GTX 690 card Linux/Windows
standev
Hardware configuration: i7-3930K CPU @ 3.20GHz
GeForce GTX 690
32Gb RAM
Post by standev »
I've got Nvidia Geforce GTX 690 card in my PC which runs F@H 24x7 basically. I wasn't able to use this card in Linux version, and I wasn't even able to use it in Windows 7. FAHControl doesn't see it, it says: GPUs: 0 in System Info.
So if anyone could guide me how I can use it, I'd be happy to contribute this card's power to a good cause. Linux solution would be preferred, as I rarely boot to Windows.
Re: GTX 690 card Linux/Windows
Hello standev, welcome to the forum.
Folding on GPUs is not yet supported in Linux.
If you would like help with Windows, please post the ***System*** section of the log from the V7 client. Thanks.
standev
GeForce GTX 690
32Gb RAM
Post by standev »
Thank you for your help, 7im. Sure, I'd like help with Windows, even though I boot into it rarely, I could still launch folding on the card when I do. Here's the System section of the log:
15:11:12:******************************* System ********************************
15:11:12:          CPU: Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz
15:11:12:       CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
15:11:12:         CPUs: 12
15:11:12:       Memory: 31.98GiB
15:11:12:  Free Memory: 29.44GiB
15:11:12:      Threads: WINDOWS_THREADS
15:11:12:   On Battery: false
15:11:12:   UTC offset: 2
15:11:12:          PID: 4436
15:11:12:          CWD: C:/Users/***/AppData/Roaming/FAHClient
15:11:12:           OS: Windows 7 Professional
15:11:12:      OS Arch: AMD64
15:11:12:         GPUs: 0
15:11:12:         CUDA: 3.0
15:11:12:  CUDA Driver: 4020
15:11:12:Win32 Service: false
15:11:12:***********************************************************************
nVidia driver version is 301.42. FAHClient version is 7.1.52 from March 20. Thanks.
standev
GeForce GTX 690
32Gb RAM
Post by standev »
Okay, I have browsed related topics to find a solution, so I've downloaded GPUs.txt and moved it into FAHClient's running directory. After I opened FAHControl, then Configure -> Connection -> [Stop] local client, then [Start], now it can see my graphics card. So then I opened Configure -> Slots and added 4 gpu slots.
Now it's like this in the Log:
11:53:49:         GPUs: 4
11:53:49:        GPU 0: FERMI:1 GK104 [Geforce GTX680]
11:53:49:        GPU 1: FERMI:1 GK104 [Geforce GTX680]
11:53:49:        GPU 2: FERMI:1 GK107 [GeForce GTX 690]
11:53:49:        GPU 3: FERMI:1 GK107 [GeForce GTX 690]
11:53:49:         CUDA: 3.0
11:53:49:  CUDA Driver: 4020
11:53:49:Win32 Service: false
11:53:49:***********************************************************************
11:53:49:Enabled folding slot 00: READY smp:12
11:53:49:Enabled folding slot 01: READY gpu:0:"GK104 [Geforce GTX680]"
11:53:49:Enabled folding slot 02: READY gpu:1:"GK104 [Geforce GTX680]"
11:53:49:Enabled folding slot 04: READY gpu:2:"GK107 [GeForce GTX 690]"
11:53:49:Enabled folding slot 05: READY gpu:3:"GK107 [GeForce GTX 690]"
I don't see any errors in the log, but all gpu slots are stuck at 0.0%, looks like nothing is happening.
bollix47
Post by bollix47 »
Was this just a typo? It should say
www.stanford.edu
Also, the a4 core is not a GPU core. It's used for SMP and Uniprocessor WUs.
standev
GeForce GTX 690
32Gb RAM
Post by standev »
bollix47, thank you for your help. I figured that the problem was that I've put GPUs.txt in the wrong directory (I should have put it in C:\Users\myusername\AppData\Roaming\FAHClient). So when I have put it in the correct directory and properly restarted FAHClient in FAHControl, it can now see my graphics card. Please check my previous post, I've edited it to describe where I'm currently stuck, that is - gpu slots seem to be stuck at 0.0%.
bollix47
Post by bollix47 »
Shutdown FAHClient and FAHControl.
