F@H Online Inactive
camb003
F@H Online Inactive
Post by camb003 »
Just installed V. 7.1.52 on Windows XP Pro running AMD Athlon 64 X2 4400+ Brisbane 2.3GHz with Radeon 4670 on Comcast cable.
When installing chose Custom and selected GPU setting.
Results:
Client: local Online inactive.
What do I need to make program download and fold?
Thanks.
iceman1992
Re: F@H Online Inactive
Post by iceman1992 »
I saw a post somewhere saying that the Radeon 4870 is going to be deprecated soon, so that means no more work for that series of GPUs. I'm wondering if that's what's happening to your 4670. Can you post the log please?
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Post by Jesse_V »
Welcome to the forum camb003!
The "local Online inactive" means that the client you are looking at is the one on the localhost (your machine) as opposed to a connection to another machine (which V7 can do). It was able to connect and get information from this client, so that's why it says "Online". I believe the "inactive" means it's shut down and not folding. Once it is set up, the client then contacts the F@h server and requests work. It seems that it's not folding either because it was unable to connect, or the server couldn't give it work for it to do. Everything is set up, you don't need to download anything more.
In any case, the log will show a lot of useful information. Under "Advanced" mode (available from drop down menu in upper right hand corner) you should see a Log tab. Copy that and paste it here, in between Code tags (available if you press the Full Editor button). That way we can see what is going on and further help you. Thanks.
camb003
Post by camb003 »
I copied the log with code but it won't post. Used the Full Editor and click "Code" before and after log. What am I missing?
Jesse_V
CPU: i7-6700k
RAM: 24 GB DDR4
Post by Jesse_V »
camb003 wrote:I copied the log with code but it won't post. Used the Full Editor and click "Code" before and after log. What am I missing?
Try placing the log in between the tags. There's an opening tag and a closing tag, just like HTML. So paste the log in between: Did it give you an error message that your post is too long?
camb003
Post by camb003 »
*********************** Log Started 2012-05-03T02:46:35Z ***********************
02:46:35:************************* Folding@home Client *************************
02:46:35:      Website: http://folding.stanford.edu/
02:46:35:    Copyright: (c) 2009-2012 Stanford University
02:46:35:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:46:35:         Args: --lifeline 3972 --command-port=36330
02:46:35:       Config: C:/Documents and Settings/Carlos/Application
02:46:35:               Data/FAHClient/config.xml
02:46:35:******************************** Build ********************************
02:46:35:      Version: 7.1.52
02:46:35:         Date: Mar 20 2012
02:46:35:         Time: 19:37:42
02:46:35:      SVN Rev: 3515
02:46:35:       Branch: fah/trunk/client
02:46:35:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
02:46:35:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
02:46:35:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
02:46:35:     Platform: win32 XP
02:46:35:         Bits: 32
02:46:35:         Mode: Release
02:46:35:******************************* System ********************************
02:46:35:          CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 4400+
02:46:35:       CPU ID: AuthenticAMD Family 15 Model 107 Stepping 1
02:46:35:         CPUs: 2
02:46:35:       Memory: 2.00GiB
02:46:35:  Free Memory: 1.18GiB
02:46:35:      Threads: WINDOWS_THREADS
02:46:35:   On Battery: false
02:46:35:   UTC offset: -7
02:46:35:          PID: 4896
02:46:35:          CWD: C:/Documents and Settings/Carlos/Application Data/FAHClient
02:46:35:           OS: Microsoft Windows XP Service Pack 3
02:46:35:      OS Arch: X86
02:46:35:         GPUs: 1
02:46:35:        GPU 0: ATI:3 RV730XT [Radeon HD 4670]
02:46:35:         CUDA: Not detected
02:46:35:Win32 Service: false
02:46:35:***********************************************************************
02:46:35:<config>
02:46:35:  <!-- Folding Slot Configuration -->
02:46:35:  <gpu v='true'/>
02:46:35:  <smp v='false'/>
02:46:35:
02:46:35:  <!-- Folding Slots -->
02:46:35:</config>
02:46:35:Trying to access database...
