171.67.108.59
RLHay
Hardware configuration: Intel i5 650, 4GB RAM, Win 7 Pro 64-bit
Post by RLHay »
Hi, I have F@H running on four machines here at work and a fifth at home. In the last week three of the machines (2 here and one at home) have had issues picking up new WU's. The attched log is typical and is from one of the more productive machines, currently sitting idle...
Let me know if you need anything else.
UPDATE: A second machine has just requested a new work unit from the same server and is also failing to be assigned WU's
01:31:57:WU01:FS00:Connecting to 171.67.108.59:8080
01:32:02:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:32:02:WU00:FS00:Connecting to assign4.stanford.edu:80
01:32:03:WU00:FS00:News: Welcome to Folding@Home
01:32:03:WU00:FS00:Assigned to work server 171.67.108.59
01:32:03:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
01:32:03:WU00:FS00:Connecting to 171.67.108.59:8080
01:32:18:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
01:32:18:WU01:FS00:Connecting to 171.67.108.59:80
01:32:19:WU01:FS00:Upload 3.23%
01:32:22:WU01:FS00:Upload complete
01:32:22:WU01:FS00:Server responded WORK_ACK (400)
01:32:22:WU01:FS00:Final credit estimate, 1179.00 points
01:32:22:WU01:FS00:Cleaning up
01:32:24:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
01:32:24:WU00:FS00:Connecting to 171.67.108.59:80
01:32:24:ERROR:WU00:FS00:Exception: Server did not assign work unit
01:32:25:WU00:FS00:Connecting to assign3.stanford.edu:8080
01:32:46:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:32:46:WU00:FS00:Connecting to assign4.stanford.edu:80
01:32:46:WU00:FS00:News: Welcome to Folding@Home
01:32:46:WU00:FS00:Assigned to work server 171.67.108.59
01:32:46:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
01:32:46:WU00:FS00:Connecting to 171.67.108.59:8080
01:33:08:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
01:33:08:WU00:FS00:Connecting to 171.67.108.59:80
01:33:08:ERROR:WU00:FS00:Exception: Server did not assign work unit
01:33:25:WU00:FS00:Connecting to assign3.stanford.edu:8080
01:33:46:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:33:46:WU00:FS00:Connecting to assign4.stanford.edu:80
01:33:47:WU00:FS00:News: Welcome to Folding@Home
01:33:47:WU00:FS00:Assigned to work server 171.67.108.59
01:33:47:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
01:33:47:WU00:FS00:Connecting to 171.67.108.59:8080
01:34:08:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
01:34:08:WU00:FS00:Connecting to 171.67.108.59:80
01:34:08:ERROR:WU00:FS00:Exception: Server did not assign work unit
01:35:02:WU00:FS00:Connecting to assign3.stanford.edu:8080
01:35:23:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:35:23:WU00:FS00:Connecting to assign4.stanford.edu:80
01:35:24:WU00:FS00:News: Welcome to Folding@Home
01:35:24:WU00:FS00:Assigned to work server 171.67.108.59
01:35:24:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
01:35:24:WU00:FS00:Connecting to 171.67.108.59:8080
01:35:45:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
01:35:45:WU00:FS00:Connecting to 171.67.108.59:80
01:35:45:ERROR:WU00:FS00:Exception: Server did not assign work unit
01:37:39:WU00:FS00:Connecting to assign3.stanford.edu:8080
01:38:00:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:38:00:WU00:FS00:Connecting to assign4.stanford.edu:80
01:38:01:WU00:FS00:News: Welcome to Folding@Home
01:38:01:WU00:FS00:Assigned to work server 171.67.108.59
01:38:01:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
01:38:01:WU00:FS00:Connecting to 171.67.108.59:8080
01:38:22:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
01:38:22:WU00:FS00:Connecting to 171.67.108.59:80
01:38:23:ERROR:WU00:FS00:Exception: Server did not assign work unit
01:41:54:WU00:FS00:Connecting to assign3.stanford.edu:8080
01:42:15:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:42:15:WU00:FS00:Connecting to assign4.stanford.edu:80
01:42:15:WU00:FS00:News: Welcome to Folding@Home
01:42:15:WU00:FS00:Assigned to work server 171.67.108.59
01:42:15:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
01:42:15:WU00:FS00:Connecting to 171.67.108.59:8080
01:42:36:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
01:42:36:WU00:FS00:Connecting to 171.67.108.59:80
01:42:37:ERROR:WU00:FS00:Exception: Server did not assign work unit
01:42:37:WU00:FS00:Cleaning up
01:42:37:WU01:FS00:Connecting to assign3.stanford.edu:8080
01:42:58:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:42:58:WU01:FS00:Connecting to assign4.stanford.edu:80
01:42:59:WU01:FS00:News: Welcome to Folding@Home
01:42:59:WU01:FS00:Assigned to work server 171.67.108.59
01:42:59:WU01:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
01:42:59:WU01:FS00:Connecting to 171.67.108.59:8080
01:43:20:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
