31:WU01:FS01:Downloading 330.97KiB
17:56:32:WU01:FS01:Download complete
17:56:32:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:OK project:7610 run:56 clone:0 gen:92 core:0xa4 unit:0x00000076664f2dd04de6d2bbe93d2aab
18:26:24:WU02:FS01:0xa4:Completed 2000000 out of 2000000 steps  (100%)
18:26:24:WU02:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
18:26:34:WU02:FS01:0xa4:
18:26:34:WU02:FS01:0xa4:Finished Work Unit:
18:26:34:WU02:FS01:0xa4:- Reading up to 488544 from "02/wudata_01.trr": Read 488544
18:26:34:WU02:FS01:0xa4:trr file hash check passed.
18:26:34:WU02:FS01:0xa4:- Reading up to 58700 from "02/wudata_01.xtc": Read 58700
18:26:34:WU02:FS01:0xa4:xtc file hash check passed.
18:26:34:WU02:FS01:0xa4:edr file hash check passed.
18:26:34:WU02:FS01:0xa4:logfile size: 49627
18:26:34:WU02:FS01:0xa4:Leaving Run
18:26:35:WU02:FS01:0xa4:- Writing 620787 bytes of core data to disk...
18:26:36:WU02:FS01:0xa4:Done: 620275 -> 547362 (compressed to 88.2 percent)
18:26:36:WU02:FS01:0xa4:  ... Done.
18:26:36:WU02:FS01:0xa4:- Shutting down core
18:26:36:WU02:FS01:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
18:26:36:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:26:36:WU02:FS01:Sending unit results: id:02 state:SEND error:OK project:7610 run:622 clone:2 gen:3 core:0xa4 unit:0x00000007664f2dd04de6d4f17926c803
18:26:36:WU02:FS01:Uploading 535.03KiB to 171.64.65.104
18:26:36:WU01:FS01:Starting
18:26:36:WU02:FS01:Connecting to 171.64.65.104:8080
18:26:36:WU01:FS01:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/All Users/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 01 -suffix 01 -version 701 -lifeline 476 -checkpoint 15 -np 2
18:26:37:WU01:FS01:Started FahCore on PID 6644
18:26:37:WU01:FS01:Core PID:2776
18:26:37:WU01:FS01:FahCore 0xa4 started
18:26:38:WU01:FS01:0xa4:
18:26:38:WU01:FS01:0xa4:*------------------------------*
18:26:38:WU01:FS01:0xa4:Folding@Home Gromacs GB Core
18:26:38:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
18:26:38:WU01:FS01:0xa4:Preparing to commence simulation
18:26:38:WU01:FS01:0xa4:- Looking at optimizations...
18:26:38:WU01:FS01:0xa4:- Created dyn
18:26:38:WU01:FS01:0xa4:- Files status OK
18:26:38:WU01:FS01:0xa4:- Expanded 338406 -> 644556 (decompressed 190.4 percent)
18:26:38:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=338406 data_size=644556, decompressed_data_size=644556 diff=0
18:26:38:WU01:FS01:0xa4:- Digital signature verified
18:26:38:WU01:FS01:0xa4:Project: 7610 (Run 56, Clone 0, Gen 92)
18:26:38:WU01:FS01:0xa4:Assembly optimizations on if available.
18:26:38:WU01:FS01:0xa4:Entering M.D.
