129.74.85.15 & 16
PeterA
Hardware configuration: PC: AMD Sempron(tm) Processor 2800+, 1024 MB RAM, Microsoft Windows XP (Home Edition) SP3
Laptop: Mobile AMD Sempron(tm) Processor 3500+, 896 MB RAM, Microsoft Windows Vista (Home Premium)
129.74.85.15 & 16
Post by PeterA »
I'm trying to upload a finished WU and I am getting the following:
*********************** Log Started 2012-04-02T17:21:25Z ***********************
17:21:25:************************* Folding@home Client *************************
17:21:25:      Website: http://folding.stanford.edu/
17:21:25:    Copyright: (c) 2009-2012 Stanford University
17:21:25:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:21:25:         Args: --lifeline 6304 --command-port=36330
17:21:25:       Config: C:/Users/Peter/AppData/Roaming/FAHClient/config.xml
17:21:25:******************************** Build ********************************
17:21:25:      Version: 7.1.52
17:21:25:         Date: Mar 20 2012
17:21:25:         Time: 19:37:42
17:21:25:      SVN Rev: 3515
17:21:25:       Branch: fah/trunk/client
17:21:25:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
17:21:25:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
17:21:25:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
17:21:25:     Platform: win32 XP
17:21:25:         Bits: 32
17:21:25:         Mode: Release
17:21:25:******************************* System ********************************
17:21:25:          CPU: AMD Athlon(tm) II P360 Dual-Core Processor
17:21:25:       CPU ID: AuthenticAMD Family 16 Model 6 Stepping 3
17:21:25:         CPUs: 2
17:21:25:       Memory: 3.75GiB
17:21:25:  Free Memory: 1.70GiB
17:21:25:      Threads: WINDOWS_THREADS
17:21:25:   On Battery: false
17:21:25:   UTC offset: -5
17:21:25:          PID: 3500
17:21:25:          CWD: C:/Users/Peter/AppData/Roaming/FAHClient
17:21:25:           OS: Windows 7 Home Premium
17:21:25:      OS Arch: AMD64
17:21:25:         GPUs: 1
17:21:25:        GPU 0: ATI:3 M880G [Mobility Radeon HD 4200]
17:21:25:         CUDA: Not detected
17:21:25:Win32 Service: false
17:21:25:***********************************************************************
17:21:25:<config>
17:21:25:  <!-- Network -->
17:21:25:  <proxy v=':8080'/>
17:21:25:
17:21:25:  <!-- Slot Control -->
17:21:25:  <pause-on-battery v='true'/>
17:21:25:
17:21:25:  <!-- User Information -->
17:21:25:  <team v='11108'/>
17:21:25:  <user v='Peter_Arcand'/>
17:21:25:
17:21:25:  <!-- Folding Slots -->
17:21:25:  <slot id='0' type='SMP'/>
17:21:25:</config>
17:21:25:Trying to access database...
17:21:25:Successfully acquired database lock
17:21:25:Enabled folding slot 00: READY smp:2
17:21:25:WU01:FS00:Sending unit results: id:01 state:SEND error:OK project:7007 run:0 clone:74 gen:62 core:0xa4 unit:0x000000900001329c4dfb903209081d98
17:21:25:WU01:FS00:Uploading 1.70MiB to 129.74.85.15
17:21:25:WU00:FS00:Connecting to assign3.stanford.edu:8080
17:21:25:WU01:FS00:Connecting to 129.74.85.15:8080
17:21:28:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
17:21:46:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
17:21:46:WU01:FS00:Connecting to 129.74.85.15:80
17:21:46:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
17:21:46:WU00:FS00:Connecting to assign4.stanford.edu:80
17:21:47:WU00:FS00:News: Welcome to Folding@Home
17:21:47:WU00:FS00:Assigned to work server 171.67.108.58
17:21:47:WU00:FS00:Requesting new work unit for slot 00: READY smp:2 from 171.67.108.58
17:21:47:WU00:FS00:Connecting to 171.67.108.58:8080
17:22:08:WU01:FS00:Upload 3.68%
17:22:08:WARNING:WU01:FS00:Exception: Failed to send results to work server: Transfer failed
17:22:08:WU01:FS00:Trying to send results to collection server
17:22:08:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
17:22:08:WU00:FS00:Connecting to 171.67.108.58:80
17:22:08:WU01:FS00:Uploading 1.70MiB to 129.74.85.16
17:22:08:WU01:FS00:Connecting to 129.74.85.16:8080
17:22:08:WU00:FS00:Downloading 533.61KiB
17:22:10:WU00:FS00:Download complete
17:22:10:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:OK project:8001 run:108 clone:95 gen:13 core:0xa4 unit:0x000000116652edca4edee10775496f56
17:22:10:WU00:FS00:Starting
17:22:10:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Peter/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 701 -lifeline 3500 -checkpoint 15 -np 2
17:22:10:WU00:FS00:Started FahCore on PID 704
17:22:10:WU00:FS00:Core PID:3812
17:22:10:WU00:FS00:FahCore 0xa4 started
17:22:11:WU00:FS00:0xa4:
17:22:11:WU00:FS00:0xa4:*------------------------------*
17:22:11:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
17:22:11:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
17:22:11:WU00:FS00:0xa4:Preparing to commence simulation
17:22:11:WU00:FS00:0xa4:- Looking at optimizations...
