Project: 7017 (Run 2, Clone 369, Gen 70)
DrBB1
Post by DrBB1 »
I have folded two 7017s in the past on my laptop and have obtained times per frame in the range of 18-19 minutes. I am currently folding this 7017 and time per frame is over 46 minutes. Indeed, another old PC (circa 2005) has folded two 7017s in about 35 minutes, consistent with my former 7017 results on my laptop. Is this particular 7017 project intended to be so different from previous ones that this makes sense?
I have rebooted my laptop to rule out something slowing folding this project down with no change in time per frame. Has anyone else experienced this?
BTW, the other 7017s took about 1.5 days to fold on the laptop; this one will take 3.5 days. As a result, projected PPD are among the lowest for any project I will have received in over six months. I intend to follow through folding this WU; however, I'd like someone affiliated with this WU to explain what might have changed with 7017, the last time I folded it. Thanks in advance.
DrBB1
Re: Project: 7017 (Run 2, Clone 369, Gen 70)
To my knowledge, there has never been a case of WUs from the same project that were intended to run at measurably different speeds.
The actual speed that a WU runs depends on a number of factors. (1) Obviously if your hardware changes or if the WU has to share resources with some other processes on your machine, there will be variations. (2) Even with the same number of atoms in a protein, there are minor variations due to the relative positions of those atoms. (Search this forum for the words "folding event") (3) Recently there was some kind of error on one particular server [Not the same project; not the same FahCore; Not the same server] where WUs suddently had the wrong number of steps. I have no reason to believe that's happening to you but if you still have the log files, check the total number of steps in the WUs. That number should always be constant.
There was also a problem detected with some WU's from Projects 7600, 7610 and 7611 where they would also run abnormally long compared to others. The project leader for that group, tjlane, posted here viewtopic.php?f=19&t=20976#p210709 on that. There are some other posts about that as well. I don't know if the same problem as that is showing up with your 7017, but it does use the same A4 core to process.
DrBB1
Post by DrBB1 »
bruce/Joe_H-- Thanks for the input. In case someone can make sense of it, attached is the log file for this WU. My previous folding on the same CPU for Project 7017:
Run 1, Clone 20, Gen 22: Atoms: 572; Frame Time: about 18 min.; Folding Time: about 30 hours.
Run 1, Clone 580, Gen 7: Atoms: 572; Frame Time: about 19 min.; Folding Time: about 31 hours.
Current WU:
Run 2, Clone 369, Gen 70: Atoms: 572; Frame Time: about 46 min.; Folding Time (est.): about 77 hours.
[04:40:24] Completed 1940000 out of 2000000 steps  (97%)
[05:15:03] Completed 1960000 out of 2000000 steps  (98%)
[05:48:55] Completed 1980000 out of 2000000 steps  (99%)
[06:22:45] Completed 2000000 out of 2000000 steps  (100%)
[06:22:46] DynamicWrapper: Finished Work Unit: sleep=10000
[06:22:56]
[06:22:56] Finished Work Unit:
[06:22:57] - Reading up to 664512 from "work/wudata_07.trr": Read 664512
[06:22:57] trr file hash check passed.
[06:22:57] - Reading up to 4074948 from "work/wudata_07.xtc": Read 4074948
[06:22:57] xtc file hash check passed.
[06:22:57] edr file hash check passed.
[06:22:57] logfile size: 47173
[06:22:57] Leaving Run
[06:23:00] - Writing 4788917 bytes of core data to disk...
[06:23:01] Done: 4788405 -> 4743805 (compressed to 99.0 percent)
[06:23:02]   ... Done.
[06:23:05] - Shutting down core
[06:23:05]
[06:23:05] Folding@home Core Shutdown: FINISHED_UNIT
[06:23:08] CoreStatus = 64 (100)
[06:23:08] Unit 7 finished with 83 percent of time to deadline remaining.
[06:23:08] Updated performance fraction: 0.867856
[06:23:08] Sending work to server
[06:23:08] Project: 10433 (Run 238, Clone 0, Gen 55)
[06:23:08] + Attempting to send results [June 22 06:23:08 UTC]
[06:23:08] - Reading file work/wuresults_07.dat from core
[06:23:08]   (Read 4744317 bytes from disk)
[06:23:08] Connecting to http://171.64.65.80:8080/
[06:23:31] Posted data.