02:46:35:Successfully acquired database lock
02:46:35:Enabled folding slot 00: READY gpu:0:"RV730XT [Radeon HD 4670]"
02:46:35:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
02:46:35:WU00:FS00:News: Welcome to Folding@Home
02:46:35:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
02:46:35:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
02:46:35:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
02:46:35:ERROR:WU00:FS00:Exception: Could not get an assignment
02:46:38:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
02:46:47:Server connection id=2 on 0.0.0.0:36330 from 127.0.0.1
02:47:35:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
02:47:35:WU00:FS00:News: Welcome to Folding@Home
02:47:35:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
02:47:35:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
02:47:35:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
02:47:35:ERROR:WU00:FS00:Exception: Could not get an assignment
02:49:12:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
02:49:13:WU00:FS00:News: Welcome to Folding@Home
02:49:13:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
02:49:13:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
02:49:13:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
02:49:13:ERROR:WU00:FS00:Exception: Could not get an assignment
02:51:50:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
02:51:50:WU00:FS00:News: Welcome to Folding@Home
02:51:50:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
02:51:50:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
02:51:50:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
02:51:50:ERROR:WU00:FS00:Exception: Could not get an assignment
02:55:27:Server connection id=2 ended
02:55:28:Server connection id=3 on 0.0.0.0:36330 from 127.0.0.1
02:56:04:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
02:56:04:WU00:FS00:News: Welcome to Folding@Home
02:56:04:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
02:56:04:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
02:56:04:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
02:56:04:ERROR:WU00:FS00:Exception: Could not get an assignment
02:59:50:Server connection id=3 ended
03:02:55:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
03:02:55:WU00:FS00:News: Welcome to Folding@Home
03:02:55:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
03:02:55:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
03:02:55:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
03:02:55:ERROR:WU00:FS00:Exception: Could not get an assignment
iceman1992
That means there is no available WUs for your GPU, unfortunately. There is nothing wrong with your client.
Welcome to foldingforum,org, camb003.
The HD 4xxx series is expected to be deprecated soon for FAH GPU processing. Current projects are gradually running out of work and I doubt there will be any new ones.
Your choices are:
> Keep trying to get GPU work and be patient when there is none.
> Enable a Uniprocessor slot, which will always get work which is compatible with the GPU either running or not running.
> Disable the GPU slot and enable a SMP slot
> Disable the GPU slot and enable two uniprocessor slots.
If it were me, I'd choose the third option.
camb003
Post by camb003 »
I think I will choose the third option. Where do I disable GPU slot and enable SMP slot? Thanks.
Jesse_V
CPU: i7-6700k
RAM: 24 GB DDR4
Post by Jesse_V »
camb003 wrote:I think I will choose the third option. Where do I disable GPU slot and enable SMP slot? Thanks.
I'd recommend that you reconfigure after you finish WUs, so that they don't time out and get reassigned to someone else to process all over again. Hit the Finish button to do that, and wait till they all complete. Then, if you click the Configure button and go to the Slots tab, you'll see what you've set up. You can then remove your GPU slot and then add an SMP slot.
camb003
Post by camb003 »
Great, thanks. I'll try that and start folding. By the way I think it never stated folding for the reason stated above. "That means there is no available WUs for your GPU, unfortunately. There is nothing wrong with your client."
Jesse_V
CPU: i7-6700k
RAM: 24 GB DDR4
Post by Jesse_V »
camb003 wrote:Great, thanks. I'll try that and start folding. By the way I think it never stated folding for the reason stated above. "That means there is no available WUs for your GPU, unfortunately. There is nothing wrong with your client."
True. Maybe it should. "Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment" Is the technical way of saying it I guess. :D
camb003
Post by camb003 »
Now it says Online Running. So I take it it's folding alright.
Neverland
Hardware configuration: i5 2500 4gb ram
Windows 7
Post by Neverland »
I have had this "Online Inactive" for a while. I set the Slots to just SMP, but it is still Inactive.
The Log reads as follows. I would appreciate some guidance.
03:06:51:  <!-- User Information -->
03:06:51:  <passkey v='********************************'/>
03:06:51:  <team v='90478'/>
03:06:51:  <user v='Neverland'/>
03:06:51:
03:06:51:  <!-- Folding Slots -->
03:06:51:  <slot id='0' type='SMP'>
03:06:51:    <cpus v='-1'/>
03:06:51:  </slot>
03:06:51:</config>
03:06:52:WU01:FS00:News: Welcome to Folding@Home
03:06:52:WU01:FS00:Assigned to work server 171.67.108.60
03:06:52:WU01:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.60
03:06:52:WU01:FS00:Connecting to 171.67.108.60:8080
03:06:53:WU01:FS00:Downloading 865.94KiB
03:06:55:WU01:FS00:Download complete
03:06:55:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:OK project:8013 run:112 clone:11 gen:20 core:0xa4 unit:0x0000001b6652edcc4f72bcb929ef78cc
03:09:41:WU01:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/x86/Core_a4.fah
03:09:41:WU01:FS00:Connecting to www.stanford.edu:80
03:09:41:ERROR:WU01:FS00:Exception: Failed to read stream
Hello Neverland, welcome to the forum.
You have software or hardware blocking the connection to Stanford. Make sure that any Anti-Virus or Firewall is configured to allow the client to connect to the internet to download work units.
