conky read out?
conky read out?
is there any way I can add a f@h monitor to my conky readout?
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
Re: conky read out?
By "conky" I assume you mean http://conky.sourceforge.net/ right? If so, it's open-source and thus very third-party. I have no idea how to add V7 to it.
Re: conky read out?
yes the open souce thrid party linux/unix conky. I'm just hoping for a wu readout so I can see how for along it is and that.
Re: conky read out?
ok I found one. just for anyone that wants to know, it is:
${font sans-serif:bold:size=8}${color FF9900}FOLDING AT HOME ${hr 2}${font sans-serif:normal:size=8}${color
FFFF00}
${color yellow}${execi 15 cat /opt/foldingathome/1/FAHlog.txt | tr '(' '\n' |tr ')' '\n' | grep -E "(%|percent)"|tail -n 1 | tr -d 'percent' | tr -d '%'} % ${execbar echo "scale=2; $(cat /opt/foldingathome/1/FAHlog.txt | tr '(' '\n' |tr ')' '\n' | grep -E "(%|percent)"|tail -n 1 | tr -d 'percent' | tr -d '%')/100" | bc -q}
I found it on the ubuntu forums and did my own color coding and that.
FFFF00}
Re: conky read out?
problem. no progress is given, and on a restart of conky I get these errors:
jlloyd13@A880GZ ~ $ conky
Conky: forked to background, pid is 3481
jlloyd13@A880GZ ~ $
Conky: desktop window (1000022) is subwindow of root window (14f)
Conky: window type - desktop
Conky: drawing to created window (0x2a00001)
Conky: drawing to double buffer
cat: /opt/foldingathome/1/FAHlog.txt: No such file or directory
(standard_in) 1: syntax error
my conky read out shows cpus at %100 (folding) but f@h readout shows nothing.
jlloyd13@A880GZ ~ $
Re: conky read out?
If /opt/foldingathome/1/FAHlog.txt dosn't exist where is my FAHlog.txt?
Re: conky read out?
I think V7 on linux uses
/var/lib/fahclient/log.txt
The log will look different than the fah6 FAHlog.txt.
You might want to check out net-fahclient as a command line monitoring tool to call from conky. Announcement thread is here.
Jesse_V
CPU: i7-6700k
Re: conky read out?
Conky is not mentioned a lot on this forum. search.php?keywords=conky but there may be some useful info on some of the older threads, idk.
Re: conky read out?
I have something that sort of works:
${color yellow}${execi 15 cat /var/lib/fahclient/log.txt | tr '(' '\n' |tr ')' '\n' | grep -E "(%|percent)"|tail -n 1 | tr -d 'percent' | tr -d '%'} % ${execbar echo "scale=2; $(cat /var/lib/fahclient/log.txt | tr '(' '\n' |tr ')' '\n' | grep -E "(%|percent)"|tail -n 1 | tr -d 'percent' | tr -d '%')/100" | bc -q}
the first part gives me a percentage fine but the second part won't give me a workin progress bar any ideas?
Re: conky read out?
fixed it!!!!
finial readout:
${color yellow}Work Unit: ${execi 15 cat /var/lib/fahclient/log.txt | tr '(' '\n' |tr ')' '\n' | grep -E "(%|percent)"|tail -n 1 | tr -d 'percent' | tr -d '%'} %
${execibar 15 cat /var/lib/fahclient/log.txt | tr '(' '\n' |tr ')' '\n' | grep -E "(%|percent)"|tail -n 1 | tr -d 'percent' | tr -d '%'}
anyones welcome to take it.
finial readout:
Re: conky read out?
Hi!
How to adopted this conky command for dual GPU?
Re: conky read out?
Somebody can rewrite HFM.Net for Linux. It's open-source, and the script above is a good start.
jimerickson
- Hardware configuration: Parts:
Intel Core i7 8700 cpu (X2)
Veddha 8 gpu miner case (X2)
Thermaltake hsf (X2)
Ubit riser card (X16) - Location: ames, iowa
Re: conky read out?
bruce,
hfm runs fine under mono on linux. running right now as a matter of fact!
Re: conky read out?
I didn't know that. Wouldn't it provide the necessary display for clients with multiple slots?