[06:23:31] Initial: 0000; - Uploaded at ~201 kB/s
[06:23:31] - Averaged speed for that direction ~207 kB/s
[06:23:31] + Results successfully sent
[06:23:31] Thank you for your contribution to Folding@Home.
[06:23:31] + Number of Units Completed: 1030
[06:23:36] Trying to send all finished work units
[06:23:36] + No unsent completed units remaining.
[06:23:36] - Preparing to get new work unit...
[06:23:36] + Attempting to get work packet
[06:23:36] - Will indicate memory of 3999 MB
[06:23:36] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 7, Stepping: 6
[06:23:36] - Connecting to assignment server
[06:23:36] Connecting to http://assign.stanford.edu:8080/
[06:23:37] Posted data.
[06:23:37] Initial: 4A81; - Successful: assigned to (129.74.85.15).
[06:23:37] + News From Folding@Home: Welcome to Folding@Home
[06:23:37] Loaded queue successfully.
[06:23:37] Connecting to http://129.74.85.15:8080/
[06:23:37] Initial: 0000; - Receiving payload (expected size: 39906)
[06:23:37] Conversation time very short, giving reduced weight in bandwidth avg
[06:23:37] - Downloaded at ~77 kB/s
[06:23:37] - Averaged speed for that direction ~484 kB/s
[06:23:37] + Received work.
[06:23:37] Trying to send all finished work units
[06:23:37] + No unsent completed units remaining.
[06:23:37] + Closed connections
[06:23:37]
[06:23:37] + Processing work unit
[06:23:37] Core required: FahCore_a4.exe
[06:23:37] Core found.
[06:23:37] Working on queue slot 08 [June 22 06:23:37 UTC]
[06:23:37] + Working ...
[06:23:37] - Calling '.\FahCore_a4.exe -dir work/ -suffix 08 -priority 96 -nocpulock -checkpoint 30 -verbose -lifeline 4820 -version 623'
[06:23:38]
[06:23:38] *------------------------------*
[06:23:38] Folding@Home Gromacs GB Core
[06:23:38] Version 2.27 (Dec. 15, 2010)
[06:23:38]
[06:23:38] Preparing to commence simulation
[06:23:38] - Looking at optimizations...
[06:23:38] - Created dyn
[06:23:38] - Files status OK
[06:23:38] - Expanded 39394 -> 202492 (decompressed 514.0 percent)
[06:23:38] Called DecompressByteArray: compressed_data_size=39394 data_size=202492, decompressed_data_size=202492 diff=0
[06:23:38] - Digital signature verified
[06:23:38]
[06:23:38] Project: 7017 (Run 2, Clone 369, Gen 70)
[06:23:38]
[06:23:38] Assembly optimizations on if available.
[06:23:38] Entering M.D.
[06:23:44] Mapping NT from 1 to 1
[06:23:44] Completed 0 out of 10000000 steps  (0%)
[07:09:55] Completed 100000 out of 10000000 steps  (1%)
[07:52:22] ***** Got a SIGTERM signal (2)
[07:52:22] Killing all core threads
Folding@Home Client Shutdown.
--- Opening Log file [June 22 07:52:34 UTC]
# Windows CPU Systray Edition #################################################
                          http://folding.stanford.edu
Launch directory: C:\Users\Bruce\AppData\Roaming\Folding@home-x86
Arguments: -verbosity 9
[07:52:34] - Ask before connecting: No
[07:52:34] - User name: DrBB1 (Team 39340)
[07:52:34] - User ID: B5E074A208A4BE8
[07:52:34] - Machine ID: 3
[07:52:34]
[07:52:34] Loaded queue successfully.
[07:52:34] Initialization complete
[07:52:34]
[07:52:34] + Processing work unit
[07:52:34] - Autosending finished units... [June 22 07:52:34 UTC]
[07:52:34] Trying to send all finished work units
[07:52:34] + No unsent completed units remaining.
[07:52:34] - Autosend completed
[07:52:34] Core required: FahCore_a4.exe
[07:52:34] Core found.
[07:52:34] Working on queue slot 08 [June 22 07:52:34 UTC]
[07:52:34] + Working ...