01:43:20:WU01:FS00:Connecting to 171.67.108.59:80
01:43:20:ERROR:WU01:FS00:Exception: Server did not assign work unit
01:43:20:WU01:FS00:Connecting to assign3.stanford.edu:8080
01:43:42:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:43:42:WU01:FS00:Connecting to assign4.stanford.edu:80
01:43:42:WU01:FS00:News: Welcome to Folding@Home
01:43:42:WU01:FS00:Assigned to work server 171.67.108.59
01:43:42:WU01:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
01:43:42:WU01:FS00:Connecting to 171.67.108.59:8080
01:44:03:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
01:44:03:WU01:FS00:Connecting to 171.67.108.59:80
01:44:04:ERROR:WU01:FS00:Exception: Server did not assign work unit
01:44:21:WU01:FS00:Connecting to assign3.stanford.edu:8080
01:44:42:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:44:42:WU01:FS00:Connecting to assign4.stanford.edu:80
01:44:42:WU01:FS00:News: Welcome to Folding@Home
01:44:42:WU01:FS00:Assigned to work server 171.67.108.59
01:44:42:WU01:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
01:44:42:WU01:FS00:Connecting to 171.67.108.59:8080
01:45:03:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
01:45:03:WU01:FS00:Connecting to 171.67.108.59:80
01:45:04:ERROR:WU01:FS00:Exception: Server did not assign work unit
01:45:58:WU01:FS00:Connecting to assign3.stanford.edu:8080
01:46:19:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:46:19:WU01:FS00:Connecting to assign4.stanford.edu:80
01:46:20:WU01:FS00:News: Welcome to Folding@Home
01:46:20:WU01:FS00:Assigned to work server 171.67.108.59
01:46:20:WU01:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
01:46:20:WU01:FS00:Connecting to 171.67.108.59:8080
01:46:41:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
01:46:41:WU01:FS00:Connecting to 171.67.108.59:80
01:46:41:ERROR:WU01:FS00:Exception: Server did not assign work unit
01:48:35:WU01:FS00:Connecting to assign3.stanford.edu:8080
01:48:56:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:48:56:WU01:FS00:Connecting to assign4.stanford.edu:80
01:48:57:WU01:FS00:News: Welcome to Folding@Home
01:48:57:WU01:FS00:Assigned to work server 171.67.108.59
01:48:57:WU01:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
01:48:57:WU01:FS00:Connecting to 171.67.108.59:8080
01:49:18:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
01:49:18:WU01:FS00:Connecting to 171.67.108.59:80
01:49:18:ERROR:WU01:FS00:Exception: Server did not assign work unit
01:52:49:WU01:FS00:Connecting to assign3.stanford.edu:8080
01:53:11:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:53:11:WU01:FS00:Connecting to assign4.stanford.edu:80
01:53:11:WU01:FS00:News: Welcome to Folding@Home
01:53:11:WU01:FS00:Assigned to work server 171.67.108.59
01:53:11:WU01:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
01:53:11:WU01:FS00:Connecting to 171.67.108.59:8080
01:53:32:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
01:53:32:WU01:FS00:Connecting to 171.67.108.59:80
01:53:33:ERROR:WU01:FS00:Exception: Server did not assign work unit
01:53:33:WU01:FS00:Cleaning up
01:53:33:WU00:FS00:Connecting to assign3.stanford.edu:8080
01:53:54:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:53:54:WU00:FS00:Connecting to assign4.stanford.edu:80
01:53:55:WU00:FS00:News: Welcome to Folding@Home
01:53:55:WU00:FS00:Assigned to work server 171.67.108.59
01:53:55:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
01:53:55:WU00:FS00:Connecting to 171.67.108.59:8080
01:54:16:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
01:54:16:WU00:FS00:Connecting to 171.67.108.59:80
01:54:16:ERROR:WU00:FS00:Exception: Server did not assign work unit
01:54:16:WU00:FS00:Connecting to assign3.stanford.edu:8080
01:54:37:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:54:37:WU00:FS00:Connecting to assign4.stanford.edu:80
01:54:38:WU00:FS00:News: Welcome to Folding@Home
01:54:38:WU00:FS00:Assigned to work server 171.67.108.59
01:54:38:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
01:54:38:WU00:FS00:Connecting to 171.67.108.59:8080
01:54:59:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
01:54:59:WU00:FS00:Connecting to 171.67.108.59:80
01:55:00:ERROR:WU00:FS00:Exception: Server did not assign work unit
01:55:16:WU00:FS00:Connecting to assign3.stanford.edu:8080
01:55:38:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:55:38:WU00:FS00:Connecting to assign4.stanford.edu:80
01:55:38:WU00:FS00:News: Welcome to Folding@Home
01:55:38:WU00:FS00:Assigned to work server 171.67.108.59
01:55:38:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
01:55:38:WU00:FS00:Connecting to 171.67.108.59:8080
01:55:59:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
01:55:59:WU00:FS00:Connecting to 171.67.108.59:80
01:56:00:ERROR:WU00:FS00:Exception: Server did not assign work unit
01:56:54:WU00:FS00:Connecting to assign3.stanford.edu:8080
