So I was folding a number of years ago and have decided to start again. I can remember that I had a big struggle then but for the most part can't remember how I finally managed to get everything working (and in time things change too :p)
OK, first the log file:
*********************** Log Started 2012-03-25T04:48:10Z ***********************
04:48:10:************************* Folding@home Client *************************
04:48:10: Website: http://folding.stanford.edu/
04:48:10: Copyright: (c) 2009-2012 Stanford University
04:48:10: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:48:10: Args: --lifeline 1468 --command-port=36330
04:48:10: Config: C:/Users/nlsthzn/AppData/Roaming/FAHClient/config.xml
04:48:10:******************************** Build ********************************
04:48:10: Version: 7.1.52
04:48:10: Date: Mar 20 2012
04:48:10: Time: 19:37:42
04:48:10: SVN Rev: 3515
04:48:10: Branch: fah/trunk/client
04:48:10: Compiler: Intel(R) C++ MSVC 1500 mode 1200
04:48:10: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
04:48:10: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
04:48:10: Platform: win32 XP
04:48:10: Bits: 32
04:48:10: Mode: Release
04:48:10:******************************* System ********************************
04:48:10: CPU: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
04:48:10: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
04:48:10: CPUs: 8
04:48:10: Memory: 3.98GiB
04:48:10: Free Memory: 2.15GiB
04:48:10: Threads: WINDOWS_THREADS
04:48:10: On Battery: false
04:48:10: UTC offset: 4
04:48:10: PID: 852
04:48:10: CWD: C:/Users/nlsthzn/AppData/Roaming/FAHClient
04:48:10: OS: Windows 7 Ultimate
04:48:10: OS Arch: AMD64
04:48:10: GPUs: 1
04:48:10: GPU 0: ATI:4 Barts PRO [ATI Radeon HD 6800 Series]
04:48:10: CUDA: Not detected
04:48:10:Win32 Service: false
04:48:10:***********************************************************************
04:48:10:<config>
04:48:10: <!-- Folding Slot Configuration -->
04:48:10: <gpu v='true'/>
04:48:10:
04:48:10: <!-- User Information -->
04:48:10: <passkey v='********************************'/>
04:48:10: <team v='45104'/>
04:48:10: <user v='not_found'/>
04:48:10:
04:48:10: <!-- Folding Slots -->
04:48:10:</config>
04:48:10:Trying to access database...
04:48:11:Successfully acquired database lock
04:48:11:Enabled folding slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]"
04:48:11:Enabled folding slot 01: READY smp:8
04:48:11:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
04:48:11:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
04:48:12:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
04:48:12:WU01:FS01:Connecting to assign3.stanford.edu:8080
04:48:13:WU00:FS00:News: Welcome to Folding@Home
04:48:13:WU00:FS00:Assigned to work server 171.67.108.44
04:48:13:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
04:48:13:WU00:FS00:Connecting to 171.67.108.44:8080
04:48:14:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
04:48:33:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04:48:33:WU01:FS01:Connecting to assign4.stanford.edu:80
04:48:34:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
04:48:34:WU00:FS00:Connecting to 171.67.108.44:80
04:48:34:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
04:48:34:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
04:48:34:WU01:FS01:News: Welcome to Folding@Home
04:48:34:WU01:FS01:Assigned to work server 171.67.108.58
04:48:34:WU01:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
04:48:34:WU01:FS01:Connecting to 171.67.108.58:8080
04:48:35:WU00:FS00:News: Welcome to Folding@Home
04:48:35:WU00:FS00:Assigned to work server 171.67.108.44
04:48:35:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
04:48:35:WU00:FS00:Connecting to 171.67.108.44:8080
04:48:55:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
04:48:55:WU01:FS01:Connecting to 171.67.108.58:80
04:48:55:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
04:48:55:WU01:FS01:Connecting to assign3.stanford.edu:8080
04:48:56:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
04:48:56:WU00:FS00:Connecting to 171.67.108.44:80
04:48:56:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
04:49:16:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04:49:16:WU01:FS01:Connecting to assign4.stanford.edu:80
04:49:17:WU01:FS01:News: Welcome to Folding@Home
04:49:17:WU01:FS01:Assigned to work server 171.67.108.58
04:49:17:WU01:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
04:49:17:WU01:FS01:Connecting to 171.67.108.58:8080
04:49:34:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
04:49:35:WU00:FS00:News: Welcome to Folding@Home
04:49:35:WU00:FS00:Assigned to work server 171.67.108.44
04:49:35:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
04:49:35:WU00:FS00:Connecting to 171.67.108.44:8080
04:49:38:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
04:49:38:WU01:FS01:Connecting to 171.67.108.58:80
