First time Foldin'
toastedArbiter
First time Foldin'
Post by toastedArbiter »
Hello everyone, this is the first time I've used this program and I'm having some trouble starting it. I went through the instillation process and now looking at the client control, but I'm not sure what to do from here. It does say "Client: local Online Inactive", so I know its not running anything. However, the folding button doesn't seem to do anything. Have I forgotten a step?
Thank you for your response ahead of time.
compdewd
Hardware configuration: [1] Debian 8 64-bit: EVGA NVIDIA GTX 650 Ti, MSI NVIDIA GTX 460, AMD FX-8120
[2] Windows 7 64-bit: MSI NVIDIA GTX 460, AMD Phenom II X4
Re: First time Foldin'
Post by compdewd »
Welcome to the forum and welcome to folding, toastedArbiter! :D
To help better diagnose your problem, please tell us the Operating System on which you are running this
toastedArbiter
Windows 7 on a MSI GT780R
Edit: And thanks for the welcome!
compdewd
Post by compdewd »
Try going into preferences and clicking the "Autostart" checkbox, click "Save", and wait a second for it to change to "Connecting", "Updating", or "Online". The latter would mean it is successfully folding :) this sometimes works for me if it doesn't start right away
PS. Don't be surprised if that doesn't work
Welcome to foldingforum.org, toastedArbiter.
It really helps to see the information in the log. I'm not certain if it will show in the "Log" tab of FAHControl or not. If so, remove the Follow checkmark and press Refresh and then scroll back to the beginning and copy/paste several screen-loads from there. If it's not shown, click on Start+All_Programs+FAHClient+Data_Directory and open log.txt and copy/paste the first few hundred lines.
Does Task Manager report that both FAHControl and FAHClient are running, perhaps with or without other programs starting with FAH....?
toastedArbiter
Ok, found the log. The last line is-
03:05:00:ERROR:WU01:FS01:Exception: Failed to connect to www.stanford.edu:80: The requested address is not valid in its context.
I think thats my problem. Here is the rest of the log in case it matters-
*********************** Log Started 2012-06-22T02:59:45Z ***********************
02:59:45:************************* Folding@home Client *************************
02:59:45:      Website: http://folding.stanford.edu/
02:59:45:    Copyright: (c) 2009-2012 Stanford University
02:59:45:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:59:45:         Args: --lifeline 10132 --command-port=36330
02:59:45:       Config: C:/ProgramData/FAHClient/config.xml
02:59:45:******************************** Build ********************************
02:59:45:      Version: 7.1.52
02:59:45:         Date: Mar 20 2012
02:59:45:         Time: 19:37:42
02:59:45:      SVN Rev: 3515
02:59:45:       Branch: fah/trunk/client
02:59:45:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
02:59:45:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
02:59:45:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
02:59:45:     Platform: win32 XP
02:59:45:         Bits: 32
02:59:45:         Mode: Release
02:59:45:******************************* System ********************************
02:59:45:          CPU: Intel(R) Core(TM) i7-2630QM CPU @ 2.00GHz
02:59:45:       CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
02:59:45:         CPUs: 8
02:59:45:       Memory: 15.98GiB
02:59:45:  Free Memory: 12.00GiB
02:59:45:      Threads: WINDOWS_THREADS
02:59:45:   On Battery: false
02:59:45:   UTC offset: -7
02:59:45:          PID: 9676
02:59:45:          CWD: C:/ProgramData/FAHClient
02:59:45:           OS: Windows 7 Home Premium
02:59:45:      OS Arch: AMD64
02:59:45:         GPUs: 1
02:59:45:        GPU 0: FERMI:1 GF116 [GeForce GTX 560M]
02:59:45:         CUDA: 2.1
02:59:45:  CUDA Driver: 3020
02:59:45:Win32 Service: false
02:59:45:***********************************************************************
02:59:45:<config>
02:59:45:  <!-- Folding Slot Configuration -->
02:59:45:  <gpu v='true'/>
02:59:45:
02:59:45:  <!-- Network -->
02:59:45:  <proxy v=':8080'/>
02:59:45:
02:59:45:  <!-- User Information -->
02:59:45:  <user v='Anon'/>
02:59:45:
02:59:45:  <!-- Folding Slots -->
02:59:45:  <slot id='0' type='GPU'/>
02:59:45:  <slot id='1' type='SMP'/>
02:59:45:</config>
02:59:45:Trying to access database...
