Project: 6892 (Run 616, Clone 1, Gen 79)
djohnston
Post by djohnston »
This WU is bad. It has repeatedly failed at 30%. Although it ran a total of 21 times before I caught it, it refused to pick another WU and mark this one as bad. Is there any way to check for these units that repeatedly loop and won't cycle to a new work unit?
I know you guys like to see the entire, unadulterated log, so here it is. It's a big one. (Part1)
[04:03:42] Completed 250000 out of 250000 steps  (100%)
[04:03:42] Writing final coordinates.
[04:03:43] Past main M.D. loop
[04:04:43]
[04:04:43] Finished Work Unit:
[04:04:43] - Reading up to 548184 from "work/wudata_08.arc": Read 548184
[04:04:43] - Reading up to 494728 from "work/wudata_08.xtc": Read 494728
[04:04:43] goefile size: 0
[04:04:43] logfile size: 29313
[04:04:43] Leaving Run
[04:04:45] - Writing 1078133 bytes of core data to disk...
[04:04:47] Done: 1077621 -> 1021736 (compressed to 94.8 percent)
[04:04:47]   ... Done.
[04:05:15] - Shutting down core
[04:05:15]
[04:05:15] Folding@home Core Shutdown: FINISHED_UNIT
[04:06:12] CoreStatus = 64 (100)
[04:06:12] Sending work to server
[04:06:12] - Read packet limit of 540015616... Set to 524286976.
[04:06:12] + Attempting to send results
[04:06:38] + Results successfully sent
[04:06:38] Thank you for your contribution to Folding@Home.
[04:06:38] + Number of Units Completed: 39
[04:06:49] - Preparing to get new work unit...
[04:06:49] + Attempting to get work packet
[04:06:49] - Connecting to assignment server
[04:06:50] - Successful: assigned to (171.67.108.53).
[04:06:50] + News From Folding@Home: Welcome to Folding@Home
[04:06:50] Loaded queue successfully.
[04:06:58] + Closed connections
[04:06:58]
[04:06:58] + Processing work unit
[04:06:58] Core required: FahCore_78.exe
[04:06:58] Core found.
[04:06:58] Working on Unit 09 [January 14 04:06:58]
[04:06:58] + Working ...
[04:06:59]
[04:06:59] *------------------------------*
[04:06:59] Folding@Home Gromacs Core
[04:06:59] Version 1.90 (March 8, 2006)
[04:06:59]
[04:06:59] Preparing to commence simulation
[04:06:59] - Looking at optimizations...
[04:06:59] - Created dyn
[04:06:59] - Files status OK
[04:07:00] - Expanded 661808 -> 3332352 (decompressed 503.5 percent)
[04:07:00] - Starting from initial work packet
[04:07:00]
[04:07:00] Project: 6892 (Run 616, Clone 1, Gen 79)
[04:07:00]
[04:07:00] Assembly optimizations on if available.
[04:07:00] Entering M.D.
[04:07:07] Protein: ALZHEIMER DISEASE AMYLOID
[04:07:07]
[04:07:07] Writing local files
[04:07:45] Extra SSE boost OK.
[04:07:47] Writing local files
[04:07:47] Completed 0 out of 250000 steps  (0%)
[05:01:05] Writing local files
[05:01:05] Completed 2500 out of 250000 steps  (1%)
[05:54:23] Writing local files
[05:54:24] Completed 5000 out of 250000 steps  (2%)
[06:47:38] Writing local files
[06:47:38] Completed 7500 out of 250000 steps  (3%)
[07:40:52] Writing local files
[07:40:52] Completed 10000 out of 250000 steps  (4%)
[08:34:03] Writing local files
[08:34:04] Completed 12500 out of 250000 steps  (5%)
[09:27:17] Writing local files
[09:27:17] Completed 15000 out of 250000 steps  (6%)
[10:20:44] Writing local files
[10:20:44] Completed 17500 out of 250000 steps  (7%)
[11:13:59] Writing local files
[11:13:59] Completed 20000 out of 250000 steps  (8%)
[12:07:09] Writing local files
[12:07:09] Completed 22500 out of 250000 steps  (9%)
[13:00:23] Writing local files
[13:00:23] Completed 25000 out of 250000 steps  (10%)
[13:53:41] Writing local files
[13:53:42] Completed 27500 out of 250000 steps  (11%)
[14:46:56] Writing local files
[14:46:56] Completed 30000 out of 250000 steps  (12%)
[15:40:05] Writing local files
[15:40:05] Completed 32500 out of 250000 steps  (13%)
[16:33:22] Writing local files
[16:33:22] Completed 35000 out of 250000 steps  (14%)
[17:26:40] Writing local files
[17:26:40] Completed 37500 out of 250000 steps  (15%)
[18:20:00] Writing local files
[18:20:00] Completed 40000 out of 250000 steps  (16%)
[19:13:19] Writing local files
[19:13:19] Completed 42500 out of 250000 steps  (17%)
[20:06:38] Writing local files
[20:06:38] Completed 45000 out of 250000 steps  (18%)
[20:59:56] Writing local files
[20:59:56] Completed 47500 out of 250000 steps  (19%)
[21:53:12] Writing local files
[21:53:12] Completed 50000 out of 250000 steps  (20%)
[22:46:29] Writing local files
[22:46:29] Completed 52500 out of 250000 steps  (21%)
[23:39:44] Writing local files
[23:39:44] Completed 55000 out of 250000 steps  (22%)
[00:32:59] Writing local files
[00:32:59] Completed 57500 out of 250000 steps  (23%)
[01:26:11] Writing local files
[01:26:12] Completed 60000 out of 250000 steps  (24%)
[02:19:37] Writing local files
[02:19:38] Completed 62500 out of 250000 steps  (25%)
[03:12:56] Writing local files
[03:12:56] Completed 65000 out of 250000 steps  (26%)
[04:06:15] Writing local files
[04:06:15] Completed 67500 out of 250000 steps  (27%)
[04:59:37] Writing local files
[04:59:37] Completed 70000 out of 250000 steps  (28%)
[05:53:01] Writing local files
[05:53:01] Completed 72500 out of 250000 steps  (29%)
[06:46:27] Writing local files
[06:46:27] Completed 75000 out of 250000 steps  (30%)
[07:23:47] CoreStatus = 0 (0)
[07:23:47] Client-core communications error: ERROR 0x0
[07:23:47] Deleting current work unit & continuing...
[07:25:03] - Preparing to get new work unit...
[07:25:03] + Attempting to get work packet
[07:25:03] - Connecting to assignment server
[07:25:04] - Successful: assigned to (171.67.108.53).
[07:25:04] + News From Folding@Home: Welcome to Folding@Home
[07:25:04] Loaded queue successfully.
[07:25:12] + Closed connections
[07:25:17]
[07:25:17] + Processing work unit
[07:25:17] Core required: FahCore_78.exe
[07:25:17] Core found.
[07:25:17] Working on Unit 00 [January 15 07:25:17]
[07:25:17] + Working ...
[07:25:17]
[07:25:17] *------------------------------*
[07:25:17] Folding@Home Gromacs Core
[07:25:17] Version 1.90 (March 8, 2006)
[07:25:17]
[07:25:17] Preparing to commence simulation
[07:25:17] - Looking at optimizations...
[07:25:17] - Created dyn
[07:25:17] - Files status OK
[07:25:18] - Expanded 661808 -> 3332352 (decompressed 503.5 percent)
[07:25:18] - Starting from initial work packet
[07:25:18]
[07:25:18] Project: 6892 (Run 616, Clone 1, Gen 79)
[07:25:18]
[07:25:18] Assembly optimizations on if available.
[07:25:18] Entering M.D.
[07:25:25] Protein: ALZHEIMER DISEASE AMYLOID
[07:25:25]
[07:25:25] Writing local files
[07:26:03] Extra SSE boost OK.
[07:26:05] Writing local files
[07:26:05] Completed 0 out of 250000 steps  (0%)
[08:20:41] Writing local files
[08:20:41] Completed 2500 out of 250000 steps  (1%)
[09:15:18] Writing local files
[09:15:18] Completed 5000 out of 250000 steps  (2%)
[10:10:06] Writing local files
[10:10:07] Completed 7500 out of 250000 steps  (3%)
[11:06:34] Writing local files
[11:06:34] Completed 10000 out of 250000 steps  (4%)
[12:01:11] Writing local files
[12:01:11] Completed 12500 out of 250000 steps  (5%)
[12:55:44] Writing local files
[12:55:44] Completed 15000 out of 250000 steps  (6%)
[13:50:21] Writing local files
[13:50:21] Completed 17500 out of 250000 steps  (7%)
[14:44:56] Writing local files
[14:44:56] Completed 20000 out of 250000 steps  (8%)
[15:39:27] Writing local files
[15:39:28] Completed 22500 out of 250000 steps  (9%)
[16:34:04] Writing local files
[16:34:04] Completed 25000 out of 250000 steps  (10%)
[17:28:42] Writing local files
[17:28:42] Completed 27500 out of 250000 steps  (11%)
[18:23:20] Writing local files
[18:23:20] Completed 30000 out of 250000 steps  (12%)
[19:17:50] Writing local files
[19:17:51] Completed 32500 out of 250000 steps  (13%)
[20:12:23] Writing local files
[20:12:23] Completed 35000 out of 250000 steps  (14%)
[21:06:50] Writing local files
[21:06:50] Completed 37500 out of 250000 steps  (15%)
[22:01:23] Writing local files
[22:01:23] Completed 40000 out of 250000 steps  (16%)
[22:55:58] Writing local files
[22:55:58] Completed 42500 out of 250000 steps  (17%)
[23:50:36] Writing local files
[23:50:36] Completed 45000 out of 250000 steps  (18%)
[00:45:13] Writing local files
[00:45:13] Completed 47500 out of 250000 steps  (19%)
[01:39:48] Writing local files
[01:39:48] Completed 50000 out of 250000 steps  (20%)
[02:34:22] Writing local files
[02:34:22] Completed 52500 out of 250000 steps  (21%)
[03:28:52] Writing local files
[03:28:53] Completed 55000 out of 250000 steps  (22%)
[04:23:26] Writing local files
[04:23:26] Completed 57500 out of 250000 steps  (23%)
[05:17:56] Writing local files
[05:17:56] Completed 60000 out of 250000 steps  (24%)
[06:12:31] Writing local files
[06:12:31] Completed 62500 out of 250000 steps  (25%)
[07:07:03] Writing local files
[07:07:03] Completed 65000 out of 250000 steps  (26%)
[08:01:36] Writing local files
[08:01:36] Completed 67500 out of 250000 steps  (27%)
[08:56:10] Writing local files
[08:56:10] Completed 70000 out of 250000 steps  (28%)
[09:50:42] Writing local files
[09:50:42] Completed 72500 out of 250000 steps  (29%)
[10:45:31] Writing local files
[10:45:31] Completed 75000 out of 250000 steps  (30%)
[11:23:40] CoreStatus = 0 (0)
[11:23:40] Client-core communications error: ERROR 0x0
[11:23:40] Deleting current work unit & continuing...
[11:24:56] - Preparing to get new work unit...
[11:24:56] + Attempting to get work packet
[11:24:56] - Connecting to assignment server
[11:24:56] - Successful: assigned to (171.67.108.53).
[11:24:56] + News From Folding@Home: Welcome to Folding@Home
[11:24:57] Loaded queue successfully.
[11:25:01] + Closed connections
[11:25:06]
[11:25:06] + Processing work unit
[11:25:06] Core required: FahCore_78.exe
[11:25:06] Core found.
[11:25:06] Working on Unit 01 [January 16 11:25:06]
[11:25:06] + Working ...
[11:25:06]
[11:25:06] *------------------------------*
[11:25:06] Folding@Home Gromacs Core
[11:25:06] Version 1.90 (March 8, 2006)
[11:25:06]
[11:25:06] Preparing to commence simulation
[11:25:06] - Looking at optimizations...
[11:25:06] - Created dyn
[11:25:06] - Files status OK
[11:25:07] - Expanded 661808 -> 3332352 (decompressed 503.5 percent)
[11:25:07] - Starting from initial work packet
[11:25:07]
[11:25:07] Project: 6892 (Run 616, Clone 1, Gen 79)
[11:25:07]
[11:25:07] Assembly optimizations on if available.
[11:25:07] Entering M.D.
[11:25:14] Protein: ALZHEIMER DISEASE AMYLOID
[11:25:14]
[11:25:14] Writing local files
[11:25:53] Extra SSE boost OK.