17:22:11:WU00:FS00:0xa4:- Created dyn
17:22:11:WU00:FS00:0xa4:- Files status OK
17:22:11:WU00:FS00:0xa4:- Expanded 545902 -> 1306176 (decompressed 239.2 percent)
17:22:11:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=545902 data_size=1306176, decompressed_data_size=1306176 diff=0
17:22:11:WU00:FS00:0xa4:- Digital signature verified
17:22:11:WU00:FS00:0xa4:Project: 8001 (Run 108, Clone 95, Gen 13)
17:22:11:WU00:FS00:0xa4:Assembly optimizations on if available.
17:22:11:WU00:FS00:0xa4:Entering M.D.
17:22:17:WU00:FS00:0xa4:Mapping NT from 2 to 2
17:22:17:WU00:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
17:22:29:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
17:22:29:WU01:FS00:Connecting to 129.74.85.16:80
17:22:50:WU01:FS00:Upload 3.68%
17:22:50:ERROR:WU01:FS00:Exception: Transfer failed
17:22:50:WU01:FS00:Sending unit results: id:01 state:SEND error:OK project:7007 run:0 clone:74 gen:62 core:0xa4 unit:0x000000900001329c4dfb903209081d98
17:22:51:WU01:FS00:Uploading 1.70MiB to 129.74.85.15
17:22:51:WU01:FS00:Connecting to 129.74.85.15:8080
17:23:12:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
17:23:12:WU01:FS00:Connecting to 129.74.85.15:80
17:23:33:WU01:FS00:Upload 3.68%
17:23:33:WARNING:WU01:FS00:Exception: Failed to send results to work server: Transfer failed
17:23:33:WU01:FS00:Trying to send results to collection server
17:23:34:WU01:FS00:Uploading 1.70MiB to 129.74.85.16
17:23:34:WU01:FS00:Connecting to 129.74.85.16:8080
17:23:55:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
17:23:55:WU01:FS00:Connecting to 129.74.85.16:80
17:24:16:WU01:FS00:Upload 3.68%
17:24:16:ERROR:WU01:FS00:Exception: Transfer failed
17:24:16:WU01:FS00:Sending unit results: id:01 state:SEND error:OK project:7007 run:0 clone:74 gen:62 core:0xa4 unit:0x000000900001329c4dfb903209081d98
17:24:16:WU01:FS00:Uploading 1.70MiB to 129.74.85.15
17:24:16:WU01:FS00:Connecting to 129.74.85.15:8080
17:24:37:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
17:24:37:WU01:FS00:Connecting to 129.74.85.15:80
17:25:01:WU01:FS00:Upload 3.68%
17:25:01:WARNING:WU01:FS00:Exception: Failed to send results to work server: Transfer failed
17:25:01:WU01:FS00:Trying to send results to collection server
17:25:02:WU01:FS00:Uploading 1.70MiB to 129.74.85.16
17:25:02:WU01:FS00:Connecting to 129.74.85.16:8080
17:25:23:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
17:25:23:WU01:FS00:Connecting to 129.74.85.16:80
17:26:02:WU01:FS00:Upload 3.68%
17:26:02:ERROR:WU01:FS00:Exception: Transfer failed
17:26:02:WU01:FS00:Sending unit results: id:01 state:SEND error:OK project:7007 run:0 clone:74 gen:62 core:0xa4 unit:0x000000900001329c4dfb903209081d98
17:26:02:WU01:FS00:Uploading 1.70MiB to 129.74.85.15
17:26:02:WU01:FS00:Connecting to 129.74.85.15:8080
17:26:23:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
17:26:23:WU01:FS00:Connecting to 129.74.85.15:80
17:26:24:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 129.74.85.15:80: No connection could be made because the target machine actively refused it.