[07:52:34] - Calling '.\FahCore_a4.exe -dir work/ -suffix 08 -priority 96 -nocpulock -checkpoint 30 -verbose -lifeline 8116 -version 623'
[07:52:35]
[07:52:35] *------------------------------*
[07:52:35] Folding@Home Gromacs GB Core
[07:52:35] Version 2.27 (Dec. 15, 2010)
[07:52:35]
[07:52:35] Preparing to commence simulation
[07:52:35] - Looking at optimizations...
[07:52:35] - Files status OK
[07:52:35] - Expanded 39394 -> 202492 (decompressed 514.0 percent)
[07:52:35] Called DecompressByteArray: compressed_data_size=39394 data_size=202492, decompressed_data_size=202492 diff=0
[07:52:35] - Digital signature verified
[07:52:35]
[07:52:35] Project: 7017 (Run 2, Clone 369, Gen 70)
[07:52:35]
[07:52:35] Assembly optimizations on if available.
[07:52:35] Entering M.D.
[07:52:41] Using Gromacs checkpoints
[07:52:41] Mapping NT from 1 to 1
[07:52:41] Resuming from checkpoint
[07:52:41] Verified work/wudata_08.log
[07:52:41] Verified work/wudata_08.trr
[07:52:41] Verified work/wudata_08.xtc
[07:52:41] Verified work/wudata_08.edr
[07:52:41] Completed 100001 out of 10000000 steps  (1%)
[08:39:52] Completed 200000 out of 10000000 steps  (2%)
[09:26:07] Completed 300000 out of 10000000 steps  (3%)
[10:12:06] Completed 400000 out of 10000000 steps  (4%)
[10:58:02] Completed 500000 out of 10000000 steps  (5%)
[11:43:56] Completed 600000 out of 10000000 steps  (6%)
[12:29:50] Completed 700000 out of 10000000 steps  (7%)
[13:15:45] Completed 800000 out of 10000000 steps  (8%)
[13:52:34] - Autosending finished units... [June 22 13:52:34 UTC]
[13:52:34] Trying to send all finished work units
[13:52:34] + No unsent completed units remaining.
[13:52:34] - Autosend completed
[13:52:34] + Working...
[14:01:40] Completed 900000 out of 10000000 steps  (9%)
[14:51:01] Completed 1000000 out of 10000000 steps  (10%)
[15:42:51] Completed 1100000 out of 10000000 steps  (11%)
[16:30:26] Completed 1200000 out of 10000000 steps  (12%)
[17:18:04] Completed 1300000 out of 10000000 steps  (13%)
[18:01:12] ***** Got a SIGTERM signal (2)
[18:01:12] Killing all core threads
--- Opening Log file [June 22 18:01:33 UTC]
[18:01:33] - Ask before connecting: No
[18:01:33] - User name: DrBB1 (Team 39340)
[18:01:33] - User ID: B5E074A208A4BE8
[18:01:33] - Machine ID: 3
[18:01:33]
[18:01:33] Loaded queue successfully.
[18:01:33] Initialization complete
[18:01:33]
[18:01:33] + Processing work unit
[18:01:33] - Autosending finished units... [June 22 18:01:33 UTC]
[18:01:33] Trying to send all finished work units
[18:01:33] + No unsent completed units remaining.
[18:01:33] - Autosend completed
[18:01:33] Core required: FahCore_a4.exe
[18:01:33] Core found.
[18:01:33] Working on queue slot 08 [June 22 18:01:33 UTC]
[18:01:33] + Working ...
[18:01:33] - Calling '.\FahCore_a4.exe -dir work/ -suffix 08 -priority 96 -nocpulock -checkpoint 30 -verbose -lifeline 6472 -version 623'
[18:01:34]
[18:01:34] *------------------------------*
[18:01:34] Folding@Home Gromacs GB Core
[18:01:34] Version 2.27 (Dec. 15, 2010)
[18:01:34]
[18:01:34] Preparing to commence simulation
[18:01:34] - Looking at optimizations...