Then open a Command window and run FAHClient.exe --lspci and post the output here.
standev
GeForce GTX 690
32Gb RAM
Post by standev »
Here it is:
0x10b5:0x8747:PLX Technology, Inc.:PCI standard PCI-to-PCI bridge
0x10de:0x0e0a:NVIDIA Corporation:High Definition Audio Controller
0x10de:0x1188:NVIDIA Corporation:NVIDIA GeForce GTX 690
0x168c:0x0030:Atheros Communications Inc.:TP-LINK 450Mbps Wireless N Adapter
0x1b21:0x0612:ASMedia Technology Inc.:Standard AHCI 1.0 Serial ATA Controller
0x1b21:0x1042:ASMedia Technology Inc.:ASMedia XHCI Controller
0x1b4b:0x9130:Marvell Technology Group Ltd.:Marvell 91xx SATA 6G Controller
0x8086:0x1503:Intel Corporation:Intel(R) 82579V Gigabit Network Connection
0x8086:0x1d02:Intel Corporation:Intel(R) C600 Series Chipset SATA AHCI Controller
0x8086:0x1d10:Intel Corporation:Intel(R) C600/X79 series chipset PCI Express Root Port 1 - 1D10
0x8086:0x1d12:Intel Corporation:Intel(R) C600/X79 series chipset PCI Express Root Port 2 - 1D12
0x8086:0x1d14:Intel Corporation:Intel(R) C600/X79 series chipset PCI Express Root Port 3 - 1D14
0x8086:0x1d16:Intel Corporation:Intel(R) C600/X79 series chipset PCI Express Root Port 4 - 1D16
0x8086:0x1d18:Intel Corporation:Intel(R) C600/X79 series chipset PCI Express Root Port 5 - 1D18
0x8086:0x1d1e:Intel Corporation:Intel(R) C600/X79 series chipset PCI Express Root Port 8 - 1D1E
0x8086:0x1d20:Intel Corporation:Intel(R) C600/X79 series chipset High Definition Audio Controller - 1D20
0x8086:0x1d22:Intel Corporation:Intel(R) C600/X79 series chipset SMBus Host Controller - 1D22
0x8086:0x1d26:Intel Corporation:Intel(R) C600/X79 series chipset USB2 Enhanced Host Controller #1 - 1D26
0x8086:0x1d2d:Intel Corporation:Intel(R) C600/X79 series chipset USB2 Enhanced Host Controller #2 - 1D2D
0x8086:0x1d3a:Intel Corporation:Intel(R) Management Engine Interface
0x8086:0x1d3e:Intel Corporation:Intel(R) C600/X79 series chipset PCI Express Virtual Root Port - 1D3E
0x8086:0x1d41:Intel Corporation:Intel(R) C600/X79 series chipset LPC Controller - 1D41
0x8086:0x244e:Intel Corporation:Intel(R) 82801 PCI Bridge - 244E
0x8086:0x3c00:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 DMI2 - 3C00
0x8086:0x3c02:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 IIO PCI Express Root Port 1a - 3C02
0x8086:0x3c04:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 IIO PCI Express Root Port 2a - 3C04
0x8086:0x3c08:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 IIO PCI Express Root Port 3a in PCI Express Mode - 3C08
0x8086:0x3c28:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Address Map, VTd_Misc, System Management - 3C28
0x8086:0x3c2a:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Control Status and Global Errors - 3C2A
0x8086:0x3c2c:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 I/O APIC - 3C2C
0x8086:0x3c43:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Ring to PCI Express Performance Monitor - 3C43
0x8086:0x3c44:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Ring to QuickPath Interconnect Link 0 Performance Monitor - 3C44
0x8086:0x3c45:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Ring to QuickPath Interconnect Link 1 Performance Monitor - 3C45
0x8086:0x3c46:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Processor Home Agent Performance Monitoring - 3C46
0x8086:0x3c71:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller RAS Registers - 3C71
0x8086:0x3c80:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 QPI Link 0 - 3C80
0x8086:0x3c83:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 QPI Link Reut 0 - 3C83
0x8086:0x3c84:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 QPI Link Reut 0 - 3C84
0x8086:0x3c90:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 QPI Link 1 - 3C90