[11:25:54] Writing local files
[11:25:54] Completed 0 out of 250000 steps  (0%)
[12:19:16] Writing local files
[12:19:16] Completed 2500 out of 250000 steps  (1%)
[13:12:38] Writing local files
[13:12:38] Completed 5000 out of 250000 steps  (2%)
[14:06:01] Writing local files
[14:06:01] Completed 7500 out of 250000 steps  (3%)
[14:59:19] Writing local files
[14:59:19] Completed 10000 out of 250000 steps  (4%)
[15:52:37] Writing local files
[15:52:37] Completed 12500 out of 250000 steps  (5%)
[16:45:55] Writing local files
[16:45:55] Completed 15000 out of 250000 steps  (6%)
[17:39:11] Writing local files
[17:39:11] Completed 17500 out of 250000 steps  (7%)
[18:32:29] Writing local files
[18:32:30] Completed 20000 out of 250000 steps  (8%)
[19:25:44] Writing local files
[19:25:44] Completed 22500 out of 250000 steps  (9%)
[20:19:02] Writing local files
[20:19:02] Completed 25000 out of 250000 steps  (10%)
[21:12:22] Writing local files
[21:12:22] Completed 27500 out of 250000 steps  (11%)
[22:05:41] Writing local files
[22:05:41] Completed 30000 out of 250000 steps  (12%)
[22:58:55] Writing local files
[22:58:55] Completed 32500 out of 250000 steps  (13%)
[23:52:22] Writing local files
[23:52:22] Completed 35000 out of 250000 steps  (14%)
[00:45:40] Writing local files
[00:45:40] Completed 37500 out of 250000 steps  (15%)
[01:38:58] Writing local files
[01:38:58] Completed 40000 out of 250000 steps  (16%)
[02:32:16] Writing local files
[02:32:16] Completed 42500 out of 250000 steps  (17%)
[03:25:34] Writing local files
[03:25:34] Completed 45000 out of 250000 steps  (18%)
[04:18:58] Writing local files
[04:18:58] Completed 47500 out of 250000 steps  (19%)
[05:12:18] Writing local files
[05:12:19] Completed 50000 out of 250000 steps  (20%)
[06:05:39] Writing local files
[06:05:39] Completed 52500 out of 250000 steps  (21%)
[06:58:55] Writing local files
[06:58:56] Completed 55000 out of 250000 steps  (22%)
[07:52:11] Writing local files
[07:52:11] Completed 57500 out of 250000 steps  (23%)
[08:45:26] Writing local files
[08:45:26] Completed 60000 out of 250000 steps  (24%)
[09:38:51] Writing local files
[09:38:52] Completed 62500 out of 250000 steps  (25%)
[10:32:24] Writing local files
[10:32:25] Completed 65000 out of 250000 steps  (26%)
[11:25:46] Writing local files
[11:25:47] Completed 67500 out of 250000 steps  (27%)
[12:19:12] Writing local files
[12:19:12] Completed 70000 out of 250000 steps  (28%)
[13:12:31] Writing local files
[13:12:31] Completed 72500 out of 250000 steps  (29%)
[14:05:58] Writing local files
[14:05:58] Completed 75000 out of 250000 steps  (30%)
[14:43:17] CoreStatus = 0 (0)
[14:43:17] Client-core communications error: ERROR 0x0
[14:43:17] - Attempting to download new core...
[14:43:17] + Downloading new core: FahCore_78.exe
[14:43:18] + 10240 bytes downloaded
[14:43:18] + 20480 bytes downloaded
[14:43:18] + 30720 bytes downloaded
[14:43:18] + 40960 bytes downloaded
[14:43:18] + 51200 bytes downloaded
[14:43:18] + 61440 bytes downloaded
[14:43:19] + 71680 bytes downloaded
[14:43:19] + 81920 bytes downloaded
[14:43:19] + 92160 bytes downloaded
[14:43:19] + 102400 bytes downloaded
[14:43:19] + 112640 bytes downloaded
[14:43:19] + 122880 bytes downloaded
[14:43:19] + 133120 bytes downloaded
[14:43:19] + 143360 bytes downloaded
[14:43:19] + 153600 bytes downloaded
[14:43:19] + 163840 bytes downloaded
[14:43:19] + 174080 bytes downloaded
[14:43:19] + 184320 bytes downloaded
[14:43:19] + 194560 bytes downloaded
[14:43:19] + 204800 bytes downloaded
[14:43:19] + 215040 bytes downloaded
[14:43:19] + 225280 bytes downloaded
[14:43:19] + 235520 bytes downloaded
[14:43:19] + 245760 bytes downloaded
[14:43:19] + 256000 bytes downloaded
[14:43:19] + 266240 bytes downloaded
[14:43:19] + 276480 bytes downloaded
[14:43:19] + 286720 bytes downloaded
[14:43:20] + 296960 bytes downloaded
[14:43:20] + 307200 bytes downloaded
[14:43:20] + 317440 bytes downloaded
[14:43:20] + 327680 bytes downloaded
[14:43:20] + 337920 bytes downloaded
[14:43:20] + 348160 bytes downloaded
[14:43:20] + 358400 bytes downloaded
[14:43:20] + 368640 bytes downloaded
[14:43:20] + 378880 bytes downloaded
[14:43:20] + 389120 bytes downloaded
[14:43:20] + 399360 bytes downloaded
[14:43:20] + 409600 bytes downloaded
[14:43:20] + 419840 bytes downloaded
[14:43:20] + 430080 bytes downloaded
[14:43:20] + 440320 bytes downloaded
[14:43:20] + 450560 bytes downloaded
[14:43:20] + 460800 bytes downloaded
[14:43:20] + 471040 bytes downloaded
[14:43:20] + 481280 bytes downloaded
[14:43:20] + 491520 bytes downloaded
[14:43:20] + 501760 bytes downloaded
[14:43:20] + 512000 bytes downloaded
[14:43:20] + 522240 bytes downloaded
[14:43:20] + 532480 bytes downloaded
[14:43:20] + 542720 bytes downloaded
[14:43:20] + 552960 bytes downloaded
[14:43:20] + 563200 bytes downloaded
[14:43:20] + 573440 bytes downloaded
[14:43:20] + 583680 bytes downloaded
[14:43:20] + 593920 bytes downloaded
[14:43:20] + 604160 bytes downloaded
[14:43:20] + 614400 bytes downloaded
[14:43:20] + 624640 bytes downloaded
[14:43:20] + 634880 bytes downloaded
[14:43:20] + 645120 bytes downloaded
[14:43:20] + 655360 bytes downloaded
[14:43:20] + 665600 bytes downloaded
[14:43:21] + 675840 bytes downloaded
[14:43:21] + 686080 bytes downloaded
[14:43:21] + 696320 bytes downloaded
[14:43:21] + 706560 bytes downloaded
[14:43:21] + 716800 bytes downloaded
[14:43:21] + 727040 bytes downloaded
[14:43:21] + 737280 bytes downloaded
[14:43:21] + 747520 bytes downloaded
[14:43:21] + 757760 bytes downloaded
[14:43:21] + 768000 bytes downloaded
[14:43:21] + 778240 bytes downloaded
[14:43:21] + 788480 bytes downloaded
[14:43:21] + 798720 bytes downloaded
[14:43:21] + 808960 bytes downloaded
[14:43:21] + 819200 bytes downloaded
[14:43:21] + 829440 bytes downloaded
[14:43:21] + 839680 bytes downloaded
[14:43:21] + 849920 bytes downloaded
[14:43:21] + 860160 bytes downloaded
[14:43:21] + 870400 bytes downloaded
[14:43:21] + 880640 bytes downloaded
[14:43:21] + 890880 bytes downloaded
[14:43:21] + 901120 bytes downloaded
[14:43:21] + 911360 bytes downloaded
[14:43:21] + 921600 bytes downloaded
[14:43:21] + 931840 bytes downloaded
[14:43:21] + 942080 bytes downloaded
[14:43:21] + 952320 bytes downloaded
[14:43:21] + 962560 bytes downloaded
[14:43:21] + 972800 bytes downloaded
[14:43:21] + 983040 bytes downloaded
[14:43:21] + 993280 bytes downloaded
[14:43:21] + 1003520 bytes downloaded
[14:43:21] + 1013760 bytes downloaded
[14:43:21] + 1024000 bytes downloaded
[14:43:22] + 1034240 bytes downloaded
[14:43:22] + 1044480 bytes downloaded
[14:43:22] + 1054720 bytes downloaded
[14:43:22] + 1064960 bytes downloaded
[14:43:22] + 1075200 bytes downloaded
[14:43:22] + 1085440 bytes downloaded
[14:43:22] + 1095680 bytes downloaded
[14:43:22] + 1105920 bytes downloaded
[14:43:22] + 1116160 bytes downloaded
[14:43:22] + 1126400 bytes downloaded
[14:43:22] + 1134407 bytes downloaded
[14:43:22] Verifying core Core_78.fah...
[14:43:22] Signature is VALID
[14:43:22]
[14:43:22] Trying to unzip core FahCore_78.exe
[14:43:23] Decompressed FahCore_78.exe (3435296 bytes) successfully
[14:43:23] + Core successfully engaged
[14:43:36] Deleting current work unit & continuing...
[14:44:52] - Preparing to get new work unit...
[14:44:52] + Attempting to get work packet
[14:44:52] - Connecting to assignment server
[14:44:52] - Successful: assigned to (171.67.108.53).
[14:44:52] + News From Folding@Home: Welcome to Folding@Home
[14:44:53] Loaded queue successfully.
[14:45:00] + Closed connections
[14:45:05]
[14:45:05] + Processing work unit
[14:45:05] Core required: FahCore_78.exe
[14:45:05] Core found.
[14:45:05] Working on Unit 02 [January 17 14:45:05]
[14:45:05] + Working ...
[14:45:05]
[14:45:05] *------------------------------*
[14:45:05] Folding@Home Gromacs Core
[14:45:05] Version 1.90 (March 8, 2006)
[14:45:05]
[14:45:05] Preparing to commence simulation
[14:45:05] - Looking at optimizations...
[14:45:05] - Created dyn
[14:45:05] - Files status OK
[14:45:06] - Expanded 661808 -> 3332352 (decompressed 503.5 percent)
[14:45:06] - Starting from initial work packet
[14:45:06]
[14:45:06] Project: 6892 (Run 616, Clone 1, Gen 79)
[14:45:06]
[14:45:06] Assembly optimizations on if available.
[14:45:06] Entering M.D.
[14:45:13] Protein: ALZHEIMER DISEASE AMYLOID
[14:45:13]
[14:45:13] Writing local files
[14:45:52] Extra SSE boost OK.
[14:45:53] Writing local files
[14:45:53] Completed 0 out of 250000 steps  (0%)
[15:39:12] Writing local files
[15:39:12] Completed 2500 out of 250000 steps  (1%)
[16:32:33] Writing local files
[16:32:33] Completed 5000 out of 250000 steps  (2%)
[17:25:54] Writing local files
[17:25:54] Completed 7500 out of 250000 steps  (3%)
[18:19:13] Writing local files
[18:19:13] Completed 10000 out of 250000 steps  (4%)
[19:12:32] Writing local files
[19:12:32] Completed 12500 out of 250000 steps  (5%)
[20:05:49] Writing local files
[20:05:49] Completed 15000 out of 250000 steps  (6%)
[20:59:04] Writing local files
[20:59:04] Completed 17500 out of 250000 steps  (7%)
[21:52:23] Writing local files
[21:52:23] Completed 20000 out of 250000 steps  (8%)
[22:45:33] Writing local files
[22:45:33] Completed 22500 out of 250000 steps  (9%)
[23:38:55] Writing local files
[23:38:55] Completed 25000 out of 250000 steps  (10%)
[00:32:14] Writing local files
[00:32:14] Completed 27500 out of 250000 steps  (11%)
[01:25:31] Writing local files
[01:25:32] Completed 30000 out of 250000 steps  (12%)
[02:18:44] Writing local files
[02:18:44] Completed 32500 out of 250000 steps  (13%)
[03:12:02] Writing local files
[03:12:02] Completed 35000 out of 250000 steps  (14%)
[04:05:14] Writing local files
[04:05:14] Completed 37500 out of 250000 steps  (15%)
[04:58:27] Writing local files
[04:58:27] Completed 40000 out of 250000 steps  (16%)
[05:51:38] Writing local files
[05:51:39] Completed 42500 out of 250000 steps  (17%)
[06:44:53] Writing local files
[06:44:53] Completed 45000 out of 250000 steps  (18%)
[07:38:09] Writing local files
[07:38:09] Completed 47500 out of 250000 steps  (19%)
[08:31:17] Writing local files
[08:31:17] Completed 50000 out of 250000 steps  (20%)
[09:24:30] Writing local files
[09:24:30] Completed 52500 out of 250000 steps  (21%)
[10:17:49] Writing local files
[10:17:49] Completed 55000 out of 250000 steps  (22%)
[11:11:02] Writing local files
[11:11:02] Completed 57500 out of 250000 steps  (23%)
[12:04:17] Writing local files
[12:04:18] Completed 60000 out of 250000 steps  (24%)
[12:57:37] Writing local files
[12:57:37] Completed 62500 out of 250000 steps  (25%)
[13:50:57] Writing local files
[13:50:57] Completed 65000 out of 250000 steps  (26%)
[14:44:18] Writing local files
[14:44:19] Completed 67500 out of 250000 steps  (27%)
[15:37:38] Writing local files
[15:37:38] Completed 70000 out of 250000 steps  (28%)
[16:30:58] Writing local files
[16:30:58] Completed 72500 out of 250000 steps  (29%)
[17:24:22] Writing local files
[17:24:22] Completed 75000 out of 250000 steps  (30%)
[18:01:40] CoreStatus = 0 (0)
[18:01:40] Client-core communications error: ERROR 0x0
[18:01:40] Deleting current work unit & continuing...