[18:01:34] - Files status OK
[18:01:34] - Expanded 39394 -> 202492 (decompressed 514.0 percent)
[18:01:34] Called DecompressByteArray: compressed_data_size=39394 data_size=202492, decompressed_data_size=202492 diff=0
[18:01:34] - Digital signature verified
[18:01:34]
[18:01:34] Project: 7017 (Run 2, Clone 369, Gen 70)
[18:01:34]
[18:01:34] Assembly optimizations on if available.
[18:01:34] Entering M.D.
[18:01:40] Using Gromacs checkpoints
[18:01:40] Mapping NT from 1 to 1
[18:01:40] Resuming from checkpoint
[18:01:40] Verified work/wudata_08.log
[18:01:40] Verified work/wudata_08.trr
[18:01:40] Verified work/wudata_08.xtc
[18:01:40] Verified work/wudata_08.edr
[18:01:40] Completed 1300001 out of 10000000 steps  (13%)
[18:48:34] Completed 1400000 out of 10000000 steps  (14%)
[19:35:45] Completed 1500000 out of 10000000 steps  (15%)
[20:24:10] Completed 1600000 out of 10000000 steps  (16%)
[21:11:39] Completed 1700000 out of 10000000 steps  (17%)
[21:19:12] ***** Got a SIGTERM signal (2)
[21:19:12] Killing all core threads
--- Opening Log file [June 22 23:23:28 UTC]
[23:23:28] - Ask before connecting: No
[23:23:28] - User name: DrBB1 (Team 39340)
[23:23:28] - User ID: B5E074A208A4BE8
[23:23:28] - Machine ID: 3
[23:23:28]
[23:23:28] Loaded queue successfully.
[23:23:28] Initialization complete
[23:23:28]
[23:23:28] + Processing work unit
[23:23:28] - Autosending finished units... [June 22 23:23:28 UTC]
[23:23:28] Trying to send all finished work units
[23:23:28] + No unsent completed units remaining.
[23:23:28] - Autosend completed
[23:23:28] Core required: FahCore_a4.exe
[23:23:28] Core found.
[23:23:28] Working on queue slot 08 [June 22 23:23:28 UTC]
[23:23:28] + Working ...
[23:23:28] - Calling '.\FahCore_a4.exe -dir work/ -suffix 08 -priority 96 -nocpulock -checkpoint 30 -verbose -lifeline 6696 -version 623'
[23:23:29]
[23:23:29] *------------------------------*
[23:23:29] Folding@Home Gromacs GB Core
[23:23:29] Version 2.27 (Dec. 15, 2010)
[23:23:29]
[23:23:29] Preparing to commence simulation
[23:23:29] - Looking at optimizations...
[23:23:29] - Files status OK
[23:23:29] - Expanded 39394 -> 202492 (decompressed 514.0 percent)
[23:23:29] Called DecompressByteArray: compressed_data_size=39394 data_size=202492, decompressed_data_size=202492 diff=0
[23:23:29] - Digital signature verified
[23:23:29]
[23:23:29] Project: 7017 (Run 2, Clone 369, Gen 70)
[23:23:29]
[23:23:29] Assembly optimizations on if available.
[23:23:29] Entering M.D.
[23:23:35] Using Gromacs checkpoints
[23:23:35] Mapping NT from 1 to 1
[23:23:35] Resuming from checkpoint
[23:23:35] Verified work/wudata_08.log
[23:23:35] Verified work/wudata_08.trr
[23:23:35] Verified work/wudata_08.xtc
[23:23:36] Verified work/wudata_08.edr
[23:23:36] Completed 1700001 out of 10000000 steps  (17%)
[00:10:57] Completed 1800000 out of 10000000 steps  (18%)
[00:58:18] Completed 1900000 out of 10000000 steps  (19%)
[01:46:16] Completed 2000000 out of 10000000 steps  (20%)
[02:40:40] ***** Got a SIGTERM signal (2)
[02:40:40] Killing all core threads
--- Opening Log file [June 23 02:40:48 UTC]
[02:40:48] - Ask before connecting: No
[02:40:48] - User name: DrBB1 (Team 39340)
[02:40:48] - User ID: B5E074A208A4BE8
[02:40:48] - Machine ID: 3
[02:40:48]
[02:40:48] Loaded queue successfully.
