Project 5772 upload issue
Stephenish
Post by Stephenish »
16:18:26:WU03:FS01:Sending unit results: id:03 state:SEND error:OK project:5772 run:14 clone:330 gen:603 core:0x11 unit:0x4ef663c84f4b9c12025b014a000e168c
16:18:26:WU03:FS01:Uploading 89.33KiB to 171.67.108.11
16:18:26:WU03:FS01:Connecting to 171.67.108.11:8080
16:18:27:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
16:18:27:WU03:FS01:Connecting to 171.67.108.11:80
16:18:30:WARNING:WU03:FS01:Exception: Failed to send results to work server: Failed to connect to 171.67.108.11:80: No connection could be made because the target machine actively refused it.
16:18:30:WU03:FS01:Trying to send results to collection server
16:18:30:WU03:FS01:Uploading 89.33KiB to 171.67.108.25
16:18:30:WU03:FS01:Connecting to 171.67.108.25:8080
16:18:31:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
16:18:31:WU03:FS01:Connecting to 171.67.108.25:80
16:18:34:ERROR:WU03:FS01:Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
Re: Project 5772 upload issue
The CPU load on this server is quite high (14.18), this might explain why it is refusing connections.
It should resolve automatically, but don't hesitate to post again if you're still having troubles in a few hours.
