Project: 6099 (Run 0, Clone 46, Gen 82)
seagreen
Post by seagreen »
i'm having failure with this unit.
[21:52:58] Project: 6099 (Run 0, Clone 46, Gen 82)
[21:52:58]
[21:52:58] Assembly optimizations on if available.
[21:52:58] Entering M.D.
                         (snip)
Reading file work/wudata_04.tpr, VERSION 4.5.1-dev-20100930-afd66-dirty (single precision)
Starting 8 threads
Making 2D domain decomposition 2 x 4 x 1
starting mdrun 'Solvated system'
41500000 steps, 166000.0 ps (continuing from step 41000000, 164000.0 ps).
[21:53:04] Mapping NT from 8 to 8
step 41000000: Water molecule starting at atom 93408 can not be settled.
Check for bad contacts and/or reduce the timestep if appropriate.
Segmentation fault
[21:53:05] Completed 0 out of 500000 steps  (0%)
[21:53:05] CoreStatus = 8B (139)
[21:53:05] Client-core communications error: ERROR 0x8b
[21:53:05] Deleting current work unit & continuing...
i've deleted, restarted computer, restarted the program, reinstalled, and it keeps pulling the same thing. lame.
Re: Project: 6099 (Run 0, Clone 46, Gen 82)
Thank you for your report, seagreen and welcome to foldingforum.org.
Others have had trouble with this WU so I've reported the WU (P6099,R0,C46,G82) as a bad WU. Note that the list of reported WUs are stopped daily at 8am pacific time.