18:26:38:WU02:FS01:Upload complete
18:26:38:WU02:FS01:Server responded WORK_ACK (400)
18:26:38:WU02:FS01:Final credit estimate, 1991.00 points
18:26:38:WU02:FS01:Cleaning up
18:26:43:WU01:FS01:0xa4:Mapping NT from 2 to 2
18:26:44:WU01:FS01:0xa4:Completed 0 out of 2000000 steps  (0%)
19:01:21:WU01:FS01:0xa4:Completed 20000 out of 2000000 steps  (1%)
19:34:32:WU01:FS01:0xa4:Completed 40000 out of 2000000 steps  (2%)
20:04:10:WU01:FS01:0xa4:Completed 60000 out of 2000000 steps  (3%)
20:33:45:WU01:FS01:0xa4:Completed 80000 out of 2000000 steps  (4%)
21:05:55:WU01:FS01:0xa4:Completed 100000 out of 2000000 steps  (5%)
21:35:21:WU01:FS01:0xa4:Completed 120000 out of 2000000 steps  (6%)
22:04:59:WU01:FS01:0xa4:Completed 140000 out of 2000000 steps  (7%)
22:34:28:WU01:FS01:0xa4:Completed 160000 out of 2000000 steps  (8%)
23:04:36:WU01:FS01:0xa4:Completed 180000 out of 2000000 steps  (9%)
23:39:27:WU01:FS01:0xa4:Completed 200000 out of 2000000 steps  (10%)
23:53:52:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
23:53:53:WU00:FS00:News: Welcome to Folding@Home
23:53:53:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
23:53:53:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
23:53:53:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
23:53:53:ERROR:WU00:FS00:Exception: Could not get an assignment
00:09:15:WU01:FS01:0xa4:Completed 220000 out of 2000000 steps  (11%)
00:38:31:WU01:FS01:0xa4:Completed 240000 out of 2000000 steps  (12%)
01:07:37:WU01:FS01:0xa4:Completed 260000 out of 2000000 steps  (13%)
01:43:14:WU01:FS01:0xa4:Completed 280000 out of 2000000 steps  (14%)
02:16:25:WU01:FS01:0xa4:Completed 300000 out of 2000000 steps  (15%)
02:48:48:WU01:FS01:0xa4:Completed 320000 out of 2000000 steps  (16%)
03:20:46:WU01:FS01:0xa4:Completed 340000 out of 2000000 steps  (17%)
03:53:23:WU01:FS01:0xa4:Completed 360000 out of 2000000 steps  (18%)
04:26:56:WU01:FS01:0xa4:Completed 380000 out of 2000000 steps  (19%)
04:33:03:Server connection id=5 on 0.0.0.0:36330 from 127.0.0.1
04:33:03:Server connection id=4 ended
04:33:13:Server connection id=5 ended
04:33:14:Server connection id=6 on 0.0.0.0:36330 from 127.0.0.1
04:33:14:WU01:FS01:FahCore returned: UNKNOWN_ENUM (-1073741819 = 0xc0000005)
04:33:14:WARNING:WU01:FS01:FahCore returned an unknown error code which probably indicates that it crashed
04:33:14:WU01:FS01:Starting
04:33:14:WU01:FS01:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/All Users/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 01 -suffix 01 -version 701 -lifeline 476 -checkpoint 15 -np 2
04:33:18:WU01:FS01:Started FahCore on PID 4304
04:33:25:Server connection id=7 on 0.0.0.0:36330 from 127.0.0.1
04:33:34:WU01:FS01:Core PID:7472
04:33:34:WU01:FS01:FahCore 0xa4 started
04:33:34:Server connection id=6 ended
04:33:35:WU01:FS01:0xa4:
04:33:35:WU01:FS01:0xa4:*------------------------------*
04:33:35:WU01:FS01:0xa4:Folding@Home Gromacs GB Core
04:33:35:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
04:33:35:WU01:FS01:0xa4:Preparing to commence simulation
04:33:35:WU01:FS01:0xa4:- Ensuring status. Please wait.
04:33:45:WU01:FS01:0xa4:- Looking at optimizations...
04:33:45:WU01:FS01:0xa4:- Working with standard loops on this execution.
04:33:45:WU01:FS01:0xa4:- Previous termination of core was improper.
04:33:45:WU01:FS01:0xa4:- Files status OK
04:33:45:WU01:FS01:0xa4:- Expanded 338406 -> 644556 (decompressed 190.4 percent)
04:33:45:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=338406 data_size=644556, decompressed_data_size=644556 diff=0
04:33:45:WU01:FS01:0xa4:- Digital signature verified
04:33:45:WU01:FS01:0xa4:Project: 7610 (Run 56, Clone 0, Gen 92)
04:33:45:WU01:FS01:0xa4:Entering M.D.
