Minimum timespan between posts?
Anything changed recently? Running into the dreaded 'You cannot make another post so soon after your last.' allot.
Re: Minimum timespan between posts?
I believe that it was a minute but that was ages ago. I will ask around and see what comes up.
The flood interval is 60 seconds as PantherX mentioned. I don't think it's been changed.
Must be me then, I did only notice it because I had allot of pm's to answer and pm's are counted in the flood interval protection ( which I understand btw ).
Guess patience is a virtue