04:49:38:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
04:49:55:WU01:FS01:Connecting to assign3.stanford.edu:8080
04:49:56:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
04:49:56:WU00:FS00:Connecting to 171.67.108.44:80
04:49:56:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
04:50:16:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04:50:16:WU01:FS01:Connecting to assign4.stanford.edu:80
04:50:17:WU01:FS01:News: Welcome to Folding@Home
04:50:17:WU01:FS01:Assigned to work server 171.67.108.58
04:50:17:WU01:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
04:50:17:WU01:FS01:Connecting to 171.67.108.58:8080
04:50:38:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
04:50:38:WU01:FS01:Connecting to 171.67.108.58:80
04:50:38:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
04:51:11:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
04:51:12:WU00:FS00:News: Welcome to Folding@Home
04:51:12:WU00:FS00:Assigned to work server 171.67.108.44
04:51:12:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
04:51:12:WU00:FS00:Connecting to 171.67.108.44:8080
04:51:32:WU01:FS01:Connecting to assign3.stanford.edu:8080
04:51:33:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
04:51:33:WU00:FS00:Connecting to 171.67.108.44:80
04:51:33:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
04:51:54:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04:51:54:WU01:FS01:Connecting to assign4.stanford.edu:80
04:51:55:WU01:FS01:News: Welcome to Folding@Home
04:51:55:WU01:FS01:Assigned to work server 171.67.108.58
04:51:55:WU01:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
04:51:55:WU01:FS01:Connecting to 171.67.108.58:8080
04:52:16:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
04:52:16:WU01:FS01:Connecting to 171.67.108.58:80
04:52:16:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
04:53:48:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
04:53:49:WU00:FS00:News: Welcome to Folding@Home
04:53:49:WU00:FS00:Assigned to work server 171.67.108.44
04:53:49:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
04:53:49:WU00:FS00:Connecting to 171.67.108.44:8080
04:54:10:WU01:FS01:Connecting to assign3.stanford.edu:8080
04:54:10:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
04:54:10:WU00:FS00:Connecting to 171.67.108.44:80
04:54:10:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
04:54:31:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04:54:31:WU01:FS01:Connecting to assign4.stanford.edu:80
04:54:32:WU01:FS01:News: Welcome to Folding@Home
04:54:32:WU01:FS01:Assigned to work server 171.67.108.58
04:54:32:WU01:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
04:54:32:WU01:FS01:Connecting to 171.67.108.58:8080
04:54:53:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
04:54:53:WU01:FS01:Connecting to 171.67.108.58:80
04:54:53:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
04:58:03:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
04:58:04:WU00:FS00:News: Welcome to Folding@Home
04:58:04:WU00:FS00:Assigned to work server 171.67.108.44
04:58:04:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
04:58:04:WU00:FS00:Connecting to 171.67.108.44:8080
04:58:24:WU01:FS01:Connecting to assign3.stanford.edu:8080
04:58:25:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
04:58:25:WU00:FS00:Connecting to 171.67.108.44:80
04:58:25:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
04:58:25:WU00:FS00:Cleaning up
04:58:26:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
04:58:27:WU02:FS00:News: Welcome to Folding@Home
04:58:27:WU02:FS00:Assigned to work server 171.67.108.44
04:58:27:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
04:58:27:WU02:FS00:Connecting to 171.67.108.44:8080
04:58:45:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04:58:45:WU01:FS01:Connecting to assign4.stanford.edu:80
04:58:46:WU01:FS01:News: Welcome to Folding@Home
04:58:46:WU01:FS01:Assigned to work server 171.67.108.58
04:58:46:WU01:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
04:58:46:WU01:FS01:Connecting to 171.67.108.58:8080
04:58:48:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
04:58:48:WU02:FS00:Connecting to 171.67.108.44:80
04:58:48:ERROR:WU02:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
04:58:48:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
04:58:49:WU02:FS00:News: Welcome to Folding@Home
04:58:49:WU02:FS00:Assigned to work server 171.67.108.44
04:58:49:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
04:58:49:WU02:FS00:Connecting to 171.67.108.44:8080
04:59:07:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
04:59:07:WU01:FS01:Connecting to 171.67.108.58:80
04:59:07:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
04:59:08:WU01:FS01:Cleaning up
04:59:08:WU00:FS01:Connecting to assign3.stanford.edu:8080
04:59:10:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
04:59:10:WU02:FS00:Connecting to 171.67.108.44:80
04:59:10:ERROR:WU02:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