[18:02:55] - Preparing to get new work unit...
[18:02:55] + Attempting to get work packet
[18:02:55] - Connecting to assignment server
[18:02:57] - Successful: assigned to (171.67.108.53).
[18:02:57] + News From Folding@Home: Welcome to Folding@Home
[18:02:57] Loaded queue successfully.
[18:03:02] + Closed connections
[18:03:07]
[18:03:07] + Processing work unit
[18:03:07] Core required: FahCore_78.exe
[18:03:07] Core found.
[18:03:07] Working on Unit 03 [January 18 18:03:07]
[18:03:07] + Working ...
[18:03:07]
[18:03:07] *------------------------------*
[18:03:07] Folding@Home Gromacs Core
[18:03:07] Version 1.90 (March 8, 2006)
[18:03:07]
[18:03:07] Preparing to commence simulation
[18:03:07] - Looking at optimizations...
[18:03:07] - Created dyn
[18:03:07] - Files status OK
[18:03:08] - Expanded 661808 -> 3332352 (decompressed 503.5 percent)
[18:03:08] - Starting from initial work packet
[18:03:08]
[18:03:08] Project: 6892 (Run 616, Clone 1, Gen 79)
[18:03:08]
[18:03:08] Assembly optimizations on if available.
[18:03:08] Entering M.D.
[18:03:15] Protein: ALZHEIMER DISEASE AMYLOID
[18:03:15]
[18:03:15] Writing local files
[18:03:54] Extra SSE boost OK.
[18:03:56] Writing local files
[18:03:56] Completed 0 out of 250000 steps  (0%)
[18:57:23] Writing local files
[18:57:23] Completed 2500 out of 250000 steps  (1%)
[19:50:45] Writing local files
[19:50:45] Completed 5000 out of 250000 steps  (2%)
[20:44:12] Writing local files
[20:44:12] Completed 7500 out of 250000 steps  (3%)
[21:37:38] Writing local files
[21:37:38] Completed 10000 out of 250000 steps  (4%)
[22:30:59] Writing local files
[22:30:59] Completed 12500 out of 250000 steps  (5%)
[23:24:22] Writing local files
[23:24:23] Completed 15000 out of 250000 steps  (6%)
[00:17:46] Writing local files
[00:17:46] Completed 17500 out of 250000 steps  (7%)
[01:11:03] Writing local files
[01:11:04] Completed 20000 out of 250000 steps  (8%)
[02:04:18] Writing local files
[02:04:18] Completed 22500 out of 250000 steps  (9%)
[02:57:35] Writing local files
[02:57:36] Completed 25000 out of 250000 steps  (10%)
[03:50:56] Writing local files
[03:50:56] Completed 27500 out of 250000 steps  (11%)
[04:44:22] Writing local files
[04:44:23] Completed 30000 out of 250000 steps  (12%)
[05:37:43] Writing local files
[05:37:44] Completed 32500 out of 250000 steps  (13%)
[06:31:13] Writing local files
[06:31:13] Completed 35000 out of 250000 steps  (14%)
[07:24:37] Writing local files
[07:24:37] Completed 37500 out of 250000 steps  (15%)
[08:18:04] Writing local files
[08:18:04] Completed 40000 out of 250000 steps  (16%)
[09:11:29] Writing local files
[09:11:29] Completed 42500 out of 250000 steps  (17%)
[10:05:08] Writing local files
[10:05:08] Completed 45000 out of 250000 steps  (18%)
[10:58:35] Writing local files
[10:58:36] Completed 47500 out of 250000 steps  (19%)
[11:51:59] Writing local files
[11:51:59] Completed 50000 out of 250000 steps  (20%)
[12:45:22] Writing local files
[12:45:22] Completed 52500 out of 250000 steps  (21%)
[13:38:39] Writing local files
[13:38:39] Completed 55000 out of 250000 steps  (22%)
[14:32:06] Writing local files
[14:32:06] Completed 57500 out of 250000 steps  (23%)
[15:25:29] Writing local files
[15:25:29] Completed 60000 out of 250000 steps  (24%)
[16:18:57] Writing local files
[16:18:57] Completed 62500 out of 250000 steps  (25%)
[17:12:21] Writing local files
[17:12:21] Completed 65000 out of 250000 steps  (26%)
[18:05:45] Writing local files
[18:05:45] Completed 67500 out of 250000 steps  (27%)
[18:59:07] Writing local files
[18:59:07] Completed 70000 out of 250000 steps  (28%)
[19:52:19] Writing local files
[19:52:19] Completed 72500 out of 250000 steps  (29%)
[20:45:39] Writing local files
[20:45:39] Completed 75000 out of 250000 steps  (30%)
[21:22:59] CoreStatus = 0 (0)
[21:22:59] Client-core communications error: ERROR 0x0
[21:22:59] Deleting current work unit & continuing...
[21:24:13] - Preparing to get new work unit...
[21:24:13] + Attempting to get work packet
[21:24:13] - Connecting to assignment server
[21:24:14] - Successful: assigned to (171.67.108.53).
[21:24:14] + News From Folding@Home: Welcome to Folding@Home
[21:24:14] Loaded queue successfully.
[21:24:21] + Closed connections
[21:24:26]
[21:24:26] + Processing work unit
[21:24:26] Core required: FahCore_78.exe
[21:24:26] Core found.
[21:24:26] Working on Unit 04 [January 19 21:24:26]
[21:24:26] + Working ...
[21:24:26]
[21:24:26] *------------------------------*
[21:24:26] Folding@Home Gromacs Core
[21:24:26] Version 1.90 (March 8, 2006)
[21:24:26]
[21:24:26] Preparing to commence simulation
[21:24:26] - Looking at optimizations...
[21:24:26] - Created dyn
[21:24:26] - Files status OK
[21:24:27] - Expanded 661808 -> 3332352 (decompressed 503.5 percent)
[21:24:27] - Starting from initial work packet
[21:24:27]
[21:24:27] Project: 6892 (Run 616, Clone 1, Gen 79)
[21:24:27]
[21:24:27] Assembly optimizations on if available.
[21:24:27] Entering M.D.
[21:24:34] Protein: ALZHEIMER DISEASE AMYLOID
[21:24:34]
[21:24:34] Writing local files
[21:25:13] Extra SSE boost OK.
[21:25:14] Writing local files
[21:25:14] Completed 0 out of 250000 steps  (0%)
[22:18:31] Writing local files
[22:18:31] Completed 2500 out of 250000 steps  (1%)
[23:11:46] Writing local files
[23:11:46] Completed 5000 out of 250000 steps  (2%)
[00:05:01] Writing local files
[00:05:01] Completed 7500 out of 250000 steps  (3%)
[00:58:12] Writing local files
[00:58:12] Completed 10000 out of 250000 steps  (4%)
[01:51:23] Writing local files
[01:51:23] Completed 12500 out of 250000 steps  (5%)
[02:44:31] Writing local files
[02:44:31] Completed 15000 out of 250000 steps  (6%)
[03:37:44] Writing local files
[03:37:44] Completed 17500 out of 250000 steps  (7%)
[04:31:01] Writing local files
[04:31:01] Completed 20000 out of 250000 steps  (8%)
[05:24:13] Writing local files
[05:24:13] Completed 22500 out of 250000 steps  (9%)
[06:17:27] Writing local files
[06:17:27] Completed 25000 out of 250000 steps  (10%)
[07:10:40] Writing local files
[07:10:40] Completed 27500 out of 250000 steps  (11%)
[08:03:52] Writing local files
[08:03:52] Completed 30000 out of 250000 steps  (12%)
[08:56:57] Writing local files
[08:56:57] Completed 32500 out of 250000 steps  (13%)
[09:50:10] Writing local files
[09:50:10] Completed 35000 out of 250000 steps  (14%)
[10:43:27] Writing local files
[10:43:27] Completed 37500 out of 250000 steps  (15%)
[11:36:36] Writing local files
[11:36:36] Completed 40000 out of 250000 steps  (16%)
[12:29:47] Writing local files
[12:29:47] Completed 42500 out of 250000 steps  (17%)
[13:22:59] Writing local files
[13:23:00] Completed 45000 out of 250000 steps  (18%)
[14:16:21] Writing local files
[14:16:22] Completed 47500 out of 250000 steps  (19%)
[15:09:37] Writing local files
[15:09:37] Completed 50000 out of 250000 steps  (20%)
[16:02:54] Writing local files
[16:02:54] Completed 52500 out of 250000 steps  (21%)
[16:56:07] Writing local files
[16:56:07] Completed 55000 out of 250000 steps  (22%)
[17:49:23] Writing local files
[17:49:23] Completed 57500 out of 250000 steps  (23%)
[18:42:36] Writing local files
[18:42:36] Completed 60000 out of 250000 steps  (24%)
[19:35:49] Writing local files
[19:35:49] Completed 62500 out of 250000 steps  (25%)
[20:28:57] Writing local files
[20:28:57] Completed 65000 out of 250000 steps  (26%)
[21:22:07] Writing local files
[21:22:07] Completed 67500 out of 250000 steps  (27%)
[22:15:20] Writing local files
[22:15:20] Completed 70000 out of 250000 steps  (28%)
[23:08:30] Writing local files
[23:08:30] Completed 72500 out of 250000 steps  (29%)
[00:01:47] Writing local files
[00:01:47] Completed 75000 out of 250000 steps  (30%)
[00:38:59] CoreStatus = 0 (0)
[00:38:59] Client-core communications error: ERROR 0x0
[00:38:59] - Attempting to download new core...
