Server responded: UNKNOWN_ENUM
cheapie
Post by cheapie »
02:43:05:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
02:43:18:WU01:FS01:Connecting to assign3.stanford.edu:8080
02:43:19:WU00:FS00:News: Welcome to Folding@Home
02:43:19:WU00:FS00:Assigned to work server 171.67.108.44
02:43:19:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
02:43:19:WU00:FS00:Connecting to 171.67.108.44:8080
02:43:36:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
02:43:36:WU01:FS01:Connecting to assign4.stanford.edu:80
02:43:37:ERROR:WU00:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
02:43:49:WU01:FS01:News: Welcome to Folding@Home
02:43:49:WU01:FS01:Assigned to work server 171.64.65.101
02:43:52:WU01:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
02:43:52:WU01:FS01:Connecting to 171.64.65.101:8080
02:44:10:ERROR:WU01:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
02:45:42:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
02:45:55:WU00:FS00:News: Welcome to Folding@Home
02:45:55:WU00:FS00:Assigned to work server 171.67.108.44
02:45:55:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
02:45:55:WU00:FS00:Connecting to 171.67.108.44:8080
02:45:55:WU01:FS01:Connecting to assign3.stanford.edu:8080
02:46:15:ERROR:WU00:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
02:46:15:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
02:46:15:WU01:FS01:Connecting to assign4.stanford.edu:80
02:46:29:WU01:FS01:News: Welcome to Folding@Home
02:46:29:WU01:FS01:Assigned to work server 171.64.65.101
02:46:29:WU01:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
02:46:29:WU01:FS01:Connecting to 171.64.65.101:8080
02:46:50:ERROR:WU01:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
Re: Server responded: UNKNOWN_ENUM
Please post the first couple hundred lines in the log where your installation details are reported.
cheapie
Post by cheapie »
Here's the full log:
*********************** Log Started 2012-06-22T02:39:52Z ***********************
02:39:52:************************* Folding@home Client *************************
02:39:52:      Website: http://folding.stanford.edu/
02:39:52:    Copyright: (c) 2009-2012 Stanford University
02:39:52:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:39:52:         Args: --lifeline 4312 --command-port=36330
02:39:52:       Config: C:/ProgramData/FAHClient/config.xml
02:39:52:******************************** Build ********************************
02:39:52:      Version: 7.1.52
02:39:52:         Date: Mar 20 2012
02:39:52:         Time: 19:37:42
02:39:52:      SVN Rev: 3515
02:39:52:       Branch: fah/trunk/client
02:39:52:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
02:39:52:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
02:39:52:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
02:39:52:     Platform: win32 XP
02:39:52:         Bits: 32
02:39:52:         Mode: Release
02:39:52:******************************* System ********************************
02:39:52:          CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 5400+
02:39:52:       CPU ID: AuthenticAMD Family 15 Model 107 Stepping 2
02:39:52:         CPUs: 2
02:39:52:       Memory: 2.00GiB
02:39:52:  Free Memory: 866.88MiB
02:39:52:      Threads: WINDOWS_THREADS
02:39:52:   On Battery: false
02:39:52:   UTC offset: -5
02:39:52:          PID: 1916
02:39:52:          CWD: C:/ProgramData/FAHClient
02:39:52:           OS: Windows 7 Ultimate
02:39:52:      OS Arch: AMD64
02:39:52:         GPUs: 1
02:39:52:        GPU 0: ATI:4 NI Turks [AMD Radeon HD 6500]
02:39:52:         CUDA: Not detected
02:39:52:Win32 Service: false
02:39:52:***********************************************************************
02:39:52:<config>
02:39:52:  <service-description v='Folding@home Client'/>
02:39:52:  <service-restart v='true'/>
02:39:52:  <service-restart-delay v='5000'/>
02:39:52:
02:39:52:  <!-- Client Control -->
02:39:52:  <cycle-rate v='4'/>
02:39:52:  <cycles v='-1'/>
02:39:52:  <data-directory v='.'/>
02:39:52:  <disable-project-lookup v='false'/>
02:39:52:  <exec-directory v='C:\Program Files (x86)\FAHClient'/>
02:39:52:  <exit-when-done v='false'/>
02:39:52:  <threads v='4'/>
02:39:52:
02:39:52:  <!-- Configuration -->
02:39:52:  <config-rotate v='true'/>
02:39:52:  <config-rotate-dir v='configs'/>
02:39:52:  <config-rotate-max v='16'/>
02:39:52:
02:39:52:  <!-- Debugging -->
02:39:52:  <assignment-servers>
02:39:52:    assign3.stanford.edu:8080 assign4.stanford.edu:80
02:39:52:  </assignment-servers>
02:39:52:  <capture-directory v='capture'/>
02:39:52:  <capture-sockets v='false'/>
02:39:52:  <debug-sockets v='false'/>
02:39:52:  <exception-locations v='true'/>
02:39:52:  <gpu-assignment-servers>
02:39:52:    assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
02:39:52:  </gpu-assignment-servers>
02:39:52:  <stack-traces v='false'/>
02:39:52:
02:39:52:  <!-- Error Handling -->
02:39:52:  <max-slot-errors v='5'/>
02:39:52:  <max-unit-errors v='5'/>
02:39:52:
02:39:52:  <!-- FahCore Control -->
02:39:52:  <checkpoint v='15'/>
02:39:52:  <core-dir v='cores'/>
02:39:52:  <core-priority v='idle'/>
02:39:52:  <cpu-affinity v='false'/>
02:39:52:  <cpu-usage v='100'/>
02:39:52:  <no-assembly v='false'/>
02:39:52:
02:39:52:  <!-- Folding Slot Configuration -->
02:39:52:  <client-subtype v='STDCLI'/>
02:39:52:  <client-type v='normal'/>
02:39:52:  <cpu-species v='X86_AMD'/>
02:39:52:  <cpu-type v='AMD64'/>
02:39:52:  <cpus v='-1'/>
02:39:52:  <cuda-index v='0'/>
02:39:52:  <gpu v='true'/>
02:39:52:  <gpu-usage v='100'/>
02:39:52:  <max-packet-size v='normal'/>
02:39:52:  <opencl-index v='0'/>
02:39:52:  <os-species v='UNKNOWN'/>
02:39:52:  <os-type v='WIN32'/>
02:39:52:  <project-key v='0'/>
02:39:52:  <smp v='true'/>
02:39:52:
02:39:52:  <!-- Logging -->
02:39:52:  <log v='log.txt'/>
02:39:52:  <log-color v='false'/>
02:39:52:  <log-crlf v='true'/>
02:39:52:  <log-date v='false'/>
02:39:52:  <log-date-periodically v='21600'/>
02:39:52:  <log-debug v='true'/>
02:39:52:  <log-domain v='false'/>
02:39:52:  <log-header v='true'/>