01:57:15:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:57:15:WU00:FS00:Connecting to assign4.stanford.edu:80
01:57:15:WU00:FS00:News: Welcome to Folding@Home
01:57:15:WU00:FS00:Assigned to work server 171.67.108.59
01:57:15:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
01:57:15:WU00:FS00:Connecting to 171.67.108.59:8080
01:57:36:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
01:57:36:WU00:FS00:Connecting to 171.67.108.59:80
01:57:37:ERROR:WU00:FS00:Exception: Server did not assign work unit
01:59:31:WU00:FS00:Connecting to assign3.stanford.edu:8080
01:59:52:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:59:52:WU00:FS00:Connecting to assign4.stanford.edu:80
01:59:53:WU00:FS00:News: Welcome to Folding@Home
01:59:53:WU00:FS00:Assigned to work server 171.67.108.59
01:59:53:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
01:59:53:WU00:FS00:Connecting to 171.67.108.59:8080
02:00:14:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
02:00:14:WU00:FS00:Connecting to 171.67.108.59:80
02:00:14:ERROR:WU00:FS00:Exception: Server did not assign work unit
02:03:45:WU00:FS00:Connecting to assign3.stanford.edu:8080
02:04:06:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:04:06:WU00:FS00:Connecting to assign4.stanford.edu:80
02:04:07:WU00:FS00:News: Welcome to Folding@Home
02:04:07:WU00:FS00:Assigned to work server 171.67.108.59
02:04:07:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:04:07:WU00:FS00:Connecting to 171.67.108.59:8080
02:04:28:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
02:04:28:WU00:FS00:Connecting to 171.67.108.59:80
02:04:29:ERROR:WU00:FS00:Exception: Server did not assign work unit
02:04:29:WU00:FS00:Cleaning up
02:04:29:WU01:FS00:Connecting to assign3.stanford.edu:8080
02:04:50:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:04:50:WU01:FS00:Connecting to assign4.stanford.edu:80
02:04:51:WU01:FS00:News: Welcome to Folding@Home
02:04:51:WU01:FS00:Assigned to work server 171.67.108.59
02:04:51:WU01:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:04:51:WU01:FS00:Connecting to 171.67.108.59:8080
02:05:12:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
02:05:12:WU01:FS00:Connecting to 171.67.108.59:80
02:05:12:ERROR:WU01:FS00:Exception: Server did not assign work unit
02:05:12:WU01:FS00:Connecting to assign3.stanford.edu:8080
02:05:33:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:05:33:WU01:FS00:Connecting to assign4.stanford.edu:80
02:05:34:WU01:FS00:News: Welcome to Folding@Home
02:05:34:WU01:FS00:Assigned to work server 171.67.108.59
02:05:34:WU01:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:05:34:WU01:FS00:Connecting to 171.67.108.59:8080
02:05:55:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
02:05:55:WU01:FS00:Connecting to 171.67.108.59:80
02:05:55:ERROR:WU01:FS00:Exception: Server did not assign work unit
02:06:12:WU01:FS00:Connecting to assign3.stanford.edu:8080
02:06:34:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:06:34:WU01:FS00:Connecting to assign4.stanford.edu:80
02:06:34:WU01:FS00:News: Welcome to Folding@Home
02:06:34:WU01:FS00:Assigned to work server 171.67.108.59
02:06:34:WU01:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:06:34:WU01:FS00:Connecting to 171.67.108.59:8080
02:06:55:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
02:06:55:WU01:FS00:Connecting to 171.67.108.59:80
02:06:56:ERROR:WU01:FS00:Exception: Server did not assign work unit
02:07:50:WU01:FS00:Connecting to assign3.stanford.edu:8080
02:08:11:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:08:11:WU01:FS00:Connecting to assign4.stanford.edu:80
02:08:11:WU01:FS00:News: Welcome to Folding@Home
02:08:11:WU01:FS00:Assigned to work server 171.67.108.59
02:08:11:WU01:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:08:11:WU01:FS00:Connecting to 171.67.108.59:8080
02:08:33:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
02:08:33:WU01:FS00:Connecting to 171.67.108.59:80
02:08:33:ERROR:WU01:FS00:Exception: Server did not assign work unit
02:10:27:WU01:FS00:Connecting to assign3.stanford.edu:8080
02:10:48:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:10:48:WU01:FS00:Connecting to assign4.stanford.edu:80
02:10:49:WU01:FS00:News: Welcome to Folding@Home
02:10:49:WU01:FS00:Assigned to work server 171.67.108.59
02:10:49:WU01:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:10:49:WU01:FS00:Connecting to 171.67.108.59:8080
02:11:10:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
02:11:10:WU01:FS00:Connecting to 171.67.108.59:80
02:11:10:ERROR:WU01:FS00:Exception: Server did not assign work unit
02:14:41:WU01:FS00:Connecting to assign3.stanford.edu:8080
02:15:02:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:15:02:WU01:FS00:Connecting to assign4.stanford.edu:80
02:15:03:WU01:FS00:News: Welcome to Folding@Home
