Project: 2605 (Run 11, Clone 522, Gen 39) : Error 0x0
[16:28:24] Completed 335000 out of 500000 steps (67 percent)
[16:28:24] Extra SSE boost OK.
[16:43:27] Timered checkpoint triggered.
[16:47:29] Writing local files
[16:47:29] Completed 340000 out of 500000 steps (68 percent)
[17:02:29] Timered checkpoint triggered.
[17:06:23] Writing local files
[17:06:23] Completed 345000 out of 500000 steps (69 percent)
[23:42:29] Completed 450000 out of 500000 steps (90 percent)
[23:57:29] Timered checkpoint triggered.
[00:01:21] Writing local files
[00:01:21] Completed 455000 out of 500000 steps (91 percent)
[0]0:Return code = 0, signaled with Segmentation fault
[0]1:Return code = 0, signaled with Segmentation fault
[0]2:Return code = 0, signaled with Segmentation fault
[0]3:Return code = 0, signaled with Segmentation fault
[00:04:32] CoreStatus = 0 (0)
[00:04:32] Client-core communications error: ERROR 0x0
[00:04:32] Deleting current work unit & continuing...
[0]0:Return code = 0, signaled with Quit
[0]1:Return code = 0, signaled with Quit
[0]2:Return code = 18
[0]3:Return code = 0, signaled with Quit
[00:09:00] - Warning: Could not delete all work unit files (3): Core returned invalid code
[00:09:00] Trying to send all finished work units
[00:09:00] + No unsent completed units remaining.
[00:09:00] - Preparing to get new work unit...
My machines doesn't seem to like this project :(
Re: Project: 2605 (Run 11, Clone 522, Gen 39) : Error 0x0
[quote="toTOW
My machines doesn't seem to like this project :([/quote]
Your overclocked machines?
This machine is overclocked yes, but you can check, it returned many WU from this project before :
Project: 2605 (Run 14, Clone 98, Gen 37)
Project: 2605 (Run 10, Clone 217, Gen 37)
Project: 2605 (Run 11, Clone 280, Gen 38)
Project: 2605 (Run 15, Clone 205, Gen 38)
Project: 2605 (Run 7, Clone 152, Gen 39)
And if you want to check for other projects with the user id of that machine, you'll that it has also completed many 2653 units (and a few from other projects).
But if you have a look at this topic : viewtopic.php?f=19&t=2072 , you'll see that I have issue with this project on another machine which is not overclocked (dedicated webserver).
Strange thing is that failures I see have started with Gen 39 WU (although some of them have been returned successfully) ... we might be reaching a point in the projet where simulations are becoming unstable ...