02:39:52:  <log-level v='true'/>
02:39:52:  <log-no-info-header v='true'/>
02:39:52:  <log-redirect v='false'/>
02:39:52:  <log-rotate v='true'/>
02:39:52:  <log-rotate-dir v='logs'/>
02:39:52:  <log-rotate-max v='16'/>
02:39:52:  <log-short-level v='false'/>
02:39:52:  <log-simple-domains v='true'/>
02:39:52:  <log-thread-id v='false'/>
02:39:52:  <log-thread-prefix v='true'/>
02:39:52:  <log-time v='true'/>
02:39:52:  <log-to-screen v='true'/>
02:39:52:  <log-truncate v='false'/>
02:39:52:  <verbosity v='5'/>
02:39:52:
02:39:52:  <!-- Network -->
02:39:52:  <proxy v=':8080'/>
02:39:52:  <proxy-enable v='false'/>
02:39:52:  <proxy-pass v=''/>
02:39:52:  <proxy-user v=''/>
02:39:52:
02:39:52:  <!-- Process Control -->
02:39:52:  <child v='false'/>
02:39:52:  <daemon v='false'/>
02:39:52:  <pid v='false'/>
02:39:52:  <pid-file v='Folding@home Client.pid'/>
02:39:52:  <respawn v='false'/>
02:39:52:  <service v='false'/>
02:39:52:
02:39:52:  <!-- Remote Command Server -->
02:39:52:  <command-address v='0.0.0.0'/>
02:39:52:  <command-allow v='127.0.0.1'/>
02:39:52:  <command-allow-no-pass v='127.0.0.1'/>
02:39:52:  <command-deny v='0.0.0.0/0'/>
02:39:52:  <command-deny-no-pass v='0.0.0.0/0'/>
02:39:52:  <command-port v='36330'/>
02:39:52:
02:39:52:  <!-- Slot Control -->
02:39:52:  <max-shutdown-wait v='60'/>
02:39:52:  <pause-on-battery v='false'/>
02:39:52:  <pause-on-start v='false'/>
02:39:52:
02:39:52:  <!-- User Information -->
02:39:52:  <machine-id v='0'/>
02:39:52:  <passkey v=''/>
02:39:52:  <team v='0'/>
02:39:52:  <user v='Anonymous'/>
02:39:52:
02:39:52:  <!-- Work Unit Control -->
02:39:52:  <dump-after-deadline v='true'/>
02:39:52:  <max-queue v='16'/>
02:39:52:  <max-units v='0'/>
02:39:52:  <next-unit-percentage v='99'/>
02:39:52:
02:39:52:  <!-- Folding Slots -->
02:39:52:  <slot id='0' type='GPU'/>
02:39:52:  <slot id='1' type='SMP'/>
02:39:52:</config>
02:39:52:Trying to access database...
02:39:52:Successfully acquired database lock
02:39:52:Enabled folding slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]"
02:39:52:Enabled folding slot 01: READY smp:2
02:39:52:Started thread 1 on PID 1916
02:39:52:Started thread 5 on PID 1916
02:39:52:Started thread 3 on PID 1916
02:39:52:Started thread 6 on PID 1916
02:39:52:Started thread 4 on PID 1916
02:39:52:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
02:39:52:WU01:FS01:Connecting to assign3.stanford.edu:8080
02:39:54:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
02:39:54:Started thread 7 on PID 1916
02:40:10:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': 10001: Server responded: UNKNOWN_ENUM
02:40:10:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
02:40:11:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
02:40:11:WU01:FS01:Connecting to assign4.stanford.edu:80
02:40:23:WU01:FS01:News: Welcome to Folding@Home
02:40:23:WU01:FS01:Assigned to work server 171.64.65.101
02:40:23:WU01:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
02:40:23:WU01:FS01:Connecting to 171.64.65.101:8080
02:40:28:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
02:40:28:ERROR:WU00:FS00:Exception: Could not get an assignment
02:40:28:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
02:40:40:WU00:FS00:News: Welcome to Folding@Home
02:40:40:WU00:FS00:Assigned to work server 171.67.108.44
02:40:40:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
02:40:40:WU00:FS00:Connecting to 171.67.108.44:8080
02:40:41:ERROR:WU01:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
02:40:41:WU01:FS01:Connecting to assign3.stanford.edu:8080
02:40:58:ERROR:WU00:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
02:40:58:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
02:40:58:WU01:FS01:Connecting to assign4.stanford.edu:80
02:41:11:WU01:FS01:News: Welcome to Folding@Home
02:41:11:WU01:FS01:Assigned to work server 171.64.65.101
02:41:11:WU01:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
02:41:11:WU01:FS01:Connecting to 171.64.65.101:8080
02:41:28:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
02:41:29:ERROR:WU01:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
02:41:41:WU01:FS01:Connecting to assign3.stanford.edu:8080
02:41:44:WU00:FS00:News: Welcome to Folding@Home
02:41:44:WU00:FS00:Assigned to work server 171.67.108.44
02:41:44:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
02:41:44:WU00:FS00:Connecting to 171.67.108.44:8080
02:41:59:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
02:41:59:WU01:FS01:Connecting to assign4.stanford.edu:80
02:42:02:ERROR:WU00:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
02:42:15:WU01:FS01:News: Welcome to Folding@Home
02:42:15:WU01:FS01:Assigned to work server 171.64.65.101
02:42:15:WU01:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
02:42:15:WU01:FS01:Connecting to 171.64.65.101:8080
02:42:32:ERROR:WU01:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
02:42:54:Saving configuration to config.xml
02:42:54:<config>
02:42:54:  <!-- FahCore Control -->
02:42:54:  <no-assembly v='true'/>
02:42:54:
02:42:54:  <!-- Folding Slot Configuration -->
02:42:54:  <gpu v='true'/>
02:42:54:
02:42:54:  <!-- Logging -->
02:42:54:  <verbosity v='5'/>
02:42:54:
02:42:54:  <!-- Network -->
02:42:54:  <proxy v=':8080'/>
02:42:54:
02:42:54:  <!-- Folding Slots -->
02:42:54:  <slot id='0' type='GPU'/>
02:42:54:  <slot id='1' type='SMP'/>
02:42:54:</config>
02:49:57:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
02:50:10:WU01:FS01:Connecting to assign3.stanford.edu:8080
02:50:12:WU00:FS00:News: Welcome to Folding@Home
02:50:12:WU00:FS00:Assigned to work server 171.67.108.44
02:50:12:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
02:50:12:WU00:FS00:Connecting to 171.67.108.44:8080
02:50:28:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
02:50:28:WU01:FS01:Connecting to assign4.stanford.edu:80
02:50:30:ERROR:WU00:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
02:50:41:WU01:FS01:News: Welcome to Folding@Home
02:50:41:WU01:FS01:Assigned to work server 171.64.65.101
02:50:44:WU01:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