[02:40:48] Initialization complete
[02:40:48]
[02:40:48] + Processing work unit
[02:40:48] - Autosending finished units... [June 23 02:40:48 UTC]
[02:40:48] Trying to send all finished work units
[02:40:48] + No unsent completed units remaining.
[02:40:48] - Autosend completed
[02:40:48] Core required: FahCore_a4.exe
[02:40:48] Core found.
[02:40:48] Working on queue slot 08 [June 23 02:40:48 UTC]
[02:40:48] + Working ...
[02:40:48] - Calling '.\FahCore_a4.exe -dir work/ -suffix 08 -priority 96 -nocpulock -checkpoint 30 -verbose -lifeline 7980 -version 623'
[02:40:49]
[02:40:49] *------------------------------*
[02:40:49] Folding@Home Gromacs GB Core
[02:40:49] Version 2.27 (Dec. 15, 2010)
[02:40:49]
[02:40:49] Preparing to commence simulation
[02:40:49] - Looking at optimizations...
[02:40:49] - Files status OK
[02:40:49] - Expanded 39394 -> 202492 (decompressed 514.0 percent)
[02:40:49] Called DecompressByteArray: compressed_data_size=39394 data_size=202492, decompressed_data_size=202492 diff=0
[02:40:49] - Digital signature verified
[02:40:49]
[02:40:49] Project: 7017 (Run 2, Clone 369, Gen 70)
[02:40:49]
[02:40:49] Assembly optimizations on if available.
[02:40:49] Entering M.D.
[02:40:55] Using Gromacs checkpoints
[02:40:55] Mapping NT from 1 to 1
[02:40:55] Resuming from checkpoint
[02:40:55] Verified work/wudata_08.log
[02:40:55] Verified work/wudata_08.trr
[02:40:55] Verified work/wudata_08.xtc
[02:40:55] Verified work/wudata_08.edr
[02:40:55] Completed 2000001 out of 10000000 steps  (20%)
[03:31:27] Completed 2100000 out of 10000000 steps  (21%)
[04:23:39] ***** Got a SIGTERM signal (2)
[04:23:39] Killing all core threads
--- Opening Log file [June 23 06:28:12 UTC]
[06:28:12] - Ask before connecting: No
[06:28:12] - User name: DrBB1 (Team 39340)
[06:28:12] - User ID: B5E074A208A4BE8
[06:28:12] - Machine ID: 3
[06:28:12]
[06:28:13] Loaded queue successfully.
[06:28:13] Initialization complete
[06:28:13]
[06:28:13] + Processing work unit
[06:28:13] - Autosending finished units... [June 23 06:28:13 UTC]
[06:28:13] Trying to send all finished work units
[06:28:13] + No unsent completed units remaining.
[06:28:13] - Autosend completed
[06:28:13] Core required: FahCore_a4.exe
[06:28:13] Core found.
[06:28:13] Working on queue slot 08 [June 23 06:28:13 UTC]
[06:28:13] + Working ...
[06:28:13] - Calling '.\FahCore_a4.exe -dir work/ -suffix 08 -priority 96 -nocpulock -checkpoint 30 -verbose -lifeline 4732 -version 623'
[06:28:13]
[06:28:13] *------------------------------*
[06:28:13] Folding@Home Gromacs GB Core
[06:28:13] Version 2.27 (Dec. 15, 2010)
[06:28:13]
[06:28:13] Preparing to commence simulation
[06:28:13] - Looking at optimizations...
[06:28:13] - Files status OK
[06:28:13] - Expanded 39394 -> 202492 (decompressed 514.0 percent)
[06:28:13] Called DecompressByteArray: compressed_data_size=39394 data_size=202492, decompressed_data_size=202492 diff=0
[06:28:13] - Digital signature verified
[06:28:13]
[06:28:13] Project: 7017 (Run 2, Clone 369, Gen 70)
[06:28:13]
[06:28:13] Assembly optimizations on if available.
[06:28:13] Entering M.D.