04:33:51:WU01:FS01:0xa4:Using Gromacs checkpoints
04:33:51:WU01:FS01:0xa4:Mapping NT from 2 to 2
04:33:52:WU01:FS01:0xa4:mdrun returned 12
04:33:52:WU01:FS01:0xa4:Going to send back what have done -- stepsTotalG=2000000
04:33:52:WU01:FS01:0xa4:Work fraction=0.0000 steps=2000000.
04:33:52:WU01:FS01:FahCore returned: UNKNOWN_ENUM (-1073741571 = 0xc00000fd)
04:33:52:WARNING:WU01:FS01:FahCore returned an unknown error code which probably indicates that it crashed
04:34:03:Server connection id=8 on 0.0.0.0:36330 from 127.0.0.1
04:34:03:Server connection id=7 ended
04:34:12:Server connection id=8 ended
04:34:14:WU01:FS01:Starting
04:34:14:WU01:FS01:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/All Users/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 01 -suffix 01 -version 701 -lifeline 476 -checkpoint 15 -np 2
04:34:14:ERROR:WU01:FS01:Failed to start core: Failed to create process with: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/All Users/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 01 -suffix 01 -version 701 -lifeline 476 -checkpoint 15 -np 2: Insufficient system resources exist to complete the requested service.
04:35:51:WU01:FS01:Starting
04:35:51:WU01:FS01:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/All Users/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 01 -suffix 01 -version 701 -lifeline 476 -checkpoint 15 -np 2
04:35:51:ERROR:WU01:FS01:Failed to start core: Failed to create process with: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/All Users/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 01 -suffix 01 -version 701 -lifeline 476 -checkpoint 15 -np 2: The paging file is too small for this operation to complete.
04:38:28:WU01:FS01:Starting
04:38:28:WU01:FS01:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/All Users/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 01 -suffix 01 -version 701 -lifeline 476 -checkpoint 15 -np 2
04:38:28:ERROR:WU01:FS01:Failed to start core: Failed to create process with: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/All Users/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 01 -suffix 01 -version 701 -lifeline 476 -checkpoint 15 -np 2: Insufficient system resources exist to complete the requested service.
04:40:36:Server connection id=9 on 0.0.0.0:36330 from 127.0.0.1
04:42:42:WU01:FS01:Starting
04:42:42:WU01:FS01:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/All Users/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 01 -suffix 01 -version 701 -lifeline 476 -checkpoint 15 -np 2
04:42:43:WU01:FS01:Started FahCore on PID 5800
04:42:43:WU01:FS01:Core PID:6368
04:42:43:WU01:FS01:FahCore 0xa4 started
04:42:44:WU01:FS01:0xa4:
04:42:44:WU01:FS01:0xa4:*------------------------------*
04:42:44:WU01:FS01:0xa4:Folding@Home Gromacs GB Core
04:42:44:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
04:42:44:WU01:FS01:0xa4:Preparing to commence simulation
04:42:44:WU01:FS01:0xa4:- Ensuring status. Please wait.
04:42:53:WU01:FS01:0xa4:- Looking at optimizations...
04:42:53:WU01:FS01:0xa4:- Working with standard loops on this execution.
04:42:53:WU01:FS01:0xa4:- Previous termination of core was improper.
04:42:53:WU01:FS01:0xa4:- Going to use standard loops.
04:42:53:WU01:FS01:0xa4:- Files status OK
04:42:53:WU01:FS01:0xa4:- Expanded 338406 -> 644556 (decompressed 190.4 percent)
04:42:53:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=338406 data_size=644556, decompressed_data_size=644556 diff=0
04:42:53:WU01:FS01:0xa4:- Digital signature verified
04:42:53:WU01:FS01:0xa4:Project: 7610 (Run 56, Clone 0, Gen 92)
04:42:53:WU01:FS01:0xa4:Entering M.D.
