Project: 6098 (Run 2, Clone 81, Gen 78)
gboeds
Post by gboeds »
100% Load on I7-960, Zero steps completed in over 3 hours after I first picked it up. Stopped client, deleted work folder, rebooted machine. Picked up the same WU and after several "client-core communications" errors, it started to run again...second attempt has been running 25 minutes with zero steps complete (typically around 9 minute TPF for this project)
[18:36:29] + Core successfully engaged
[18:36:29] Deleting current work unit & continuing...
[18:36:43] Trying to send all finished work units
[18:36:43] + No unsent completed units remaining.
[18:36:43] - Preparing to get new work unit...
[18:36:43] Cleaning up work directory
[18:36:43] + Attempting to get work packet
[18:36:43] Passkey found
[18:36:43] - Will indicate memory of 12286 MB
[18:36:43] - Connecting to assignment server
[18:36:43] Connecting to http://assign.stanford.edu:8080/
[18:36:44] Posted data.
[18:36:44] Initial: 8F80; - Successful: assigned to (128.143.231.202).
[18:36:44] + News From Folding@Home: Welcome to Folding@Home
[18:36:44] Loaded queue successfully.
[18:36:44] Sent data
[18:36:44] Connecting to http://128.143.231.202:8080/
[18:36:45] Posted data.
[18:36:45] Initial: 0000; - Receiving payload (expected size: 3812179)
[18:36:50] - Downloaded at ~744 kB/s
[18:36:50] - Averaged speed for that direction ~917 kB/s
[18:36:50] + Received work.
[18:36:50] + Closed connections
[18:36:55]
[18:36:55] + Processing work unit
[18:36:55] Core required: FahCore_a3.exe
[18:36:55] Core found.
[18:36:55] Working on queue slot 07 [March 20 18:36:55 UTC]
[18:36:55] + Working ...
[18:36:55] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 07 -np 8 -nocpulock -checkpoint 3 -forceasm -verbose -lifeline 6080 -version 634'
[18:36:55]
[18:36:55] *------------------------------*
[18:36:55] Folding@Home Gromacs SMP Core
[18:36:55] Version 2.27 (Dec. 15, 2010)
[18:36:55]
[18:36:55] Preparing to commence simulation
[18:36:55] - Assembly optimizations manually forced on.
[18:36:55] - Not checking prior termination.
[18:36:55] - Expanded 3811667 -> 4136808 (decompressed 108.5 percent)
[18:36:55] Called DecompressByteArray: compressed_data_size=3811667 data_size=4136808, decompressed_data_size=4136808 diff=0
[18:36:55] - Digital signature verified
[18:36:55]
[18:36:55] Project: 6098 (Run 2, Clone 81, Gen 79)
[18:36:55]
[18:36:55] Assembly optimizations on if available.
[18:36:55] Entering M.D.
[18:37:01] Mapping NT from 8 to 8
[18:37:02] Completed 0 out of 500000 steps  (0%)
[18:37:09] CoreStatus = C0000005 (-1073741819)
[18:37:09] Client-core communications error: ERROR 0xc0000005
[18:37:09] Deleting current work unit & continuing...
[18:37:23] Trying to send all finished work units
[18:37:23] + No unsent completed units remaining.
[18:37:23] - Preparing to get new work unit...
[18:37:23] Cleaning up work directory
[18:37:23] + Attempting to get work packet
[18:37:23] Passkey found
[18:37:23] - Will indicate memory of 12286 MB
[18:37:23] - Connecting to assignment server
[18:37:23] Connecting to http://assign.stanford.edu:8080/
[18:37:24] Posted data.
[18:37:24] Initial: 8F80; - Successful: assigned to (128.143.231.202).
[18:37:24] + News From Folding@Home: Welcome to Folding@Home
[18:37:24] Loaded queue successfully.
[18:37:24] Sent data
[18:37:24] Connecting to http://128.143.231.202:8080/
[18:37:25] Posted data.
[18:37:25] Initial: 0000; - Receiving payload (expected size: 3812179)
[18:37:29] - Downloaded at ~930 kB/s
[18:37:29] - Averaged speed for that direction ~919 kB/s
[18:37:29] + Received work.
[18:37:29] + Closed connections
[18:37:34]
[18:37:34] + Processing work unit
[18:37:34] Core required: FahCore_a3.exe
[18:37:34] Core found.
[18:37:34] Working on queue slot 08 [March 20 18:37:34 UTC]
[18:37:34] + Working ...