04:59:29:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04:59:29:WU00:FS01:Connecting to assign4.stanford.edu:80
04:59:30:WU00:FS01:News: Welcome to Folding@Home
04:59:30:WU00:FS01:Assigned to work server 171.67.108.58
04:59:30:WU00:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
04:59:30:WU00:FS01:Connecting to 171.67.108.58:8080
04:59:48:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
04:59:49:WU02:FS00:News: Welcome to Folding@Home
04:59:49:WU02:FS00:Assigned to work server 171.67.108.44
04:59:49:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
04:59:49:WU02:FS00:Connecting to 171.67.108.44:8080
04:59:51:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
04:59:51:WU00:FS01:Connecting to 171.67.108.58:80
04:59:51:ERROR:WU00:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
04:59:51:WU00:FS01:Connecting to assign3.stanford.edu:8080
05:00:10:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
05:00:10:WU02:FS00:Connecting to 171.67.108.44:80
05:00:10:ERROR:WU02:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:00:12:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:00:12:WU00:FS01:Connecting to assign4.stanford.edu:80
05:00:13:WU00:FS01:News: Welcome to Folding@Home
05:00:13:WU00:FS01:Assigned to work server 171.67.108.58
05:00:13:WU00:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
05:00:13:WU00:FS01:Connecting to 171.67.108.58:8080
05:00:34:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
05:00:34:WU00:FS01:Connecting to 171.67.108.58:80
05:00:34:ERROR:WU00:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:00:51:WU00:FS01:Connecting to assign3.stanford.edu:8080
05:01:12:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:01:12:WU00:FS01:Connecting to assign4.stanford.edu:80
05:01:13:WU00:FS01:News: Welcome to Folding@Home
05:01:13:WU00:FS01:Assigned to work server 171.67.108.58
05:01:13:WU00:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
05:01:13:WU00:FS01:Connecting to 171.67.108.58:8080
05:01:25:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
05:01:26:WU02:FS00:News: Welcome to Folding@Home
05:01:26:WU02:FS00:Assigned to work server 171.67.108.44
05:01:26:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
05:01:26:WU02:FS00:Connecting to 171.67.108.44:8080
05:01:34:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
05:01:34:WU00:FS01:Connecting to 171.67.108.58:80
05:01:34:ERROR:WU00:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:01:47:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
05:01:47:WU02:FS00:Connecting to 171.67.108.44:80
05:01:47:ERROR:WU02:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:02:28:WU00:FS01:Connecting to assign3.stanford.edu:8080
05:02:49:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:02:49:WU00:FS01:Connecting to assign4.stanford.edu:80
05:02:50:WU00:FS01:News: Welcome to Folding@Home
05:02:50:WU00:FS01:Assigned to work server 171.67.108.58
05:02:50:WU00:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
05:02:50:WU00:FS01:Connecting to 171.67.108.58:8080
05:03:11:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
05:03:11:WU00:FS01:Connecting to 171.67.108.58:80
05:03:11:ERROR:WU00:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:04:02:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
05:04:03:WU02:FS00:News: Welcome to Folding@Home
05:04:03:WU02:FS00:Assigned to work server 171.67.108.44
05:04:03:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
05:04:03:WU02:FS00:Connecting to 171.67.108.44:8080
05:04:24:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
05:04:24:WU02:FS00:Connecting to 171.67.108.44:80
05:04:25:ERROR:WU02:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:05:05:WU00:FS01:Connecting to assign3.stanford.edu:8080
05:05:26:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:05:26:WU00:FS01:Connecting to assign4.stanford.edu:80
05:05:28:WU00:FS01:News: Welcome to Folding@Home
05:05:28:WU00:FS01:Assigned to work server 171.67.108.58
05:05:28:WU00:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
05:05:28:WU00:FS01:Connecting to 171.67.108.58:8080
05:05:49:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
05:05:49:WU00:FS01:Connecting to 171.67.108.58:80
05:05:49:ERROR:WU00:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:08:16:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
05:08:17:WU02:FS00:News: Welcome to Folding@Home
05:08:17:WU02:FS00:Assigned to work server 171.67.108.44
05:08:18:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
05:08:18:WU02:FS00:Connecting to 171.67.108.44:8080
05:08:39:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
05:08:39:WU02:FS00:Connecting to 171.67.108.44:80
05:08:39:ERROR:WU02:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:08:39:WU02:FS00:Cleaning up
05:08:39:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
05:08:40:WU01:FS00:News: Welcome to Folding@Home
05:08:40:WU01:FS00:Assigned to work server 171.67.108.44
