Problem with 128.143.199.96
artoar_11
Hardware configuration: AMD R7 3700X @ 4.0 GHz; ASUS ROG STRIX X470-F GAMING; DDR4 2x8GB @ 3.0 GHz; GByte RTX 3060 Ti @ 1890 MHz; Fortron-550W 80+ bronze; Win10 Pro/64
Post by artoar_11 »
http://fah-web.stanford.edu/pybeta/serverstat.html - Status - full; Connect - Reject.
http://fah-web.stanford.edu/serverstat.html - STATUS - No Response; CONNECT - Reject.
[16:27:38] Completed 495000 out of 500000 steps  (99%)
[16:30:44] Completed 500000 out of 500000 steps  (100%)
[16:30:45] DynamicWrapper: Finished Work Unit: sleep=10000
[16:30:55]
[16:30:55] Finished Work Unit:
[16:30:55] - Reading up to 3700224 from "work/wudata_07.trr": Read 3700224
[16:30:55] trr file hash check passed.
[16:30:55] edr file hash check passed.
[16:30:55] logfile size: 59218
[16:30:55] Leaving Run
[16:30:55] - Writing 3794378 bytes of core data to disk...
[16:30:56] Done: 3793866 -> 3522108 (compressed to 92.8 percent)
[16:30:56]   ... Done.
[16:31:02] - Shutting down core
[16:31:02]
[16:31:02] Folding@home Core Shutdown: FINISHED_UNIT
[16:31:04] CoreStatus = 64 (100)
[16:31:04] Unit 7 finished with 94 percent of time to deadline remaining.
[16:31:04] Updated performance fraction: 0.948964
[16:31:04] Sending work to server
[16:31:04] Project: 6990 (Run 0, Clone 66, Gen 177)
[16:31:04] + Attempting to send results [June 30 16:31:04 UTC]
[16:31:04] - Reading file work/wuresults_07.dat from core
[16:31:04]   (Read 3522620 bytes from disk)
[16:31:04] Connecting to http://128.143.199.96:8080/
[16:31:25] - Couldn't send HTTP request to server
[16:31:25] + Could not connect to Work Server (results)
[16:31:25]     (128.143.199.96:8080)
[16:31:25] + Retrying using alternative port
[16:31:25] Connecting to http://128.143.199.96:80/
[16:31:46] - Couldn't send HTTP request to server
[16:31:46] + Could not connect to Work Server (results)
[16:31:46]     (128.143.199.96:80)
[16:31:46] - Error: Could not transmit unit 07 (completed June 30) to work server.
[16:31:46] - 1 failed uploads of this unit.
[16:31:46]   Keeping unit 07 in queue.
[17:17:17]     (128.143.199.96:80)
[17:17:17] - Error: Could not transmit unit 07 (completed June 30) to work server.
[17:17:17] - 3 failed uploads of this unit.
[17:17:17] + Attempting to send results [June 30 17:17:17 UTC]
[17:17:17] - Reading file work/wuresults_07.dat from core
[17:17:17]   (Read 3522620 bytes from disk)
[17:17:17] Connecting to http://130.237.165.141:8080/
[17:17:31] Posted data.
[17:17:31] Initial: 0000; - Uploaded at ~245 kB/s
[17:17:31] - Averaged speed for that direction ~147 kB/s
[17:17:31] - Server does not have record of this unit. Will try again later.
[17:17:31]   Could not transmit unit 07 to Collection server; keeping in queue.
[17:17:31] + Sent 0 of 1 completed units to the server
[17:17:31] - Autosend completed
[17:27:57] ***** Got an Activate signal (2)
[17:27:57] Killing all core threads
kasson
Pande Group Member
Re: Problem with 128.143.199.96
Post by kasson »
We had a power outage in one of our Virginia server rooms due to the East Coast storms. Those machines are now back online. Apologies for the interruption.
artoar_11
Post by artoar_11 »
Now the server is OK. Thanks kasson.
[18:06:01] - Autosending finished units... [July 1 18:06:01 UTC]
[18:06:01] Trying to send all finished work units
[18:06:01] Project: 6990 (Run 0, Clone 66, Gen 177)
[18:06:01] + Attempting to send results [July 1 18:06:01 UTC]
[18:06:01] - Reading file work/wuresults_07.dat from core
[18:06:01]   (Read 3522620 bytes from disk)
[18:06:01] Connecting to http://128.143.199.96:8080/
[18:06:35] Posted data.
[18:06:35] Initial: 0000; - Uploaded at ~101 kB/s
[18:06:35] - Averaged speed for that direction ~186 kB/s
[18:06:35] + Results successfully sent
[18:06:35] Thank you for your contribution to Folding@Home.
[18:06:35] + Number of Units Completed: 1595
[18:06:36] + Sent 1 of 1 completed units to the server