17:26:24:WU01:FS00:Trying to send results to collection server
17:26:24:WU01:FS00:Uploading 1.70MiB to 129.74.85.16
17:26:24:WU01:FS00:Connecting to 129.74.85.16:8080
17:26:45:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
17:26:45:WU01:FS00:Connecting to 129.74.85.16:80
17:26:59:ERROR:WU01:FS00:Exception: Failed to connect to 129.74.85.16:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
17:27:13:WU00:FS00:0xa4:Completed 2500 out of 250000 steps  (1%)
17:28:39:WU01:FS00:Sending unit results: id:01 state:SEND error:OK project:7007 run:0 clone:74 gen:62 core:0xa4 unit:0x000000900001329c4dfb903209081d98
17:28:39:WU01:FS00:Uploading 1.70MiB to 129.74.85.15
17:28:39:WU01:FS00:Connecting to 129.74.85.15:8080
17:29:00:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
17:29:00:WU01:FS00:Connecting to 129.74.85.15:80
17:29:04:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 129.74.85.15:80: No connection could be made because the target machine actively refused it.
17:29:04:WU01:FS00:Trying to send results to collection server
17:29:04:WU01:FS00:Uploading 1.70MiB to 129.74.85.16
17:29:04:WU01:FS00:Connecting to 129.74.85.16:8080
17:29:25:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
17:29:25:WU01:FS00:Connecting to 129.74.85.16:80
17:29:27:ERROR:WU01:FS00:Exception: Failed to connect to 129.74.85.16:80: No connection could be made because the target machine actively refused it.
17:32:38:WU00:FS00:0xa4:Completed 5000 out of 250000 steps  (2%)
17:32:53:WU01:FS00:Sending unit results: id:01 state:SEND error:OK project:7007 run:0 clone:74 gen:62 core:0xa4 unit:0x000000900001329c4dfb903209081d98
17:32:53:WU01:FS00:Uploading 1.70MiB to 129.74.85.15
17:32:53:WU01:FS00:Connecting to 129.74.85.15:8080
17:33:14:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
17:33:14:WU01:FS00:Connecting to 129.74.85.15:80
17:33:16:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 129.74.85.15:80: No connection could be made because the target machine actively refused it.
17:33:16:WU01:FS00:Trying to send results to collection server
17:33:16:WU01:FS00:Uploading 1.70MiB to 129.74.85.16
17:33:16:WU01:FS00:Connecting to 129.74.85.16:8080
17:33:37:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
17:33:37:WU01:FS00:Connecting to 129.74.85.16:80
17:33:44:ERROR:WU01:FS00:Exception: Failed to connect to 129.74.85.16:80: No connection could be made because the target machine actively refused it.
17:39:45:WU01:FS00:Sending unit results: id:01 state:SEND error:OK project:7007 run:0 clone:74 gen:62 core:0xa4 unit:0x000000900001329c4dfb903209081d98
17:39:45:WU01:FS00:Uploading 1.70MiB to 129.74.85.15
17:39:45:WU01:FS00:Connecting to 129.74.85.15:8080
17:40:06:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
17:40:06:WU01:FS00:Connecting to 129.74.85.15:80
17:40:07:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 129.74.85.15:80: No connection could be made because the target machine actively refused it.
17:40:07:WU01:FS00:Trying to send results to collection server
17:40:07:WU01:FS00:Uploading 1.70MiB to 129.74.85.16
17:40:07:WU01:FS00:Connecting to 129.74.85.16:8080
17:40:21:WU00:FS00:0xa4:Completed 7500 out of 250000 steps  (3%)
17:40:28:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
17:40:28:WU01:FS00:Connecting to 129.74.85.16:80
17:40:30:ERROR:WU01:FS00:Exception: Failed to connect to 129.74.85.16:80: No connection could be made because the target machine actively refused it.
17:46:57:WU00:FS00:0xa4:Completed 10000 out of 250000 steps  (4%)
17:50:50:WU01:FS00:Sending unit results: id:01 state:SEND error:OK project:7007 run:0 clone:74 gen:62 core:0xa4 unit:0x000000900001329c4dfb903209081d98
17:50:51:WU01:FS00:Uploading 1.70MiB to 129.74.85.15
17:50:51:WU01:FS00:Connecting to 129.74.85.15:8080
17:51:12:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
17:51:12:WU01:FS00:Connecting to 129.74.85.15:80
17:51:25:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 129.74.85.15:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
17:51:25:WU01:FS00:Trying to send results to collection server
17:51:25:WU01:FS00:Uploading 1.70MiB to 129.74.85.16
17:51:25:WU01:FS00:Connecting to 129.74.85.16:8080
17:51:46:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
17:51:46:WU01:FS00:Connecting to 129.74.85.16:80
17:51:50:ERROR:WU01:FS00:Exception: Failed to connect to 129.74.85.16:80: No connection could be made because the target machine actively refused it.