05:08:40:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
05:08:40:WU01:FS00:Connecting to 171.67.108.44:8080
05:09:01:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
05:09:01:WU01:FS00:Connecting to 171.67.108.44:80
05:09:01:ERROR:WU01:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:09:01:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
05:09:02:WU01:FS00:News: Welcome to Folding@Home
05:09:02:WU01:FS00:Assigned to work server 171.67.108.44
05:09:02:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
05:09:02:WU01:FS00:Connecting to 171.67.108.44:8080
05:09:20:WU00:FS01:Connecting to assign3.stanford.edu:8080
05:09:23:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
05:09:23:WU01:FS00:Connecting to 171.67.108.44:80
05:09:23:ERROR:WU01:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:09:41:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:09:41:WU00:FS01:Connecting to assign4.stanford.edu:80
05:09:42:WU00:FS01:News: Welcome to Folding@Home
05:09:42:WU00:FS01:Assigned to work server 171.67.108.58
05:09:42:WU00:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
05:09:42:WU00:FS01:Connecting to 171.67.108.58:8080
05:10:01:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
05:10:03:WU01:FS00:News: Welcome to Folding@Home
05:10:03:WU01:FS00:Assigned to work server 171.67.108.44
05:10:03:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
05:10:03:WU01:FS00:Connecting to 171.67.108.44:8080
05:10:03:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
05:10:03:WU00:FS01:Connecting to 171.67.108.58:80
05:10:03:ERROR:WU00:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:10:03:WU00:FS01:Cleaning up
05:10:03:WU02:FS01:Connecting to assign3.stanford.edu:8080
05:10:24:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
05:10:24:WU01:FS00:Connecting to 171.67.108.44:80
05:10:24:ERROR:WU01:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:10:24:WARNING:WU02:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:10:24:WU02:FS01:Connecting to assign4.stanford.edu:80
05:10:25:WU02:FS01:News: Welcome to Folding@Home
05:10:25:WU02:FS01:Assigned to work server 171.67.108.58
05:10:25:WU02:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
05:10:25:WU02:FS01:Connecting to 171.67.108.58:8080
05:10:46:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
05:10:46:WU02:FS01:Connecting to 171.67.108.58:80
05:10:46:ERROR:WU02:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:10:46:WU02:FS01:Connecting to assign3.stanford.edu:8080
05:11:07:WARNING:WU02:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:11:07:WU02:FS01:Connecting to assign4.stanford.edu:80
05:11:09:WU02:FS01:News: Welcome to Folding@Home
05:11:09:WU02:FS01:Assigned to work server 171.67.108.58
05:11:09:WU02:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
05:11:09:WU02:FS01:Connecting to 171.67.108.58:8080
05:11:30:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
05:11:30:WU02:FS01:Connecting to 171.67.108.58:80
05:11:30:ERROR:WU02:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:11:38:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
05:11:39:WU01:FS00:News: Welcome to Folding@Home
05:11:39:WU01:FS00:Assigned to work server 171.67.108.44
05:11:40:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
05:11:40:WU01:FS00:Connecting to 171.67.108.44:8080
05:11:47:WU02:FS01:Connecting to assign3.stanford.edu:8080
05:12:01:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
05:12:01:WU01:FS00:Connecting to 171.67.108.44:80
05:12:01:ERROR:WU01:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:12:08:WARNING:WU02:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:12:08:WU02:FS01:Connecting to assign4.stanford.edu:80
05:12:09:WU02:FS01:News: Welcome to Folding@Home
05:12:09:WU02:FS01:Assigned to work server 171.67.108.58
05:12:09:WU02:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
05:12:09:WU02:FS01:Connecting to 171.67.108.58:8080
05:12:30:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
05:12:30:WU02:FS01:Connecting to 171.67.108.58:80
05:12:30:ERROR:WU02:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:13:24:WU02:FS01:Connecting to assign3.stanford.edu:8080
05:13:45:WARNING:WU02:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:13:45:WU02:FS01:Connecting to assign4.stanford.edu:80
05:13:46:WU02:FS01:News: Welcome to Folding@Home
05:13:46:WU02:FS01:Assigned to work server 171.67.108.58
05:13:46:WU02:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
05:13:46:WU02:FS01:Connecting to 171.67.108.58:8080
05:14:07:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
05:14:07:WU02:FS01:Connecting to 171.67.108.58:80
05:14:07:ERROR:WU02:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:14:16:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
05:14:16:WU01:FS00:News: Welcome to Folding@Home
05:14:16:WU01:FS00:Assigned to work server 171.67.108.44
05:14:17:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
