I am happily running FAH with no problems, but I was wondering if it is possible, when I click "view" to see a graphical representation of the thing I'm actually working on?
I'm obviously working under the assumption that what is appearing is not my work unit, which I base off of the fact that under "status" in the bottom left I read "Protein: Demo", which cycles periodically between snapshots 1 and 4 with no seeming progression, and furthermore when I view different work units they appear (though this is somewhat hard to distinguish) the same.
How to 'view' Current Work Unit
Re: How to 'view' Current Work Unit
Welcome to the forum, Fendred.
The cores that are currently in widespread use do not produce the necessary files that the viewer needs to display their progress. It's on the Pande Group's agenda, but I don't know when it'll get done.
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
The PG is aware of the issue and it's on their to-do list. This is the bug ticket that needs to be resolved is https://fah-web.stanford.edu/projects/F ... ticket/409 and perhaps there are other necessary changes as well. Obviously the FAHViewer issue you're describing was not resolved before the release of V7, but now that V7 works much more reliably now than it did before, I'm hopeful that they'll resume work on some of the non-essential pieces that will really finish off the software. We'll just have to wait and see; only time will tell.
Ah fair enough. I thought I had read somewhere in passing that it was possible but I guess not.
To the wait and see mobile!