[18:37:34] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 08 -np 8 -nocpulock -checkpoint 3 -forceasm -verbose -lifeline 6080 -version 634'
[18:37:35]
[18:37:35] *------------------------------*
[18:37:35] Folding@Home Gromacs SMP Core
[18:37:35] Version 2.27 (Dec. 15, 2010)
[18:37:35]
[18:37:35] Preparing to commence simulation
[18:37:35] - Assembly optimizations manually forced on.
[18:37:35] - Not checking prior termination.
[18:37:35] - Expanded 3811667 -> 4136808 (decompressed 108.5 percent)
[18:37:35] Called DecompressByteArray: compressed_data_size=3811667 data_size=4136808, decompressed_data_size=4136808 diff=0
[18:37:35] - Digital signature verified
[18:37:35]
[18:37:35] Project: 6098 (Run 2, Clone 81, Gen 79)
[18:37:35]
[18:37:35] Assembly optimizations on if available.
[18:37:35] Entering M.D.
[18:37:41] Mapping NT from 8 to 8
[18:37:42] Completed 0 out of 500000 steps  (0%)
[18:37:49] CoreStatus = C0000029 (-1073741783)
[18:37:49] Client-core communications error: ERROR 0xc0000029
[18:37:49] Deleting current work unit & continuing...
[18:38:03] Trying to send all finished work units
[18:38:03] + No unsent completed units remaining.
[18:38:03] - Preparing to get new work unit...
[18:38:03] Cleaning up work directory
[18:38:03] + Attempting to get work packet
[18:38:03] Passkey found
[18:38:03] - Will indicate memory of 12286 MB
[18:38:03] - Connecting to assignment server
[18:38:03] Connecting to http://assign.stanford.edu:8080/
[18:38:03] Posted data.
[18:38:03] Initial: 8F80; - Successful: assigned to (128.143.231.202).
[18:38:03] + News From Folding@Home: Welcome to Folding@Home
[18:38:03] Loaded queue successfully.
[18:38:03] Sent data
[18:38:03] Connecting to http://128.143.231.202:8080/
[18:38:05] Posted data.
[18:38:05] Initial: 0000; - Receiving payload (expected size: 3812179)
[18:38:10] - Downloaded at ~744 kB/s
[18:38:10] - Averaged speed for that direction ~884 kB/s
[18:38:10] + Received work.
[18:38:10] + Closed connections
[18:38:15]
[18:38:15] + Processing work unit
[18:38:15] Core required: FahCore_a3.exe
[18:38:15] Core found.
[18:38:15] Working on queue slot 09 [March 20 18:38:15 UTC]
[18:38:15] + Working ...
[18:38:15] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 09 -np 8 -nocpulock -checkpoint 3 -forceasm -verbose -lifeline 6080 -version 634'
[18:38:15]
[18:38:15] *------------------------------*
[18:38:15] Folding@Home Gromacs SMP Core
[18:38:15] Version 2.27 (Dec. 15, 2010)
[18:38:15]
[18:38:15] Preparing to commence simulation
[18:38:15] - Assembly optimizations manually forced on.
[18:38:15] - Not checking prior termination.
[18:38:15] - Expanded 3811667 -> 4136808 (decompressed 108.5 percent)
[18:38:15] Called DecompressByteArray: compressed_data_size=3811667 data_size=4136808, decompressed_data_size=4136808 diff=0
[18:38:15] - Digital signature verified
[18:38:15]
[18:38:15] Project: 6098 (Run 2, Clone 81, Gen 79)
[18:38:15]
[18:38:15] Assembly optimizations on if available.
[18:38:15] Entering M.D.
[18:38:21] Mapping NT from 8 to 8
[18:38:22] Completed 0 out of 500000 steps  (0%)
Xavier Zepherious
Re: 6098 (R2, C81, G79)
Post by Xavier Zepherious »
I seemed to have same issue as you..eventually it picks it up and odes it - after crashing the core a bunch of times
There's no record of Project: 6098 (Run 2, Clone 81, Gen 79) being returned by anyone yet. Presumably Gen 79 was created directly from Gen 78, which was entered into logs at: 2012-03-17 01:02:42 so Gen 79 has been kicking around for a few days and the timeout is 7.7 days.
Xavier Zepherious
Re: Project: 6098 (Run 2, Clone 81, Gen 78)
actually mine is hung I thought it would go...but is on zero
update - still can't run them -dropping very time it picks up
sortofageek
Post by sortofageek »
For the record, this one was completed successfully by another donor.
Your WU (P6098 R2 C81 G78) was added to the stats database on 2012-03-17 00:07:56 for 9838.37 points of credit.