0x8086:0x3c93:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 QPI Link Reut 1 - 3C93
0x8086:0x3c94:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 QPI Link Reut 1 - 3C94
0x8086:0x3ca0:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Processor Home Agent - 3CA0
0x8086:0x3ca8:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Registers - 3CA8
0x8086:0x3caa:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Target Address Decoder 0 - 3CAA
0x8086:0x3cab:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Target Address Decoder 1 - 3CAB
0x8086:0x3cac:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Target Address Decoder 2 - 3CAC
0x8086:0x3cad:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Target Address Decoder 3 - 3CAD
0x8086:0x3cae:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Target Address Decoder 4 - 3CAE
0x8086:0x3cb0:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Channel 0-3 Thermal Control 0 - 3CB0
0x8086:0x3cb1:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Channel 0-3 Thermal Control 1 - 3CB1
0x8086:0x3cb2:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller ERROR Registers 0 - 3CB2
0x8086:0x3cb3:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller ERROR Registers 1 - 3CB3
0x8086:0x3cb4:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Channel 0-3 Thermal Control 2 - 3CB4
0x8086:0x3cb5:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Channel 0-3 Thermal Control 3 - 3CB5
0x8086:0x3cb6:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller ERROR Registers 2 - 3CB6
0x8086:0x3cb7:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller ERROR Registers 3 - 3CB7
0x8086:0x3cb8:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 DDRIO - 3CB8
0x8086:0x3cc0:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Power Control Unit 0 - 3CC0
0x8086:0x3cc1:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Power Control Unit 1 - 3CC1
0x8086:0x3cc2:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Power Control Unit 2 - 3CC2
0x8086:0x3cd0:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Power Control Unit 3 - 3CD0
0x8086:0x3ce0:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Interrupt Control Registers - 3CE0
0x8086:0x3ce3:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Semaphore and Scratchpad Configuration Registers - 3CE3
0x8086:0x3ce4:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 R2PCIe - 3CE4
0x8086:0x3ce6:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 QuickPath Interconnect Agent Ring Registers - 3CE6
0x8086:0x3ce8:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Unicast Register 0 - 3CE8
0x8086:0x3cf4:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller System Address Decoder 0 - 3CF4
0x8086:0x3cf5:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller System Address Decoder 1 - 3CF5
0x8086:0x3cf6:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 System Address Decoder - 3CF6
UPD: Okay, in the Windows Task Manager I can see that FahCore_a4.exe is taking about 63%, and there are 4 FahCore_15.exe processes which take 8-9% of CPU power. So it looks like it's doing something. Perhaps I just have to wait longer to see some progress? It's odd, because now smp's work unit is estimated to be completed in 21 hours (previously it was like 4-8 hours per work unit). Total estimated points per day is only 1232 (I used to have more like 30,000). All folding slots are at 0.0% currently, including smp.
UPD2: I have paused gpu slots in FAHControl, and now at least smp slot is working again. Seems like gpu slots were blocking smp from getting started.
bollix47
Post by bollix47 »
I'm not sure why you're showing 2 680s in FAHControl. I don't see any in your lspci list.
If you only have one 690 graphics card in your computer then you should only show 2 690 entries.