[00:38:59] + Downloading new core: FahCore_78.exe
[00:39:01] + 10240 bytes downloaded
[00:39:01] + 20480 bytes downloaded
[00:39:01] + 30720 bytes downloaded
[00:39:02] + 40960 bytes downloaded
[00:39:02] + 51200 bytes downloaded
[00:39:02] + 61440 bytes downloaded
[00:39:02] + 71680 bytes downloaded
[00:39:02] + 81920 bytes downloaded
[00:39:02] + 92160 bytes downloaded
[00:39:02] + 102400 bytes downloaded
[00:39:02] + 112640 bytes downloaded
[00:39:02] + 122880 bytes downloaded
[00:39:02] + 133120 bytes downloaded
[00:39:02] + 143360 bytes downloaded
[00:39:02] + 153600 bytes downloaded
[00:39:02] + 163840 bytes downloaded
[00:39:02] + 174080 bytes downloaded
[00:39:02] + 184320 bytes downloaded
[00:39:02] + 194560 bytes downloaded
[00:39:02] + 204800 bytes downloaded
[00:39:02] + 215040 bytes downloaded
[00:39:02] + 225280 bytes downloaded
[00:39:03] + 235520 bytes downloaded
[00:39:03] + 245760 bytes downloaded
[00:39:03] + 256000 bytes downloaded
[00:39:03] + 266240 bytes downloaded
[00:39:03] + 276480 bytes downloaded
[00:39:03] + 286720 bytes downloaded
[00:39:03] + 296960 bytes downloaded
[00:39:03] + 307200 bytes downloaded
[00:39:03] + 317440 bytes downloaded
[00:39:03] + 327680 bytes downloaded
[00:39:03] + 337920 bytes downloaded
[00:39:03] + 348160 bytes downloaded
[00:39:03] + 358400 bytes downloaded
[00:39:03] + 368640 bytes downloaded
[00:39:03] + 378880 bytes downloaded
[00:39:03] + 389120 bytes downloaded
[00:39:03] + 399360 bytes downloaded
[00:39:03] + 409600 bytes downloaded
[00:39:03] + 419840 bytes downloaded
[00:39:03] + 430080 bytes downloaded
[00:39:03] + 440320 bytes downloaded
[00:39:03] + 450560 bytes downloaded
[00:39:03] + 460800 bytes downloaded
[00:39:03] + 471040 bytes downloaded
[00:39:03] + 481280 bytes downloaded
[00:39:03] + 491520 bytes downloaded
[00:39:03] + 501760 bytes downloaded
[00:39:03] + 512000 bytes downloaded
[00:39:03] + 522240 bytes downloaded
[00:39:03] + 532480 bytes downloaded
[00:39:03] + 542720 bytes downloaded
[00:39:03] + 552960 bytes downloaded
[00:39:04] + 563200 bytes downloaded
[00:39:04] + 573440 bytes downloaded
[00:39:04] + 583680 bytes downloaded
[00:39:04] + 593920 bytes downloaded
[00:39:04] + 604160 bytes downloaded
[00:39:04] + 614400 bytes downloaded
[00:39:04] + 624640 bytes downloaded
[00:39:04] + 634880 bytes downloaded
[00:39:04] + 645120 bytes downloaded
[00:39:04] + 655360 bytes downloaded
[00:39:04] + 665600 bytes downloaded
[00:39:04] + 675840 bytes downloaded
[00:39:04] + 686080 bytes downloaded
[00:39:04] + 696320 bytes downloaded
[00:39:04] + 706560 bytes downloaded
[00:39:04] + 716800 bytes downloaded
[00:39:04] + 727040 bytes downloaded
[00:39:04] + 737280 bytes downloaded
[00:39:04] + 747520 bytes downloaded
[00:39:04] + 757760 bytes downloaded
[00:39:04] + 768000 bytes downloaded
[00:39:04] + 778240 bytes downloaded
[00:39:04] + 788480 bytes downloaded
[00:39:04] + 798720 bytes downloaded
[00:39:04] + 808960 bytes downloaded
[00:39:04] + 819200 bytes downloaded
[00:39:04] + 829440 bytes downloaded
[00:39:04] + 839680 bytes downloaded
[00:39:04] + 849920 bytes downloaded
[00:39:04] + 860160 bytes downloaded
[00:39:04] + 870400 bytes downloaded
[00:39:04] + 880640 bytes downloaded
[00:39:04] + 890880 bytes downloaded
[00:39:04] + 901120 bytes downloaded
[00:39:04] + 911360 bytes downloaded
[00:39:05] + 921600 bytes downloaded
[00:39:05] + 931840 bytes downloaded
[00:39:05] + 942080 bytes downloaded
[00:39:05] + 952320 bytes downloaded
[00:39:05] + 962560 bytes downloaded
[00:39:05] + 972800 bytes downloaded
[00:39:05] + 983040 bytes downloaded
[00:39:05] + 993280 bytes downloaded
[00:39:05] + 1003520 bytes downloaded
[00:39:05] + 1013760 bytes downloaded
[00:39:05] + 1024000 bytes downloaded
[00:39:05] + 1034240 bytes downloaded
[00:39:05] + 1044480 bytes downloaded
[00:39:05] + 1054720 bytes downloaded
[00:39:05] + 1064960 bytes downloaded
[00:39:05] + 1075200 bytes downloaded
[00:39:05] + 1085440 bytes downloaded
[00:39:05] + 1095680 bytes downloaded
[00:39:05] + 1105920 bytes downloaded
[00:39:05] + 1116160 bytes downloaded
[00:39:05] + 1126400 bytes downloaded
[00:39:06] + 1134407 bytes downloaded
[00:39:06] Verifying core Core_78.fah...
[00:39:06] Signature is VALID
[00:39:06]
[00:39:06] Trying to unzip core FahCore_78.exe
[00:39:07] Decompressed FahCore_78.exe (3435296 bytes) successfully
[00:39:07] + Core successfully engaged
[00:39:19] Deleting current work unit & continuing...
[00:40:34] - Preparing to get new work unit...
[00:40:34] + Attempting to get work packet
[00:40:34] - Connecting to assignment server
[00:40:43] - Successful: assigned to (171.67.108.53).
[00:40:43] + News From Folding@Home: Welcome to Folding@Home
[00:40:43] Loaded queue successfully.
[00:40:48] + Closed connections
[00:40:53]
[00:40:53] + Processing work unit
[00:40:53] Core required: FahCore_78.exe
[00:40:53] Core found.
[00:40:53] Working on Unit 05 [January 21 00:40:53]
[00:40:53] + Working ...
[00:40:53]
[00:40:53] *------------------------------*
[00:40:53] Folding@Home Gromacs Core
[00:40:53] Version 1.90 (March 8, 2006)
[00:40:53]
[00:40:53] Preparing to commence simulation
[00:40:53] - Looking at optimizations...
[00:40:53] - Created dyn
[00:40:53] - Files status OK
[00:40:54] - Expanded 661808 -> 3332352 (decompressed 503.5 percent)
[00:40:54] - Starting from initial work packet
[00:40:54]
[00:40:54] Project: 6892 (Run 616, Clone 1, Gen 79)
[00:40:54]
[00:40:54] Assembly optimizations on if available.
[00:40:54] Entering M.D.
[00:41:01] Protein: ALZHEIMER DISEASE AMYLOID
[00:41:01]
[00:41:01] Writing local files
[00:41:39] Extra SSE boost OK.
[00:41:41] Writing local files
[00:41:41] Completed 0 out of 250000 steps  (0%)
[01:35:05] Writing local files
[01:35:05] Completed 2500 out of 250000 steps  (1%)
[02:28:26] Writing local files
[02:28:26] Completed 5000 out of 250000 steps  (2%)
[03:21:43] Writing local files
[03:21:44] Completed 7500 out of 250000 steps  (3%)
[04:14:57] Writing local files
[04:14:58] Completed 10000 out of 250000 steps  (4%)
[05:08:16] Writing local files
[05:08:16] Completed 12500 out of 250000 steps  (5%)
[06:01:39] Writing local files
[06:01:39] Completed 15000 out of 250000 steps  (6%)
[06:55:00] Writing local files
[06:55:01] Completed 17500 out of 250000 steps  (7%)
[07:48:21] Writing local files
[07:48:21] Completed 20000 out of 250000 steps  (8%)
[08:41:38] Writing local files
[08:41:38] Completed 22500 out of 250000 steps  (9%)
[09:35:02] Writing local files
[09:35:02] Completed 25000 out of 250000 steps  (10%)
[10:28:39] Writing local files
[10:28:39] Completed 27500 out of 250000 steps  (11%)
[11:22:01] Writing local files
[11:22:01] Completed 30000 out of 250000 steps  (12%)
[12:15:19] Writing local files
[12:15:19] Completed 32500 out of 250000 steps  (13%)
[13:08:43] Writing local files
[13:08:44] Completed 35000 out of 250000 steps  (14%)
[14:02:08] Writing local files
[14:02:09] Completed 37500 out of 250000 steps  (15%)
[14:55:37] Writing local files
[14:55:37] Completed 40000 out of 250000 steps  (16%)
[15:48:57] Writing local files
[15:48:57] Completed 42500 out of 250000 steps  (17%)
[16:42:18] Writing local files
[16:42:18] Completed 45000 out of 250000 steps  (18%)
[17:35:38] Writing local files
[17:35:38] Completed 47500 out of 250000 steps  (19%)
[18:28:49] Writing local files
[18:28:49] Completed 50000 out of 250000 steps  (20%)
[19:22:01] Writing local files
[19:22:01] Completed 52500 out of 250000 steps  (21%)
[20:15:10] Writing local files
[20:15:10] Completed 55000 out of 250000 steps  (22%)
[21:08:22] Writing local files
[21:08:22] Completed 57500 out of 250000 steps  (23%)
[22:01:33] Writing local files
[22:01:33] Completed 60000 out of 250000 steps  (24%)
[22:54:46] Writing local files
[22:54:46] Completed 62500 out of 250000 steps  (25%)
[23:48:00] Writing local files
[23:48:00] Completed 65000 out of 250000 steps  (26%)
[00:41:11] Writing local files
[00:41:11] Completed 67500 out of 250000 steps  (27%)
[01:34:22] Writing local files
[01:34:23] Completed 70000 out of 250000 steps  (28%)
[02:27:34] Writing local files
[02:27:34] Completed 72500 out of 250000 steps  (29%)
[03:20:50] Writing local files
[03:20:50] Completed 75000 out of 250000 steps  (30%)
[03:58:04] CoreStatus = 0 (0)
[03:58:04] Client-core communications error: ERROR 0x0
[03:58:04] Deleting current work unit & continuing...
[03:59:19] - Preparing to get new work unit...
[03:59:19] + Attempting to get work packet
[03:59:19] - Connecting to assignment server
[03:59:25] - Successful: assigned to (171.67.108.53).
[03:59:25] + News From Folding@Home: Welcome to Folding@Home
[03:59:25] Loaded queue successfully.
[03:59:30] + Closed connections
djohnston
Re: Project: 6892 (Run 616, Clone 1, Gen 79)
Post by djohnston »
More of the run log. (Part 2)
[03:59:35]
[03:59:35] + Processing work unit
[03:59:35] Core required: FahCore_78.exe
[03:59:35] Core found.
[03:59:35] Working on Unit 06 [January 22 03:59:35]
[03:59:35] + Working ...
[03:59:35]
[03:59:35] *------------------------------*
[03:59:35] Folding@Home Gromacs Core
[03:59:35] Version 1.90 (March 8, 2006)
[03:59:35]
[03:59:35] Preparing to commence simulation
[03:59:35] - Looking at optimizations...
[03:59:35] - Created dyn
[03:59:35] - Files status OK
[03:59:36] - Expanded 661808 -> 3332352 (decompressed 503.5 percent)
[03:59:36] - Starting from initial work packet
[03:59:36]
[03:59:36] Project: 6892 (Run 616, Clone 1, Gen 79)
[03:59:36]
[03:59:36] Assembly optimizations on if available.
[03:59:36] Entering M.D.
[03:59:43] Protein: ALZHEIMER DISEASE AMYLOID
[03:59:43]
[03:59:43] Writing local files
[04:00:22] Extra SSE boost OK.
[04:00:23] Writing local files
[04:00:23] Completed 0 out of 250000 steps  (0%)
[04:55:29] Writing local files
[04:55:29] Completed 2500 out of 250000 steps  (1%)
[05:50:34] Writing local files
[05:50:34] Completed 5000 out of 250000 steps  (2%)
[06:45:38] Writing local files
[06:45:38] Completed 7500 out of 250000 steps  (3%)
[07:40:43] Writing local files
[07:40:43] Completed 10000 out of 250000 steps  (4%)
[08:35:45] Writing local files
[08:35:45] Completed 12500 out of 250000 steps  (5%)
[09:30:50] Writing local files
[09:30:50] Completed 15000 out of 250000 steps  (6%)
[10:27:55] Writing local files
[10:27:55] Completed 17500 out of 250000 steps  (7%)
[11:22:50] Writing local files
[11:22:50] Completed 20000 out of 250000 steps  (8%)
[12:17:41] Writing local files
[12:17:41] Completed 22500 out of 250000 steps  (9%)
[13:12:38] Completed 25000 out of 250000 steps  (10%)
[14:07:40] Writing local files
[14:07:40] Completed 27500 out of 250000 steps  (11%)
[15:02:41] Writing local files
[15:02:42] Completed 30000 out of 250000 steps  (12%)
[15:57:36] Writing local files
[15:57:37] Completed 32500 out of 250000 steps  (13%)
[16:52:39] Writing local files
[16:52:39] Completed 35000 out of 250000 steps  (14%)
[17:47:38] Writing local files
[17:47:38] Completed 37500 out of 250000 steps  (15%)
[18:42:37] Writing local files
[18:42:38] Completed 40000 out of 250000 steps  (16%)
[19:37:35] Writing local files
[19:37:35] Completed 42500 out of 250000 steps  (17%)
[20:32:28] Writing local files
[20:32:28] Completed 45000 out of 250000 steps  (18%)
[21:27:24] Writing local files
[21:27:24] Completed 47500 out of 250000 steps  (19%)
[22:22:19] Writing local files
[22:22:19] Completed 50000 out of 250000 steps  (20%)
[23:17:15] Writing local files
[23:17:16] Completed 52500 out of 250000 steps  (21%)
[00:12:11] Writing local files
[00:12:11] Completed 55000 out of 250000 steps  (22%)
[01:07:07] Writing local files
[01:07:07] Completed 57500 out of 250000 steps  (23%)
[02:02:01] Writing local files
[02:02:01] Completed 60000 out of 250000 steps  (24%)
[02:56:56] Writing local files
[02:56:56] Completed 62500 out of 250000 steps  (25%)
[03:51:57] Writing local files
[03:51:57] Completed 65000 out of 250000 steps  (26%)
[04:47:00] Writing local files
[04:47:00] Completed 67500 out of 250000 steps  (27%)
[05:42:05] Writing local files
[05:42:06] Completed 70000 out of 250000 steps  (28%)
[06:37:10] Writing local files
[06:37:10] Completed 72500 out of 250000 steps  (29%)
[07:32:18] Writing local files
[07:32:18] Completed 75000 out of 250000 steps  (30%)
[08:10:49] CoreStatus = 0 (0)
[08:10:49] Client-core communications error: ERROR 0x0
[08:10:49] Deleting current work unit & continuing...