04:42:59:WU01:FS01:0xa4:Using Gromacs checkpoints
04:42:59:WU01:FS01:0xa4:Mapping NT from 2 to 2
04:43:00:WU01:FS01:0xa4:Resuming from checkpoint
04:43:00:WU01:FS01:0xa4:Verified 01/wudata_01.log
04:43:00:WU01:FS01:0xa4:Verified 01/wudata_01.trr
04:43:00:WU01:FS01:0xa4:Verified 01/wudata_01.xtc
04:43:00:WU01:FS01:0xa4:Verified 01/wudata_01.edr
04:43:00:WU01:FS01:0xa4:Completed 379880 out of 2000000 steps  (18%)
04:43:12:WU01:FS01:0xa4:Completed 380000 out of 2000000 steps  (19%)
04:48:46:Server connection id=10 on 0.0.0.0:36330 from 127.0.0.1
04:48:46:Server connection id=9 ended
04:48:55:Server connection id=10 ended
04:49:21:WU01:FS01:FahCore returned: UNKNOWN_ENUM (-1073741819 = 0xc0000005)
04:49:21:WARNING:WU01:FS01:FahCore returned an unknown error code which probably indicates that it crashed
04:49:21:Server connection id=11 on 0.0.0.0:36330 from 127.0.0.1
04:49:34:WU01:FS01:Starting
04:49:34:WU01:FS01:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/All Users/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 01 -suffix 01 -version 701 -lifeline 476 -checkpoint 15 -np 2
04:49:34:WU01:FS01:Started FahCore on PID 6296
04:49:35:WU01:FS01:Core PID:7400
04:49:35:WU01:FS01:FahCore 0xa4 started
04:49:36:WU01:FS01:0xa4:
04:49:36:WU01:FS01:0xa4:*------------------------------*
04:49:36:WU01:FS01:0xa4:Folding@Home Gromacs GB Core
04:49:36:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
04:49:36:WU01:FS01:0xa4:Preparing to commence simulation
04:49:36:WU01:FS01:0xa4:- Ensuring status. Please wait.
04:49:45:WU01:FS01:0xa4:- Looking at optimizations...
04:49:45:WU01:FS01:0xa4:- Working with standard loops on this execution.
04:49:45:WU01:FS01:0xa4:- Previous termination of core was improper.
04:49:45:WU01:FS01:0xa4:- Going to use standard loops.
04:49:45:WU01:FS01:0xa4:- Files status OK
04:49:45:WU01:FS01:0xa4:- Expanded 338406 -> 644556 (decompressed 190.4 percent)
04:49:45:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=338406 data_size=644556, decompressed_data_size=644556 diff=0
04:49:45:WU01:FS01:0xa4:- Digital signature verified
04:49:45:WU01:FS01:0xa4:Project: 7610 (Run 56, Clone 0, Gen 92)
04:49:45:WU01:FS01:0xa4:Entering M.D.
04:49:51:WU01:FS01:0xa4:Using Gromacs checkpoints
04:49:51:WU01:FS01:0xa4:Mapping NT from 2 to 2
04:49:52:WU01:FS01:FahCore returned: UNKNOWN_ENUM (-1073741783 = 0xc0000029)
04:49:52:WARNING:WU01:FS01:FahCore returned an unknown error code which probably indicates that it crashed
04:49:52:Server connection id=12 on 0.0.0.0:36330 from 127.0.0.1
04:49:52:Server connection id=11 ended
04:50:02:Server connection id=12 ended
04:53:46:Server connection id=13 on 0.0.0.0:36330 from 127.0.0.1
04:57:16:Server connection id=14 on 0.0.0.0:36330 from 127.0.0.1
04:57:16:Server connection id=13 ended
04:57:25:Server connection id=14 ended
04:57:26:Server connection id=15 on 0.0.0.0:36330 from 127.0.0.1
04:59:42:Server connection id=16 on 0.0.0.0:36330 from 127.0.0.1
04:59:42:Server connection id=15 ended
04:59:51:Server connection id=16 ended
05:00:39:WU01:FS01:Starting
05:00:40:WU01:FS01:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/All Users/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 01 -suffix 01 -version 701 -lifeline 476 -checkpoint 15 -np 2
05:00:40:ERROR:WU01:FS01:Failed to start core: Failed to create process with: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/All Users/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 01 -suffix 01 -version 701 -lifeline 476 -checkpoint 15 -np 2: Insufficient system resources exist to complete the requested service.
