Multiple GPU Setup
lothar863
Multiple GPU Setup
Post by lothar863 »
I have 2 GPU's in my system.
One is and older 4870 used for secondary monitors
One is a newer 7770 used for primary displays
I am having issues setting these up to fold
the 4870 is found and the status is ready on the slot but on the work que it sits at download
The 7770 is not detected. I have tried manually adding the slots and disabling the 4870 but it still does not see the 7770 at all.
I am using the GPUs.txt from here:
https://fah-web.stanford.edu/file-relea ... c/GPUs.txt
in the program data folder.
Here is the client control;
If anyone knows how to get this folding that would be great and I could get alot more work done for the program.
Re: Multiple GPU Setup
Welcome to foldingforum.org, lothar863.
A year ago, FAH announced that the HD4xxx and earlier ATI GPUs would be deprecated. No new projects are being developed for it and it has taken until now to finish most of the projects for that platform. ATI and Stanford have put all of their GPU development efforts into OpenCL. See the discussion here: viewtopic.php?f=51&t=21337
IMHO, the HD 7770 should be supported. Perhaps you have an unusual model which has not been whitelisted (see viewtopic.php?f=83&t=21205)
I see that 0x1002:0x9446:1:3:RV770 ATI FirePro V7770 (FireGL) is listed, so maybe there's a problem with the drivers.
run "fahclient --lspci" from the fahclient folder and post the output here.