02:50:44:WU01:FS01:Connecting to 171.64.65.101:8080
02:51:03:ERROR:WU01:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
02:51:03:WU01:FS01:Cleaning up
02:51:03:WU02:FS01:Connecting to assign3.stanford.edu:8080
02:51:23:WARNING:WU02:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
02:51:23:WU02:FS01:Connecting to assign4.stanford.edu:80
02:51:36:WU02:FS01:News: Welcome to Folding@Home
02:51:36:WU02:FS01:Assigned to work server 171.64.65.101
02:51:36:WU02:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
02:51:36:WU02:FS01:Connecting to 171.64.65.101:8080
02:51:54:ERROR:WU02:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
02:51:55:WU02:FS01:Connecting to assign3.stanford.edu:8080
02:52:14:WARNING:WU02:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
02:52:14:WU02:FS01:Connecting to assign4.stanford.edu:80
02:52:29:WU02:FS01:News: Welcome to Folding@Home
02:52:29:WU02:FS01:Assigned to work server 171.64.65.101
02:52:29:WU02:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
02:52:29:WU02:FS01:Connecting to 171.64.65.101:8080
02:52:47:ERROR:WU02:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
02:52:55:WU02:FS01:Connecting to assign3.stanford.edu:8080
02:53:15:WARNING:WU02:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
02:53:15:WU02:FS01:Connecting to assign4.stanford.edu:80
02:53:29:WU02:FS01:News: Welcome to Folding@Home
02:53:29:WU02:FS01:Assigned to work server 171.64.65.101
02:53:29:WU02:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
02:53:29:WU02:FS01:Connecting to 171.64.65.101:8080
02:53:48:ERROR:WU02:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
02:54:32:WU02:FS01:Connecting to assign3.stanford.edu:8080
02:54:52:WARNING:WU02:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
02:54:52:WU02:FS01:Connecting to assign4.stanford.edu:80
02:55:07:WU02:FS01:News: Welcome to Folding@Home
02:55:07:WU02:FS01:Assigned to work server 171.64.65.101
02:55:07:WU02:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
02:55:07:WU02:FS01:Connecting to 171.64.65.101:8080
02:55:26:ERROR:WU02:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
02:56:48:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
02:57:02:WU00:FS00:News: Welcome to Folding@Home
02:57:02:WU00:FS00:Assigned to work server 171.67.108.44
02:57:02:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
02:57:02:WU00:FS00:Connecting to 171.67.108.44:8080
02:57:09:WU02:FS01:Connecting to assign3.stanford.edu:8080
02:57:21:ERROR:WU00:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
02:57:21:WU00:FS00:Cleaning up
02:57:21:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
02:57:29:WARNING:WU02:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
02:57:29:WU02:FS01:Connecting to assign4.stanford.edu:80
02:57:35:WU01:FS00:News: Welcome to Folding@Home
02:57:35:WU01:FS00:Assigned to work server 171.67.108.44
02:57:35:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
02:57:35:WU01:FS00:Connecting to 171.67.108.44:8080
02:57:43:WU02:FS01:News: Welcome to Folding@Home
02:57:43:WU02:FS01:Assigned to work server 171.64.65.101
02:57:44:WU02:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
02:57:44:WU02:FS01:Connecting to 171.64.65.101:8080
02:57:54:ERROR:WU01:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
02:57:54:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
02:58:03:ERROR:WU02:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
02:58:08:WU01:FS00:News: Welcome to Folding@Home
02:58:08:WU01:FS00:Assigned to work server 171.67.108.44
02:58:08:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
02:58:08:WU01:FS00:Connecting to 171.67.108.44:8080
02:58:37:ERROR:WU01:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
02:58:54:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
02:59:08:WU01:FS00:News: Welcome to Folding@Home
02:59:08:WU01:FS00:Assigned to work server 171.67.108.44
02:59:09:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
02:59:09:WU01:FS00:Connecting to 171.67.108.44:8080
02:59:28:ERROR:WU01:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:00:32:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
03:00:47:WU01:FS00:News: Welcome to Folding@Home
03:00:47:WU01:FS00:Assigned to work server 171.67.108.44
03:00:47:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:00:47:WU01:FS00:Connecting to 171.67.108.44:8080
03:01:06:ERROR:WU01:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:01:24:WU02:FS01:Connecting to assign3.stanford.edu:8080
03:01:44:WARNING:WU02:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:01:44:WU02:FS01:Connecting to assign4.stanford.edu:80
03:01:58:WU02:FS01:News: Welcome to Folding@Home
03:01:58:WU02:FS01:Assigned to work server 171.64.65.101
03:01:58:WU02:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:01:58:WU02:FS01:Connecting to 171.64.65.101:8080
03:02:17:ERROR:WU02:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:02:17:WU02:FS01:Cleaning up
03:02:17:WU00:FS01:Connecting to assign3.stanford.edu:8080
03:02:37:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:02:37:WU00:FS01:Connecting to assign4.stanford.edu:80
03:02:51:WU00:FS01:News: Welcome to Folding@Home
03:02:51:WU00:FS01:Assigned to work server 171.64.65.101
03:02:51:WU00:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:02:51:WU00:FS01:Connecting to 171.64.65.101:8080
03:03:09:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
03:03:10:ERROR:WU00:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:03:10:WU00:FS01:Connecting to assign3.stanford.edu:8080
03:03:24:WU01:FS00:News: Welcome to Folding@Home
03:03:24:WU01:FS00:Assigned to work server 171.67.108.44
03:03:24:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:03:24:WU01:FS00:Connecting to 171.67.108.44:8080
03:03:29:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:03:29:WU00:FS01:Connecting to assign4.stanford.edu:80
03:03:43:WU00:FS01:News: Welcome to Folding@Home
03:03:43:WU00:FS01:Assigned to work server 171.64.65.101
03:03:43:WU00:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:03:43:WU00:FS01:Connecting to 171.64.65.101:8080
