Hello all, I have a new computer, Opteron 4284 "Valencia" with 8 cores @ 3.0 Ghz and 16 GB registered ECC memory @ 1333 Mhz. My operating system is Ubuntu Linux 11.04 AMD64.
It's nicely faster than my old Opteron 1218HE but puts out a little more heat for sure.
Is there some tips for settings or optimisations for best performance on my system? I am currently running as ./fah6 -smp -bigadv and it works ok, uses all 8 cores.
Thanks you!
Folding on Opteron 4284 "Valencia"
tmillic
- Hardware configuration: AMD3200+ w/ NVIDIA GT220.
Tyan S2912 with 1 Opteron 2347HE.
Via C3. - Location: Fayetteville, Arkansas
Re: Folding on Opteron 4284 "Valencia"
If you won't be doing anything else with it, booting into Runlevel 3 may help.
Edit: Apparently Ubuntu 11.04 doesn't have that option.
Ravage7779
- Hardware configuration: .
6x Intel i3-4130 (4) @ 3.400GHz
Apple M1 (8) @ 3.2 GHz
AMD Ryzen 5 5500U (12) @ 4.06 GHz
Intel Core i7-9700 (8) @ 4.70 GHz
AMD Ryzen 7 5700G (16) @ 4.67 GHz
Seems many of the -bigadv guys use a piece of software called "the kraken" to help improve throughput. I don't know anything about it, or if it helps with only 8 cores, but it's something that you can look into.
IIRC, kraken helps with multiple chips, and 16-32 core range.
orion
- Hardware configuration: 4p/4 MC ES @ 3.0GHz/32GB
4p/4x6128 @ 2.47GHz/32GB
2p/2 IL ES @ 2.7GHz/16GB
1p/8150/8GB
1p/1090T/4GB - Location: neither here nor there
If your MB will take it running tighter timing desktop memory, CL 6 or 7, will help the most in dropping TPF other then OC the cpu. 7im is right about the Kraken, it won't help on 8 threads.
What MB do you have?
And what are your TPF on -bigadv?
iustus quia...
Actually, the kraken will benefit 8 threads on a multi-socket board. Verified on a 2P/8T system.
You are getting away with -bigadv and you only have 8 cores at 3GHz?
Not on any of the new BA16 work units, no.dreiter wrote:You are getting away with -bigadv and you only have 8 cores at 3GHz?
