GPU stuck at 0.00% + only Base points being credited ?
DreamShard
Post by DreamShard »
Hi, I am pretty new to the folding@home "thing" (started folding yesterday). I am running the GUI based client V7.1.52 I have had SMP : 4 running for a number of hours and I have finished two work units so SMP seems to be working fine :D
But I am having difficulty trying to get the GPU to work properly its been stuck at 0.00% for a number of hours now. It was originally giving me an error message saying OpenCl.dll not found so I went ahead and installed the AMD APP SDK v2 and I am not getting that message anymore, and everything seems fine, it says that it is running but its been stuck at 0.00%, Estimated time remaining : unknown for a couple of hours
It's an ATI Mobility HD Radeon 5650 with the latest drivers installed. I should add that the laptop has switchable graphics (the other card is Intel HD graphics) I have disabled the switch in my options so it doesn't switch anymore cause the laptop is plugged in 24/7).
Here are the log files :
12:24:59:WU00:FS02:Starting
12:24:59:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 00 -suffix 01 -version 701 -lifeline 3292 -checkpoint 15 -gpu 0
12:25:00:WU00:FS02:Started FahCore on PID 1064
12:25:00:WU00:FS02:Core PID:4068
12:25:00:WU00:FS02:FahCore 0x16 started
12:25:02:WU00:FS02:0x16:
12:25:02:WU00:FS02:0x16:*------------------------------*
12:25:02:WU00:FS02:0x16:Folding@Home GPU Core
12:25:02:WU00:FS02:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
12:25:02:WU00:FS02:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
12:25:02:WU00:FS02:0x16:Build host: user-f6d030f24f
12:25:02:WU00:FS02:0x16:Board Type: AMD/OpenCL
12:25:02:WU00:FS02:0x16:Core      : x=16
12:25:02:WU00:FS02:0x16: Window's signal control handler registered.
12:25:02:WU00:FS02:0x16:Preparing to commence simulation
12:25:02:WU00:FS02:0x16:- Looking at optimizations...
12:25:02:WU00:FS02:0x16:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
12:25:02:WU00:FS02:0x16:- Created dyn
12:25:02:WU00:FS02:0x16:- Files status OK
12:25:02:WU00:FS02:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
12:25:02:WU00:FS02:0x16:- Expanded 44943 -> 171163 (decompressed 380.8 percent)
12:25:02:WU00:FS02:0x16:Called DecompressByteArray: compressed_data_size=44943 data_size=171163, decompressed_data_size=171163 diff=0
12:25:02:WU00:FS02:0x16:- Digital signature verified
12:25:02:WU00:FS02:0x16:Project: 11293 (Run 8, Clone 464, Gen 13)
12:25:02:WU00:FS02:0x16:Assembly optimizations on if available.
12:25:02:WU00:FS02:0x16:Entering M.D.
12:25:04:WU00:FS02:0x16:Tpr hash 00/wudata_01.tpr:  1649817233 3128482845 2165083543 1300074973 2730781568
12:25:04:WU00:FS02:0x16:Working on ALZHEIMER DISEASE AMYLOID
12:25:04:WU00:FS02:0x16:Client config unavailable.
12:25:04:WU00:FS02:0x16:Starting GUI Server
12:25:29:WU00:FS02:0x16:Setting checkpoint frequency: 500000
12:25:29:WU00:FS02:0x16:Completed         3 out of 50000000 steps (0%).
12:34:26:FS02:Paused
12:34:26:FS02:Shutting core down
12:34:29:FS02:Unpaused
12:34:32:WU00:FS02:0x16:Client no longer detected. Shutting down core
12:34:32:WU00:FS02:0x16:Folding@home Core Shutdown: CLIENT_DIED
12:34:32:WU00:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
12:34:32:WU00:FS02:Starting
12:34:32:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 00 -suffix 01 -version 701 -lifeline 3292 -checkpoint 15 -gpu 0
12:34:33:WU00:FS02:Started FahCore on PID 1340
12:34:33:WU00:FS02:Core PID:2772
12:34:33:WU00:FS02:FahCore 0x16 started
12:34:34:WU00:FS02:0x16:
12:34:34:WU00:FS02:0x16:*------------------------------*
12:34:34:WU00:FS02:0x16:Folding@Home GPU Core
12:34:34:WU00:FS02:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
12:34:34:WU00:FS02:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
12:34:34:WU00:FS02:0x16:Build host: user-f6d030f24f
12:34:34:WU00:FS02:0x16:Board Type: AMD/OpenCL
12:34:34:WU00:FS02:0x16:Core      : x=16
12:34:34:WU00:FS02:0x16: Window's signal control handler registered.
12:34:34:WU00:FS02:0x16:Preparing to commence simulation
12:34:34:WU00:FS02:0x16:- Looking at optimizations...
