configure expert option v7
shiryunaga
Hardware configuration: Intel Core i3 2100 3092.91 MHz (99.77 x 31.0)
Post by shiryunaga »
i wanna know detaill about configure expert option "ektra slot","extra client" and "extra core" @ client v7 thx
Folding@Home user since Feb 2009
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Re: configure expert option v7
Post by Jesse_V »
Could you be more specific? What exactly would you like to know about? I don't understand.
shiryunaga
can u explain how many variabel i can add to this expert options thx
Panels with "expert" in their name are called that because you can get into trouble by using them. If you do not understand exactly what a particular expert option will do, leave it set to the default value. The program is designed to work correctly without changing anything except your Name, Team Number and passkey.
Our goal here is to fix problems if you have them, not to cause new ones. Exactly what are you trying to accomplish?