GPUs.txt:
0x10de:0x1180:3:1:GF114 [GeForce GTX 680]
0x10de:0x1188:3:1:GK107 [GeForce GTX 690]
lspci:
Try pausing the following slots to see the effect:
standev
GeForce GTX 690
32Gb RAM
Post by standev »
Thank you for your help. I indeed only have one 690 card. However in System Info of FAHControl I see
GPUs: 4.
GPU 0: FERMI:1 GK104 [Geforce GTX680].
GPU 1: FERMI:1 GK104 [Geforce GTX680].
GPU 2: FERMI:1 GK107 [GeForce GTX 690].
GPU 3: FERMI:1 GK107 [Geforce GTX 690].
Currently I have paused all gpu slots and I've unpaused only one folding slot 04 which is listed as gpu:2:GK107 [Geforce GTX 690]. In Task Manager I see that FahCore_a4.exe takes 90-91% CPU, FahCore_15.exe takes 8% CPU, however this gpu slot doesn't show any progress, it's stuck at 0.0%.
This is what's in Log:
12:29:08:FS04:Unpaused
12:29:08:WU04:FS04:Starting
12:29:08:WU04:FS04:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/***/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 04 -suffix 01 -version 701 -lifeline 8608 -checkpoint 15 -gpu 2
12:29:08:WU04:FS04:Started FahCore on PID 7112
12:29:08:WU04:FS04:Core PID:8552
12:29:08:WU04:FS04:FahCore 0x15 started
12:29:08:WU04:FS04:0x15:
12:29:08:WU04:FS04:0x15:*------------------------------*
12:29:08:WU04:FS04:0x15:Folding@Home GPU Core
12:29:08:WU04:FS04:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
12:29:08:WU04:FS04:0x15:Build host             SimbiosNvdWin7
12:29:08:WU04:FS04:0x15:Board Type             NVIDIA/CUDA
12:29:08:WU04:FS04:0x15:Core                   15
12:29:08:WU04:FS04:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=2
12:29:08:WU04:FS04:0x15:Window's signal control handler registered.
12:29:08:WU04:FS04:0x15:Preparing to commence simulation
12:29:08:WU04:FS04:0x15:- Looking at optimizations...
12:29:08:WU04:FS04:0x15:- Files status OK
12:29:08:WU04:FS04:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
12:29:08:WU04:FS04:0x15:- Expanded 66389 -> 285182 (decompressed 429.5 percent)
12:29:08:WU04:FS04:0x15:Called DecompressByteArray: compressed_data_size=66389 data_size=285182, decompressed_data_size=285182 diff=0
12:29:08:WU04:FS04:0x15:- Digital signature verified
12:29:08:WU04:FS04:0x15:Project: 8010 (Run 0, Clone 670, Gen 68)
12:29:08:WU04:FS04:0x15:Assembly optimizations on if available.
12:29:08:WU04:FS04:0x15:Entering M.D.
12:29:10:WU04:FS04:0x15:Tpr hash 04/wudata_01.tpr:  3102759895 1389118750 3530345362 1666066736 3006950948
12:29:10:WU04:FS04:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
12:29:10:WU04:FS04:0x15:Working on Good ROcking Metal Altar for Chronical Sinners
12:29:10:WU04:FS04:0x15:Client config unavailable.
12:29:10:WU04:FS04:0x15:Starting GUI Server
## my comment: at this point I've decided to pause it and try another gpu slot, it still was at 0.0%
12:41:32:FS04:Paused
12:41:32:FS04:Shutting core down
12:41:38:WU04:FS04:0x15:Client no longer detected. Shutting down core
12:41:38:WU04:FS04:0x15:Folding@home Core Shutdown: CLIENT_DIED
12:41:38:WU04:FS04:FahCore returned: INTERRUPTED (102 = 0x66)
bollix47
Post by bollix47 »
Try unpausing just slot 01.
