FahCore returned an unknown error code which probably indicates that it crashed
I am no sure what do you mean by ***System*** section, but hope this is it:7im wrote:Hello mezhaka, welcome to the forum.
There are more than one possible cause. Please post the ***System*** section of the log file, and then please describe the OS and HW config of this machine. Please also post a bit more more the log before and after the error, so we can see what the client was doing when this failed. Thanks.
02:11:55:WU00:FS00:Running FahCore: "E:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/anton/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 00 -suffix 01 -version 701 -lifeline 7668 -checkpoint 15 -gpu 0
02:11:55:WU00:FS00:Started FahCore on PID 5912
02:11:55:WU00:FS00:Core PID:6356
02:11:55:WU00:FS00:FahCore 0x15 started
02:11:56:WU00:FS00:0x15:
02:11:56:WU00:FS00:0x15:*------------------------------*
02:11:56:WU00:FS00:0x15:Folding@Home GPU Core
02:11:56:WU00:FS00:0x15:Version 2.22 (Thu Dec 8 17:08:05 PST 2011)
02:11:56:WU00:FS00:0x15:Build host SimbiosNvdWin7
02:11:56:WU00:FS00:0x15:Board Type NVIDIA/CUDA
02:11:56:WU00:FS00:0x15:Core 15
02:11:56:WU00:FS00:0x15:Window's signal control handler registered.
02:11:56:WU00:FS00:0x15:Preparing to commence simulation
02:11:56:WU00:FS00:0x15:- Ensuring status. Please wait.
02:12:05:WU00:FS00:0x15:- Looking at optimizations...
02:12:05:WU00:FS00:0x15:- Working with standard loops on this execution.
02:12:05:WU00:FS00:0x15:- Previous termination of core was improper.
02:12:05:WU00:FS00:0x15:- Going to use standard loops.
02:12:05:WU00:FS00:0x15:- Files status OK
02:12:05:WU00:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
02:12:05:WU00:FS00:0x15:- Expanded 119778 -> 542246 (decompressed 452.7 percent)
02:12:05:WU00:FS00:0x15:Called DecompressByteArray: compressed_data_size=119778 data_size=542246, decompressed_data_size=542246 diff=0
02:12:05:WU00:FS00:0x15:- Digital signature verified
02:12:05:WU00:FS00:0x15:Project: 8034 (Run 8, Clone 0, Gen 17)
02:12:05:WU00:FS00:0x15:Entering M.D.
02:12:07:WU00:FS00:0x15:Tpr hash 00/wudata_01.tpr: 3722898689 317970079 1029131593 2824764440 902500743
02:12:07:WU00:FS00:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
02:12:07:WU00:FS00:0x15:Working on Protein
02:12:07:WU00:FS00:0x15:Client config unavailable.
02:12:07:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1 = 0xffffffff)
02:12:07:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
02:12:07:WARNING:WU00:FS00:Too many errors, failing
02:12:07:WU00:FS00:Sending unit results: id:00 state:SEND error:FAILED project:8034 run:8 clone:0 gen:17 core:0x15 unit:0x000000126953ee2e4f72de226aa1212a
02:12:07:WU00:FS00:Connecting to 171.67.108.142:8080
02:12:08:WU00:FS00:Server responded WORK_QUIT (404)
02:12:08:WARNING:WU00:FS00:Server did not like results, dumping
02:12:08:WU00:FS00:Cleaning up
. . . or by clicking on the System Info tab in FAHControl.bollix47 wrote:If you Refresh the log the system section including config can be seen by scrolling up to the top.
08:43:14:******************************** Build ********************************
08:43:14: Version: 7.1.52
08:43:14: Date: Mar 20 2012
08:43:14: Time: 19:37:42
08:43:14: SVN Rev: 3515
08:43:14: Branch: fah/trunk/client
08:43:14: Compiler: Intel(R) C++ MSVC 1500 mode 1200
08:43:14: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
08:43:14: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
08:43:14: Platform: win32 XP
08:43:14: Bits: 32
08:43:14: Mode: Release
08:43:14:******************************* System ********************************
08:43:14: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
08:43:14: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
08:43:14: CPUs: 8
08:43:14: Memory: 7.98GiB
08:43:14: Free Memory: 6.25GiB
08:43:14: Threads: WINDOWS_THREADS
08:43:14: On Battery: false
08:43:14: UTC offset: 2
08:43:14: PID: 4272
08:43:14: CWD: C:/Users/anton/AppData/Roaming/FAHClient
08:43:14: OS: Windows 7 Professional
08:43:14: OS Arch: AMD64
08:43:14: GPUs: 1
08:43:14: GPU 0: FERMI:1 GF116 [GeForce GTX 550 Ti]
08:43:14: CUDA: 2.1
08:43:14: CUDA Driver: 4020
08:43:14:Win32 Service: false
08:43:14:***********************************************************************
I'm not sure how we can help you. Stasnford does not have technicians who will diagnose problems with your hardward. We can guess that you GPU is overclocked or more power is being used than can be provided by your power supply or the heat in the vicinity of the GPU is more than it's happy with, but without your active participation, all we can do is offer suggestions. When a GPU is unstable under load, the cause cannot be determined remotely without you giving us enough information to determine and fix the cause.mezhaka wrote:Concerning the power -- I have no idea how to check if it's "enough" power, i.e. how much is enough?
In general I am not that interested to investigate into this problem on my own. Last months my client stays idle.
