Firstly, let me thank you for all the effort that you guys are putting in to keep folding at home alive and kicking. Its really good to be a part of something this spectacular. However I have a problem. (Not so much a problem as a minor inconvenience).
My setup:
Windows 7 Home Premium 64 bit SP1
AMD Phenom 1090T o/clocked 3850 MHz
8GB o/clocked G.Skill RAM @ 1920 MHz (9/9/9/24)
ASUS ROG Crosshair V AMD 990FX/SB950 mainboard
- - I am running GPU folding on two NVidia GTX480s in SLI and have set them up correctly. (different machine IDs etc).
- Both cards are underclocked slightly and have higher settings for fan speed. I did this using MSI Afterburner (650MHz from 700MHz) due to power draw and heat. (Maximum load on both cards at factory clock is enough to cause the power protection on my 1200W PSU to trip out).
- I am also running the SMP client, folding on 3 cores of the CPU. (Keeps the temperatures down and enables me to use the PC whilst folding).
- I have recently updated the graphics drivers to NVidia's 296.1 driver having had problems with the 295.x driver not picking up new work units when the monitor went into "sleep" mode. I have also disabled the "sleep" mode for the monitor due to this problem.
- All overclocks have been extensivley stability tested using prime95, memtest etc.
New problem:
Both GPUs now seem to be on a new project (7643) and are only running at 86% load in their underclocked state. I can't seem to narrow down the reason for this as I have changed too many variables recently to ascertain the source of the issue.
What I've done that may have caused it, or my best guesses as to the cause:
- 1. Updated the graphics driver?
2. New project doesn't use as much load? (Unlikely I'd have thought).
3. Changed the properties of the shortcuts to disable visual themes? (Thought this might give a slight performance boost but I'll change it back if it's the problem).
4. Set the graphics to SLI performance mode? (Never made a difference before. . . Does it now?)
5. I have also just noticed that a newer version of fahcore_15.exe was aquired before undertaking these new projects as the previous on I had was "out of date". Is this a problem with the design of the new core or possibly a measure taken to ensure stability during testing of the new core?
Thanks all.
{RaW}Eagle1 of The {RaW}Gaming team (208841)
