Could not get an assignment
shiryunaga
Hardware configuration: Intel Core i3 2100 3092.91 MHz (99.77 x 31.0)
Post by shiryunaga »
10:48:00:WU00:FS00:Connecting to assign3.stanford.edu:8080
10:48:00:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Could not get IP address for assign3.stanford.edu: A non-recoverable error occurred during a database lookup.
10:48:00:WU00:FS00:Connecting to assign4.stanford.edu:80
10:48:00:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Could not get IP address for assign4.stanford.edu: A non-recoverable error occurred during a database lookup.
10:48:00:ERROR:WU00:FS00:Exception: Could not get an assignment
I get this error
Folding@Home user since Feb 2009
artoar_11
Hardware configuration: AMD R7 3700X @ 4.0 GHz; ASUS ROG STRIX X470-F GAMING; DDR4 2x8GB @ 3.0 GHz; GByte RTX 3060 Ti @ 1890 MHz; Fortron-550W 80+ bronze; Win10 Pro/64
Re: Could not get an assignment
Post by artoar_11 »
sortofageek
Post by sortofageek »
Have you worked through the stickied Troubleshooting Tips yet? Please let us know wht you are finding as you do that.
codysluder
Post by codysluder »
FAHClient could not get IP address but your browser could. I'm 99% certain that your security software is blocking FAHClient from making an internet connection.
Are you using IPv6 ?
shiryunaga
04:41:57:</config>
04:41:57:Trying to access database...
04:41:57:Successfully acquired database lock
04:41:57:Enabled folding slot 00: READY smp:4
04:41:57:Started thread 4 on PID 1520
04:41:57:Started thread 5 on PID 1520
04:41:57:Started thread 6 on PID 1520
04:41:57:Started thread 3 on PID 1520
04:41:57:Started thread 1 on PID 1520
04:41:57:WU00:FS00:Connecting to assign3.stanford.edu:8080
04:41:58:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Could not get IP address for assign3.stanford.edu: A non-recoverable error occurred during a database lookup.
04:41:58:WU00:FS00:Connecting to assign4.stanford.edu:80
04:41:58:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
04:41:58:Started thread 7 on PID 1520
04:41:58:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Could not get IP address for assign4.stanford.edu: A non-recoverable error occurred during a database lookup.
04:41:58:ERROR:WU00:FS00:Exception: Could not get an assignment
04:41:59:WU00:FS00:Connecting to assign3.stanford.edu:8080
04:41:59:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Could not get IP address for assign3.stanford.edu: A non-recoverable error occurred during a database lookup.
04:41:59:WU00:FS00:Connecting to assign4.stanford.edu:80
04:41:59:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Could not get IP address for assign4.stanford.edu: A non-recoverable error occurred during a database lookup.
04:41:59:ERROR:WU00:FS00:Exception: Could not get an assignment
04:42:59:WU00:FS00:Connecting to assign3.stanford.edu:8080
04:42:59:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Could not get IP address for assign3.stanford.edu: A non-recoverable error occurred during a database lookup.
04:42:59:WU00:FS00:Connecting to assign4.stanford.edu:80
04:42:59:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Could not get IP address for assign4.stanford.edu: A non-recoverable error occurred during a database lookup.
04:42:59:ERROR:WU00:FS00:Exception: Could not get an assignment
04:44:36:WU00:FS00:Connecting to assign3.stanford.edu:8080
04:44:36:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Could not get IP address for assign3.stanford.edu: A non-recoverable error occurred during a database lookup.
04:44:36:WU00:FS00:Connecting to assign4.stanford.edu:80
04:44:36:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Could not get IP address for assign4.stanford.edu: A non-recoverable error occurred during a database lookup.
04:44:36:ERROR:WU00:FS00:Exception: Could not get an assignment
04:47:13:WU00:FS00:Connecting to assign3.stanford.edu:8080
04:47:13:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Could not get IP address for assign3.stanford.edu: A non-recoverable error occurred during a database lookup.
04:47:13:WU00:FS00:Connecting to assign4.stanford.edu:80
04:47:13:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Could not get IP address for assign4.stanford.edu: A non-recoverable error occurred during a database lookup.
04:47:13:ERROR:WU00:FS00:Exception: Could not get an assignment
04:51:27:WU00:FS00:Connecting to assign3.stanford.edu:8080
04:51:28:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Could not get IP address for assign3.stanford.edu: A non-recoverable error occurred during a database lookup.
04:51:28:WU00:FS00:Connecting to assign4.stanford.edu:80
04:51:28:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Could not get IP address for assign4.stanford.edu: A non-recoverable error occurred during a database lookup.