[06:28:20] Using Gromacs checkpoints
[06:28:20] Mapping NT from 1 to 1
[06:28:20] Resuming from checkpoint
[06:28:20] Verified work/wudata_08.log
[06:28:20] Verified work/wudata_08.trr
[06:28:20] Verified work/wudata_08.xtc
[06:28:20] Verified work/wudata_08.edr
[06:28:20] Completed 2100001 out of 10000000 steps  (21%)
[07:15:28] Completed 2200000 out of 10000000 steps  (22%)
[08:01:17] Completed 2300000 out of 10000000 steps  (23%)
[08:47:04] Completed 2400000 out of 10000000 steps  (24%)
[09:33:08] Completed 2500000 out of 10000000 steps  (25%)
[10:18:52] Completed 2600000 out of 10000000 steps  (26%)
[11:04:35] Completed 2700000 out of 10000000 steps  (27%)
[11:50:22] Completed 2800000 out of 10000000 steps  (28%)
[12:28:13] - Autosending finished units... [June 23 12:28:13 UTC]
[12:28:13] Trying to send all finished work units
[12:28:13] + No unsent completed units remaining.
[12:28:13] - Autosend completed
[12:28:13] + Working...
[12:36:05] Completed 2900000 out of 10000000 steps  (29%)
[13:21:54] Completed 3000000 out of 10000000 steps  (30%)
[14:07:35] Completed 3100000 out of 10000000 steps  (31%)
[14:53:21] Completed 3200000 out of 10000000 steps  (32%)
[15:39:05] Completed 3300000 out of 10000000 steps  (33%)
[16:24:49] Completed 3400000 out of 10000000 steps  (34%)
[17:12:06] Completed 3500000 out of 10000000 steps  (35%)
[18:01:03] Completed 3600000 out of 10000000 steps  (36%)
[18:28:13] - Autosending finished units... [June 23 18:28:13 UTC]
[18:28:13] Trying to send all finished work units
[18:28:13] + No unsent completed units remaining.
[18:28:13] - Autosend completed
[18:28:13] + Working...
[18:49:29] Completed 3700000 out of 10000000 steps  (37%)
[19:40:00] Completed 3800000 out of 10000000 steps  (38%)
[20:25:44] Completed 3900000 out of 10000000 steps  (39%)
[21:11:32] Completed 4000000 out of 10000000 steps  (40%)
[21:57:15] Completed 4100000 out of 10000000 steps  (41%)
[22:42:58] Completed 4200000 out of 10000000 steps  (42%)
[23:28:44] Completed 4300000 out of 10000000 steps  (43%)
[00:14:26] Completed 4400000 out of 10000000 steps  (44%)
[00:28:13] - Autosending finished units... [June 24 00:28:13 UTC]
[00:28:13] Trying to send all finished work units
[00:28:13] + No unsent completed units remaining.
[00:28:13] - Autosend completed
[00:28:13] + Working...
[01:00:10] Completed 4500000 out of 10000000 steps  (45%)
[01:45:55] Completed 4600000 out of 10000000 steps  (46%)
[02:32:27] Completed 4700000 out of 10000000 steps  (47%)
[03:20:01] Completed 4800000 out of 10000000 steps  (48%)
[04:06:17] Completed 4900000 out of 10000000 steps  (49%)
[04:52:10] Completed 5000000 out of 10000000 steps  (50%)
[05:38:04] Completed 5100000 out of 10000000 steps  (51%)
[06:23:56] Completed 5200000 out of 10000000 steps  (52%)
[06:28:13] - Autosending finished units... [June 24 06:28:13 UTC]
[06:28:13] + Working...