[08:12:05] - Preparing to get new work unit...
[08:12:05] + Attempting to get work packet
[08:12:05] - Connecting to assignment server
[08:12:05] - Successful: assigned to (171.67.108.53).
[08:12:05] + News From Folding@Home: Welcome to Folding@Home
[08:12:06] Loaded queue successfully.
[08:12:10] + Closed connections
[08:12:15]
[08:12:15] + Processing work unit
[08:12:15] Core required: FahCore_78.exe
[08:12:15] Core found.
[08:12:15] Working on Unit 07 [January 23 08:12:15]
[08:12:15] + Working ...
[08:12:16]
[08:12:16] *------------------------------*
[08:12:16] Folding@Home Gromacs Core
[08:12:16] Version 1.90 (March 8, 2006)
[08:12:16]
[08:12:16] Preparing to commence simulation
[08:12:16] - Looking at optimizations...
[08:12:16] - Created dyn
[08:12:16] - Files status OK
[08:12:17] - Expanded 661808 -> 3332352 (decompressed 503.5 percent)
[08:12:17] - Starting from initial work packet
[08:12:17]
[08:12:17] Project: 6892 (Run 616, Clone 1, Gen 79)
[08:12:17]
[08:12:17] Assembly optimizations on if available.
[08:12:17] Entering M.D.
[08:12:24] Protein: ALZHEIMER DISEASE AMYLOID
[08:12:24]
[08:12:24] Writing local files
[08:13:02] Extra SSE boost OK.
[08:13:04] Writing local files
[08:13:04] Completed 0 out of 250000 steps  (0%)
[09:06:27] Writing local files
[09:06:27] Completed 2500 out of 250000 steps  (1%)
[09:59:54] Writing local files
[09:59:54] Completed 5000 out of 250000 steps  (2%)
[10:53:34] Writing local files
[10:53:34] Completed 7500 out of 250000 steps  (3%)
[11:47:00] Writing local files
[11:47:00] Completed 10000 out of 250000 steps  (4%)
[12:40:24] Writing local files
[12:40:24] Completed 12500 out of 250000 steps  (5%)
[13:33:52] Writing local files
[13:33:52] Completed 15000 out of 250000 steps  (6%)
[14:27:20] Writing local files
[14:27:20] Completed 17500 out of 250000 steps  (7%)
[15:20:45] Writing local files
[15:20:45] Completed 20000 out of 250000 steps  (8%)
[16:14:07] Writing local files
[16:14:07] Completed 22500 out of 250000 steps  (9%)
[17:07:34] Writing local files
[17:07:34] Completed 25000 out of 250000 steps  (10%)
[18:01:01] Writing local files
[18:01:01] Completed 27500 out of 250000 steps  (11%)
[18:54:26] Writing local files
[18:54:26] Completed 30000 out of 250000 steps  (12%)
[19:47:48] Writing local files
[19:47:48] Completed 32500 out of 250000 steps  (13%)
[20:41:16] Writing local files
[20:41:16] Completed 35000 out of 250000 steps  (14%)
[21:34:38] Writing local files
[21:34:38] Completed 37500 out of 250000 steps  (15%)
[22:28:01] Writing local files
[22:28:01] Completed 40000 out of 250000 steps  (16%)
[23:21:25] Writing local files
[23:21:25] Completed 42500 out of 250000 steps  (17%)
[00:14:50] Writing local files
[00:14:50] Completed 45000 out of 250000 steps  (18%)
[01:08:14] Writing local files
[01:08:14] Completed 47500 out of 250000 steps  (19%)
[02:01:30] Writing local files
[02:01:30] Completed 50000 out of 250000 steps  (20%)
[02:54:46] Writing local files
[02:54:46] Completed 52500 out of 250000 steps  (21%)
[03:47:58] Writing local files
[03:47:59] Completed 55000 out of 250000 steps  (22%)
[04:41:08] Writing local files
[04:41:08] Completed 57500 out of 250000 steps  (23%)
[05:34:18] Writing local files
[05:34:18] Completed 60000 out of 250000 steps  (24%)
[06:27:35] Writing local files
[06:27:35] Completed 62500 out of 250000 steps  (25%)
[07:20:48] Writing local files
[07:20:48] Completed 65000 out of 250000 steps  (26%)
[08:13:57] Writing local files
[08:13:57] Completed 67500 out of 250000 steps  (27%)
[09:07:08] Writing local files
[09:07:08] Completed 70000 out of 250000 steps  (28%)
[10:00:17] Writing local files
[10:00:17] Completed 72500 out of 250000 steps  (29%)
[10:53:41] Writing local files
[10:53:42] Completed 75000 out of 250000 steps  (30%)
[11:30:56] CoreStatus = 0 (0)
[11:30:56] Client-core communications error: ERROR 0x0
[11:30:56] - Attempting to download new core...
[11:30:56] + Downloading new core: FahCore_78.exe
[11:30:56] + 10240 bytes downloaded
[11:30:57] + 20480 bytes downloaded
[11:30:57] + 30720 bytes downloaded
[11:30:57] + 40960 bytes downloaded
[11:30:57] + 51200 bytes downloaded
[11:30:57] + 61440 bytes downloaded
[11:30:57] + 71680 bytes downloaded
[11:30:57] + 81920 bytes downloaded
[11:30:57] + 92160 bytes downloaded
[11:30:57] + 102400 bytes downloaded
[11:30:57] + 112640 bytes downloaded
[11:30:57] + 122880 bytes downloaded
[11:30:57] + 133120 bytes downloaded
[11:30:57] + 143360 bytes downloaded
[11:30:57] + 153600 bytes downloaded
[11:30:57] + 163840 bytes downloaded
[11:30:57] + 174080 bytes downloaded
[11:30:57] + 184320 bytes downloaded
[11:30:57] + 194560 bytes downloaded
[11:30:57] + 204800 bytes downloaded
[11:30:57] + 215040 bytes downloaded
[11:30:57] + 225280 bytes downloaded
[11:30:57] + 235520 bytes downloaded
[11:30:57] + 245760 bytes downloaded
[11:30:57] + 256000 bytes downloaded
[11:30:57] + 266240 bytes downloaded
[11:30:57] + 276480 bytes downloaded
[11:30:57] + 286720 bytes downloaded
[11:30:57] + 296960 bytes downloaded
[11:30:57] + 307200 bytes downloaded
[11:30:57] + 317440 bytes downloaded
[11:30:57] + 327680 bytes downloaded
[11:30:57] + 337920 bytes downloaded
[11:30:57] + 348160 bytes downloaded
[11:30:57] + 358400 bytes downloaded
[11:30:57] + 368640 bytes downloaded
[11:30:57] + 378880 bytes downloaded
[11:30:58] + 389120 bytes downloaded
[11:30:58] + 399360 bytes downloaded
[11:30:58] + 409600 bytes downloaded
[11:30:58] + 419840 bytes downloaded
[11:30:58] + 430080 bytes downloaded
[11:30:58] + 440320 bytes downloaded
[11:30:58] + 450560 bytes downloaded
[11:30:58] + 460800 bytes downloaded
[11:30:58] + 471040 bytes downloaded
[11:30:58] + 481280 bytes downloaded
[11:30:58] + 491520 bytes downloaded
[11:30:58] + 501760 bytes downloaded
[11:30:58] + 512000 bytes downloaded
[11:30:58] + 522240 bytes downloaded
[11:30:58] + 532480 bytes downloaded
[11:30:58] + 542720 bytes downloaded
[11:30:58] + 552960 bytes downloaded
[11:30:58] + 563200 bytes downloaded
[11:30:58] + 573440 bytes downloaded
[11:30:58] + 583680 bytes downloaded
[11:30:58] + 593920 bytes downloaded
[11:30:58] + 604160 bytes downloaded
[11:30:58] + 614400 bytes downloaded
[11:30:58] + 624640 bytes downloaded
[11:30:58] + 634880 bytes downloaded
[11:30:58] + 645120 bytes downloaded
[11:30:58] + 655360 bytes downloaded
[11:30:58] + 665600 bytes downloaded
[11:30:58] + 675840 bytes downloaded
[11:30:58] + 686080 bytes downloaded
[11:30:58] + 696320 bytes downloaded
[11:30:58] + 706560 bytes downloaded
[11:30:58] + 716800 bytes downloaded
[11:30:58] + 727040 bytes downloaded
[11:30:58] + 737280 bytes downloaded
[11:30:58] + 747520 bytes downloaded
[11:30:59] + 757760 bytes downloaded
[11:30:59] + 768000 bytes downloaded
[11:30:59] + 778240 bytes downloaded
[11:30:59] + 788480 bytes downloaded
[11:30:59] + 798720 bytes downloaded
[11:30:59] + 808960 bytes downloaded
[11:30:59] + 819200 bytes downloaded
[11:30:59] + 829440 bytes downloaded
[11:30:59] + 839680 bytes downloaded
[11:30:59] + 849920 bytes downloaded
[11:30:59] + 860160 bytes downloaded
[11:30:59] + 870400 bytes downloaded
[11:30:59] + 880640 bytes downloaded
[11:30:59] + 890880 bytes downloaded
[11:30:59] + 901120 bytes downloaded
[11:30:59] + 911360 bytes downloaded
[11:30:59] + 921600 bytes downloaded
[11:30:59] + 931840 bytes downloaded
[11:30:59] + 942080 bytes downloaded
[11:30:59] + 952320 bytes downloaded
[11:30:59] + 962560 bytes downloaded
[11:30:59] + 972800 bytes downloaded
[11:30:59] + 983040 bytes downloaded
[11:30:59] + 993280 bytes downloaded
[11:30:59] + 1003520 bytes downloaded
[11:30:59] + 1013760 bytes downloaded
[11:30:59] + 1024000 bytes downloaded
[11:30:59] + 1034240 bytes downloaded
[11:30:59] + 1044480 bytes downloaded
[11:30:59] + 1054720 bytes downloaded
[11:30:59] + 1064960 bytes downloaded
[11:30:59] + 1075200 bytes downloaded
[11:30:59] + 1085440 bytes downloaded
[11:30:59] + 1095680 bytes downloaded
[11:30:59] + 1105920 bytes downloaded
[11:31:00] + 1116160 bytes downloaded
[11:31:00] + 1126400 bytes downloaded
[11:31:00] + 1134407 bytes downloaded
[11:31:00] Verifying core Core_78.fah...
[11:31:00] Signature is VALID
[11:31:00]
[11:31:00] Trying to unzip core FahCore_78.exe
[11:31:01] Decompressed FahCore_78.exe (3435296 bytes) successfully
[11:31:01] + Core successfully engaged
[11:31:13] Deleting current work unit & continuing...
[11:32:28] - Preparing to get new work unit...
[11:32:28] + Attempting to get work packet
[11:32:28] - Connecting to assignment server
[11:32:31] - Successful: assigned to (171.67.108.53).
[11:32:31] + News From Folding@Home: Welcome to Folding@Home
[11:32:31] Loaded queue successfully.
[11:32:41] + Closed connections
[11:32:46]
[11:32:46] + Processing work unit
[11:32:46] Core required: FahCore_78.exe
[11:32:46] Core found.
[11:32:46] Working on Unit 08 [January 24 11:32:46]
[11:32:46] + Working ...
[11:32:46]
[11:32:46] *------------------------------*
[11:32:46] Folding@Home Gromacs Core
[11:32:46] Version 1.90 (March 8, 2006)
[11:32:46]
[11:32:46] Preparing to commence simulation
[11:32:46] - Looking at optimizations...
[11:32:46] - Created dyn
[11:32:46] - Files status OK
[11:32:47] - Expanded 661808 -> 3332352 (decompressed 503.5 percent)
[11:32:47] - Starting from initial work packet
[11:32:47]
[11:32:47] Project: 6892 (Run 616, Clone 1, Gen 79)
[11:32:47]
[11:32:47] Assembly optimizations on if available.
[11:32:47] Entering M.D.
[11:32:54] Protein: ALZHEIMER DISEASE AMYLOID
[11:32:54]
[11:32:54] Writing local files
[11:33:33] Extra SSE boost OK.
