Hi,
Where do I put the new GPUs.txt file on Mac OS X?
GPUs.txt on Mac [GPUs not supported on OS-X]
willwinuk
- Hardware configuration: Macbook Pro 13" (late '13), 2.4 GHz Intel Core i5, 8 GB RAM.
--William Cody Winter--
Ravage7779
- Hardware configuration: .
6x Intel i3-4130 (4) @ 3.400GHz
Apple M1 (8) @ 3.2 GHz
AMD Ryzen 5 5500U (12) @ 4.06 GHz
Intel Core i7-9700 (8) @ 4.70 GHz
AMD Ryzen 7 5700G (16) @ 4.67 GHz
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
Re: GPUs.txt on Mac
AFAIK, GPU folding is not supported in Mac OS X at this time, though I think it may in the future. I think there's a feature request ticket out there for the V7 to mention that, but from what I've read it will set itself up fine, but be unable to get any work from the servers. See the client will connect to the F@h servers and request work. The servers will then look around and see what they have that supports that OS and the hardware. It seems that right now the servers will be unable to send you WUs for your GPU. That's not V7's fault, and I don't think there's much you can do about it. Just fold on with your CPU!