03:03:43:ERROR:WU01:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:04:02:ERROR:WU00:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:04:11:WU00:FS01:Connecting to assign3.stanford.edu:8080
03:04:31:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:04:31:WU00:FS01:Connecting to assign4.stanford.edu:80
03:04:45:WU00:FS01:News: Welcome to Folding@Home
03:04:45:WU00:FS01:Assigned to work server 171.64.65.101
03:04:45:WU00:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:04:45:WU00:FS01:Connecting to 171.64.65.101:8080
03:05:04:ERROR:WU00:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:05:48:WU00:FS01:Connecting to assign3.stanford.edu:8080
03:06:07:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:06:07:WU00:FS01:Connecting to assign4.stanford.edu:80
03:06:21:WU00:FS01:News: Welcome to Folding@Home
03:06:21:WU00:FS01:Assigned to work server 171.64.65.101
03:06:22:WU00:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:06:22:WU00:FS01:Connecting to 171.64.65.101:8080
03:06:42:ERROR:WU00:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:07:23:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
03:07:37:WU01:FS00:News: Welcome to Folding@Home
03:07:37:WU01:FS00:Assigned to work server 171.67.108.44
03:07:38:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:07:38:WU01:FS00:Connecting to 171.67.108.44:8080
03:07:58:ERROR:WU01:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:07:58:WU01:FS00:Cleaning up
03:07:58:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
03:08:12:WU02:FS00:News: Welcome to Folding@Home
03:08:12:WU02:FS00:Assigned to work server 171.67.108.44
03:08:12:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:08:12:WU02:FS00:Connecting to 171.67.108.44:8080
03:08:25:WU00:FS01:Connecting to assign3.stanford.edu:8080
03:08:31:ERROR:WU02:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:08:31:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
03:08:45:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:08:45:WU02:FS00:News: Welcome to Folding@Home
03:08:45:WU00:FS01:Connecting to assign4.stanford.edu:80
03:08:45:WU02:FS00:Assigned to work server 171.67.108.44
03:08:45:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:08:45:WU02:FS00:Connecting to 171.67.108.44:8080
03:08:59:WU00:FS01:News: Welcome to Folding@Home
03:08:59:WU00:FS01:Assigned to work server 171.64.65.101
03:08:59:WU00:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:08:59:WU00:FS01:Connecting to 171.64.65.101:8080
03:09:05:ERROR:WU02:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:09:19:ERROR:WU00:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:09:31:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
03:09:46:WU02:FS00:News: Welcome to Folding@Home
03:09:46:WU02:FS00:Assigned to work server 171.67.108.44
03:09:46:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:09:46:WU02:FS00:Connecting to 171.67.108.44:8080
03:10:04:ERROR:WU02:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:11:08:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
03:11:22:WU02:FS00:News: Welcome to Folding@Home
03:11:22:WU02:FS00:Assigned to work server 171.67.108.44
03:11:23:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:11:23:WU02:FS00:Connecting to 171.67.108.44:8080
03:11:42:ERROR:WU02:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:12:39:WU00:FS01:Connecting to assign3.stanford.edu:8080
03:12:58:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:12:58:WU00:FS01:Connecting to assign4.stanford.edu:80
03:13:12:WU00:FS01:News: Welcome to Folding@Home
03:13:12:WU00:FS01:Assigned to work server 171.64.65.101
03:13:14:WU00:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:13:14:WU00:FS01:Connecting to 171.64.65.101:8080
03:13:33:ERROR:WU00:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:13:33:WU00:FS01:Cleaning up
03:13:33:WU01:FS01:Connecting to assign3.stanford.edu:8080
03:13:45:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
03:13:52:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:13:52:WU01:FS01:Connecting to assign4.stanford.edu:80
03:14:00:WU02:FS00:News: Welcome to Folding@Home
03:14:00:WU02:FS00:Assigned to work server 171.67.108.44
03:14:00:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:14:00:WU02:FS00:Connecting to 171.67.108.44:8080
03:14:06:WU01:FS01:News: Welcome to Folding@Home
03:14:06:WU01:FS01:Assigned to work server 171.64.65.101
03:14:06:WU01:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:14:06:WU01:FS01:Connecting to 171.64.65.101:8080
03:14:20:ERROR:WU02:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:14:35:ERROR:WU01:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:14:35:WU01:FS01:Connecting to assign3.stanford.edu:8080
03:14:55:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:14:55:WU01:FS01:Connecting to assign4.stanford.edu:80
03:15:11:WU01:FS01:News: Welcome to Folding@Home
03:15:11:WU01:FS01:Assigned to work server 171.64.65.101
03:15:11:WU01:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:15:11:WU01:FS01:Connecting to 171.64.65.101:8080
03:15:30:ERROR:WU01:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:15:35:WU01:FS01:Connecting to assign3.stanford.edu:8080
03:15:54:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:15:54:WU01:FS01:Connecting to assign4.stanford.edu:80
03:16:08:WU01:FS01:News: Welcome to Folding@Home
03:16:08:WU01:FS01:Assigned to work server 171.64.65.101
03:16:11:WU01:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:16:11:WU01:FS01:Connecting to 171.64.65.101:8080
03:16:30:ERROR:WU01:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:17:12:WU01:FS01:Connecting to assign3.stanford.edu:8080
03:17:32:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:17:32:WU01:FS01:Connecting to assign4.stanford.edu:80
03:17:46:WU01:FS01:News: Welcome to Folding@Home
03:17:46:WU01:FS01:Assigned to work server 171.64.65.101
03:17:48:WU01:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:17:48:WU01:FS01:Connecting to 171.64.65.101:8080
03:18:00:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
