My statistics are not showing up. I register the user, all goes well and starts folding. The only problem my stats dont show up. Anyideas?
~fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=LuckyLake&teamnum=900900
~fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=900900
FAH6.02-Linux
[02:38:59] - Ask before connecting: No
[02:38:59] - User name: LuckyLake (Team 900900)
[02:38:59] - User ID not found locally
[02:38:59] + Requesting User ID from server
[02:38:59] - Machine ID: 1
[02:38:59]
[02:38:59] Work directory not found. Creating...
[02:38:59] Could not open work queue, generating new queue...
[02:38:59] - Preparing to get new work unit...
[02:38:59] + Attempting to get work packet
[02:38:59] - Connecting to assignment server
[02:39:00] - Successful: assigned to (171.67.108.59).
[02:39:00] + News From Folding@Home: Welcome to Folding@Home
[02:39:00] Loaded queue successfully.
[02:39:03] + Closed connections
[02:39:03]
[02:39:03] + Processing work unit
[02:39:03] Core required: FahCore_a4.exe
[02:39:03] Core not found.
[02:39:03] - Core is not present or corrupted.
[02:39:03] - Attempting to download new core...
[02:39:03] + Downloading new core: FahCore_a4.exe
Having Problems with stats
Re: Having Problems with stats
Have you completed any work units yet? Stats will only show up after WU's are completed and turned in by the client software. It takes an hour or two from the time a WU is turned in and when it shows up to a query.
Yes, I have successfully completed 2 WU and am running my 3rd one, Still nothing.
Okay I think I may have fixed it. I have peerblock running and it was blocking the request. I will have to wait for the current work unit to finish and I will follow up after.
There does not appear to be a team numbered 900900. Did you just enter a number you made up? You need to use a valid team number, or use 0 for the default team. If you want to create your own team, use the link to start one from the Stats page - http://folding.stanford.edu/Stats. I don't know what happens to the stats for WU's submitted with an invalid team number, perhaps one of the mods can answer that.
Also, have you applied for a passkey? There is a bonus points program for quick return of WU's, details and a link to get a passkey are on this page - http://folding.stanford.edu/English/FAQ-passkey.
Nathan_P
Not currently folding
6.34 is need to run a4 as smp. 6.02 might work in CPU mode...
In any case, a valid team # is required, and v6.34 is strongly recommended.
Okay, Thanks for all the comments. Everything is now up and running. I set up an account for team stats(check), Set up my user under that team (check). Unblocked the ip's that were being blocked on moblock(check). perfecto. Im using the 6.02 because im running f@h on a virtual machine and it only can run 32 bit. Thanks for the help