04:51:28:ERROR:WU00:FS00:Exception: Could not get an assignment
04:58:19:WU00:FS00:Connecting to assign3.stanford.edu:8080
04:58:19:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Could not get IP address for assign3.stanford.edu: A non-recoverable error occurred during a database lookup.
04:58:19:WU00:FS00:Connecting to assign4.stanford.edu:80
04:58:20:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Could not get IP address for assign4.stanford.edu: A non-recoverable error occurred during a database lookup.
04:58:20:ERROR:WU00:FS00:Exception: Could not get an assignment
05:09:24:WU00:FS00:Connecting to assign3.stanford.edu:8080
05:09:24:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Could not get IP address for assign3.stanford.edu: A non-recoverable error occurred during a database lookup.
05:09:24:WU00:FS00:Connecting to assign4.stanford.edu:80
05:09:24:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Could not get IP address for assign4.stanford.edu: A non-recoverable error occurred during a database lookup.
05:09:24:ERROR:WU00:FS00:Exception: Could not get an assignment
05:27:21:WU00:FS00:Connecting to assign3.stanford.edu:8080
05:27:21:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Could not get IP address for assign3.stanford.edu: A non-recoverable error occurred during a database lookup.
05:27:21:WU00:FS00:Connecting to assign4.stanford.edu:80
05:27:21:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Could not get IP address for assign4.stanford.edu: A non-recoverable error occurred during a database lookup.
05:27:21:ERROR:WU00:FS00:Exception: Could not get an assignment
05:56:23:WU00:FS00:Connecting to assign3.stanford.edu:8080
05:56:24:WU00:FS00:News: Welcome to Folding@Home
05:56:24:WU00:FS00:Assigned to work server 171.67.108.60
05:56:24:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.60
05:56:24:WU00:FS00:Connecting to 171.67.108.60:8080
05:56:25:WU00:FS00:Downloading 1.73MiB
05:56:31:WU00:FS00:Download 14.42%
05:56:37:WU00:FS00:Download 18.02%
05:56:43:WU00:FS00:Download 21.63%
05:56:49:WU00:FS00:Download 28.84%
05:56:55:WU00:FS00:Download 36.04%
05:57:01:WU00:FS00:Download 43.25%
05:57:07:WU00:FS00:Download 54.07%
05:57:17:WU00:FS00:Download 72.09%
05:57:25:WU00:FS00:Download 82.90%
05:57:32:WU00:FS00:Download 93.71%
05:57:39:WU00:FS00:Download 100.00%
05:57:39:WU00:FS00:Download complete
05:57:39:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:OK project:8050 run:0 clone:15 gen:3 core:0xa4 unit:0x000000076652edcc50133b9557ed120f
05:57:39:WU00:FS00:Starting
05:57:39:WU00:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:/Users/m.02.11.0022/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 701 -lifeline 1520 -checkpoint 30 -np 4
05:57:39:WU00:FS00:Started FahCore on PID 3316
05:57:39:Started thread 8 on PID 1520
05:57:40:WU00:FS00:Core PID:1528
05:57:40:WU00:FS00:FahCore 0xa4 started
05:57:40:WU00:FS00:Downloading project 8050 description
05:57:40:WU00:FS00:Connecting to fah-web.stanford.edu:80
05:57:40:WU00:FS00:0xa4:
05:57:40:WU00:FS00:0xa4:*------------------------------*
05:57:40:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
05:57:40:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
05:57:40:WU00:FS00:0xa4:Preparing to commence simulation
05:57:40:WU00:FS00:0xa4:- Looking at optimizations...
05:57:40:WU00:FS00:0xa4:- Created dyn
05:57:40:WU00:FS00:0xa4:- Files status OK
05:57:41:WU00:FS00:0xa4:- Expanded 1817721 -> 3989804 (decompressed 219.4 percent)
05:57:41:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=1817721 data_size=3989804, decompressed_data_size=3989804 diff=0
05:57:41:WU00:FS00:0xa4:- Digital signature verified
05:57:41:WU00:FS00:0xa4:Project: 8050 (Run 0, Clone 15, Gen 3)
05:57:41:WU00:FS00:0xa4:Assembly optimizations on if available.
05:57:41:WU00:FS00:0xa4:Entering M.D.
05:57:44:WU00:FS00:Project 8050 description downloaded successfully
05:57:46:WU00:FS00:0xa4:Mapping NT from 4 to 4
ok i don't change anything but finally i get WU...