02:15:03:WU01:FS00:Assigned to work server 171.67.108.59
02:15:03:WU01:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:15:03:WU01:FS00:Connecting to 171.67.108.59:8080
02:15:24:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
02:15:24:WU01:FS00:Connecting to 171.67.108.59:80
02:15:25:ERROR:WU01:FS00:Exception: Server did not assign work unit
02:15:25:WU01:FS00:Cleaning up
02:15:25:WU00:FS00:Connecting to assign3.stanford.edu:8080
02:15:46:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:15:46:WU00:FS00:Connecting to assign4.stanford.edu:80
02:15:47:WU00:FS00:News: Welcome to Folding@Home
02:15:47:WU00:FS00:Assigned to work server 171.67.108.59
02:15:47:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:15:47:WU00:FS00:Connecting to 171.67.108.59:8080
02:16:08:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
02:16:08:WU00:FS00:Connecting to 171.67.108.59:80
02:16:08:ERROR:WU00:FS00:Exception: Server did not assign work unit
02:16:08:WU00:FS00:Connecting to assign3.stanford.edu:8080
02:16:29:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:16:29:WU00:FS00:Connecting to assign4.stanford.edu:80
02:16:30:WU00:FS00:News: Welcome to Folding@Home
02:16:30:WU00:FS00:Assigned to work server 171.67.108.59
02:16:30:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:16:30:WU00:FS00:Connecting to 171.67.108.59:8080
02:16:51:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
02:16:51:WU00:FS00:Connecting to 171.67.108.59:80
02:16:52:ERROR:WU00:FS00:Exception: Server did not assign work unit
02:17:08:WU00:FS00:Connecting to assign3.stanford.edu:8080
02:17:30:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:17:30:WU00:FS00:Connecting to assign4.stanford.edu:80
02:17:30:WU00:FS00:News: Welcome to Folding@Home
02:17:30:WU00:FS00:Assigned to work server 171.67.108.59
02:17:30:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:17:30:WU00:FS00:Connecting to 171.67.108.59:8080
02:17:51:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
02:17:51:WU00:FS00:Connecting to 171.67.108.59:80
02:17:52:ERROR:WU00:FS00:Exception: Server did not assign work unit
02:18:46:WU00:FS00:Connecting to assign3.stanford.edu:8080
02:19:07:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:19:07:WU00:FS00:Connecting to assign4.stanford.edu:80
02:19:07:WU00:FS00:News: Welcome to Folding@Home
02:19:07:WU00:FS00:Assigned to work server 171.67.108.59
02:19:07:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:19:07:WU00:FS00:Connecting to 171.67.108.59:8080
02:19:28:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
02:19:28:WU00:FS00:Connecting to 171.67.108.59:80
02:19:29:ERROR:WU00:FS00:Exception: Server did not assign work unit
02:21:23:WU00:FS00:Connecting to assign3.stanford.edu:8080
02:21:44:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:21:44:WU00:FS00:Connecting to assign4.stanford.edu:80
02:21:45:WU00:FS00:News: Welcome to Folding@Home
02:21:45:WU00:FS00:Assigned to work server 171.67.108.59
02:21:45:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:21:45:WU00:FS00:Connecting to 171.67.108.59:8080
02:22:06:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
02:22:06:WU00:FS00:Connecting to 171.67.108.59:80
02:22:06:ERROR:WU00:FS00:Exception: Server did not assign work unit
02:25:37:WU00:FS00:Connecting to assign3.stanford.edu:8080
02:25:58:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:25:58:WU00:FS00:Connecting to assign4.stanford.edu:80
02:25:59:WU00:FS00:News: Welcome to Folding@Home
02:25:59:WU00:FS00:Assigned to work server 171.67.108.59
02:25:59:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:25:59:WU00:FS00:Connecting to 171.67.108.59:8080
02:26:20:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
02:26:20:WU00:FS00:Connecting to 171.67.108.59:80
02:26:20:ERROR:WU00:FS00:Exception: Server did not assign work unit
02:26:21:WU00:FS00:Cleaning up
02:26:21:WU01:FS00:Connecting to assign3.stanford.edu:8080
02:26:42:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:26:42:WU01:FS00:Connecting to assign4.stanford.edu:80
02:26:42:WU01:FS00:News: Welcome to Folding@Home
02:26:42:WU01:FS00:Assigned to work server 171.67.108.59
02:26:42:WU01:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:26:42:WU01:FS00:Connecting to 171.67.108.59:8080
02:27:03:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
02:27:03:WU01:FS00:Connecting to 171.67.108.59:80
02:27:04:ERROR:WU01:FS00:Exception: Server did not assign work unit
02:27:04:WU01:FS00:Connecting to assign3.stanford.edu:8080
02:27:25:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:27:25:WU01:FS00:Connecting to assign4.stanford.edu:80
02:27:26:WU01:FS00:News: Welcome to Folding@Home
02:27:26:WU01:FS00:Assigned to work server 171.67.108.59
02:27:26:WU01:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:27:26:WU01:FS00:Connecting to 171.67.108.59:8080