standev
GeForce GTX 690
32Gb RAM
Post by standev »
Done that now (paused all slots including smp and unpaused only slot 01). Effect seems to be pretty much the same. FahCore_15.exe *32 is taking 8% of CPU and 32 976K of memory. Log is as follows:
13:00:32:FS01:Unpaused
13:00:32:WU01:FS01:Starting
13:00:32:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/***/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 701 -lifeline 8608 -checkpoint 15 -gpu 0
13:00:32:WU01:FS01:Started FahCore on PID 4840
13:00:32:WU01:FS01:Core PID:4904
13:00:32:WU01:FS01:FahCore 0x15 started
13:00:33:WU01:FS01:0x15:
13:00:33:WU01:FS01:0x15:*------------------------------*
13:00:33:WU01:FS01:0x15:Folding@Home GPU Core
13:00:33:WU01:FS01:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
13:00:33:WU01:FS01:0x15:Build host             SimbiosNvdWin7
13:00:33:WU01:FS01:0x15:Board Type             NVIDIA/CUDA
13:00:33:WU01:FS01:0x15:Core                   15
13:00:33:WU01:FS01:0x15:Window's signal control handler registered.
13:00:33:WU01:FS01:0x15:Preparing to commence simulation
13:00:33:WU01:FS01:0x15:- Looking at optimizations...
13:00:33:WU01:FS01:0x15:- Files status OK
13:00:33:WU01:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
13:00:33:WU01:FS01:0x15:- Expanded 66447 -> 285182 (decompressed 429.1 percent)
13:00:33:WU01:FS01:0x15:Called DecompressByteArray: compressed_data_size=66447 data_size=285182, decompressed_data_size=285182 diff=0
13:00:33:WU01:FS01:0x15:- Digital signature verified
13:00:33:WU01:FS01:0x15:Project: 8010 (Run 0, Clone 1410, Gen 141)
13:00:33:WU01:FS01:0x15:Assembly optimizations on if available.
13:00:33:WU01:FS01:0x15:Entering M.D.
13:00:35:WU01:FS01:0x15:Tpr hash 01/wudata_01.tpr:  2649975436 2508123176 2614204242 1115949158 2559426812
13:00:35:WU01:FS01:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
13:00:35:WU01:FS01:0x15:Working on Good ROcking Metal Altar for Chronical Sinners
13:00:35:WU01:FS01:0x15:Client config unavailable.
13:00:35:WU01:FS01:0x15:Starting GUI Server
Folding Slot ID 01. Work Queue ID 01. Status: Running. Progress: 0.00%. ETA: Unknown. Project: 8010. FahCore: 0x15. Total Estimated Points Per Day: 0.
bollix47
Post by bollix47 »
Basically two of your GPU slots need to be removed, but until one of them shows progress while the other 3 are paused it's hard to say which ones should be deleted. You would think that it's the two 680s that require deleting but one 690 is made up of two 680s so it's a little confusing. I know nvidia is supposed to enhance their drivers for kepler GPUs and maybe even the core is being updated:
viewtopic.php?f=66&t=21571
Also, you can up the priority:
Configure>Advanced>FAH Priority>Slightly Higher
standev
GeForce GTX 690
32Gb RAM
Post by standev »
Thank you for your suggestions. I've set priority to Slightly Higher.
First I removed two GK107 slots and unpaused only 1 of the 2 remaining GK104 (GTX 680) slots. No luck. Then I added two GK107 slots back and removed two GK104 (GTX 680) slots. Again, with no luck. Oh, actually since I've added all gpu slots with -1 index, it reverted remaining 2 slots back to GK104 after restarting FAHClient. So now I removed all gpu slots and added gpu slot with manually set index: 2. So now I have 1 gpu slot GK107 GTX 690. Unfortunately, it still doesn't seem to do anything, stuck at 0.00%.
Perhaps these lines in log have to do something with it:
13:38:42:WU03:FS01:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
13:38:42:WU03:FS01:0x15:Client config unavailable.
Or maybe not.
bollix47
Post by bollix47 »
set index: 2
Since you only have 1 double GPU the value of the index should be 0 or 1.
