Project: 8042 (Run 0, Clone 192, Gen 35) EUE
rhavern
Post by rhavern »
Long time dedicated folding box, over 1100 WU submitted, QX6700 @ stock, 2G RAM, XP-32 SP3, v6.34 in a temperature controlled hosting environment with excellent cooling.
[10:41:29] + Attempting to get work packet
[10:41:29] Passkey found
[10:41:29] - Will indicate memory of 2046 MB
[10:41:29] - Connecting to assignment server
[10:41:29] Connecting to http://assign.stanford.edu:8080/
[10:41:30] Posted data.
[10:41:30] Initial: 43AB; - Successful: assigned to (171.67.108.59).
[10:41:30] + News From Folding@Home: Welcome to Folding@Home
[10:41:30] Loaded queue successfully.
[10:41:30] Sent data
[10:41:30] Connecting to http://171.67.108.59:8080/
[10:41:32] Posted data.
[10:41:32] Initial: 0000; - Receiving payload (expected size: 258758)
[10:41:33] - Downloaded at ~252 kB/s
[10:41:33] - Averaged speed for that direction ~329 kB/s
[10:41:33] + Received work.
[10:41:34] Trying to send all finished work units
[10:41:34] + No unsent completed units remaining.
[10:41:34] + Closed connections
[10:41:34]
[10:41:34] + Processing work unit
[10:41:34] A4 will attempt to use 4 threads.
[10:41:34] Core required: FahCore_a4.exe
[10:41:34] Core found.
[10:41:34] Working on queue slot 09 [July 7 10:41:34 UTC]
[10:41:34] + Working ...
[10:41:34] - Calling '.\FahCore_a4.exe -dir work/ -nice 19 -suffix 09 -np 4 -checkpoint 30 -service -verbose -lifeline 740 -version 634'
[10:41:34]
[10:41:34] *------------------------------*
[10:41:34] Folding@Home Gromacs GB Core
[10:41:34] Version 2.27 (Dec. 15, 2010)
[10:41:34]
[10:41:34] Preparing to commence simulation
[10:41:34] - Looking at optimizations...
[10:41:34] - Created dyn
[10:41:34] - Files status OK
[10:41:34] - Expanded 258246 -> 3058560 (decompressed 1184.3 percent)
[10:41:34] Called DecompressByteArray: compressed_data_size=258246 data_size=3058560, decompressed_data_size=3058560 diff=0
[10:41:34] - Digital signature verified
[10:41:34]
[10:41:34] Project: 8042 (Run 0, Clone 192, Gen 35)
[10:41:34]
[10:41:34] Assembly optimizations on if available.
[10:41:34] Entering M.D.
[10:41:40] Mapping NT from 4 to 4
[10:41:40] mdrun returned 255
[10:41:40] Going to send back what have done -- stepsTotalG=250000
[10:41:40] Work fraction=0.0000 steps=250000.
[10:41:44] logfile size=6836 infoLength=6836 edr=0 trr=25
[10:41:44] logfile size: 6836 info=6836 bed=0 hdr=25
[10:41:44] - Writing 7374 bytes of core data to disk...
[10:41:44] Done: 6862 -> 2452 (compressed to 35.7 percent)
[10:41:44]   ... Done.
[10:41:45]
[10:41:45] Folding@home Core Shutdown: EARLY_UNIT_END
[10:41:48] CoreStatus = 72 (114)
[10:41:48] Sending work to server
[10:41:48] Project: 8042 (Run 0, Clone 192, Gen 35)
[10:41:48] + Attempting to send results [July 7 10:41:48 UTC]
[10:41:48] - Reading file work/wuresults_09.dat from core
[10:41:48]   (Read 2964 bytes from disk)
[10:41:48] Connecting to http://171.67.108.59:8080/
[10:41:48] Posted data.
[10:41:48] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[10:41:48] - Uploaded at ~7 kB/s
[10:41:48] - Averaged speed for that direction ~330 kB/s
[10:41:48] + Results successfully sent
[10:41:48] Thank you for your contribution to Folding@Home.
Folding since 1 WU=1 point
Re: Project: 8042 (Run 0, Clone 192, Gen 35) EUE
The WU (P8042,R0,C192,G35) has been reported as a bad WU. Note that the list of reported WUs are stopped daily at 8am pacific time.