02:27:47:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
02:27:47:WU01:FS00:Connecting to 171.67.108.59:80
02:27:48:ERROR:WU01:FS00:Exception: Server did not assign work unit
02:28:04:WU01:FS00:Connecting to assign3.stanford.edu:8080
02:28:25:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:28:25:WU01:FS00:Connecting to assign4.stanford.edu:80
02:28:26:WU01:FS00:News: Welcome to Folding@Home
02:28:26:WU01:FS00:Assigned to work server 171.67.108.59
02:28:26:WU01:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:28:26:WU01:FS00:Connecting to 171.67.108.59:8080
02:28:47:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
02:28:47:WU01:FS00:Connecting to 171.67.108.59:80
02:28:48:ERROR:WU01:FS00:Exception: Server did not assign work unit
02:29:41:WU01:FS00:Connecting to assign3.stanford.edu:8080
02:30:03:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:30:03:WU01:FS00:Connecting to assign4.stanford.edu:80
02:30:03:WU01:FS00:News: Welcome to Folding@Home
02:30:03:WU01:FS00:Assigned to work server 171.67.108.59
02:30:03:WU01:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:30:03:WU01:FS00:Connecting to 171.67.108.59:8080
02:30:24:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
02:30:24:WU01:FS00:Connecting to 171.67.108.59:80
02:30:25:ERROR:WU01:FS00:Exception: Server did not assign work unit
02:32:19:WU01:FS00:Connecting to assign3.stanford.edu:8080
02:32:40:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:32:40:WU01:FS00:Connecting to assign4.stanford.edu:80
02:32:41:WU01:FS00:News: Welcome to Folding@Home
02:32:41:WU01:FS00:Assigned to work server 171.67.108.59
02:32:41:WU01:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:32:41:WU01:FS00:Connecting to 171.67.108.59:8080
02:33:02:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
02:33:02:WU01:FS00:Connecting to 171.67.108.59:80
02:33:02:ERROR:WU01:FS00:Exception: Server did not assign work unit
02:36:33:WU01:FS00:Connecting to assign3.stanford.edu:8080
02:36:54:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:36:54:WU01:FS00:Connecting to assign4.stanford.edu:80
02:36:55:WU01:FS00:News: Welcome to Folding@Home
02:36:55:WU01:FS00:Assigned to work server 171.67.108.59
02:36:55:WU01:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:36:55:WU01:FS00:Connecting to 171.67.108.59:8080
02:37:16:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
02:37:16:WU01:FS00:Connecting to 171.67.108.59:80
02:37:17:ERROR:WU01:FS00:Exception: Server did not assign work unit
02:37:17:WU01:FS00:Cleaning up
02:37:17:WU00:FS00:Connecting to assign3.stanford.edu:8080
02:37:38:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:37:38:WU00:FS00:Connecting to assign4.stanford.edu:80
02:37:39:WU00:FS00:News: Welcome to Folding@Home
02:37:39:WU00:FS00:Assigned to work server 171.67.108.59
02:37:39:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:37:39:WU00:FS00:Connecting to 171.67.108.59:8080
02:38:00:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
02:38:00:WU00:FS00:Connecting to 171.67.108.59:80
02:38:00:ERROR:WU00:FS00:Exception: Server did not assign work unit
02:38:00:WU00:FS00:Connecting to assign3.stanford.edu:8080
02:38:21:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:38:21:WU00:FS00:Connecting to assign4.stanford.edu:80
02:38:22:WU00:FS00:News: Welcome to Folding@Home
02:38:22:WU00:FS00:Assigned to work server 171.67.108.59
02:38:22:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:38:22:WU00:FS00:Connecting to 171.67.108.59:8080
02:38:43:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
02:38:43:WU00:FS00:Connecting to 171.67.108.59:80
02:38:44:ERROR:WU00:FS00:Exception: Server did not assign work unit
02:39:00:WU00:FS00:Connecting to assign3.stanford.edu:8080
02:39:22:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:39:22:WU00:FS00:Connecting to assign4.stanford.edu:80
02:39:23:WU00:FS00:News: Welcome to Folding@Home
02:39:23:WU00:FS00:Assigned to work server 171.67.108.59
02:39:23:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:39:23:WU00:FS00:Connecting to 171.67.108.59:8080
02:39:44:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
02:39:44:WU00:FS00:Connecting to 171.67.108.59:80
02:39:44:ERROR:WU00:FS00:Exception: Server did not assign work unit
02:40:38:WU00:FS00:Connecting to assign3.stanford.edu:8080
02:40:59:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:40:59:WU00:FS00:Connecting to assign4.stanford.edu:80
02:40:59:WU00:FS00:News: Welcome to Folding@Home
02:40:59:WU00:FS00:Assigned to work server 171.67.108.59
02:41:00:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:41:00:WU00:FS00:Connecting to 171.67.108.59:8080
02:41:21:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
02:41:21:WU00:FS00:Connecting to 171.67.108.59:80