03:18:07:ERROR:WU01:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:18:13:WU02:FS00:News: Welcome to Folding@Home
03:18:13:WU02:FS00:Assigned to work server 171.67.108.44
03:18:15:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:18:15:WU02:FS00:Connecting to 171.67.108.44:8080
03:18:34:ERROR:WU02:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:18:34:WU02:FS00:Cleaning up
03:18:34:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
03:18:47:WU00:FS00:News: Welcome to Folding@Home
03:18:47:WU00:FS00:Assigned to work server 171.67.108.44
03:18:47:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:18:47:WU00:FS00:Connecting to 171.67.108.44:8080
03:19:07:ERROR:WU00:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:19:07:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
03:19:21:WU00:FS00:News: Welcome to Folding@Home
03:19:21:WU00:FS00:Assigned to work server 171.67.108.44
03:19:21:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:19:21:WU00:FS00:Connecting to 171.67.108.44:8080
03:19:40:ERROR:WU00:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:19:50:WU01:FS01:Connecting to assign3.stanford.edu:8080
03:20:07:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
03:20:08:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:20:09:WU01:FS01:Connecting to assign4.stanford.edu:80
03:20:21:WU00:FS00:News: Welcome to Folding@Home
03:20:21:WU00:FS00:Assigned to work server 171.67.108.44
03:20:21:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:20:21:WU00:FS00:Connecting to 171.67.108.44:8080
03:20:22:WU01:FS01:News: Welcome to Folding@Home
03:20:22:WU01:FS01:Assigned to work server 171.64.65.101
03:20:25:WU01:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:20:25:WU01:FS01:Connecting to 171.64.65.101:8080
03:20:40:ERROR:WU00:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:20:45:ERROR:WU01:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:21:44:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
03:21:59:WU00:FS00:News: Welcome to Folding@Home
03:21:59:WU00:FS00:Assigned to work server 171.67.108.44
03:21:59:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:21:59:WU00:FS00:Connecting to 171.67.108.44:8080
03:22:18:ERROR:WU00:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:24:04:WU01:FS01:Connecting to assign3.stanford.edu:8080
03:24:22:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
03:24:23:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:24:23:WU01:FS01:Connecting to assign4.stanford.edu:80
03:24:35:WU00:FS00:News: Welcome to Folding@Home
03:24:35:WU00:FS00:Assigned to work server 171.67.108.44
03:24:36:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:24:36:WU00:FS00:Connecting to 171.67.108.44:8080
03:24:40:WU01:FS01:News: Welcome to Folding@Home
03:24:40:WU01:FS01:Assigned to work server 171.64.65.101
03:24:40:WU01:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:24:40:WU01:FS01:Connecting to 171.64.65.101:8080
03:24:55:ERROR:WU00:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:24:59:ERROR:WU01:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:24:59:WU01:FS01:Cleaning up
03:25:00:WU02:FS01:Connecting to assign3.stanford.edu:8080
03:25:20:WARNING:WU02:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:25:20:WU02:FS01:Connecting to assign4.stanford.edu:80
03:25:34:WU02:FS01:News: Welcome to Folding@Home
03:25:34:WU02:FS01:Assigned to work server 171.64.65.101
03:25:34:WU02:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:25:34:WU02:FS01:Connecting to 171.64.65.101:8080
03:25:54:ERROR:WU02:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:25:54:WU02:FS01:Connecting to assign3.stanford.edu:8080
03:26:13:WARNING:WU02:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:26:13:WU02:FS01:Connecting to assign4.stanford.edu:80
03:26:30:WU02:FS01:News: Welcome to Folding@Home
03:26:30:WU02:FS01:Assigned to work server 171.64.65.101
03:26:30:WU02:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:26:30:WU02:FS01:Connecting to 171.64.65.101:8080
03:26:49:ERROR:WU02:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:26:54:WU02:FS01:Connecting to assign3.stanford.edu:8080
03:27:13:WARNING:WU02:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:27:13:WU02:FS01:Connecting to assign4.stanford.edu:80
03:27:27:WU02:FS01:News: Welcome to Folding@Home
03:27:27:WU02:FS01:Assigned to work server 171.64.65.101
03:27:30:WU02:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:27:30:WU02:FS01:Connecting to 171.64.65.101:8080
03:27:49:ERROR:WU02:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:28:31:WU02:FS01:Connecting to assign3.stanford.edu:8080
03:28:36:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
03:28:50:WU00:FS00:News: Welcome to Folding@Home
03:28:50:WU00:FS00:Assigned to work server 171.67.108.44
03:28:50:WARNING:WU02:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:28:50:WU02:FS01:Connecting to assign4.stanford.edu:80
03:28:50:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:28:50:WU00:FS00:Connecting to 171.67.108.44:8080
03:29:04:WU02:FS01:News: Welcome to Folding@Home
03:29:04:WU02:FS01:Assigned to work server 171.64.65.101
03:29:07:WU02:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:29:07:WU02:FS01:Connecting to 171.64.65.101:8080
03:29:09:ERROR:WU00:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:29:09:WU00:FS00:Cleaning up
03:29:10:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
03:29:23:WU01:FS00:News: Welcome to Folding@Home
03:29:23:WU01:FS00:Assigned to work server 171.67.108.44
03:29:23:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:29:23:WU01:FS00:Connecting to 171.67.108.44:8080
03:29:26:ERROR:WU02:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:29:43:ERROR:WU01:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:29:43:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
03:29:57:WU01:FS00:News: Welcome to Folding@Home
03:29:57:WU01:FS00:Assigned to work server 171.67.108.44
03:29:57:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:29:57:WU01:FS00:Connecting to 171.67.108.44:8080