05:14:17:WU01:FS00:Connecting to 171.67.108.44:8080
05:14:38:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
05:14:38:WU01:FS00:Connecting to 171.67.108.44:80
05:14:38:ERROR:WU01:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:16:01:WU02:FS01:Connecting to assign3.stanford.edu:8080
05:16:23:WARNING:WU02:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:16:23:WU02:FS01:Connecting to assign4.stanford.edu:80
05:16:24:WU02:FS01:News: Welcome to Folding@Home
05:16:24:WU02:FS01:Assigned to work server 171.67.108.58
05:16:24:WU02:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
05:16:24:WU02:FS01:Connecting to 171.67.108.58:8080
05:16:45:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
05:16:45:WU02:FS01:Connecting to 171.67.108.58:80
05:16:45:ERROR:WU02:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:18:30:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
05:18:31:WU01:FS00:News: Welcome to Folding@Home
05:18:31:WU01:FS00:Assigned to work server 171.67.108.44
05:18:31:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
05:18:31:WU01:FS00:Connecting to 171.67.108.44:8080
05:18:52:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
05:18:52:WU01:FS00:Connecting to 171.67.108.44:80
05:18:52:ERROR:WU01:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:18:53:WU01:FS00:Cleaning up
05:18:53:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
05:18:54:WU00:FS00:News: Welcome to Folding@Home
05:18:54:WU00:FS00:Assigned to work server 171.67.108.44
05:18:54:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
05:18:54:WU00:FS00:Connecting to 171.67.108.44:8080
05:19:15:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
05:19:15:WU00:FS00:Connecting to 171.67.108.44:80
05:19:15:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:19:15:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
05:19:16:WU00:FS00:News: Welcome to Folding@Home
05:19:16:WU00:FS00:Assigned to work server 171.67.108.44
05:19:16:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
05:19:16:WU00:FS00:Connecting to 171.67.108.44:8080
05:19:37:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
05:19:37:WU00:FS00:Connecting to 171.67.108.44:80
05:19:37:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:20:15:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
05:20:15:WU02:FS01:Connecting to assign3.stanford.edu:8080
05:20:16:WU00:FS00:News: Welcome to Folding@Home
05:20:16:WU00:FS00:Assigned to work server 171.67.108.44
05:20:16:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
05:20:16:WU00:FS00:Connecting to 171.67.108.44:8080
05:20:36:WARNING:WU02:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:20:36:WU02:FS01:Connecting to assign4.stanford.edu:80
05:20:37:WU02:FS01:News: Welcome to Folding@Home
05:20:37:WU02:FS01:Assigned to work server 171.67.108.58
05:20:37:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
05:20:37:WU00:FS00:Connecting to 171.67.108.44:80
05:20:37:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:20:38:WU02:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
05:20:38:WU02:FS01:Connecting to 171.67.108.58:8080
05:20:59:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
05:20:59:WU02:FS01:Connecting to 171.67.108.58:80
05:20:59:ERROR:WU02:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:20:59:WU02:FS01:Cleaning up
05:20:59:WU01:FS01:Connecting to assign3.stanford.edu:8080
05:21:20:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:21:20:WU01:FS01:Connecting to assign4.stanford.edu:80
05:21:21:WU01:FS01:News: Welcome to Folding@Home
05:21:21:WU01:FS01:Assigned to work server 171.67.108.58
05:21:21:WU01:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
05:21:21:WU01:FS01:Connecting to 171.67.108.58:8080
05:21:42:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
05:21:42:WU01:FS01:Connecting to 171.67.108.58:80
05:21:42:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:21:43:WU01:FS01:Connecting to assign3.stanford.edu:8080
05:21:52:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
05:21:54:WU00:FS00:News: Welcome to Folding@Home
05:21:54:WU00:FS00:Assigned to work server 171.67.108.44
05:21:54:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
05:21:54:WU00:FS00:Connecting to 171.67.108.44:8080
05:22:04:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:22:04:WU01:FS01:Connecting to assign4.stanford.edu:80
05:22:05:WU01:FS01:News: Welcome to Folding@Home
05:22:05:WU01:FS01:Assigned to work server 171.67.108.58
05:22:05:WU01:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
05:22:05:WU01:FS01:Connecting to 171.67.108.58:8080
05:22:15:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
05:22:15:WU00:FS00:Connecting to 171.67.108.44:80
05:22:15:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:22:26:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
05:22:26:WU01:FS01:Connecting to 171.67.108.58:80
05:22:26:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:22:43:WU01:FS01:Connecting to assign3.stanford.edu:8080