02:41:21:ERROR:WU00:FS00:Exception: Server did not assign work unit
02:43:15:WU00:FS00:Connecting to assign3.stanford.edu:8080
02:43:36:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:43:36:WU00:FS00:Connecting to assign4.stanford.edu:80
02:43:37:WU00:FS00:News: Welcome to Folding@Home
02:43:37:WU00:FS00:Assigned to work server 171.67.108.59
02:43:37:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:43:37:WU00:FS00:Connecting to 171.67.108.59:8080
02:43:58:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
02:43:58:WU00:FS00:Connecting to 171.67.108.59:80
02:43:59:ERROR:WU00:FS00:Exception: Server did not assign work unit
02:47:29:WU00:FS00:Connecting to assign3.stanford.edu:8080
02:47:50:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:47:50:WU00:FS00:Connecting to assign4.stanford.edu:80
02:47:51:WU00:FS00:News: Welcome to Folding@Home
02:47:51:WU00:FS00:Assigned to work server 171.67.108.59
02:47:51:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:47:51:WU00:FS00:Connecting to 171.67.108.59:8080
02:48:12:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
02:48:12:WU00:FS00:Connecting to 171.67.108.59:80
02:48:13:ERROR:WU00:FS00:Exception: Server did not assign work unit
02:48:13:WU00:FS00:Cleaning up
02:48:13:WU01:FS00:Connecting to assign3.stanford.edu:8080
02:48:34:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:48:34:WU01:FS00:Connecting to assign4.stanford.edu:80
02:48:35:WU01:FS00:News: Welcome to Folding@Home
02:48:35:WU01:FS00:Assigned to work server 171.67.108.59
02:48:35:WU01:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:48:35:WU01:FS00:Connecting to 171.67.108.59:8080
02:48:56:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
02:48:56:WU01:FS00:Connecting to 171.67.108.59:80
02:48:57:ERROR:WU01:FS00:Exception: Server did not assign work unit
02:48:57:WU01:FS00:Connecting to assign3.stanford.edu:8080
02:49:18:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:49:18:WU01:FS00:Connecting to assign4.stanford.edu:80
02:49:19:WU01:FS00:News: Welcome to Folding@Home
02:49:19:WU01:FS00:Assigned to work server 171.67.108.59
02:49:19:WU01:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:49:19:WU01:FS00:Connecting to 171.67.108.59:8080
02:49:40:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
02:49:40:WU01:FS00:Connecting to 171.67.108.59:80
02:49:40:ERROR:WU01:FS00:Exception: Server did not assign work unit
02:49:57:WU01:FS00:Connecting to assign3.stanford.edu:8080
02:50:18:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:50:18:WU01:FS00:Connecting to assign4.stanford.edu:80
02:50:19:WU01:FS00:News: Welcome to Folding@Home
02:50:19:WU01:FS00:Assigned to work server 171.67.108.59
02:50:19:WU01:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:50:19:WU01:FS00:Connecting to 171.67.108.59:8080
02:50:40:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
02:50:40:WU01:FS00:Connecting to 171.67.108.59:80
02:50:40:ERROR:WU01:FS00:Exception: Server did not assign work unit
02:51:34:WU01:FS00:Connecting to assign3.stanford.edu:8080
02:51:55:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:51:55:WU01:FS00:Connecting to assign4.stanford.edu:80
02:51:56:WU01:FS00:News: Welcome to Folding@Home
02:51:56:WU01:FS00:Assigned to work server 171.67.108.59
02:51:56:WU01:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:51:56:WU01:FS00:Connecting to 171.67.108.59:8080
02:52:17:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
02:52:17:WU01:FS00:Connecting to 171.67.108.59:80
02:52:17:ERROR:WU01:FS00:Exception: Server did not assign work unit
02:54:11:WU01:FS00:Connecting to assign3.stanford.edu:8080
02:54:33:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:54:33:WU01:FS00:Connecting to assign4.stanford.edu:80
02:54:33:WU01:FS00:News: Welcome to Folding@Home
02:54:33:WU01:FS00:Assigned to work server 171.67.108.59
02:54:33:WU01:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:54:33:WU01:FS00:Connecting to 171.67.108.59:8080
02:54:54:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
02:54:54:WU01:FS00:Connecting to 171.67.108.59:80
02:54:55:ERROR:WU01:FS00:Exception: Server did not assign work unit
02:58:26:WU01:FS00:Connecting to assign3.stanford.edu:8080
02:58:47:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:58:47:WU01:FS00:Connecting to assign4.stanford.edu:80
02:58:48:WU01:FS00:News: Welcome to Folding@Home
02:58:48:WU01:FS00:Assigned to work server 171.67.108.59
02:58:48:WU01:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:58:48:WU01:FS00:Connecting to 171.67.108.59:8080
02:59:09:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
02:59:09:WU01:FS00:Connecting to 171.67.108.59:80
02:59:09:ERROR:WU01:FS00:Exception: Server did not assign work unit
02:59:09:WU01:FS00:Cleaning up
02:59:09:WU00:FS00:Connecting to assign3.stanford.edu:8080