03:30:16:ERROR:WU01:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:30:43:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
03:30:56:WU01:FS00:News: Welcome to Folding@Home
03:30:56:WU01:FS00:Assigned to work server 171.67.108.44
03:30:57:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:30:57:WU01:FS00:Connecting to 171.67.108.44:8080
03:31:08:WU02:FS01:Connecting to assign3.stanford.edu:8080
03:31:16:ERROR:WU01:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:31:28:WARNING:WU02:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:31:28:WU02:FS01:Connecting to assign4.stanford.edu:80
03:31:44:WU02:FS01:News: Welcome to Folding@Home
03:31:44:WU02:FS01:Assigned to work server 171.64.65.101
03:31:44:WU02:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:31:44:WU02:FS01:Connecting to 171.64.65.101:8080
03:32:04:ERROR:WU02:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:32:20:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
03:32:35:WU01:FS00:News: Welcome to Folding@Home
03:32:35:WU01:FS00:Assigned to work server 171.67.108.44
03:32:35:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:32:35:WU01:FS00:Connecting to 171.67.108.44:8080
03:32:55:ERROR:WU01:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:34:57:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
03:35:11:WU01:FS00:News: Welcome to Folding@Home
03:35:11:WU01:FS00:Assigned to work server 171.67.108.44
03:35:13:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:35:13:WU01:FS00:Connecting to 171.67.108.44:8080
03:35:23:WU02:FS01:Connecting to assign3.stanford.edu:8080
03:35:32:ERROR:WU01:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:35:42:WARNING:WU02:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:35:42:WU02:FS01:Connecting to assign4.stanford.edu:80
03:35:56:WU02:FS01:News: Welcome to Folding@Home
03:35:56:WU02:FS01:Assigned to work server 171.64.65.101
03:35:58:WU02:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:35:58:WU02:FS01:Connecting to 171.64.65.101:8080
03:36:18:ERROR:WU02:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:36:18:WU02:FS01:Cleaning up
03:36:18:WU00:FS01:Connecting to assign3.stanford.edu:8080
03:36:37:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:36:37:WU00:FS01:Connecting to assign4.stanford.edu:80
03:36:51:WU00:FS01:News: Welcome to Folding@Home
03:36:51:WU00:FS01:Assigned to work server 171.64.65.101
03:36:51:WU00:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:36:51:WU00:FS01:Connecting to 171.64.65.101:8080
03:37:11:ERROR:WU00:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:37:11:WU00:FS01:Connecting to assign3.stanford.edu:8080
03:37:30:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:37:30:WU00:FS01:Connecting to assign4.stanford.edu:80
03:37:44:WU00:FS01:News: Welcome to Folding@Home
03:37:44:WU00:FS01:Assigned to work server 171.64.65.101
03:37:44:WU00:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:37:44:WU00:FS01:Connecting to 171.64.65.101:8080
03:38:04:ERROR:WU00:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:38:11:WU00:FS01:Connecting to assign3.stanford.edu:8080
03:38:30:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:38:30:WU00:FS01:Connecting to assign4.stanford.edu:80
03:38:44:WU00:FS01:News: Welcome to Folding@Home
03:38:44:WU00:FS01:Assigned to work server 171.64.65.101
03:38:44:WU00:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:38:44:WU00:FS01:Connecting to 171.64.65.101:8080
03:39:03:ERROR:WU00:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:39:11:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
03:39:25:WU01:FS00:News: Welcome to Folding@Home
03:39:25:WU01:FS00:Assigned to work server 171.67.108.44
03:39:27:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:39:27:WU01:FS00:Connecting to 171.67.108.44:8080
03:39:46:ERROR:WU01:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:39:46:WU01:FS00:Cleaning up
03:39:46:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
03:39:48:WU00:FS01:Connecting to assign3.stanford.edu:8080
03:40:00:WU02:FS00:News: Welcome to Folding@Home
03:40:00:WU02:FS00:Assigned to work server 171.67.108.44
03:40:00:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:40:00:WU02:FS00:Connecting to 171.67.108.44:8080
03:40:07:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:40:07:WU00:FS01:Connecting to assign4.stanford.edu:80
03:40:19:ERROR:WU02:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:40:19:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
03:40:20:WU00:FS01:News: Welcome to Folding@Home
03:40:20:WU00:FS01:Assigned to work server 171.64.65.101
03:40:22:WU00:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:40:22:WU00:FS01:Connecting to 171.64.65.101:8080
03:40:33:WU02:FS00:News: Welcome to Folding@Home
03:40:33:WU02:FS00:Assigned to work server 171.67.108.44
03:40:33:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:40:33:WU02:FS00:Connecting to 171.67.108.44:8080
03:40:41:ERROR:WU00:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:40:53:ERROR:WU02:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:41:19:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
03:41:33:WU02:FS00:News: Welcome to Folding@Home
03:41:33:WU02:FS00:Assigned to work server 171.67.108.44
03:41:33:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:41:33:WU02:FS00:Connecting to 171.67.108.44:8080
03:41:52:ERROR:WU02:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:42:25:WU00:FS01:Connecting to assign3.stanford.edu:8080
03:42:44:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:42:44:WU00:FS01:Connecting to assign4.stanford.edu:80
03:42:56:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
03:42:58:WU00:FS01:News: Welcome to Folding@Home
03:42:58:WU00:FS01:Assigned to work server 171.64.65.101
03:42:59:WU00:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:42:59:WU00:FS01:Connecting to 171.64.65.101:8080
03:43:09:WU02:FS00:News: Welcome to Folding@Home
03:43:09:WU02:FS00:Assigned to work server 171.67.108.44
03:43:10:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:43:10:WU02:FS00:Connecting to 171.67.108.44:8080