[11:33:34] Writing local files
[11:33:34] Completed 0 out of 250000 steps  (0%)
[12:27:04] Writing local files
[12:27:04] Completed 2500 out of 250000 steps  (1%)
[13:20:32] Writing local files
[13:20:33] Completed 5000 out of 250000 steps  (2%)
[14:14:03] Writing local files
[14:14:03] Completed 7500 out of 250000 steps  (3%)
[15:07:32] Writing local files
[15:07:33] Completed 10000 out of 250000 steps  (4%)
[16:01:03] Writing local files
[16:01:03] Completed 12500 out of 250000 steps  (5%)
[16:54:35] Writing local files
[16:54:35] Completed 15000 out of 250000 steps  (6%)
[17:48:08] Writing local files
[17:48:08] Completed 17500 out of 250000 steps  (7%)
[18:41:41] Writing local files
[18:41:41] Completed 20000 out of 250000 steps  (8%)
[19:35:12] Writing local files
[19:35:13] Completed 22500 out of 250000 steps  (9%)
[20:28:43] Writing local files
[20:28:44] Completed 25000 out of 250000 steps  (10%)
[21:22:17] Writing local files
[21:22:17] Completed 27500 out of 250000 steps  (11%)
[22:15:50] Writing local files
[22:15:50] Completed 30000 out of 250000 steps  (12%)
[23:09:19] Writing local files
[23:09:19] Completed 32500 out of 250000 steps  (13%)
[00:02:54] Writing local files
[00:02:54] Completed 35000 out of 250000 steps  (14%)
[00:56:20] Writing local files
[00:56:20] Completed 37500 out of 250000 steps  (15%)
[01:49:54] Writing local files
[01:49:54] Completed 40000 out of 250000 steps  (16%)
[02:43:28] Writing local files
[02:43:28] Completed 42500 out of 250000 steps  (17%)
[03:37:05] Writing local files
[03:37:05] Completed 45000 out of 250000 steps  (18%)
[04:30:44] Writing local files
[04:30:44] Completed 47500 out of 250000 steps  (19%)
[05:24:18] Writing local files
[05:24:18] Completed 50000 out of 250000 steps  (20%)
[06:17:50] Writing local files
[06:17:50] Completed 52500 out of 250000 steps  (21%)
[07:11:23] Writing local files
[07:11:23] Completed 55000 out of 250000 steps  (22%)
[08:04:59] Writing local files
[08:05:00] Completed 57500 out of 250000 steps  (23%)
[08:58:29] Writing local files
[08:58:29] Completed 60000 out of 250000 steps  (24%)
[09:51:59] Writing local files
[09:51:59] Completed 62500 out of 250000 steps  (25%)
[10:45:35] Writing local files
[10:45:35] Completed 65000 out of 250000 steps  (26%)
[11:39:02] Writing local files
[11:39:03] Completed 67500 out of 250000 steps  (27%)
[12:32:30] Writing local files
[12:32:30] Completed 70000 out of 250000 steps  (28%)
[13:25:55] Writing local files
[13:25:55] Completed 72500 out of 250000 steps  (29%)
[14:19:27] Writing local files
[14:19:28] Completed 75000 out of 250000 steps  (30%)
[14:56:50] CoreStatus = 0 (0)
[14:56:50] Client-core communications error: ERROR 0x0
[14:56:50] Deleting current work unit & continuing...
[14:58:05] - Preparing to get new work unit...
[14:58:05] + Attempting to get work packet
[14:58:05] - Connecting to assignment server
[14:58:06] - Successful: assigned to (171.67.108.53).
[14:58:06] + News From Folding@Home: Welcome to Folding@Home
[14:58:06] Loaded queue successfully.
[14:58:16] + Closed connections
[14:58:21]
[14:58:21] + Processing work unit
[14:58:21] Core required: FahCore_78.exe
[14:58:21] Core found.
[14:58:21] Working on Unit 09 [January 25 14:58:21]
[14:58:21] + Working ...
[14:58:21]
[14:58:21] *------------------------------*
[14:58:21] Folding@Home Gromacs Core
[14:58:21] Version 1.90 (March 8, 2006)
[14:58:21]
[14:58:21] Preparing to commence simulation
[14:58:21] - Looking at optimizations...
[14:58:21] - Created dyn
[14:58:21] - Files status OK
[14:58:22] - Expanded 661808 -> 3332352 (decompressed 503.5 percent)
[14:58:22] - Starting from initial work packet
[14:58:22]
[14:58:22] Project: 6892 (Run 616, Clone 1, Gen 79)
[14:58:22]
[14:58:22] Assembly optimizations on if available.
[14:58:22] Entering M.D.
[14:58:29] Protein: ALZHEIMER DISEASE AMYLOID
[14:58:29]
[14:58:29] Writing local files
[14:59:07] Extra SSE boost OK.
[14:59:08] Writing local files
[14:59:09] Completed 0 out of 250000 steps  (0%)
[15:52:32] Writing local files
[15:52:32] Completed 2500 out of 250000 steps  (1%)
[16:45:53] Writing local files
[16:45:54] Completed 5000 out of 250000 steps  (2%)
[17:39:15] Writing local files
[17:39:15] Completed 7500 out of 250000 steps  (3%)
[18:32:35] Writing local files
[18:32:36] Completed 10000 out of 250000 steps  (4%)
[19:25:54] Writing local files
[19:25:54] Completed 12500 out of 250000 steps  (5%)
[20:19:15] Writing local files
[20:19:15] Completed 15000 out of 250000 steps  (6%)
[21:12:34] Writing local files
[21:12:34] Completed 17500 out of 250000 steps  (7%)
[22:05:55] Writing local files
[22:05:55] Completed 20000 out of 250000 steps  (8%)
[22:59:13] Writing local files
[22:59:13] Completed 22500 out of 250000 steps  (9%)
[23:52:37] Writing local files
[23:52:37] Completed 25000 out of 250000 steps  (10%)
[00:46:00] Writing local files
[00:46:00] Completed 27500 out of 250000 steps  (11%)
[01:39:22] Writing local files
[01:39:22] Completed 30000 out of 250000 steps  (12%)
[02:32:38] Writing local files
[02:32:39] Completed 32500 out of 250000 steps  (13%)
[03:26:02] Writing local files
[03:26:02] Completed 35000 out of 250000 steps  (14%)
[04:19:30] Writing local files
[04:19:30] Completed 37500 out of 250000 steps  (15%)
[05:12:59] Writing local files
[05:12:59] Completed 40000 out of 250000 steps  (16%)
[06:06:27] Writing local files
[06:06:27] Completed 42500 out of 250000 steps  (17%)
[06:59:56] Writing local files
[06:59:56] Completed 45000 out of 250000 steps  (18%)
[07:53:26] Writing local files
[07:53:27] Completed 47500 out of 250000 steps  (19%)
[08:46:53] Writing local files
[08:46:53] Completed 50000 out of 250000 steps  (20%)
[09:40:21] Writing local files
[09:40:21] Completed 52500 out of 250000 steps  (21%)
[10:33:58] Writing local files
[10:33:58] Completed 55000 out of 250000 steps  (22%)
[11:27:25] Writing local files
[11:27:25] Completed 57500 out of 250000 steps  (23%)
[12:20:52] Writing local files
[12:20:52] Completed 60000 out of 250000 steps  (24%)
[13:14:17] Writing local files
[13:14:17] Completed 62500 out of 250000 steps  (25%)
[14:07:41] Writing local files
[14:07:41] Completed 65000 out of 250000 steps  (26%)
[15:01:01] Writing local files
[15:01:01] Completed 67500 out of 250000 steps  (27%)
[15:54:27] Writing local files
[15:54:27] Completed 70000 out of 250000 steps  (28%)
[16:47:55] Writing local files
[16:47:55] Completed 72500 out of 250000 steps  (29%)
[17:41:26] Writing local files
[17:41:26] Completed 75000 out of 250000 steps  (30%)
[18:18:51] CoreStatus = 0 (0)
[18:18:51] Client-core communications error: ERROR 0x0
[18:18:51] Too many errors during run. Purging queue.
[18:20:05]
[18:20:05] + Processing work unit
[18:20:05] Core required: FahCore_78.exe
[18:20:05] Core found.
[18:20:05] Working on Unit 09 [January 26 18:20:05]
[18:20:05] + Working ...
[18:20:05]
[18:20:05] *------------------------------*
[18:20:05] Folding@Home Gromacs Core
[18:20:05] Version 1.90 (March 8, 2006)
[18:20:05]
[18:20:05] Preparing to commence simulation
[18:20:05] - Looking at optimizations...
[18:20:05] - Created dyn
[18:20:05] - Files status OK
[18:20:05]
[18:20:05] Folding@home Core Shutdown: MISSING_WORK_FILES
[18:20:06] CoreStatus = 74 (116)
[18:20:06] The core could not find the work files specified. Removing from queue
[18:20:06] Deleting current work unit & continuing...
[18:20:06] - Preparing to get new work unit...
[18:20:06] + Attempting to get work packet
[18:20:06] - Connecting to assignment server
[18:20:07] - Successful: assigned to (171.67.108.53).
[18:20:07] + News From Folding@Home: Welcome to Folding@Home
[18:20:07] Loaded queue successfully.
[18:20:13] + Closed connections
[18:20:18]
[18:20:18] + Processing work unit
[18:20:18] Core required: FahCore_78.exe
[18:20:18] Core found.
[18:20:18] Working on Unit 00 [January 26 18:20:18]
[18:20:18] + Working ...
[18:20:18]
[18:20:18] *------------------------------*
[18:20:18] Folding@Home Gromacs Core
[18:20:18] Version 1.90 (March 8, 2006)
[18:20:18]
[18:20:18] Preparing to commence simulation
[18:20:18] - Looking at optimizations...
[18:20:18] - Created dyn
[18:20:18] - Files status OK
[18:20:19] - Expanded 661808 -> 3332352 (decompressed 503.5 percent)
[18:20:19] - Starting from initial work packet
[18:20:19]
[18:20:19] Project: 6892 (Run 616, Clone 1, Gen 79)
[18:20:19]
[18:20:19] Assembly optimizations on if available.
[18:20:19] Entering M.D.
[18:20:26] Protein: ALZHEIMER DISEASE AMYLOID
[18:20:26]
[18:20:26] Writing local files
[18:21:05] Extra SSE boost OK.
[18:21:06] Writing local files
[18:21:06] Completed 0 out of 250000 steps  (0%)
[19:18:12] Writing local files
[19:18:12] Completed 2500 out of 250000 steps  (1%)
[20:15:16] Writing local files
[20:15:16] Completed 5000 out of 250000 steps  (2%)
[21:12:20] Writing local files
[21:12:20] Completed 7500 out of 250000 steps  (3%)
[22:09:24] Writing local files
[22:09:24] Completed 10000 out of 250000 steps  (4%)
[23:06:25] Writing local files
[23:06:25] Completed 12500 out of 250000 steps  (5%)
[00:03:32] Writing local files
[00:03:32] Completed 15000 out of 250000 steps  (6%)
[01:00:29] Writing local files
[01:00:29] Completed 17500 out of 250000 steps  (7%)
[01:57:25] Writing local files
[01:57:25] Completed 20000 out of 250000 steps  (8%)
[02:54:18] Writing local files
[02:54:18] Completed 22500 out of 250000 steps  (9%)
[03:51:14] Writing local files
[03:51:15] Completed 25000 out of 250000 steps  (10%)
[04:48:13] Writing local files
[04:48:14] Completed 27500 out of 250000 steps  (11%)
[05:45:12] Writing local files
[05:45:12] Completed 30000 out of 250000 steps  (12%)
[06:42:02] Writing local files
[06:42:02] Completed 32500 out of 250000 steps  (13%)
[07:39:02] Writing local files
[07:39:02] Completed 35000 out of 250000 steps  (14%)
[08:35:56] Writing local files
[08:35:56] Completed 37500 out of 250000 steps  (15%)
[09:32:53] Writing local files
[09:32:53] Completed 40000 out of 250000 steps  (16%)
[10:29:59] Writing local files
[10:29:59] Completed 42500 out of 250000 steps  (17%)
[11:26:56] Writing local files
[11:26:56] Completed 45000 out of 250000 steps  (18%)
[12:23:56] Writing local files
[12:23:56] Completed 47500 out of 250000 steps  (19%)
[13:20:51] Writing local files
[13:20:51] Completed 50000 out of 250000 steps  (20%)
[14:17:50] Writing local files
[14:17:51] Completed 52500 out of 250000 steps  (21%)
[15:14:45] Writing local files
[15:14:45] Completed 55000 out of 250000 steps  (22%)
[16:11:40] Writing local files
[16:11:40] Completed 57500 out of 250000 steps  (23%)
[17:08:36] Writing local files
[17:08:36] Completed 60000 out of 250000 steps  (24%)
[18:05:35] Writing local files
[18:05:35] Completed 62500 out of 250000 steps  (25%)
[19:02:30] Writing local files
[19:02:30] Completed 65000 out of 250000 steps  (26%)
[19:59:26] Writing local files
[19:59:26] Completed 67500 out of 250000 steps  (27%)
[20:56:23] Writing local files
[20:56:24] Completed 70000 out of 250000 steps  (28%)
[21:53:17] Writing local files
[21:53:17] Completed 72500 out of 250000 steps  (29%)
[22:50:17] Writing local files
[22:50:17] Completed 75000 out of 250000 steps  (30%)
[23:30:07] CoreStatus = 0 (0)
[23:30:07] Client-core communications error: ERROR 0x0
[23:30:07] - Attempting to download new core...