02:59:30:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:59:30:WU00:FS00:Connecting to assign4.stanford.edu:80
02:59:31:WU00:FS00:News: Welcome to Folding@Home
02:59:31:WU00:FS00:Assigned to work server 171.67.108.59
02:59:31:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
02:59:31:WU00:FS00:Connecting to 171.67.108.59:8080
02:59:52:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
02:59:52:WU00:FS00:Connecting to 171.67.108.59:80
02:59:53:ERROR:WU00:FS00:Exception: Server did not assign work unit
02:59:53:WU00:FS00:Connecting to assign3.stanford.edu:8080
03:00:14:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:00:14:WU00:FS00:Connecting to assign4.stanford.edu:80
03:00:15:WU00:FS00:News: Welcome to Folding@Home
03:00:15:WU00:FS00:Assigned to work server 171.67.108.59
03:00:15:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
03:00:15:WU00:FS00:Connecting to 171.67.108.59:8080
03:00:36:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
03:00:36:WU00:FS00:Connecting to 171.67.108.59:80
03:00:36:ERROR:WU00:FS00:Exception: Server did not assign work unit
03:00:53:WU00:FS00:Connecting to assign3.stanford.edu:8080
03:01:14:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:01:14:WU00:FS00:Connecting to assign4.stanford.edu:80
03:01:15:WU00:FS00:News: Welcome to Folding@Home
03:01:15:WU00:FS00:Assigned to work server 171.67.108.59
03:01:15:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
03:01:15:WU00:FS00:Connecting to 171.67.108.59:8080
03:01:36:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
03:01:36:WU00:FS00:Connecting to 171.67.108.59:80
03:01:36:ERROR:WU00:FS00:Exception: Server did not assign work unit
03:02:30:WU00:FS00:Connecting to assign3.stanford.edu:8080
03:02:51:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:02:51:WU00:FS00:Connecting to assign4.stanford.edu:80
03:02:52:WU00:FS00:News: Welcome to Folding@Home
03:02:52:WU00:FS00:Assigned to work server 171.67.108.59
03:02:52:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
03:02:52:WU00:FS00:Connecting to 171.67.108.59:8080
03:03:13:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
03:03:13:WU00:FS00:Connecting to 171.67.108.59:80
03:03:14:ERROR:WU00:FS00:Exception: Server did not assign work unit
******************************** Date: 27/03/12 ********************************
03:05:08:WU00:FS00:Connecting to assign3.stanford.edu:8080
03:05:29:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:05:29:WU00:FS00:Connecting to assign4.stanford.edu:80
03:05:29:WU00:FS00:News: Welcome to Folding@Home
03:05:29:WU00:FS00:Assigned to work server 171.67.108.59
03:05:29:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
03:05:29:WU00:FS00:Connecting to 171.67.108.59:8080
03:05:50:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
03:05:50:WU00:FS00:Connecting to 171.67.108.59:80
03:05:51:ERROR:WU00:FS00:Exception: Server did not assign work unit
03:09:22:WU00:FS00:Connecting to assign3.stanford.edu:8080
03:09:43:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:09:43:WU00:FS00:Connecting to assign4.stanford.edu:80
03:09:44:WU00:FS00:News: Welcome to Folding@Home
03:09:44:WU00:FS00:Assigned to work server 171.67.108.59
03:09:44:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
03:09:44:WU00:FS00:Connecting to 171.67.108.59:8080
03:10:05:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
03:10:05:WU00:FS00:Connecting to 171.67.108.59:80
03:10:06:ERROR:WU00:FS00:Exception: Server did not assign work unit
03:10:06:WU00:FS00:Cleaning up
03:10:06:WU01:FS00:Connecting to assign3.stanford.edu:8080
03:10:27:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:10:27:WU01:FS00:Connecting to assign4.stanford.edu:80
03:10:28:WU01:FS00:News: Welcome to Folding@Home
03:10:28:WU01:FS00:Assigned to work server 171.67.108.59
03:10:28:WU01:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
03:10:28:WU01:FS00:Connecting to 171.67.108.59:8080
03:10:49:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
03:10:49:WU01:FS00:Connecting to 171.67.108.59:80
03:10:49:ERROR:WU01:FS00:Exception: Server did not assign work unit
03:10:49:WU01:FS00:Connecting to assign3.stanford.edu:8080
03:11:11:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:11:11:WU01:FS00:Connecting to assign4.stanford.edu:80
03:11:11:WU01:FS00:News: Welcome to Folding@Home
03:11:11:WU01:FS00:Assigned to work server 171.67.108.59
03:11:11:WU01:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
03:11:11:WU01:FS00:Connecting to 171.67.108.59:8080
03:11:32:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
03:11:32:WU01:FS00:Connecting to 171.67.108.59:80
03:11:33:ERROR:WU01:FS00:Exception: Server did not assign work unit
03:11:50:WU01:FS00:Connecting to assign3.stanford.edu:8080
03:12:11:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:12:11:WU01:FS00:Connecting to assign4.stanford.edu:80