05:00:40:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:7610 run:56 clone:0 gen:92 core:0xa4 unit:0x00000076664f2dd04de6d2bbe93d2aab
05:00:40:WU01:FS01:Connecting to 171.64.65.104:8080
05:00:40:WU02:FS01:Connecting to assign3.stanford.edu:8080
05:00:40:WU01:FS01:Server responded WORK_QUIT (404)
05:00:40:WARNING:WU01:FS01:Server did not like results, dumping
05:00:40:WU01:FS01:Cleaning up
05:00:40:WU02:FS01:News: Welcome to Folding@Home
05:00:40:WU02:FS01:Assigned to work server 171.67.108.58
05:00:40:WU02:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.67.108.58
05:00:40:WU02:FS01:Connecting to 171.67.108.58:8080
05:00:41:WU02:FS01:Downloading 534.18KiB
05:00:42:WU02:FS01:Download complete
05:00:42:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:OK project:8014 run:9 clone:700 gen:83 core:0xa4 unit:0x000000776652edca4f9b0a769e514ec2
05:00:43:WU02:FS01:Starting
05:00:43:WU02:FS01:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/All Users/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 02 -suffix 01 -version 701 -lifeline 476 -checkpoint 15 -np 2
05:00:43:ERROR:WU02:FS01:Failed to start core: Failed to create process with: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/All Users/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 02 -suffix 01 -version 701 -lifeline 476 -checkpoint 15 -np 2: The paging file is too small for this operation to complete.
05:00:43:WU02:FS01:Downloading project 8014 description
05:00:43:WU02:FS01:Connecting to fah-web.stanford.edu:80
05:00:43:WU02:FS01:Project 8014 description downloaded successfully
05:01:43:WU02:FS01:Starting
05:01:43:WU02:FS01:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/All Users/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 02 -suffix 01 -version 701 -lifeline 476 -checkpoint 15 -np 2
05:01:43:ERROR:WU02:FS01:Failed to start core: Failed to create process with: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/All Users/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 02 -suffix 01 -version 701 -lifeline 476 -checkpoint 15 -np 2: Insufficient system resources exist to complete the requested service.
05:03:21:WU02:FS01:Starting
05:03:21:WU02:FS01:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/All Users/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 02 -suffix 01 -version 701 -lifeline 476 -checkpoint 15 -np 2
05:03:21:WU02:FS01:Started FahCore on PID 6388
05:03:21:WU02:FS01:Core PID:7656
05:03:21:WU02:FS01:FahCore 0xa4 started
05:03:22:WU02:FS01:0xa4:
05:03:22:WU02:FS01:0xa4:*------------------------------*
05:03:22:WU02:FS01:0xa4:Folding@Home Gromacs GB Core
05:03:22:WU02:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
05:03:22:WU02:FS01:0xa4:Preparing to commence simulation
05:03:22:WU02:FS01:0xa4:- Looking at optimizations...