12:34:34:WU00:FS02:0x16:- Files status OK
12:34:34:WU00:FS02:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
12:34:34:WU00:FS02:0x16:- Expanded 44943 -> 171163 (decompressed 380.8 percent)
12:34:34:WU00:FS02:0x16:Called DecompressByteArray: compressed_data_size=44943 data_size=171163, decompressed_data_size=171163 diff=0
12:34:34:WU00:FS02:0x16:- Digital signature verified
12:34:34:WU00:FS02:0x16:Project: 11293 (Run 8, Clone 464, Gen 13)
12:34:34:WU00:FS02:0x16:Assembly optimizations on if available.
12:34:34:WU00:FS02:0x16:Entering M.D.
12:34:36:WU00:FS02:0x16:Tpr hash 00/wudata_01.tpr:  1649817233 3128482845 2165083543 1300074973 2730781568
12:34:36:WU00:FS02:0x16:Working on ALZHEIMER DISEASE AMYLOID
12:34:36:WU00:FS02:0x16:Client config unavailable.
12:34:36:WU00:FS02:0x16:Starting GUI Server
12:34:51:WU00:FS02:0x16:Setting checkpoint frequency: 500000
12:34:51:WU00:FS02:0x16:Completed         3 out of 50000000 steps (0%).
and its been stuck at the value above ^ for a couple hours
Are there any flags that I need to add / is there something I am doing wrong ?
On an unrelated note, I have completed two work units on the Username : DreamShard with a passkey set and I seem to have only been awarded the base credits for example:
one of the work units log files said this
03:34:22:WU01:FS01:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
03:34:22:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:34:22:WU01:FS01:Sending unit results: id:01 state:SEND error:OK project:8013 run:211 clone:9 gen:81 core:0xa4 unit:0x000000906652edcc4f72bed3c55e70ba
03:34:22:WU01:FS01:Uploading 1.93MiB to 171.67.108.60
03:34:22:WU01:FS01:Connecting to 171.67.108.60:8080
03:34:31:WU01:FS01:Upload 29.13%
03:34:37:WU01:FS01:Upload 55.02%
03:34:43:WU01:FS01:Upload 77.68%
03:34:49:WU01:FS01:Upload 100.00%
03:34:50:WU01:FS01:Upload complete
03:34:50:WU01:FS01:Server responded WORK_ACK (400)
03:34:50:WU01:FS01:Final credit estimate, [b]483.00 points[/b]
and again
03:38:43:WU00:FS00:Upload 74.41%
03:38:49:WU00:FS00:Upload 97.06%
03:38:51:WU00:FS00:Upload complete
03:38:51:WU00:FS00:Server responded WORK_ACK (400)
03:38:51:WU00:FS00:Final credit estimate, 497.00 points
the stats have credited the two units and everything but for some reason I have only gotten 2 * Base credit [180.60] and so my score is sitting at only 361.2 rather than around 990ish :(
It's not a big deal I was originally planning to fold anonymously anyways but I just thought it would be cool to have the points tracked.
Sorry for just dumping log files and random problems on you guys I honestly did try to fix it for a couple of hours, updated drivers, reinstalled FAHcontrol, tried setting GPU to 0 instead of -1 etc.. etc. but alas it was to no avail.
Any ideas?
Thanks !
ChelseaOilman
Re: GPU stuck at 0.00% + only Base points being credited ?
Post by ChelseaOilman »
Welcome to the forum DreamShard. You'll need to post the system part of the log so people can see which of your GPUs is being used and if it identified properly. As for the bonus points, after entering the passkey you need to complete 10 bonus qualified WUs before actually getting bonus points. GPU WUs don't count towards that total.
ChelseaOilman wrote:GPU WUs don't count towards that total.
Initially, the bonus plan was adopted only for SMP projects. Over the past year or so, it has been extended to include many of the Uniprocessor projects, but not yet all of them. There have been hints that the bonus plan might someday be extended to include GPU projects someday, but there's no signs of it happening any time soon. (As with all future developments, there's never a prediction of when something might happen, if at all.)
DreamShard
Thanks for the help guys !
as for the system part of the log file would that be this ??
22:44:08:******************************* System ********************************
22:44:08:          CPU: Intel(R) Core(TM) i5 CPU M 450 @ 2.40GHz
22:44:08:       CPU ID: GenuineIntel Family 6 Model 37 Stepping 5
22:44:08:         CPUs: 4
22:44:08:       Memory: 3.80GiB
22:44:08:  Free Memory: 2.42GiB
22:44:08:      Threads: WINDOWS_THREADS
22:44:08:   On Battery: false
22:44:08:   UTC offset: 10
22:44:08:          PID: 3468
22:44:08:          CWD: C:/ProgramData/FAHClient
22:44:08:           OS: Windows 7 Home Premium
22:44:08:      OS Arch: AMD64
22:44:08:         GPUs: 1
22:44:08:        GPU 0: ATI:4 Redwood [Radeon HD 5600 Series]
22:44:08:         CUDA: Not detected
22:44:08:Win32 Service: false
22:44:08:***********************************************************************
If that's not it could you please explain where the system log files are found/direct me to a link that does
Thanks again.
I must have been tired when I posted earlier. Where are my manners? Welcome to foldingforum.org, DreamShard.
DreamShard wrote:as for the system part of the log file would that be this ??
Yes, that's it.
