Project: 7200 (Run 34, Clone 10, Gen 235)
Hey everyone.
Just got into this folding thing and I do not mind using my PC to help.
But the other day i got this project and it has no information and it is pretty large it has an ETA of 4 hours at a rate of 4,500PPD
If this is an error is their a way i can skip this WU?
iceman1992
Re: Project: 7200 (34, 10, 235)
4 hours is a small-medium WU
The big ones can take over 24 hours.
And you haven't given enough information on your specs and client version.
What do you mean by "it has no information"?
Skipping WUs is not recommended unless it's the best thing to do.
FYI
You won't get 4500 PPD unless you've completed 10 WUs using a passkey:
http://folding.stanford.edu/English/FAQ-passkey
Not knowing your system specs I can't say how reasonable the 4500 prediction is but after looking at my history it sounds right for a quad core @ stock.
btw without a passkey you'll get a credit of 484.
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
Welcome to the Folding@home support forum |GrayFox|!
Thanks for joining us!
Projects vary from one to the other, and some just take longer than others. WUs are benchmarked before they are released, so if they take longer the deadline is correspondingly longer, and your PPD should be about the same. As long as you're making the deadline (which I'm sure you are), you don't need to worry.
I also don't understand what you mean by "has no information", but I'm guessing you mean that it has no project description. I see from http://fah-web.stanford.edu/cgi-bin/fah ... ned?p=7200 that's indeed the case. Hmm. The scientist who launched project 7200 is responsible for setting the description, and normally it's a good idea to find out who that scientist is, so that they can be notified. Unfortunately, 7200 does not appear on http://fah-web.stanford.edu/psummary.html which is a bit odd. I'm not entirely sure what's going on here, and since it doesn't appear in the list of active projects, I'm a bit surprised that you ended up with a WU from this project.
According to my history the contact is pontiggi .
iceman1992
A bit off topic, FYI I once received a 7600 (I think it was 7600) when it no longer appeared in psummary.Jesse_V wrote:and since it doesn't appear in the list of active projects, I'm a bit surprised that you ended up with a WU from this project.
And btw, about the 7200 description, I'm positive I've visited it before and it wasn't blank.
Here's a bit more info:
viewtopic.php?p=185697#p185697
Re: Project: 7200 (Run 34, Clone 10, Gen 235)
It has happened before that projects with a short supply of WU's have not shown up on the Project Summary pages. If all available WU's for a project are "checked out" from their work server when the list is updated, then the project will not be on the list as active. In my experience that is usually as a project is nearing completion. Perhaps at some time in the future the PG will modify the way the lists are generated so projects in this state will show up.
My other WU did not take this long.
But my system specs are
Intel i5 3570k with a boost clock of 4.2Ghz
FVGA GTX680SC(can't get to work(stock clocks))
8GB DDR3 1600Mhz RAM
OCZ 850w PSU
OCZ 850w PSU
Yes, there was data there and I don't have any way of knowing what happened to it. It's being submitted for re-installation but I have no idea how long that will take.iceman1992 wrote:And btw, about the 7200 description, I'm positive I've visited it before and it wasn't blank.
Significant variations are very common. All that means is that your other WU was a different protein with a different project number. See the earlier information:|Grayfox| wrote:My other WU did not take this long.
If you get another Project 7200, it will be almost identical to the present one in spite of variations in Run/Clone/Gen numbers.Jesse_V wrote:Projects vary from one to the other, and some just take longer than others. WUs are benchmarked before they are released, so if they take longer the deadline is correspondingly longer, and your PPD should be about the same. As long as you're making the deadline (which I'm sure you are), you don't need to worry.
I am guessing that it is an EVGA GPU. If that's the case, can you please elaborate as to why it won't work? You can post log (in the Code tags available in the Full Editor) or describe what happens.|Grayfox| wrote:...FVGA GTX680SC(can't get to work(stock clocks))...
Yeah it is an EVGA GPU.
The WU downloads but it just sits at 0% with the ETA of unknown.
Project 7200 finished and got a new WU after(10mins(i am shaped so downloading takes ages))
I have also added the GPU.txt to C:\Program Files (x86)\FAHClient as well as C:\Users\Grayfox\AppData\Roaming\FAHClient (data directory from All programs)
*********************** Log Started 2012-06-22T11:47:07Z ***********************
11:47:07:************************* Folding@home Client *************************
11:47:07: Website: http://folding.stanford.edu/
11:47:07: Copyright: (c) 2009-2012 Stanford University
11:47:07: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:47:07: Args: --lifeline 1668 --command-port=36330
11:47:07: Config: C:/Users/Grayfox/AppData/Roaming/FAHClient/config.xml
11:47:07:******************************** Build ********************************
11:47:07: Version: 7.1.52
11:47:07: Date: Mar 20 2012
11:47:07: Time: 19:37:42
11:47:07: SVN Rev: 3515
11:47:07: Branch: fah/trunk/client
11:47:07: Compiler: Intel(R) C++ MSVC 1500 mode 1200
11:47:07: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
11:47:07: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
11:47:07: Platform: win32 XP
11:47:07: Bits: 32
11:47:07: Mode: Release
11:47:07:******************************* System ********************************
11:47:07: CPU: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
11:47:07: CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
11:47:07: CPUs: 4
11:47:07: Memory: 7.95GiB
11:47:07: Free Memory: 5.56GiB
11:47:07: Threads: WINDOWS_THREADS
11:47:07: On Battery: false
11:47:07: UTC offset: 10
11:47:07: PID: 3280
11:47:07: CWD: C:/Users/Grayfox/AppData/Roaming/FAHClient
11:47:07: OS: Windows 7 Ultimate
11:47:07: OS Arch: AMD64
11:47:07: GPUs: 2
11:47:07: GPU 0: FERMI:1 GK104 [Geforce GTX680]
11:47:07: GPU 1: FERMI:1 GF114 [GeForce GTX 680]
11:47:07: CUDA: 3.0
11:47:07: CUDA Driver: 5000
11:47:07:Win32 Service: false
11:47:07:***********************************************************************
11:47:07:<config>
11:47:07: <!-- FahCore Control -->
11:47:07: <checkpoint v='10'/>
11:47:07:
11:47:07: <!-- Folding Slot Configuration -->
11:47:07: <gpu v='true'/>
11:47:07:
11:47:07: <!-- Network -->
11:47:07: <proxy v=':8080'/>
11:47:07:
11:47:07: <!-- User Information -->
11:47:07: <passkey v='********************************'/>
11:47:07: <user v='Grayfox@GTPlanet'/>
11:47:07:
11:47:07: <!-- Folding Slots -->
11:47:07: <slot id='0' type='SMP'>
11:47:07: <cpus v='-1'/>
11:47:07: </slot>
11:47:07: <slot id='1' type='GPU'/>
11:47:07:</config>
11:47:07:Trying to access database...