05:03:22:WU02:FS01:0xa4:- Created dyn
05:03:22:WU02:FS01:0xa4:- Files status OK
05:03:22:WU02:FS01:0xa4:Couldn't Decompress
05:03:22:WU02:FS01:0xa4:Called DecompressByteArray: compressed_data_size=546492 data_size=1326096, decompressed_data_size=0 diff=1326096
05:03:22:WU02:FS01:0xa4:- Fatal: Could not decompress work unit data
05:03:22:WU02:FS01:0xa4:Error: Could not open work file
05:03:22:WU02:FS01:0xa4:Folding@home Core Shutdown: FILE_IO_ERROR
05:03:22:WU02:FS01:FahCore returned: FILE_IO_ERROR (117 = 0x75)
05:03:22:WARNING:WU02:FS01:Fatal error, dumping
05:03:22:WU02:FS01:Sending unit results: id:02 state:SEND error:DUMPED project:8014 run:9 clone:700 gen:83 core:0xa4 unit:0x000000776652edca4f9b0a769e514ec2
05:03:22:WU02:FS01:Connecting to 171.67.108.58:8080
05:03:22:WU02:FS01:Server responded WORK_ACK (400)
05:03:22:WU02:FS01:Cleaning up
05:03:22:WU01:FS01:Connecting to assign3.stanford.edu:8080
05:03:22:WU01:FS01:News: Welcome to Folding@Home
05:03:22:WU01:FS01:Assigned to work server 171.67.108.58
05:03:22:WU01:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.67.108.58
05:03:22:WU01:FS01:Connecting to 171.67.108.58:8080
05:03:23:WU01:FS01:Downloading 534.70KiB
05:03:24:WU01:FS01:Download complete
05:03:24:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:OK project:8014 run:0 clone:242 gen:53 core:0xa4 unit:0x000000566652edca4f9b0355219aecc2
05:03:24:WU01:FS01:Starting
05:03:24:WU01:FS01:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/All Users/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 01 -suffix 01 -version 701 -lifeline 476 -checkpoint 15 -np 2
05:03:24:WU01:FS01:Started FahCore on PID 2760
05:03:25:WU01:FS01:Core PID:3716
05:03:25:WU01:FS01:FahCore 0xa4 started
05:03:25:WU01:FS01:0xa4:
05:03:25:WU01:FS01:0xa4:*------------------------------*
05:03:25:WU01:FS01:0xa4:Folding@Home Gromacs GB Core
05:03:25:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
05:03:25:WU01:FS01:0xa4:Preparing to commence simulation
05:03:25:WU01:FS01:0xa4:- Looking at optimizations...
05:03:25:WU01:FS01:0xa4:- Created dyn
05:03:25:WU01:FS01:0xa4:- Files status OK
05:23:28:Server connection id=17 on 0.0.0.0:36330 from 127.0.0.1
******************************** Date: 06/08/12 ********************************
05:53:52:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
05:53:53:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': 10002: Received short response, expected 272 bytes, got 0
05:53:53:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
05:53:53:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': 10002: Received short response, expected 272 bytes, got 0
05:53:53:ERROR:WU00:FS00:Exception: Could not get an assignment
11:53:52:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
11:53:53:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': 10002: Received short response, expected 272 bytes, got 0
11:53:53:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': 10002: Received short response, expected 272 bytes, got 0
13:44:19:WU01:FS01:FahCore returned: UNKNOWN_ENUM (-1073740777 = 0xc0000417)
13:44:19:WARNING:WU01:FS01:FahCore returned an unknown error code which probably indicates that it crashed
13:44:19:WU01:FS01:Starting
13:44:19:WU01:FS01:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/All Users/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 01 -suffix 01 -version 701 -lifeline 476 -checkpoint 15 -np 2
13:44:22:WU01:FS01:Started FahCore on PID 7128
13:44:24:WU01:FS01:Core PID:6596
13:44:24:WU01:FS01:FahCore 0xa4 started
13:44:24:WU01:FS01:0xa4:
13:44:24:WU01:FS01:0xa4:*------------------------------*
13:44:24:WU01:FS01:0xa4:Folding@Home Gromacs GB Core
13:44:25:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
13:44:25:WU01:FS01:0xa4:Preparing to commence simulation
13:44:25:WU01:FS01:0xa4:- Ensuring status. Please wait.
13:44:34:WU01:FS01:0xa4:- Looking at optimizations...
13:44:34:WU01:FS01:0xa4:- Working with standard loops on this execution.