djohnston
Post by djohnston »
Last part of the log. (Part 3)
[23:30:07] + Downloading new core: FahCore_78.exe
[23:30:07] + 10240 bytes downloaded
[23:30:07] + 20480 bytes downloaded
[23:30:07] + 30720 bytes downloaded
[23:30:07] + 40960 bytes downloaded
[23:30:07] + 51200 bytes downloaded
[23:30:07] + 61440 bytes downloaded
[23:30:07] + 71680 bytes downloaded
[23:30:07] + 81920 bytes downloaded
[23:30:07] + 92160 bytes downloaded
[23:30:07] + 102400 bytes downloaded
[23:30:07] + 112640 bytes downloaded
[23:30:08] + 122880 bytes downloaded
[23:30:08] + 133120 bytes downloaded
[23:30:08] + 143360 bytes downloaded
[23:30:08] + 153600 bytes downloaded
[23:30:08] + 163840 bytes downloaded
[23:30:08] + 174080 bytes downloaded
[23:30:08] + 184320 bytes downloaded
[23:30:08] + 194560 bytes downloaded
[23:30:08] + 204800 bytes downloaded
[23:30:08] + 215040 bytes downloaded
[23:30:08] + 225280 bytes downloaded
[23:30:08] + 235520 bytes downloaded
[23:30:08] + 245760 bytes downloaded
[23:30:08] + 256000 bytes downloaded
[23:30:08] + 266240 bytes downloaded
[23:30:08] + 276480 bytes downloaded
[23:30:08] + 286720 bytes downloaded
[23:30:08] + 296960 bytes downloaded
[23:30:08] + 307200 bytes downloaded
[23:30:08] + 317440 bytes downloaded
[23:30:08] + 327680 bytes downloaded
[23:30:08] + 337920 bytes downloaded
[23:30:08] + 348160 bytes downloaded
[23:30:08] + 358400 bytes downloaded
[23:30:08] + 368640 bytes downloaded
[23:30:08] + 378880 bytes downloaded
[23:30:08] + 389120 bytes downloaded
[23:30:08] + 399360 bytes downloaded
[23:30:08] + 409600 bytes downloaded
[23:30:08] + 419840 bytes downloaded
[23:30:08] + 430080 bytes downloaded
[23:30:08] + 440320 bytes downloaded
[23:30:08] + 450560 bytes downloaded
[23:30:08] + 460800 bytes downloaded
[23:30:08] + 471040 bytes downloaded
[23:30:08] + 481280 bytes downloaded
[23:30:08] + 491520 bytes downloaded
[23:30:09] + 501760 bytes downloaded
[23:30:09] + 512000 bytes downloaded
[23:30:09] + 522240 bytes downloaded
[23:30:09] + 532480 bytes downloaded
[23:30:09] + 542720 bytes downloaded
[23:30:09] + 552960 bytes downloaded
[23:30:09] + 563200 bytes downloaded
[23:30:09] + 573440 bytes downloaded
[23:30:09] + 583680 bytes downloaded
[23:30:09] + 593920 bytes downloaded
[23:30:09] + 604160 bytes downloaded
[23:30:09] + 614400 bytes downloaded
[23:30:09] + 624640 bytes downloaded
[23:30:09] + 634880 bytes downloaded
[23:30:09] + 645120 bytes downloaded
[23:30:09] + 655360 bytes downloaded
[23:30:09] + 665600 bytes downloaded
[23:30:09] + 675840 bytes downloaded
[23:30:09] + 686080 bytes downloaded
[23:30:09] + 696320 bytes downloaded
[23:30:09] + 706560 bytes downloaded
[23:30:09] + 716800 bytes downloaded
[23:30:09] + 727040 bytes downloaded
[23:30:09] + 737280 bytes downloaded
[23:30:09] + 747520 bytes downloaded
[23:30:09] + 757760 bytes downloaded
[23:30:09] + 768000 bytes downloaded
[23:30:09] + 778240 bytes downloaded
[23:30:09] + 788480 bytes downloaded
[23:30:09] + 798720 bytes downloaded
[23:30:09] + 808960 bytes downloaded
[23:30:09] + 819200 bytes downloaded
[23:30:09] + 829440 bytes downloaded
[23:30:09] + 839680 bytes downloaded
[23:30:09] + 849920 bytes downloaded
[23:30:10] + 860160 bytes downloaded
[23:30:10] + 870400 bytes downloaded
[23:30:10] + 880640 bytes downloaded
[23:30:10] + 890880 bytes downloaded
[23:30:10] + 901120 bytes downloaded
[23:30:10] + 911360 bytes downloaded
[23:30:10] + 921600 bytes downloaded
[23:30:10] + 931840 bytes downloaded
[23:30:10] + 942080 bytes downloaded
[23:30:10] + 952320 bytes downloaded
[23:30:10] + 962560 bytes downloaded
[23:30:10] + 972800 bytes downloaded
[23:30:10] + 983040 bytes downloaded
[23:30:10] + 993280 bytes downloaded
[23:30:10] + 1003520 bytes downloaded
[23:30:10] + 1013760 bytes downloaded
[23:30:10] + 1024000 bytes downloaded
[23:30:10] + 1034240 bytes downloaded
[23:30:10] + 1044480 bytes downloaded
[23:30:10] + 1054720 bytes downloaded
[23:30:10] + 1064960 bytes downloaded
[23:30:10] + 1075200 bytes downloaded
[23:30:10] + 1085440 bytes downloaded
[23:30:10] + 1095680 bytes downloaded
[23:30:10] + 1105920 bytes downloaded
[23:30:10] + 1116160 bytes downloaded
[23:30:10] + 1126400 bytes downloaded
[23:30:10] + 1134407 bytes downloaded
[23:30:10] Verifying core Core_78.fah...
[23:30:10] Signature is VALID
[23:30:10]
[23:30:10] Trying to unzip core FahCore_78.exe
[23:30:12] Decompressed FahCore_78.exe (3435296 bytes) successfully
[23:30:12] + Core successfully engaged
[23:30:23] Deleting current work unit & continuing...
[23:31:38] - Preparing to get new work unit...
[23:31:38] + Attempting to get work packet
[23:31:38] - Connecting to assignment server
[23:31:38] - Successful: assigned to (171.67.108.53).
[23:31:38] + News From Folding@Home: Welcome to Folding@Home
[23:31:38] Loaded queue successfully.
[23:31:44] + Closed connections
[23:31:49]
[23:31:49] + Processing work unit
[23:31:49] Core required: FahCore_78.exe
[23:31:49] Core found.
[23:31:49] Working on Unit 01 [January 27 23:31:49]
[23:31:49] + Working ...
[23:31:49]
[23:31:49] *------------------------------*
[23:31:49] Folding@Home Gromacs Core
[23:31:49] Version 1.90 (March 8, 2006)
[23:31:49]
[23:31:49] Preparing to commence simulation
[23:31:49] - Looking at optimizations...
[23:31:49] - Created dyn
[23:31:49] - Files status OK
[23:31:50] - Expanded 661808 -> 3332352 (decompressed 503.5 percent)
[23:31:50] - Starting from initial work packet
[23:31:50]
[23:31:50] Project: 6892 (Run 616, Clone 1, Gen 79)
[23:31:50]
[23:31:50] Assembly optimizations on if available.
[23:31:50] Entering M.D.
[23:31:57] Protein: ALZHEIMER DISEASE AMYLOID
[23:31:57]
[23:31:57] Writing local files
[23:32:35] Extra SSE boost OK.
[23:32:37] Writing local files
[23:32:37] Completed 0 out of 250000 steps  (0%)
[00:27:19] Writing local files
[00:27:20] Completed 2500 out of 250000 steps  (1%)
[01:21:58] Writing local files
[01:21:58] Completed 5000 out of 250000 steps  (2%)
[02:16:37] Writing local files
[02:16:37] Completed 7500 out of 250000 steps  (3%)
[03:11:14] Writing local files
[03:11:15] Completed 10000 out of 250000 steps  (4%)
[04:05:52] Writing local files
[04:05:52] Completed 12500 out of 250000 steps  (5%)
[05:00:29] Writing local files
[05:00:29] Completed 15000 out of 250000 steps  (6%)
[05:55:04] Writing local files
[05:55:04] Completed 17500 out of 250000 steps  (7%)
[06:49:43] Writing local files
[06:49:43] Completed 20000 out of 250000 steps  (8%)
[07:44:17] Writing local files
[07:44:17] Completed 22500 out of 250000 steps  (9%)
[08:38:56] Writing local files
[08:38:56] Completed 25000 out of 250000 steps  (10%)
[09:33:37] Writing local files
[09:33:37] Completed 27500 out of 250000 steps  (11%)
[10:28:30] Writing local files
[10:28:30] Completed 30000 out of 250000 steps  (12%)
[11:23:03] Writing local files
[11:23:03] Completed 32500 out of 250000 steps  (13%)
[12:17:45] Writing local files
[12:17:45] Completed 35000 out of 250000 steps  (14%)
[13:12:22] Writing local files
[13:12:23] Completed 37500 out of 250000 steps  (15%)
[14:07:07] Writing local files
[14:07:07] Completed 40000 out of 250000 steps  (16%)
[15:01:45] Writing local files
[15:01:45] Completed 42500 out of 250000 steps  (17%)
[15:56:22] Writing local files
[15:56:22] Completed 45000 out of 250000 steps  (18%)
[16:51:02] Writing local files
[16:51:02] Completed 47500 out of 250000 steps  (19%)
[17:45:38] Writing local files
[17:45:39] Completed 50000 out of 250000 steps  (20%)
[18:40:17] Writing local files
[18:40:17] Completed 52500 out of 250000 steps  (21%)
[19:34:52] Writing local files
[19:34:52] Completed 55000 out of 250000 steps  (22%)
[20:29:29] Writing local files
[20:29:29] Completed 57500 out of 250000 steps  (23%)
[21:24:06] Writing local files
[21:24:06] Completed 60000 out of 250000 steps  (24%)
[22:18:47] Writing local files
[22:18:47] Completed 62500 out of 250000 steps  (25%)
[23:13:22] Writing local files
[23:13:22] Completed 65000 out of 250000 steps  (26%)
[00:08:04] Writing local files
[00:08:04] Completed 67500 out of 250000 steps  (27%)
[01:02:44] Writing local files
[01:02:44] Completed 70000 out of 250000 steps  (28%)
[01:57:21] Writing local files
[01:57:22] Completed 72500 out of 250000 steps  (29%)
[02:52:06] Writing local files
[02:52:07] Completed 75000 out of 250000 steps  (30%)
[03:30:22] CoreStatus = 0 (0)
[03:30:22] Client-core communications error: ERROR 0x0
[03:30:22] Deleting current work unit & continuing...
[03:31:37] - Preparing to get new work unit...
[03:31:37] + Attempting to get work packet
[03:31:37] - Connecting to assignment server
[03:31:47] - Successful: assigned to (171.67.108.53).
[03:31:47] + News From Folding@Home: Welcome to Folding@Home
[03:31:47] Loaded queue successfully.
[03:31:54] + Closed connections
[03:31:59]
[03:31:59] + Processing work unit
[03:31:59] Core required: FahCore_78.exe
[03:31:59] Core found.
[03:31:59] Working on Unit 02 [January 29 03:31:59]
[03:31:59] + Working ...
[03:31:59]
[03:31:59] *------------------------------*
[03:31:59] Folding@Home Gromacs Core
[03:31:59] Version 1.90 (March 8, 2006)
[03:31:59]
[03:31:59] Preparing to commence simulation
[03:31:59] - Looking at optimizations...
[03:31:59] - Created dyn
[03:31:59] - Files status OK
[03:32:00] - Expanded 661808 -> 3332352 (decompressed 503.5 percent)
[03:32:00] - Starting from initial work packet
[03:32:00]
[03:32:00] Project: 6892 (Run 616, Clone 1, Gen 79)
[03:32:00]
[03:32:00] Assembly optimizations on if available.
[03:32:00] Entering M.D.
[03:32:07] Protein: ALZHEIMER DISEASE AMYLOID
[03:32:07]
[03:32:07] Writing local files
[03:32:46] Extra SSE boost OK.