05:23:04:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:23:04:WU01:FS01:Connecting to assign4.stanford.edu:80
05:23:05:WU01:FS01:News: Welcome to Folding@Home
05:23:05:WU01:FS01:Assigned to work server 171.67.108.58
05:23:05:WU01:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
05:23:05:WU01:FS01:Connecting to 171.67.108.58:8080
05:23:26:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
05:23:26:WU01:FS01:Connecting to 171.67.108.58:80
05:23:26:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:24:20:WU01:FS01:Connecting to assign3.stanford.edu:8080
05:24:29:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
05:24:30:WU00:FS00:News: Welcome to Folding@Home
05:24:30:WU00:FS00:Assigned to work server 171.67.108.44
05:24:31:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
05:24:31:WU00:FS00:Connecting to 171.67.108.44:8080
05:24:41:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:24:41:WU01:FS01:Connecting to assign4.stanford.edu:80
05:24:42:WU01:FS01:News: Welcome to Folding@Home
05:24:42:WU01:FS01:Assigned to work server 171.67.108.58
05:24:42:WU01:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
05:24:42:WU01:FS01:Connecting to 171.67.108.58:8080
05:24:52:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
05:24:52:WU00:FS00:Connecting to 171.67.108.44:80
05:24:52:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:25:03:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
05:25:03:WU01:FS01:Connecting to 171.67.108.58:80
05:25:03:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:26:57:WU01:FS01:Connecting to assign3.stanford.edu:8080
05:27:18:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:27:18:WU01:FS01:Connecting to assign4.stanford.edu:80
05:27:19:WU01:FS01:News: Welcome to Folding@Home
05:27:19:WU01:FS01:Assigned to work server 171.67.108.58
05:27:19:WU01:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
05:27:19:WU01:FS01:Connecting to 171.67.108.58:8080
05:27:40:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
05:27:40:WU01:FS01:Connecting to 171.67.108.58:80
05:27:40:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:28:44:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
05:28:45:WU00:FS00:News: Welcome to Folding@Home
05:28:45:WU00:FS00:Assigned to work server 171.67.108.44
05:28:46:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
05:28:46:WU00:FS00:Connecting to 171.67.108.44:8080
05:29:07:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
05:29:07:WU00:FS00:Connecting to 171.67.108.44:80
05:29:07:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:29:07:WU00:FS00:Cleaning up
05:29:07:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
05:29:08:WU02:FS00:News: Welcome to Folding@Home
05:29:08:WU02:FS00:Assigned to work server 171.67.108.44
05:29:08:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
05:29:08:WU02:FS00:Connecting to 171.67.108.44:8080
05:29:29:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
05:29:29:WU02:FS00:Connecting to 171.67.108.44:80
05:29:29:ERROR:WU02:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:29:29:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
05:29:30:WU02:FS00:News: Welcome to Folding@Home
05:29:30:WU02:FS00:Assigned to work server 171.67.108.44
05:29:30:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
05:29:30:WU02:FS00:Connecting to 171.67.108.44:8080
05:29:51:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
05:29:51:WU02:FS00:Connecting to 171.67.108.44:80
05:29:51:ERROR:WU02:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:30:29:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
05:30:30:WU02:FS00:News: Welcome to Folding@Home
05:30:30:WU02:FS00:Assigned to work server 171.67.108.44
05:30:30:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
05:30:30:WU02:FS00:Connecting to 171.67.108.44:8080
05:30:51:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
05:30:51:WU02:FS00:Connecting to 171.67.108.44:80
05:30:51:ERROR:WU02:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:31:11:WU01:FS01:Connecting to assign3.stanford.edu:8080
05:31:32:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:31:32:WU01:FS01:Connecting to assign4.stanford.edu:80
05:31:33:WU01:FS01:News: Welcome to Folding@Home
05:31:33:WU01:FS01:Assigned to work server 171.67.108.58
05:31:34:WU01:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
05:31:34:WU01:FS01:Connecting to 171.67.108.58:8080
05:31:55:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
05:31:55:WU01:FS01:Connecting to 171.67.108.58:80
05:31:55:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:31:55:WU01:FS01:Cleaning up
05:31:55:WU00:FS01:Connecting to assign3.stanford.edu:8080
05:32:06:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
05:32:07:WU02:FS00:News: Welcome to Folding@Home
05:32:07:WU02:FS00:Assigned to work server 171.67.108.44
05:32:07:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
