Does this have what it needs to function in a GPU slot in 7.1.52 or should I just stay w/ SMP ? ( processor is a Turion X2 Dual-Core Mobile RM-70 2 Ghz and 4GB ram on 64 bit Vista Home Premium ).
Thanks in advance for feedback/advice
Radeon HD 3200 Graphics ?
- Hardware configuration: GIGABYTE GA-P55A-UD3 LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Intel Core i7-860 Lynnfield 2.8GHz 8MB L3 Cache LGA 1156 95W Quad-Core Processor BX80605I7860
16 Gb ram
PNY VCGGTS2501XPB GeForce GTS 250 1GB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
Kingston SSDNow V Series SNV425-S2/64GB 2.5" 64GB SATA II Internal Solid State Drive (SSD)
GIGABYTE GA-P55A-UD3 LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX Intel MB
Intel Core i7-860 Lynnfield 2.8GHz 8MB L3 Cache LGA 1156 95W Quad-Core Proc.BX80605I7860
16Gb ram
16Gb ram
Re: Radeon HD 3200 Graphics ?
It should be able to fold, but it may not be powerful enough to meet all of the deadlines and, due to the AMD core requiring a lot of CPU time, it'll drag down your SMP frame times significantly. The recommendation with integrated AMD GPUs is usually to skip them since you'll earn more points with SMP alone than SMP/GPU or uniprocessor/GPU.
16 Gb ram
Thank you!
16Gb ram
16Gb ram