03:12:11:WU01:FS00:News: Welcome to Folding@Home
03:12:11:WU01:FS00:Assigned to work server 171.67.108.59
03:12:11:WU01:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
03:12:11:WU01:FS00:Connecting to 171.67.108.59:8080
03:12:32:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
03:12:32:WU01:FS00:Connecting to 171.67.108.59:80
03:12:33:ERROR:WU01:FS00:Exception: Server did not assign work unit
03:13:27:WU01:FS00:Connecting to assign3.stanford.edu:8080
03:13:48:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:13:48:WU01:FS00:Connecting to assign4.stanford.edu:80
03:13:49:WU01:FS00:News: Welcome to Folding@Home
03:13:49:WU01:FS00:Assigned to work server 171.67.108.59
03:13:49:WU01:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.59
03:13:49:WU01:FS00:Connecting to 171.67.108.59:8080
03:14:10:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
03:14:10:WU01:FS00:Connecting to 171.67.108.59:80
03:14:10:ERROR:WU01:FS00:Exception: Server did not assign work unit
anamespeltwrong
Re: 171.67.108.59
Post by anamespeltwrong »
Edit: removed post after t/s. I found that Peerblock had added the Stanford University Network IP range to their University list. After allowing Stanford to get by unscathed they all got going again.
It is strange, however, that I have had these running for almost a week with no issues whatsoever. If you are running Peerblock, I'd recommend you check to see if it's blocking the stanford IPs.
sortofageek
Re: 171.67.108.59
Post by sortofageek »
RLHay, what have you discovered when working through the troubleshooting tips stickied at the top of this forum?
RLHay
Re: 171.67.108.59
Post by RLHay »
sortofageek wrote:RLHay, what have you discovered when working through the troubleshooting tips stickied at the top of this forum?
Sortofageek - I'm so glad you asked. Admittedly I was checking the sticky at the end of a long, hot and rather unsatisfactory day, but I didn't learn anything that HELPED - which is why I posted.
Post 1 in the sticky is regarding log verbosity. It recommends verbosity 9. I'm running v7.1.50 installed without having changed defaults - hence it is set to verbosity 3 for the log (recommended) - incidentally the highest setting is 5, so perhaps the sticky can be changed. If I missed something useful in the log, please tell me. Edit by Mod: Revised Post 1 to show both V6 and V7.
Post 2 recommends testing the assignment server - I get an 'ok' off assign2....:80 as expected. The post also suggests checking:
1) Internet Connection -> Make sure that you are online - YES
2) Firewall -> Make sure that you have configured the Firewall to allow F@h Client to connect to the internet - YES, 2 machines still working fine and no changes since F@H work commenced last year
3) Router -> Make sure that it configured correctly. F@h Clients use port 80 and 8080 only. - YES, 2 machines still working fine and no changes since F@H work commenced last year
4) Installed Software(s) -> Make sure that any internet monitoring software is configured to allow the F@h Client to connect to the internet. For example, Anti-Spyware software which may be included with your Firewall, Anti-Virus, or other Anti-Malware software - YES, 2 machines still working fine and no changes since F@H work commenced last year
The Sticky also implies that if no WU's are available for the client type then the assign server will show 0.0.0.0 - this was not the case. The online log for the server did not show any issues that I spotted.
It's also working on all machines now, but PG lost 1.5 days combined folding time yesterday. It's CPU time I would rather have seen put to good use.
@anamespeltwrong - not running peerblock. In fact in terms of both software and hardware we keep our network very stable and with a limited regime of updates or new software installs. Nothing recent on these machines or the server.
UPDATE: On completion of Wu's these machines successfully uploaded the WU's, but again failed to get any new WU from 171.67.108.59. Eventually (~2hours) they were reassigned to 171.67.108.60 and picked up WU's.
22:15:22:WU01:FS00:Connecting to 171.67.108.59:80
22:15:22:ERROR:WU01:FS00:Exception: Server did not assign work unit
22:16:16:WU01:FS00:Connecting to assign3.stanford.edu:8080
22:16:38:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
22:16:38:WU01:FS00:Connecting to assign4.stanford.edu:80
22:16:38:WU01:FS00:News: Welcome to Folding@Home
22:16:38:WU01:FS00:Assigned to work server 171.67.108.60
22:16:38:WU01:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.67.108.60
22:16:38:WU01:FS00:Connecting to 171.67.108.60:8080
22:16:59:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
22:16:59:WU01:FS00:Connecting to 171.67.108.60:80
22:17:00:WU01:FS00:Downloading 554.92KiB
22:17:02:WU01:FS00:Download complete