03:43:19:ERROR:WU00:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:43:29:ERROR:WU02:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:45:34:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
03:45:48:WU02:FS00:News: Welcome to Folding@Home
03:45:48:WU02:FS00:Assigned to work server 171.67.108.44
03:45:48:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:45:48:WU02:FS00:Connecting to 171.67.108.44:8080
03:46:07:ERROR:WU02:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:46:39:WU00:FS01:Connecting to assign3.stanford.edu:8080
03:46:59:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:46:59:WU00:FS01:Connecting to assign4.stanford.edu:80
03:47:17:WU00:FS01:News: Welcome to Folding@Home
03:47:17:WU00:FS01:Assigned to work server 171.64.65.101
03:47:17:WU00:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:47:17:WU00:FS01:Connecting to 171.64.65.101:8080
03:47:38:ERROR:WU00:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:47:38:WU00:FS01:Cleaning up
03:47:38:WU01:FS01:Connecting to assign3.stanford.edu:8080
03:47:57:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:47:57:WU01:FS01:Connecting to assign4.stanford.edu:80
03:48:11:WU01:FS01:News: Welcome to Folding@Home
03:48:11:WU01:FS01:Assigned to work server 171.64.65.101
03:48:11:WU01:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:48:11:WU01:FS01:Connecting to 171.64.65.101:8080
03:48:31:ERROR:WU01:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:48:31:WU01:FS01:Connecting to assign3.stanford.edu:8080
03:48:50:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:48:50:WU01:FS01:Connecting to assign4.stanford.edu:80
03:49:04:WU01:FS01:News: Welcome to Folding@Home
03:49:04:WU01:FS01:Assigned to work server 171.64.65.101
03:49:04:WU01:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:49:04:WU01:FS01:Connecting to 171.64.65.101:8080
03:49:24:ERROR:WU01:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:49:31:WU01:FS01:Connecting to assign3.stanford.edu:8080
03:49:48:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
03:49:51:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:49:51:WU01:FS01:Connecting to assign4.stanford.edu:80
03:50:02:WU02:FS00:News: Welcome to Folding@Home
03:50:02:WU02:FS00:Assigned to work server 171.67.108.44
03:50:02:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:50:02:WU02:FS00:Connecting to 171.67.108.44:8080
03:50:04:WU01:FS01:News: Welcome to Folding@Home
03:50:04:WU01:FS01:Assigned to work server 171.64.65.101
03:50:04:WU01:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:50:04:WU01:FS01:Connecting to 171.64.65.101:8080
03:50:21:ERROR:WU02:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:50:21:WU02:FS00:Cleaning up
03:50:21:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
03:50:24:ERROR:WU01:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:50:36:WU00:FS00:News: Welcome to Folding@Home
03:50:36:WU00:FS00:Assigned to work server 171.67.108.44
03:50:36:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:50:36:WU00:FS00:Connecting to 171.67.108.44:8080
03:50:55:ERROR:WU00:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:50:55:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
03:51:08:WU01:FS01:Connecting to assign3.stanford.edu:8080
03:51:09:WU00:FS00:News: Welcome to Folding@Home
03:51:09:WU00:FS00:Assigned to work server 171.67.108.44
03:51:09:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:51:09:WU00:FS00:Connecting to 171.67.108.44:8080
03:51:28:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:51:28:WU01:FS01:Connecting to assign4.stanford.edu:80
03:51:29:ERROR:WU00:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:51:42:WU01:FS01:News: Welcome to Folding@Home
03:51:42:WU01:FS01:Assigned to work server 171.64.65.101
03:51:42:WU01:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:51:42:WU01:FS01:Connecting to 171.64.65.101:8080
03:51:55:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
03:52:02:ERROR:WU01:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:52:10:WU00:FS00:News: Welcome to Folding@Home
03:52:10:WU00:FS00:Assigned to work server 171.67.108.44
03:52:10:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:52:10:WU00:FS00:Connecting to 171.67.108.44:8080
03:52:30:ERROR:WU00:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:53:33:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
03:53:45:WU01:FS01:Connecting to assign3.stanford.edu:8080
03:53:47:WU00:FS00:News: Welcome to Folding@Home
03:53:47:WU00:FS00:Assigned to work server 171.67.108.44
03:53:47:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:53:47:WU00:FS00:Connecting to 171.67.108.44:8080
03:54:05:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:54:05:WU01:FS01:Connecting to assign4.stanford.edu:80
03:54:06:ERROR:WU00:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:54:19:WU01:FS01:News: Welcome to Folding@Home
03:54:19:WU01:FS01:Assigned to work server 171.64.65.101
03:54:19:WU01:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:54:19:WU01:FS01:Connecting to 171.64.65.101:8080
03:54:39:ERROR:WU01:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:56:10:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
03:56:24:WU00:FS00:News: Welcome to Folding@Home
03:56:24:WU00:FS00:Assigned to work server 171.67.108.44
03:56:25:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
03:56:25:WU00:FS00:Connecting to 171.67.108.44:8080
03:56:44:ERROR:WU00:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
03:58:00:WU01:FS01:Connecting to assign3.stanford.edu:8080
03:58:19:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:58:19:WU01:FS01:Connecting to assign4.stanford.edu:80
03:58:33:WU01:FS01:News: Welcome to Folding@Home
03:58:33:WU01:FS01:Assigned to work server 171.64.65.101
03:58:34:WU01:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:58:34:WU01:FS01:Connecting to 171.64.65.101:8080
03:58:53:ERROR:WU01:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:58:53:WU01:FS01:Cleaning up
03:58:53:WU02:FS01:Connecting to assign3.stanford.edu:8080