05:32:07:WU02:FS00:Connecting to 171.67.108.44:8080
05:32:16:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:32:16:WU00:FS01:Connecting to assign4.stanford.edu:80
05:32:17:WU00:FS01:News: Welcome to Folding@Home
05:32:17:WU00:FS01:Assigned to work server 171.67.108.58
05:32:17:WU00:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
05:32:17:WU00:FS01:Connecting to 171.67.108.58:8080
05:32:28:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
05:32:28:WU02:FS00:Connecting to 171.67.108.44:80
05:32:28:ERROR:WU02:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:32:38:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
05:32:38:WU00:FS01:Connecting to 171.67.108.58:80
05:32:38:ERROR:WU00:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:32:38:WU00:FS01:Connecting to assign3.stanford.edu:8080
05:32:59:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:32:59:WU00:FS01:Connecting to assign4.stanford.edu:80
05:33:00:WU00:FS01:News: Welcome to Folding@Home
05:33:00:WU00:FS01:Assigned to work server 171.67.108.58
05:33:00:WU00:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
05:33:00:WU00:FS01:Connecting to 171.67.108.58:8080
05:33:21:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
05:33:21:WU00:FS01:Connecting to 171.67.108.58:80
05:33:21:ERROR:WU00:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:33:38:WU00:FS01:Connecting to assign3.stanford.edu:8080
05:33:59:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:33:59:WU00:FS01:Connecting to assign4.stanford.edu:80
05:34:00:WU00:FS01:News: Welcome to Folding@Home
05:34:00:WU00:FS01:Assigned to work server 171.67.108.58
05:34:00:WU00:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
05:34:00:WU00:FS01:Connecting to 171.67.108.58:8080
05:34:21:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
05:34:21:WU00:FS01:Connecting to 171.67.108.58:80
05:34:21:ERROR:WU00:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:34:44:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
05:34:44:WU02:FS00:News: Welcome to Folding@Home
05:34:44:WU02:FS00:Assigned to work server 171.67.108.44
05:34:44:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
05:34:44:WU02:FS00:Connecting to 171.67.108.44:8080
05:35:05:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
05:35:05:WU02:FS00:Connecting to 171.67.108.44:80
05:35:05:ERROR:WU02:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:35:15:WU00:FS01:Connecting to assign3.stanford.edu:8080
05:35:36:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:35:36:WU00:FS01:Connecting to assign4.stanford.edu:80
05:35:37:WU00:FS01:News: Welcome to Folding@Home
05:35:37:WU00:FS01:Assigned to work server 171.67.108.58
05:35:37:WU00:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
05:35:37:WU00:FS01:Connecting to 171.67.108.58:8080
05:35:58:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
05:35:58:WU00:FS01:Connecting to 171.67.108.58:80
05:35:58:ERROR:WU00:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:37:52:WU00:FS01:Connecting to assign3.stanford.edu:8080
05:38:14:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:38:14:WU00:FS01:Connecting to assign4.stanford.edu:80
05:38:15:WU00:FS01:News: Welcome to Folding@Home
05:38:15:WU00:FS01:Assigned to work server 171.67.108.58
05:38:15:WU00:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
05:38:15:WU00:FS01:Connecting to 171.67.108.58:8080
05:38:36:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
05:38:36:WU00:FS01:Connecting to 171.67.108.58:80
05:38:36:ERROR:WU00:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:38:58:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
05:38:59:WU02:FS00:News: Welcome to Folding@Home
05:38:59:WU02:FS00:Assigned to work server 171.67.108.44
05:38:59:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
05:38:59:WU02:FS00:Connecting to 171.67.108.44:8080
05:39:20:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
05:39:20:WU02:FS00:Connecting to 171.67.108.44:80
05:39:20:ERROR:WU02:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:39:20:WU02:FS00:Cleaning up
05:39:20:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
05:39:21:WU01:FS00:News: Welcome to Folding@Home
05:39:21:WU01:FS00:Assigned to work server 171.67.108.44
05:39:21:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
05:39:21:WU01:FS00:Connecting to 171.67.108.44:8080
05:39:42:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
05:39:42:WU01:FS00:Connecting to 171.67.108.44:80
05:39:42:ERROR:WU01:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:39:43:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
05:39:43:WU01:FS00:News: Welcome to Folding@Home
05:39:43:WU01:FS00:Assigned to work server 171.67.108.44
05:39:43:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
05:39:43:WU01:FS00:Connecting to 171.67.108.44:8080
05:40:04:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
05:40:04:WU01:FS00:Connecting to 171.67.108.44:80