[07:16:57] Completed 5300000 out of 10000000 steps  (53%)
[08:04:01] Completed 5400000 out of 10000000 steps  (54%)
[08:50:45] Completed 5500000 out of 10000000 steps  (55%)
[09:39:58] Completed 5600000 out of 10000000 steps  (56%)
[10:31:06] Completed 5700000 out of 10000000 steps  (57%)
[11:18:15] Completed 5800000 out of 10000000 steps  (58%)
[12:05:00] Completed 5900000 out of 10000000 steps  (59%)
[12:28:13] - Autosending finished units... [June 24 12:28:13 UTC]
[12:51:47] Completed 6000000 out of 10000000 steps  (60%)
[13:38:33] Completed 6100000 out of 10000000 steps  (61%)
[14:26:31] Completed 6200000 out of 10000000 steps  (62%)
[15:14:19] Completed 6300000 out of 10000000 steps  (63%)
[16:02:02] Completed 6400000 out of 10000000 steps  (64%)
[16:49:46] Completed 6500000 out of 10000000 steps  (65%)
[17:37:28] Completed 6600000 out of 10000000 steps  (66%)
[18:24:14] Completed 6700000 out of 10000000 steps  (67%)
[18:28:13] - Autosending finished units... [June 24 18:28:13 UTC]
[19:10:20] Completed 6800000 out of 10000000 steps  (68%)
[19:56:28] Completed 6900000 out of 10000000 steps  (69%)
[20:42:38] Completed 7000000 out of 10000000 steps  (70%)
[21:28:44] Completed 7100000 out of 10000000 steps  (71%)
[22:14:47] Completed 7200000 out of 10000000 steps  (72%)
[23:00:47] Completed 7300000 out of 10000000 steps  (73%)
[23:46:47] Completed 7400000 out of 10000000 steps  (74%)
[00:28:13] - Autosending finished units... [June 25 00:28:13 UTC]
Is there anyone in particular I should notify about this, or is this thread enough to have an appropriate person check out the WU?
DrBB1
This thread is enough.
Did (1,20,22) and (1,580,7) also say "...out of 2000000 steps." like the log shows for (2,369,70)
By the way, only Project 7017, Run 1, Clone 580, Gen 7 seems to be credited to DrBB1. the other two were completed by someone else.
DrBB1
Post by DrBB1 »
bruce--
I don't have old log files, so I can't answer your first question. Both were folded late 2011/early 2012.
My bad: Should have been (1,30,22). :oops: Also, (2,369,70) is the WU currently folding--in progress (89% complete; ETA about 9 hours).
DrBB1
Yes, you received credit for P7017 R1 C30 G22 though there's some strange annotation in the file. According to the server, it took you 1.76 days to complete the WU.
DrBB1
Post by DrBB1 »
I don't know what that annotation is about. HFM.NET shows that from download to completion was 1 day, 7 hours, 2 minutes. bruce-- is the annotation automated, or is this something added to the file manually?
Does this combination (annotation and extended folding time) reflect other unpublished issues with Project 7017 suggesting instability--or am I just that lucky guy to have two coincidences happen on different runs of the same project? [No need to answer....]Image
BTW: Run 2, Clone 369, Gen 70 is now complete. TPF: 47.22 min. Am now folding Project 7005 at a TPF of about 19 min, comparable to the 18 min. I have seen with another 7005 I have folded on this CPU. Presumably this suggests a problem with the 7017 gen I just completed, or (less likely) a unique interaction between the gen and my CPU, since things seem now to be stable on my end.
Thanks for your help and patience.
DrBB1
From the part of the credit record I can see, both of these reports WU look "normal" though the duration is, as you say, different.
Hi DrBB1 (team 39340),
Your WU (P7017 R2 C369 G70) was added to the stats database on 2012-06-25 14:07:30 for 907.8 points of credit.
Days taken to complete WU: 3.61
It most definitely took longer than
Your WU (P7017 R1 C580 G7) was added to the stats database on 2011-12-31 10:10:22 for 1162.8 points of credit.
Days taken to complete WU: 2.22
and the strange annotation has been removed. I don't know what it meant, how it changed, or why.
DrBB1
Post by DrBB1 »
[spooky music] "... The Shadow knows...." :twisted:
bruce-- Thanks for your help!
DrBB1
heikosch
Hardware configuration: i7-3930K@4.1GHz
GTX680@1.275GHz
Q9300@2.4GHz
GTX460@800MHz
Post by heikosch »
My i7-3930K@4.1GHz got a P7017 (1, 199, 24) and runs it with PPD 7300 (TPF 5:30 min).
That is far below normal PPD (22000-28000) of the SMP client.
Heiko
Image Image
DrBB1
Post by DrBB1 »
Hi Heiko-- When I posted this problem in June, I was running the V6, CPU client. I have since updated to V7, and my processing intensity and PPD have increased immensely. I think this was either a unique case or--though I don't know if this turned out to be the issue--a problem with Gen 70. Also, my equipment is older and slower than yours, anyway, so I would guess that if I were to get a 7017 again--all things being equal--I would improve my performance, but not to the extent that you have achieved.
DrBB1
