Radeon 5670 issue
MWebber
Radeon 5670 issue
Post by MWebber »
Trying to run V7.152 with a Radeon card, currently running Catalyst 10.9, after a failed attempt to update to 11.12 (system would only display 640x480 4 bit!)
Error on startup of control: "GetLogicalProcessorInformation could not be Located in the dynamic link library KERNEL32.dll" F@H control tries to retrieve several times, then gives up.
19:53:46:WU02:FS00:Connecting to 171.67.108.44:8080
19:53:46:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
19:53:46:WU02:FS00:Server responded WORK_ACK (400)
19:53:46:WU02:FS00:Cleaning up
19:53:46:WU00:FS00:News: Welcome to Folding@Home
19:53:46:WU00:FS00:Assigned to work server 171.67.108.44
19:53:46:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"Redwood [Radeon HD 5670]" from 171.67.108.44
19:53:46:WU00:FS00:Connecting to 171.67.108.44:8080
19:53:47:WU00:FS00:Downloading 44.36KiB
19:53:47:WU00:FS00:Download complete
19:53:47:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:OK project:11293 run:13 clone:5 gen:14 core:0x16 unit:0x000000166652edbc4d643938c9455f0f
19:53:47:WU00:FS00:Starting
19:53:47:WU00:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/Administrator/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/ATI/R600/Core_16.fah/FahCore_16.exe" -dir 00 -suffix 01 -version 701 -lifeline 2920 -checkpoint 15 -gpu 0
19:53:47:WU00:FS00:Started FahCore on PID 196
19:53:47:WU00:FS00:Core PID:3248
19:53:47:WU00:FS00:FahCore 0x16 started
19:53:47:WU00:FS00:0x16:
19:53:47:WU00:FS00:0x16:*------------------------------*
19:53:47:WU00:FS00:0x16:Folding@Home GPU Core
19:53:47:WU00:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
19:53:47:WU00:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
19:53:47:WU00:FS00:0x16:Build host: user-f6d030f24f
19:53:47:WU00:FS00:0x16:Board Type: AMD/OpenCL
19:53:47:WU00:FS00:0x16:Core      : x=16
19:53:47:WU00:FS00:0x16: Window's signal control handler registered.
19:53:47:WU00:FS00:0x16:Preparing to commence simulation
19:53:47:WU00:FS00:0x16:- Looking at optimizations...
19:53:47:WU00:FS00:0x16:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
19:53:47:WU00:FS00:0x16:- Created dyn
19:53:47:WU00:FS00:0x16:- Files status OK
19:53:47:WU00:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
19:53:47:WU00:FS00:0x16:- Expanded 44911 -> 171163 (decompressed 381.1 percent)
19:53:47:WU00:FS00:0x16:Called DecompressByteArray: compressed_data_size=44911 data_size=171163, decompressed_data_size=171163 diff=0
19:53:47:WU00:FS00:0x16:- Digital signature verified
19:53:47:WU00:FS00:0x16:Project: 11293 (Run 13, Clone 5, Gen 14)
19:53:47:WU00:FS00:0x16:Assembly optimizations on if available.
19:53:47:WU00:FS00:0x16:Entering M.D.
19:53:49:WU00:FS00:0x16:Tpr hash 00/wudata_01.tpr:  247367724 971971484 811652274 2632284926 1582571357
19:53:49:WU00:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
19:53:49:WU00:FS00:0x16:Client config unavailable.
19:53:50:WU00:FS00:0x16:Starting GUI Server
19:53:50:WU00:FS00:0x16:Finished fah_main
19:53:50:WU00:FS00:0x16:Successful run
19:53:50:WU00:FS00:0x16:DynamicWrapper: Finished Work Unit: sleep=10000
19:53:54:FS00:Finishing
19:53:54:FS01:Finishing
19:54:00:WU00:FS00:0x16:Reserved 0 bytes for xtc file; Cosm status=0
19:54:00:WU00:FS00:0x16:Reserved 0 0 786430464 bytes for arc file=<00/wudata_01.trr> Cosm status=0
19:54:00:WU00:FS00:0x16:Allocated 544 bytes for edr file
19:54:00:WU00:FS00:0x16:Read bedfile
19:54:00:WU00:FS00:0x16:- Checksum of file (00/wudata_01.edr) read from disk doesn't match
19:54:00:WU00:FS00:0x16:edrfile file hash check failed.