03:59:14:WARNING:WU02:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
03:59:14:WU02:FS01:Connecting to assign4.stanford.edu:80
03:59:27:WU02:FS01:News: Welcome to Folding@Home
03:59:27:WU02:FS01:Assigned to work server 171.64.65.101
03:59:27:WU02:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
03:59:27:WU02:FS01:Connecting to 171.64.65.101:8080
03:59:46:ERROR:WU02:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
03:59:47:WU02:FS01:Connecting to assign3.stanford.edu:8080
04:00:06:WARNING:WU02:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
04:00:06:WU02:FS01:Connecting to assign4.stanford.edu:80
04:00:19:WU02:FS01:News: Welcome to Folding@Home
04:00:19:WU02:FS01:Assigned to work server 171.64.65.101
04:00:19:WU02:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
04:00:19:WU02:FS01:Connecting to 171.64.65.101:8080
04:00:24:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
04:00:38:ERROR:WU02:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
04:00:38:WU00:FS00:News: Welcome to Folding@Home
04:00:38:WU00:FS00:Assigned to work server 171.67.108.44
04:00:39:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
04:00:39:WU00:FS00:Connecting to 171.67.108.44:8080
04:00:47:WU02:FS01:Connecting to assign3.stanford.edu:8080
04:00:58:ERROR:WU00:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
04:00:58:WU00:FS00:Cleaning up
04:00:58:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
04:01:07:WARNING:WU02:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
04:01:07:WU02:FS01:Connecting to assign4.stanford.edu:80
04:01:14:WU01:FS00:News: Welcome to Folding@Home
04:01:14:WU01:FS00:Assigned to work server 171.67.108.44
04:01:14:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
04:01:14:WU01:FS00:Connecting to 171.67.108.44:8080
04:01:21:WU02:FS01:News: Welcome to Folding@Home
04:01:21:WU02:FS01:Assigned to work server 171.64.65.101
04:01:21:WU02:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
04:01:21:WU02:FS01:Connecting to 171.64.65.101:8080
04:01:33:ERROR:WU01:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
04:01:33:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
04:01:50:ERROR:WU02:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
04:01:50:WU01:FS00:News: Welcome to Folding@Home
04:01:50:WU01:FS00:Assigned to work server 171.67.108.44
04:01:50:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
04:01:50:WU01:FS00:Connecting to 171.67.108.44:8080
04:02:10:ERROR:WU01:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
04:02:24:WU02:FS01:Connecting to assign3.stanford.edu:8080
04:02:33:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
04:02:43:WARNING:WU02:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
04:02:43:WU02:FS01:Connecting to assign4.stanford.edu:80
04:02:47:WU01:FS00:News: Welcome to Folding@Home
04:02:47:WU01:FS00:Assigned to work server 171.67.108.44
04:02:50:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
04:02:50:WU01:FS00:Connecting to 171.67.108.44:8080
04:02:59:WU02:FS01:News: Welcome to Folding@Home
04:02:59:WU02:FS01:Assigned to work server 171.64.65.101
04:02:59:WU02:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
04:02:59:WU02:FS01:Connecting to 171.64.65.101:8080
04:03:10:ERROR:WU01:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
04:03:18:ERROR:WU02:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
04:04:11:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
04:04:25:WU01:FS00:News: Welcome to Folding@Home
04:04:25:WU01:FS00:Assigned to work server 171.67.108.44
04:04:28:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
04:04:28:WU01:FS00:Connecting to 171.67.108.44:8080
04:04:46:ERROR:WU01:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
04:05:01:WU02:FS01:Connecting to assign3.stanford.edu:8080
04:05:20:WARNING:WU02:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
04:05:20:WU02:FS01:Connecting to assign4.stanford.edu:80
04:05:35:WU02:FS01:News: Welcome to Folding@Home
04:05:35:WU02:FS01:Assigned to work server 171.64.65.101
04:05:36:WU02:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
04:05:36:WU02:FS01:Connecting to 171.64.65.101:8080
04:05:56:ERROR:WU02:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
04:06:48:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
04:07:04:WU01:FS00:News: Welcome to Folding@Home
04:07:04:WU01:FS00:Assigned to work server 171.67.108.44
04:07:05:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"NI Turks [AMD Radeon HD 6500]" from 171.67.108.44
04:07:05:WU01:FS00:Connecting to 171.67.108.44:8080
04:07:24:ERROR:WU01:FS00:Exception: 10001: Server responded: UNKNOWN_ENUM
04:09:16:WU02:FS01:Connecting to assign3.stanford.edu:8080
04:09:35:WARNING:WU02:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
04:09:35:WU02:FS01:Connecting to assign4.stanford.edu:80
04:09:49:WU02:FS01:News: Welcome to Folding@Home
04:09:49:WU02:FS01:Assigned to work server 171.64.65.101
04:09:50:WU02:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
04:09:50:WU02:FS01:Connecting to 171.64.65.101:8080
04:10:10:ERROR:WU02:FS01:Exception: 10001: Server responded: UNKNOWN_ENUM
04:10:10:WU02:FS01:Cleaning up
04:10:10:WU00:FS01:Connecting to assign3.stanford.edu:8080
04:10:28:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: UNKNOWN_ENUM
04:10:28:WU00:FS01:Connecting to assign4.stanford.edu:80
04:10:40:WU00:FS01:News: Welcome to Folding@Home
04:10:40:WU00:FS01:Assigned to work server 171.64.65.101
04:10:40:WU00:FS01:Requesting new work unit for slot 01: READY smp:2 from 171.64.65.101
04:10:40:WU00:FS01:Connecting to 171.64.65.101:8080
Which version of the Catalyst drivers are you running?
cheapie
Post by cheapie »
Never mind... It spit out some strange errors, then started working.
Mmmm. I wish we understood it.
What changed between when it didn't work and when it did?
Post the segment of the log between the last failure and the first success.
cheapie
Post by cheapie »
OK... that error was from something else. Looking at the log, I don't see anything between the last failure and first success.