17:55:34:WU00:FS00:0xa4:Completed 12500 out of 250000 steps  (5%)
I checked the server status and it appears to be normal. Any idea what's up??
PeterA
Re: 129.74.85.15 & 16
Post by PeterA »
Don't know what happened, but everything upload fine this morning. Server problem fixed? Maybe I should keep quiet (I don't want to jink it). :lol:
PeterA wrote:Server problem fixed?
Apparently so. I gave the server owner a heads-up late last night so they probably fixed something early this morning. That's the whole purpose of this forum topic -- to catch problems that aren't apparent using the "normal" monitoring functions like serverstat.
nogginthenog
Re: 129.74.85.16 - repeated failure to upload completely
Post by nogginthenog »
*********************** Log Started 2012-07-13T09:42:01Z ***********************
09:42:01:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:7006 run:0 clone:141 gen:52 core:0xa4 unit:0x000000880001329c4dfb8ea9f21c0b82
09:42:01:WU00:FS00:Uploading 1.82MiB to 129.74.85.15
09:42:01:WU00:FS00:Connecting to 129.74.85.15:8080
09:42:22:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
09:42:22:WU00:FS00:Connecting to 129.74.85.15:80
09:42:43:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 129.74.85.15:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:42:43:WU00:FS00:Trying to send results to collection server
09:42:43:WU00:FS00:Uploading 1.82MiB to 129.74.85.16
09:42:43:WU00:FS00:Connecting to 129.74.85.16:8080
09:43:04:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
09:43:04:WU00:FS00:Connecting to 129.74.85.16:80
09:43:25:ERROR:WU00:FS00:Exception: Failed to connect to 129.74.85.16:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:43:26:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:7006 run:0 clone:141 gen:52 core:0xa4 unit:0x000000880001329c4dfb8ea9f21c0b82
09:43:26:WU00:FS00:Uploading 1.82MiB to 129.74.85.15
09:43:26:WU00:FS00:Connecting to 129.74.85.15:8080
09:43:47:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
09:43:47:WU00:FS00:Connecting to 129.74.85.15:80
09:46:56:WU00:FS00:Upload 3.44%
09:46:56:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
09:46:56:WU00:FS00:Trying to send results to collection server
09:46:56:WU00:FS00:Uploading 1.82MiB to 129.74.85.16
09:46:56:WU00:FS00:Connecting to 129.74.85.16:8080
09:48:04:WU00:FS00:Upload 3.44%
09:54:08:WU00:FS00:Upload 6.89%
09:54:08:ERROR:WU00:FS00:Exception: Transfer failed
09:54:08:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:7006 run:0 clone:141 gen:52 core:0xa4 unit:0x000000880001329c4dfb8ea9f21c0b82
09:54:08:WU00:FS00:Uploading 1.82MiB to 129.74.85.15
09:54:08:WU00:FS00:Connecting to 129.74.85.15:8080
09:54:44:WU00:FS00:Upload 3.44%
09:54:56:WU00:FS00:Upload 6.89%
09:56:34:WU00:FS00:Upload 10.33%
09:56:34:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
09:56:34:WU00:FS00:Trying to send results to collection server
09:56:34:WU00:FS00:Uploading 1.82MiB to 129.74.85.16
09:56:34:WU00:FS00:Connecting to 129.74.85.16:8080
09:56:55:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
09:56:55:WU00:FS00:Connecting to 129.74.85.16:80
09:57:16:ERROR:WU00:FS00:Exception: Failed to connect to 129.74.85.16:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:57:17:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:7006 run:0 clone:141 gen:52 core:0xa4 unit:0x000000880001329c4dfb8ea9f21c0b82
09:57:17:WU00:FS00:Uploading 1.82MiB to 129.74.85.15
09:57:17:WU00:FS00:Connecting to 129.74.85.15:8080
09:57:31:WU00:FS00:Upload 3.44%
09:57:37:WU00:FS00:Upload 6.89%
09:57:49:WU00:FS00:Upload 10.33%
10:01:25:WU00:FS00:Upload 13.77%
10:01:25:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
10:01:25:WU00:FS00:Trying to send results to collection server
10:01:25:WU00:FS00:Uploading 1.82MiB to 129.74.85.16
10:01:25:WU00:FS00:Connecting to 129.74.85.16:8080
10:01:46:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
10:01:46:WU00:FS00:Connecting to 129.74.85.16:80
10:02:07:ERROR:WU00:FS00:Exception: Failed to connect to 129.74.85.16:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:02:08:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:7006 run:0 clone:141 gen:52 core:0xa4 unit:0x000000880001329c4dfb8ea9f21c0b82
10:02:08:WU00:FS00:Uploading 1.82MiB to 129.74.85.15
10:02:08:WU00:FS00:Connecting to 129.74.85.15:8080
10:02:29:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
10:02:29:WU00:FS00:Connecting to 129.74.85.15:80
10:02:34:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 129.74.85.15:80: No connection could be made because the target machine actively refused it.