19:54:00:WU00:FS00:0x16:Folding@home Core Shutdown: FILE_IO_ERROR
19:54:01:WU00:FS00:FahCore returned: FILE_IO_ERROR (117 = 0x75)
19:54:01:WARNING:WU00:FS00:Fatal error, dumping
19:54:01:WU00:FS00:Sending unit results: id:00 state:SEND error:DUMPED project:11293 run:13 clone:5 gen:14 core:0x16 unit:0x000000166652edbc4d643938c9455f0f
19:54:01:WU00:FS00:Connecting to 171.67.108.44:8080
19:54:02:WU00:FS00:Server responded WORK_ACK (400)
19:54:02:WU00:FS00:Cleaning up
*********************** Log Started 2012-06-07T19:50:15Z ***********************
19:50:15:************************* Folding@home Client *************************
19:50:15:      Website: http://folding.stanford.edu/
19:50:15:    Copyright: (c) 2009-2012 Stanford University
19:50:15:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:50:15:         Args: --lifeline 2900 --command-port=36330
19:50:15:       Config: C:/Documents and Settings/Administrator/Application
19:50:15:               Data/FAHClient/config.xml
19:50:15:******************************** Build ********************************
19:50:15:      Version: 7.1.52
19:50:15:         Date: Mar 20 2012
19:50:15:         Time: 19:37:42
19:50:15:      SVN Rev: 3515
19:50:15:       Branch: fah/trunk/client
19:50:15:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
19:50:15:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
19:50:15:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
19:50:15:     Platform: win32 XP
19:50:15:         Bits: 32
19:50:15:         Mode: Release
19:50:15:******************************* System ********************************
19:50:15:          CPU: Intel(R) Pentium(R) D CPU 3.20GHz
19:50:15:       CPU ID: GenuineIntel Family 15 Model 6 Stepping 5
19:50:15:         CPUs: 2
19:50:15:       Memory: 2.00GiB
19:50:15:  Free Memory: 912.48MiB
19:50:15:      Threads: WINDOWS_THREADS
19:50:15:   On Battery: false
19:50:15:   UTC offset: -7
19:50:15:          PID: 2920
19:50:15:          CWD: C:/Documents and Settings/Administrator/Application
19:50:15:           OS: Microsoft Windows XP Service Pack 2
19:50:15:      OS Arch: X86
19:50:15:         GPUs: 1
19:50:15:        GPU 0: ATI:4 Redwood [Radeon HD 5670]
19:50:15:         CUDA: Not detected
19:50:15:Win32 Service: false
19:50:15:***********************************************************************
19:50:15:<config>
19:50:15:  <!-- Folding Slot Configuration -->
19:50:15:  <gpu v='true'/>
19:50:15:
19:50:15:  <!-- Network -->
19:50:15:  <proxy v=':8080'/>
19:50:15:
19:50:15:  <!-- User Information -->
19:50:15:  <team v='189096'/>
19:50:15:  <user v='Captain_Morgan_BzC'/>
19:50:15:
19:50:15:  <!-- Folding Slots -->
19:50:15:  <slot id='0' type='GPU'/>
19:50:15:  <slot id='1' type='SMP'/>
19:50:15:</config>
Re: Radeon 5670 issue
Hello MWebber, welcome to the forum.
Driver clean and then go to v11.10 driver. People had good luck with that version.
MWebber
Post by MWebber »
Thank you, I'll try that tomorrow.
Also consider running Windows Update more frequently. ;)
