Update your project list
Xavier Zepherious
Post by Xavier Zepherious »
Seems you don't have Wu 6900 listed in your project list even tho the wU been out since last year
Grandpa_01
Re: Update your project list
Post by Grandpa_01 »
The project has actually been out for several years. My guess is it has been completed thus pulled from the list. I have not seen one in a very long time. Plenty of 6901, 03 and 04's but no 6900 so the list is probably up to date.
2 - I7 980X 4.4Ghz 2-GTX680
1 - 2700k 4.4Ghz GTX680
Total = 464 cores folding
Xavier Zepherious
Well I picked one up...so unless the project is over you keep it on the list
Project Summary is updated dynamically, bult from the list of work currently available work units. As a project winds down, there may only be a handful of WUs going out. If the are all assigned when the list is built, they won't get on the list.
Or did you mean the list of project descriptions?
Xavier Zepherious
No im not talking about the the description - you can find that on stanfords webpage
FAh project list or PSUMMARY (that is complete) would be nice so you can get work unit info like tpf, credits, etc
currently Im doing the WU and it shows no points or PPD
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Post by Jesse_V »
6900 has a project description: http://fah-web.stanford.edu/cgi-bin/fah ... ned?p=6900
It does not appear on any of the psummaries. How odd.
Are you also saying that V7 doesn't give a description or other information?
Xavier Zepherious wrote:No im not talking about the the description - you can find that on stanfords webpage
As I said, the PSummary only shows the WUs currently available to be assigned. If the WUs are all sent out and being worked on by donors, it won't show in the PSum list.
However, if you let us know which monitoring tool you are using to show TPF, etc. we'll point you to instructions on how to work around this PSum behavior.
Xavier Zepherious
Im still using FAH GPU Tracker
If I had the project info I could manually update the projects file in the config folder by adding it
ChelseaOilman
Post by ChelseaOilman »
Project ID: 6900
Core: GRO-A5
Credit: 7164
Frames: 100
Xavier Zepherious
I would need
project (I know this)
points
preferred deadline
final deadline
Kfactor
GreyWhiskers
--i7 2600K@4.2 GHz
--ASUS P8P67 DeluxeB3
--4GB ADATA 1600 RAM
--750W Corsair PS
--MSI GTX560Ti @900MHz
Post by GreyWhiskers »
FWIW, here's the info from the last p6900 I processed (probably in Nov 2011 :roll: ). Unless they've changed it. FYI, the project info is at the bottom:
Xavier Zepherious
thx... at least my project list(summary) is updated
PS: it works - had to stop the tracker and restart after
Amaruk
Post by Amaruk »
GreyWhiskers wrote:Unless they've changed it.
Base credit for 6900 is 8597.
viewtopic.php?f=24&t=20788
BWG
Post by BWG »
I am currently folding this project too, and using HFM to monitor my progress. This project is not on psummary.html or psummaryc.html
I know there are other project download url's that do have this project listed on them that I can use, but I am having trouble locating one. Does anyone have a link to one I could use so HFM shows me the PPD, ETA, etc?
Editor for teams 37726 and 239902
BWG
Post by BWG »
Bump
We are getting a few of these projects every month, and the project details are not on any of the psummary pages for HFM to pick up the information to show PPD etc. I fixed this issue once before by using a url to update HFM that had P6900 listed, but I switched both my folding rigs over to native Ubuntu and lost the url.
Can you either put this project back on one of the psummary pages or direct me to some alternate psummary pages? I manage the Team Competition over on OCN. Thanks!