10:02:34:WU00:FS00:Trying to send results to collection server
10:02:34:WU00:FS00:Uploading 1.82MiB to 129.74.85.16
10:02:34:WU00:FS00:Connecting to 129.74.85.16:8080
10:03:24:WU00:FS00:Upload 3.44%
10:03:37:WU00:FS00:Upload 6.89%
10:04:11:WU00:FS00:Upload 10.33%
10:05:13:WU00:FS00:Upload 13.77%
10:05:38:WU00:FS00:Upload 17.22%
10:07:25:WU00:FS00:Upload 20.66%
10:07:48:WU00:FS00:Upload 24.10%
10:07:58:WU00:FS00:Upload 27.55%
10:15:23:WU00:FS00:Upload 30.99%
10:15:23:ERROR:WU00:FS00:Exception: Transfer failed
10:15:23:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:7006 run:0 clone:141 gen:52 core:0xa4 unit:0x000000880001329c4dfb8ea9f21c0b82
10:15:23:WU00:FS00:Uploading 1.82MiB to 129.74.85.15
10:15:23:WU00:FS00:Connecting to 129.74.85.15:8080
10:15:29:WU00:FS00:Upload 10.33%
10:15:36:WU00:FS00:Upload 34.44%
10:15:59:WU00:FS00:Upload 37.88%
10:18:29:WU00:FS00:Upload 41.32%
10:18:29:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
10:18:29:WU00:FS00:Trying to send results to collection server
10:18:29:WU00:FS00:Uploading 1.82MiB to 129.74.85.16
10:18:29:WU00:FS00:Connecting to 129.74.85.16:8080
10:18:35:WU00:FS00:Upload 10.33%
10:18:42:WU00:FS00:Upload 20.66%
10:19:23:WU00:FS00:Upload 27.55%
10:19:29:WU00:FS00:Upload 34.44%
10:19:39:WU00:FS00:Upload 48.21%
10:19:50:WU00:FS00:Upload 55.10%
10:21:03:WU00:FS00:Upload 58.54%
10:21:03:ERROR:WU00:FS00:Exception: Transfer failed
10:22:14:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:7006 run:0 clone:141 gen:52 core:0xa4 unit:0x000000880001329c4dfb8ea9f21c0b82
10:22:14:WU00:FS00:Uploading 1.82MiB to 129.74.85.15
10:22:14:WU00:FS00:Connecting to 129.74.85.15:8080
10:22:27:WU00:FS00:Upload 10.33%
10:23:26:WU00:FS00:Upload 13.77%
10:23:35:WU00:FS00:Upload 24.10%
10:23:44:WU00:FS00:Upload 37.88%
10:24:24:WU00:FS00:Upload 41.32%
10:24:24:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
10:24:24:WU00:FS00:Trying to send results to collection server
10:24:24:WU00:FS00:Uploading 1.82MiB to 129.74.85.16
10:24:24:WU00:FS00:Connecting to 129.74.85.16:8080
10:29:24:WU00:FS00:Upload 3.44%
10:29:24:ERROR:WU00:FS00:Exception: Transfer failed
10:33:20:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:7006 run:0 clone:141 gen:52 core:0xa4 unit:0x000000880001329c4dfb8ea9f21c0b82
10:33:20:WU00:FS00:Uploading 1.82MiB to 129.74.85.15
10:33:20:WU00:FS00:Connecting to 129.74.85.15:8080
10:33:41:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
10:33:41:WU00:FS00:Connecting to 129.74.85.15:80
10:33:50:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 129.74.85.15:80: No connection could be made because the target machine actively refused it.
10:33:50:WU00:FS00:Trying to send results to collection server
10:33:50:WU00:FS00:Uploading 1.82MiB to 129.74.85.16
10:33:50:WU00:FS00:Connecting to 129.74.85.16:8080
10:34:16:WU00:FS00:Upload 3.44%
10:36:22:WU00:FS00:Upload 10.33%
10:36:22:ERROR:WU00:FS00:Exception: Transfer failed
nogginthenog
Seems to have completed eventually !