05:40:04:ERROR:WU01:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:40:43:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
05:40:44:WU01:FS00:News: Welcome to Folding@Home
05:40:44:WU01:FS00:Assigned to work server 171.67.108.44
05:40:44:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
05:40:44:WU01:FS00:Connecting to 171.67.108.44:8080
05:41:05:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
05:41:05:WU01:FS00:Connecting to 171.67.108.44:80
05:41:05:ERROR:WU01:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:42:07:WU00:FS01:Connecting to assign3.stanford.edu:8080
05:42:20:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
05:42:21:WU01:FS00:News: Welcome to Folding@Home
05:42:21:WU01:FS00:Assigned to work server 171.67.108.44
05:42:21:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
05:42:21:WU01:FS00:Connecting to 171.67.108.44:8080
05:42:28:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:42:28:WU00:FS01:Connecting to assign4.stanford.edu:80
05:42:29:WU00:FS01:News: Welcome to Folding@Home
05:42:29:WU00:FS01:Assigned to work server 171.67.108.58
05:42:29:WU00:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
05:42:29:WU00:FS01:Connecting to 171.67.108.58:8080
05:42:42:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
05:42:42:WU01:FS00:Connecting to 171.67.108.44:80
05:42:42:ERROR:WU01:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:42:50:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
05:42:50:WU00:FS01:Connecting to 171.67.108.58:80
05:42:50:ERROR:WU00:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:42:50:WU00:FS01:Cleaning up
05:42:51:WU02:FS01:Connecting to assign3.stanford.edu:8080
05:43:12:WARNING:WU02:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:43:12:WU02:FS01:Connecting to assign4.stanford.edu:80
05:43:13:WU02:FS01:News: Welcome to Folding@Home
05:43:13:WU02:FS01:Assigned to work server 171.67.108.58
05:43:13:WU02:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
05:43:13:WU02:FS01:Connecting to 171.67.108.58:8080
05:43:34:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
05:43:34:WU02:FS01:Connecting to 171.67.108.58:80
05:43:34:ERROR:WU02:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:43:34:WU02:FS01:Connecting to assign3.stanford.edu:8080
05:43:55:WARNING:WU02:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:43:55:WU02:FS01:Connecting to assign4.stanford.edu:80
05:43:56:WU02:FS01:News: Welcome to Folding@Home
05:43:56:WU02:FS01:Assigned to work server 171.67.108.58
05:43:56:WU02:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
05:43:56:WU02:FS01:Connecting to 171.67.108.58:8080
05:44:17:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
05:44:17:WU02:FS01:Connecting to 171.67.108.58:80
05:44:17:ERROR:WU02:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:44:34:WU02:FS01:Connecting to assign3.stanford.edu:8080
05:44:55:WARNING:WU02:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:44:55:WU02:FS01:Connecting to assign4.stanford.edu:80
05:44:56:WU02:FS01:News: Welcome to Folding@Home
05:44:56:WU02:FS01:Assigned to work server 171.67.108.58
05:44:56:WU02:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
05:44:56:WU02:FS01:Connecting to 171.67.108.58:8080
05:44:57:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
05:44:58:WU01:FS00:News: Welcome to Folding@Home
05:44:58:WU01:FS00:Assigned to work server 171.67.108.44
05:44:58:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
05:44:58:WU01:FS00:Connecting to 171.67.108.44:8080
05:45:17:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
05:45:17:WU02:FS01:Connecting to 171.67.108.58:80
05:45:17:ERROR:WU02:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:45:19:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
05:45:19:WU01:FS00:Connecting to 171.67.108.44:80
05:45:19:ERROR:WU01:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:46:11:WU02:FS01:Connecting to assign3.stanford.edu:8080
05:46:32:WARNING:WU02:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:46:32:WU02:FS01:Connecting to assign4.stanford.edu:80
05:46:33:WU02:FS01:News: Welcome to Folding@Home
05:46:33:WU02:FS01:Assigned to work server 171.67.108.58
05:46:33:WU02:FS01:Requesting new work unit for slot 01: READY smp:8 from 171.67.108.58
05:46:33:WU02:FS01:Connecting to 171.67.108.58:8080
05:46:54:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
05:46:54:WU02:FS01:Connecting to 171.67.108.58:80
05:46:54:ERROR:WU02:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
05:48:48:WU02:FS01:Connecting to assign3.stanford.edu:8080
Some considerations: I have an exception for the FAHClient in Windows firewall (think it is set up correct but might be wrong); I have not made any changes to my router (Cisco E2000) as I am not sure what to do in it :p; My ISP has been known not to play nice with different ports...
If we could slowly work through this and get it sorted I would love to get this I7 and Radeon HD 6850 contributing.
Neil