02:59:45:Successfully acquired database lock
02:59:45:Enabled folding slot 00: READY gpu:0:"GF116 [GeForce GTX 560M]"
02:59:45:Enabled folding slot 01: READY smp:8
02:59:46:WU00:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah
02:59:46:WU00:FS00:Connecting to www.stanford.edu:80
02:59:46:WU01:FS01:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
02:59:46:WU01:FS01:Connecting to www.stanford.edu:80
02:59:46:ERROR:WU00:FS00:Exception: Failed to connect to www.stanford.edu:80: The requested address is not valid in its context.
02:59:46:ERROR:WU01:FS01:Exception: Failed to connect to www.stanford.edu:80: The requested address is not valid in its context.
02:59:49:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
03:00:46:WU00:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah
03:00:46:WU00:FS00:Connecting to www.stanford.edu:80
03:00:46:ERROR:WU00:FS00:Exception: Failed to connect to www.stanford.edu:80: The requested address is not valid in its context.
03:00:46:WU01:FS01:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
03:00:46:WU01:FS01:Connecting to www.stanford.edu:80
03:00:46:ERROR:WU01:FS01:Exception: Failed to connect to www.stanford.edu:80: The requested address is not valid in its context.
03:02:23:WU00:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah
03:02:23:WU00:FS00:Connecting to www.stanford.edu:80
03:02:23:ERROR:WU00:FS00:Exception: Failed to connect to www.stanford.edu:80: The requested address is not valid in its context.
03:02:23:WU01:FS01:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
03:02:23:WU01:FS01:Connecting to www.stanford.edu:80
03:02:23:ERROR:WU01:FS01:Exception: Failed to connect to www.stanford.edu:80: The requested address is not valid in its context.
03:05:00:WU00:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah
03:05:00:WU00:FS00:Connecting to www.stanford.edu:80
03:05:00:ERROR:WU00:FS00:Exception: Failed to connect to www.stanford.edu:80: The requested address is not valid in its context.
03:05:00:WU01:FS01:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
03:05:00:WU01:FS01:Connecting to www.stanford.edu:80
Ok, how would I go about fixing this little issue?
PinHead
Hardware configuration: Quad Q9550 2.83 contains the GPU 57xx - running SMP and GPU
Post by PinHead »
Looks like your anti-virus, fire-wall, security measures are blocking your out bound connection. Not sure what flavour or version you are running.
But I am guessing that you clicked 'NO' on a bunch of popups that you might should have said 'Yes' to since you installed a new program.
toastedArbiter
How would I go about giving you the right information so we could work through this?
Also, it said it connected to download something called 'core' from the site in two locations. Wouldn't that mean it has already made contact?
Edit: Also, the only pop-up that came up I said yes to.
Edit: I think the Version is in the block of code.
02:59:45:         Bits: 32
toastedArbiter
Ok, update. I told it to run in administrator, and restarted the program. Waited a bit, and now it says "Client: local Online Running"
Apparently its working on something, but the viewer only has a demo protein showing. Is there another step for that?
Zagen30
Post by Zagen30 »
The viewer requires the core to write a certain file in order to render the protein. I don't believe any of the cores currently in use do so, so all the viewer can show is the demo protein. As long as the progress bar in the Work Queue window goes up every so often, you should be good.
Zagen30 wrote:...I don't believe any of the cores currently in use do so...
Last I heard (some time ago), only FahCore_78, the UNI one was able to display the actual protein while others displayed the demo. A ticket was opened to resolve this but am unsure of this current status.
iceman1992
Post by iceman1992 »
Yes it's here https://fah-web.stanford.edu/projects/F ... ticket/409
I wonder what it means by "(accepted enhancement)"?
iceman1992 wrote:Yes it's here https://fah-web.stanford.edu/projects/F ... ticket/409
That's the ticket that I was referring to. "accepted enhancement" means that the the ticket is accepted, i.e. it isn't a duplicate or incorrect. Moreover, its an enhancement rather than a bug (which is classified as a defect), i.e. the functionality of the client is increased instead of trying to repair a broken functionality.
toastedArbiter
alrighty, So I've been messing around with it a little bit, and let it sit last night. Its workin' hard on project 7000, but the core update hasn't moved, and is currently 'unknown'.
How would I got about uploading a screen cap to this forum? Can I directly upload it or do I need to host it on an alternitive site and link it?
compdewd
Post by compdewd »
AFAIK direct uploads here are not supported so you would have to link to it
