Project: 2615 (Run 0, Clone 92, Gen 50) not credited
Mactin
Post by Mactin »
Hello,
Project: 2615 (Run 0, Clone 92, Gen 50) was sent now 19 hours ago and is not cretited.
Another WU (p2620) from the same client and same server (171.64.65.65) has since completed and has been properly credited.
Log :
[13:01:46] + Number of Units Completed: 144
[13:01:50] Trying to send all finished work units
[13:01:50] + No unsent completed units remaining.
[13:01:50] - Preparing to get new work unit...
[13:01:50] + Attempting to get work packet
[13:01:50] - Will indicate memory of 503 MB
[13:01:50] - Connecting to assignment server
[13:01:50] Connecting to http://assign.stanford.edu:8080/
[13:01:51] Posted data.
[13:01:51] Initial: 40AB; - Successful: assigned to (171.64.65.65).
[13:01:51] + News From Folding@Home: Welcome to Folding@Home
[13:01:51] Loaded queue successfully.
[13:01:51] Connecting to http://171.64.65.65:8080/
[13:01:55] Posted data.
[13:01:55] Initial: 0000; - Receiving payload (expected size: 3130273)
[13:02:01] - Downloaded at ~509 kB/s
[13:02:01] - Averaged speed for that direction ~485 kB/s
[13:02:01] + Received work.
[13:02:01] Trying to send all finished work units
[13:02:01] + No unsent completed units remaining.
[13:02:01] + Closed connections
[13:02:01]
[13:02:01] + Processing work unit
[13:02:01] Core required: FahCore_78.exe
[13:02:01] Core found.
[13:02:01] Working on Unit 01 [April 12 13:02:01]
[13:02:01] + Working ...
[13:02:01] - Calling 'FahCore_78.exe -dir work/ -suffix 01 -checkpoint 10 -forceasm -verbose -lifeline 944 -version 504'
[13:02:02]
[13:02:02] *------------------------------*
[13:02:02] Folding@Home Gromacs Core
[13:02:02] Version 1.90 (March 8, 2006)
[13:02:02]
[13:02:02] Preparing to commence simulation
[13:02:02] - Assembly optimizations manually forced on.
[13:02:02] - Not checking prior termination.
[13:02:07] - Expanded 3129761 -> 17211533 (decompressed 549.9 percent)
[13:02:08] - Starting from initial work packet
[13:02:08]
[13:02:08] Project: 2615 (Run 0, Clone 92, Gen 50)
[13:02:08]
[13:02:08] Assembly optimizations on if available.
[13:02:08] Entering M.D.
[13:02:15] Protein: p2615_Protein
[13:02:15]
[13:02:15] Writing local files
[13:02:20] Extra SSE boost OK.
[13:02:21] Writing local files
[13:02:21] Completed 0 out of 250000 steps  (0)
[13:12:22] Timered checkpoint triggered.
[13:22:23] Timered checkpoint triggered.
[13:23:44] Writing local files
[13:23:44] Completed 2500 out of 250000 steps  (1)
[13:33:46] Timered checkpoint triggered.
[13:43:46] Timered checkpoint triggered.
[13:45:08] Writing local files
[13:45:08] Completed 5000 out of 250000 steps  (2)
[00:24:09] Completed 247500 out of 250000 steps  (99)
[00:34:10] Timered checkpoint triggered.
[00:44:11] Timered checkpoint triggered.
[00:45:34] Writing local files
[00:45:34] Completed 250000 out of 250000 steps  (100)
[00:45:34] Writing final coordinates.
[00:45:36] Past main M.D. loop
[00:46:36]
[00:46:36] Finished Work Unit:
[00:46:36] - Reading up to 3026712 from "work/wudata_01.arc": Read 3026712
[00:46:36] - Reading up to 5271860 from "work/wudata_01.xtc": Read 5271860
[00:46:36] goefile size: 0
[00:46:36] logfile size: 52948
[00:46:36] Leaving Run
[00:46:40] - Writing 8402768 bytes of core data to disk...
[00:46:45] Done: 8402256 -> 7863312 (compressed to 93.5 percent)
[00:46:45]   ... Done.
[00:46:45] - Shutting down core
[00:46:45]
[00:46:45] Folding@home Core Shutdown: FINISHED_UNIT
[00:46:49] CoreStatus = 64 (100)
[00:46:49] Unit 1 finished with 97 percent of time to deadline remaining.
[00:46:49] Updated performance fraction: 0.980033
[00:46:49] Sending work to server
[00:46:49] + Attempting to send results
[00:46:49] - Reading file work/wuresults_01.dat from core
[00:46:49]   (Read 7863824 bytes from disk)
[00:46:49] Connecting to http://171.64.65.65:8080/
[00:47:01] Posted data.
[00:47:01] Initial: 0000; - Uploaded at ~640 kB/s
[00:47:01] - Averaged speed for that direction ~482 kB/s
[00:47:01] + Results successfully sent
[00:47:01] Thank you for your contribution to Folding@Home.
[00:47:01] + Number of Units Completed: 145
[00:47:05] Trying to send all finished work units
Thanks
Re: Project: 2615 (Run 0, Clone 92, Gen 50) not credited
Yep, no record of this WU in the Mod search tool.
Mactin
Post by Mactin »
I've got another WU from the same server that got uncredited : Project: 2620 (Run 66, Clone 96, Gen 10). It completed Apr.17, 00:32U (12 hours ago).
Logs are available.
There is another tread about uncredited WUs from 171.64.65.65, it might be usefull to check it out ?
ChelseaOilman
Post by ChelseaOilman »
See here: Re: Is this one credited? (171.64.65.65) [No credit given] :(
kasson wrote:We see the problem and are working on it; I've taken the server down until we have the fix implemented.