11:47:07:Successfully acquired database lock
11:47:07:Enabled folding slot 00: READY smp:4
11:47:07:Enabled folding slot 01: READY gpu:0:"GK104 [Geforce GTX680] "
11:47:07:WU00:FS00:Starting
11:47:07:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Grayfox/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 00 -suffix 01 -version 701 -lifeline 3280 -checkpoint 10 -np 4
11:47:07:WU00:FS00:Started FahCore on PID 7024
11:47:07:WU00:FS00:Core PID:2464
11:47:07:WU00:FS00:FahCore 0xa3 started
11:47:07:WU01:FS01:Starting
11:47:07:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Grayfox/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 701 -lifeline 3280 -checkpoint 10 -gpu 0
11:47:07:WU01:FS01:Started FahCore on PID 5312
11:47:07:WU01:FS01:Core PID:7140
11:47:07:WU01:FS01:FahCore 0x15 started
11:47:08:WU00:FS00:0xa3:
11:47:08:WU00:FS00:0xa3:*------------------------------*
11:47:08:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
11:47:08:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
11:47:08:WU00:FS00:0xa3:Preparing to commence simulation
11:47:08:WU00:FS00:0xa3:- Looking at optimizations...
11:47:08:WU00:FS00:0xa3:- Files status OK
11:47:08:WU00:FS00:0xa3:- Expanded 659727 -> 1092080 (decompressed 165.5 percent)
11:47:08:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=659727 data_size=1092080, decompressed_data_size=1092080 diff=0
11:47:08:WU00:FS00:0xa3:- Digital signature verified
11:47:08:WU00:FS00:0xa3:Project: 11060 (Run 0, Clone 2728, Gen 7)
11:47:08:WU00:FS00:0xa3:Assembly optimizations on if available.
11:47:08:WU00:FS00:0xa3:Entering M.D.
11:47:08:WU01:FS01:0x15:
11:47:08:WU01:FS01:0x15:*------------------------------*
11:47:08:WU01:FS01:0x15:Folding@Home GPU Core
11:47:08:WU01:FS01:0x15:Version 2.22 (Thu Dec 8 17:08:05 PST 2011)
11:47:08:WU01:FS01:0x15:Build host SimbiosNvdWin7
11:47:08:WU01:FS01:0x15:Board Type NVIDIA/CUDA
11:47:08:WU01:FS01:0x15:Core 15
11:47:08:WU01:FS01:0x15:Window's signal control handler registered.
11:47:08:WU01:FS01:0x15:Preparing to commence simulation
11:47:08:WU01:FS01:0x15:- Looking at optimizations...
11:47:08:WU01:FS01:0x15:- Files status OK
11:47:08:WU01:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
11:47:08:WU01:FS01:0x15:- Expanded 66630 -> 287478 (decompressed 431.4 percent)
11:47:08:WU01:FS01:0x15:Called DecompressByteArray: compressed_data_size=66630 data_size=287478, decompressed_data_size=287478 diff=0
11:47:08:WU01:FS01:0x15:- Digital signature verified
11:47:08:WU01:FS01:0x15:Project: 8009 (Run 3, Clone 117, Gen 91)
11:47:08:WU01:FS01:0x15:Assembly optimizations on if available.
11:47:08:WU01:FS01:0x15:Entering M.D.
11:47:10:WU01:FS01:0x15:Tpr hash 01/wudata_01.tpr: 1148275434 1556489316 2741933032 2944034793 4096834952
11:47:10:WU01:FS01:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
11:47:10:WU01:FS01:0x15:Working on S C A M O R G
11:47:10:WU01:FS01:0x15:Client config unavailable.
11:47:10:WU01:FS01:0x15:Starting GUI Server
11:47:10:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
11:47:14:WU00:FS00:0xa3:Mapping NT from 4 to 4 -
Just to confirm, you have only installed a single GPU in your system which is GTX 680?
I have one EVGA GTX680.
I do not know why the log says i have 2.
My GPU slot is set to -1 for the GPU-index.