13:44:34:WU01:FS01:0xa4:- Previous termination of core was improper.
13:44:34:WU01:FS01:0xa4:- Files status OK
13:44:34:WU01:FS01:0xa4:- Expanded 547019 -> 1326096 (decompressed 242.4 percent)
13:44:34:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=547019 data_size=1326096, decompressed_data_size=1326096 diff=0
13:44:34:WU01:FS01:0xa4:- Digital signature verified
13:44:34:WU01:FS01:0xa4:Project: 8014 (Run 0, Clone 242, Gen 53)
13:44:34:WU01:FS01:0xa4:Entering M.D.
13:44:40:WU01:FS01:0xa4:Mapping NT from 2 to 2
13:44:41:WU01:FS01:0xa4:Completed 0 out of 250000 steps  (0%)
13:46:43:Server connection id=17 ended
13:46:45:Lost lifeline PID 1364, exiting
13:46:46:FS01:Shutting core down
13:46:54:Clean exit
13:46:54:WU01:FS01:0xa4:Client no longer detected. Shutting down core
13:46:54:WU01:FS01:0xa4:Folding@home Core Shutdown: CLIENT_DIED
Processor: I7-4770 Memory: 32Gig RAM GPU: GeForce GTX 1660 MB: GigaByte GA-B85M-D3H
Re: Project: 7610 (Run 56, Clone 0, Gen 92)
Someone else has been able to complete Project: 7610 (Run 56, Clone 0, Gen 92) successfully.
To disable the GPU portion, delete the associated slot in FAHControl.
gwildperson
Post by gwildperson »
Search this forum for Avast. There have been some reports of problems with it and FAH.
Robby_Firefox wrote:Sorry but there is a lot of extraneous material related to the GPU having no job to process; making it hard to tell exactly what happened. Anyway to blank out that material in future posts?
In Advanced mode FAHControl can filter the log display by slot, that can be used to keep out the messages from your GPU slot. Then copy from the log window of FAHControl.
toTOW wrote:To disable the GPU portion, delete the associated slot in FAHControl.
You might as well delete your GPU slot, it is very unlikely you will get work for the 4650 again. From the Windows setup guide, http://folding.stanford.edu/English/WinGuide#ntoc4, there is this statement:
The end of support for ATI/AMD 4xxx series and below was announced in March 2011, and scheduled to end in September 2011. The last of the Fahcore_11 (GPU2) work units actually lasted until June 2012, more than a year after the original announcement.
Robby_Firefox
Hi Folks,
Thanks for the replies and advice.
From toTOW, I got rid of the GPU portion of the client as was noted above. It is a shame that my 4xxx GPU can not be used by FAH anymore. When mine was running, it seemed to work fine; faster than the CPU in this rather old machine. For me to go to a 5xxx or higher, I would need a newer computer. Am thinking about replacing/upgrading the PC sometime next year; but this one is still doing a great job despite its age and first generation dual-core processor.
About AVAST! from past entries from others. Have not had trouble with AVAST! before and FAH on this machine. Still think that run of 7610 somehow became corrupted; probably exasperated by a long time between boots, especially with a big job like 7610. This PC had not been rebooted for a number of weeks as you can see from the logs. Even though Windows XP is rather stable, 24/7 FAH and other tasks, games, etc., will erode that stability. Was waiting till today, to see if Microsoft was going to issue their usual Tuesday patches/updates before rebooting. I ran out of time/luck this time. Wed AM CDT as I type this, no MS updates yet. May be next Tuesday...?
Still no partial credit for 7610??
About the lengthy log, I copied what was in the Code area from archived/backup logs at C:\Documents and Settings\All Users\Application Data\FAHClient\logs ~ as it was not available inside the client after rebooting the machine and restarting FAH. I know you can remove 'unwanted' log material in the FAH client under Advanced/Expert mode for stuff already being processed before shutting the client down. Could not do it this time.
Thanks again,
Robby of Team Firefox