[03:32:47] Writing local files
[03:32:47] Completed 0 out of 250000 steps  (0%)
[04:27:41] Writing local files
[04:27:41] Completed 2500 out of 250000 steps  (1%)
[05:22:33] Writing local files
[05:22:33] Completed 5000 out of 250000 steps  (2%)
[06:17:23] Writing local files
[06:17:23] Completed 7500 out of 250000 steps  (3%)
[07:12:12] Writing local files
[07:12:12] Completed 10000 out of 250000 steps  (4%)
[08:07:04] Writing local files
[08:07:04] Completed 12500 out of 250000 steps  (5%)
[09:01:56] Writing local files
[09:01:57] Completed 15000 out of 250000 steps  (6%)
[09:56:44] Writing local files
[09:56:44] Completed 17500 out of 250000 steps  (7%)
[10:53:36] Writing local files
[10:53:36] Completed 20000 out of 250000 steps  (8%)
[11:48:21] Writing local files
[11:48:21] Completed 22500 out of 250000 steps  (9%)
[12:43:15] Writing local files
[12:43:15] Completed 25000 out of 250000 steps  (10%)
[13:38:08] Writing local files
[13:38:08] Completed 27500 out of 250000 steps  (11%)
[14:33:01] Writing local files
[14:33:02] Completed 30000 out of 250000 steps  (12%)
[15:27:46] Writing local files
[15:27:47] Completed 32500 out of 250000 steps  (13%)
[16:22:40] Writing local files
[16:22:40] Completed 35000 out of 250000 steps  (14%)
[17:17:29] Writing local files
[17:17:29] Completed 37500 out of 250000 steps  (15%)
[18:12:20] Writing local files
[18:12:20] Completed 40000 out of 250000 steps  (16%)
[19:07:10] Writing local files
[19:07:10] Completed 42500 out of 250000 steps  (17%)
[20:02:02] Writing local files
[20:02:02] Completed 45000 out of 250000 steps  (18%)
[20:56:57] Writing local files
[20:56:57] Completed 47500 out of 250000 steps  (19%)
[21:51:45] Writing local files
[21:51:45] Completed 50000 out of 250000 steps  (20%)
[22:46:35] Writing local files
[22:46:36] Completed 52500 out of 250000 steps  (21%)
[23:41:23] Writing local files
[23:41:23] Completed 55000 out of 250000 steps  (22%)
[00:36:16] Writing local files
[00:36:16] Completed 57500 out of 250000 steps  (23%)
[01:31:04] Writing local files
[01:31:04] Completed 60000 out of 250000 steps  (24%)
[02:25:56] Writing local files
[02:25:56] Completed 62500 out of 250000 steps  (25%)
[03:20:46] Writing local files
[03:20:46] Completed 65000 out of 250000 steps  (26%)
[04:15:36] Writing local files
[04:15:37] Completed 67500 out of 250000 steps  (27%)
[05:10:27] Writing local files
[05:10:27] Completed 70000 out of 250000 steps  (28%)
[06:05:16] Writing local files
[06:05:16] Completed 72500 out of 250000 steps  (29%)
[07:00:09] Writing local files
[07:00:09] Completed 75000 out of 250000 steps  (30%)
[07:38:31] CoreStatus = 0 (0)
[07:38:31] Client-core communications error: ERROR 0x0
[07:38:31] Deleting current work unit & continuing...
[07:39:46] - Preparing to get new work unit...
[07:39:46] + Attempting to get work packet
[07:39:46] - Connecting to assignment server
[07:39:51] - Successful: assigned to (171.67.108.53).
[07:39:51] + News From Folding@Home: Welcome to Folding@Home
[07:39:51] Loaded queue successfully.
[07:39:56] + Closed connections
[07:40:01]
[07:40:01] + Processing work unit
[07:40:01] Core required: FahCore_78.exe
[07:40:01] Core found.
[07:40:01] Working on Unit 03 [January 30 07:40:01]
[07:40:01] + Working ...
[07:40:01]
[07:40:01] *------------------------------*
[07:40:01] Folding@Home Gromacs Core
[07:40:01] Version 1.90 (March 8, 2006)
[07:40:01]
[07:40:01] Preparing to commence simulation
[07:40:01] - Looking at optimizations...
[07:40:01] - Created dyn
[07:40:01] - Files status OK
[07:40:02] - Expanded 661808 -> 3332352 (decompressed 503.5 percent)
[07:40:02] - Starting from initial work packet
[07:40:02]
[07:40:02] Project: 6892 (Run 616, Clone 1, Gen 79)
[07:40:02]
[07:40:02] Assembly optimizations on if available.
[07:40:02] Entering M.D.
[07:40:09] Protein: ALZHEIMER DISEASE AMYLOID
[07:40:09]
[07:40:09] Writing local files
[07:40:47] Extra SSE boost OK.
[07:40:48] Writing local files
[07:40:49] Completed 0 out of 250000 steps  (0%)
[08:37:45] Writing local files
[08:37:46] Completed 2500 out of 250000 steps  (1%)
[09:34:41] Writing local files
[09:34:41] Completed 5000 out of 250000 steps  (2%)
[10:31:48] Writing local files
[10:31:48] Completed 7500 out of 250000 steps  (3%)
[11:28:44] Writing local files
[11:28:44] Completed 10000 out of 250000 steps  (4%)
[12:25:38] Writing local files
[12:25:38] Completed 12500 out of 250000 steps  (5%)
[13:22:34] Writing local files
[13:22:34] Completed 15000 out of 250000 steps  (6%)
[14:19:30] Writing local files
[14:19:30] Completed 17500 out of 250000 steps  (7%)
[15:16:24] Writing local files
[15:16:24] Completed 20000 out of 250000 steps  (8%)
[16:13:15] Writing local files
[16:13:15] Completed 22500 out of 250000 steps  (9%)
[17:10:10] Writing local files
[17:10:10] Completed 25000 out of 250000 steps  (10%)
[18:07:07] Writing local files
[18:07:07] Completed 27500 out of 250000 steps  (11%)
[19:04:04] Writing local files
[19:04:04] Completed 30000 out of 250000 steps  (12%)
[20:00:54] Writing local files
[20:00:54] Completed 32500 out of 250000 steps  (13%)
[20:57:54] Writing local files
[20:57:54] Completed 35000 out of 250000 steps  (14%)
[21:54:47] Writing local files
[21:54:47] Completed 37500 out of 250000 steps  (15%)
[22:51:43] Writing local files
[22:51:43] Completed 40000 out of 250000 steps  (16%)
[23:48:38] Writing local files
[23:48:38] Completed 42500 out of 250000 steps  (17%)
[00:45:37] Writing local files
[00:45:37] Completed 45000 out of 250000 steps  (18%)
[01:42:36] Writing local files
[01:42:36] Completed 47500 out of 250000 steps  (19%)
[02:39:29] Writing local files
[02:39:30] Completed 50000 out of 250000 steps  (20%)
[03:36:24] Writing local files
[03:36:25] Completed 52500 out of 250000 steps  (21%)
[04:33:17] Writing local files
[04:33:18] Completed 55000 out of 250000 steps  (22%)
[05:30:13] Writing local files
[05:30:13] Completed 57500 out of 250000 steps  (23%)
[06:27:09] Writing local files
[06:27:09] Completed 60000 out of 250000 steps  (24%)
[07:24:08] Writing local files
[07:24:09] Completed 62500 out of 250000 steps  (25%)
[08:21:01] Writing local files
[08:21:01] Completed 65000 out of 250000 steps  (26%)
[09:17:56] Writing local files
[09:17:56] Completed 67500 out of 250000 steps  (27%)
[10:15:03] Writing local files
[10:15:03] Completed 70000 out of 250000 steps  (28%)
[11:11:56] Writing local files
[11:11:56] Completed 72500 out of 250000 steps  (29%)
[12:08:55] Writing local files
[12:08:55] Completed 75000 out of 250000 steps  (30%)
[12:48:43] CoreStatus = 0 (0)
[12:48:43] Client-core communications error: ERROR 0x0
[12:48:43] - Attempting to download new core...
[12:48:43] + Downloading new core: FahCore_78.exe
[12:48:48] + 10240 bytes downloaded
[12:48:48] + 20480 bytes downloaded
[12:48:48] + 30720 bytes downloaded
[12:48:48] + 40960 bytes downloaded
[12:48:48] + 51200 bytes downloaded
[12:48:48] + 61440 bytes downloaded
[12:48:48] + 71680 bytes downloaded
[12:48:48] + 81920 bytes downloaded
[12:48:49] + 92160 bytes downloaded
[12:48:49] + 102400 bytes downloaded
[12:48:49] + 112640 bytes downloaded
[12:48:49] + 122880 bytes downloaded
[12:48:49] + 133120 bytes downloaded
[12:48:49] + 143360 bytes downloaded
[12:48:49] + 153600 bytes downloaded
[12:48:49] + 163840 bytes downloaded
[12:48:49] + 174080 bytes downloaded
[12:48:49] + 184320 bytes downloaded
[12:48:49] + 194560 bytes downloaded
[12:48:49] + 204800 bytes downloaded
[12:48:49] + 215040 bytes downloaded
[12:48:49] + 225280 bytes downloaded
[12:48:49] + 235520 bytes downloaded
[12:48:49] + 245760 bytes downloaded
[12:48:49] + 256000 bytes downloaded
[12:48:49] + 266240 bytes downloaded
[12:48:49] + 276480 bytes downloaded
[12:48:49] + 286720 bytes downloaded
[12:48:49] + 296960 bytes downloaded
[12:48:49] + 307200 bytes downloaded
[12:48:49] + 317440 bytes downloaded
[12:48:49] + 327680 bytes downloaded
[12:48:49] + 337920 bytes downloaded
[12:48:49] + 348160 bytes downloaded
[12:48:49] + 358400 bytes downloaded
[12:48:49] + 368640 bytes downloaded
[12:48:49] + 378880 bytes downloaded
[12:48:49] + 389120 bytes downloaded
[12:48:49] + 399360 bytes downloaded
[12:48:49] + 409600 bytes downloaded
[12:48:49] + 419840 bytes downloaded
[12:48:49] + 430080 bytes downloaded
[12:48:49] + 440320 bytes downloaded
[12:48:50] + 450560 bytes downloaded
[12:48:50] + 460800 bytes downloaded
[12:48:50] + 471040 bytes downloaded
[12:48:50] + 481280 bytes downloaded
[12:48:50] + 491520 bytes downloaded
[12:48:50] + 501760 bytes downloaded
[12:48:50] + 512000 bytes downloaded
[12:48:50] + 522240 bytes downloaded
[12:48:50] + 532480 bytes downloaded
[12:48:50] + 542720 bytes downloaded
[12:48:50] + 552960 bytes downloaded
[12:48:50] + 563200 bytes downloaded
[12:48:50] + 573440 bytes downloaded
[12:48:50] + 583680 bytes downloaded
[12:48:50] + 593920 bytes downloaded
[12:48:50] + 604160 bytes downloaded
[12:48:50] + 614400 bytes downloaded
[12:48:50] + 624640 bytes downloaded
[12:48:50] + 634880 bytes downloaded
[12:48:50] + 645120 bytes downloaded
[12:48:50] + 655360 bytes downloaded
[12:48:50] + 665600 bytes downloaded
[12:48:50] + 675840 bytes downloaded
[12:48:50] + 686080 bytes downloaded
[12:48:50] + 696320 bytes downloaded
[12:48:50] + 706560 bytes downloaded
[12:48:50] + 716800 bytes downloaded
[12:48:50] + 727040 bytes downloaded
[12:48:50] + 737280 bytes downloaded
[12:48:50] + 747520 bytes downloaded
[12:48:50] + 757760 bytes downloaded
[12:48:50] + 768000 bytes downloaded
[12:48:50] + 778240 bytes downloaded
[12:48:50] + 788480 bytes downloaded
[12:48:50] + 798720 bytes downloaded
[12:48:50] + 808960 bytes downloaded
[12:48:50] + 819200 bytes downloaded
[12:48:51] + 829440 bytes downloaded
[12:48:51] + 839680 bytes downloaded
[12:48:51] + 849920 bytes downloaded
[12:48:51] + 860160 bytes downloaded
[12:48:51] + 870400 bytes downloaded
[12:48:51] + 880640 bytes downloaded
[12:48:51] + 890880 bytes downloaded
[12:48:51] + 901120 bytes downloaded
[12:48:51] + 911360 bytes downloaded
[12:48:51] + 921600 bytes downloaded
[12:48:51] + 931840 bytes downloaded
[12:48:51] + 942080 bytes downloaded
[12:48:51] + 952320 bytes downloaded
[12:48:51] + 962560 bytes downloaded
[12:48:51] + 972800 bytes downloaded
[12:48:51] + 983040 bytes downloaded
[12:48:51] + 993280 bytes downloaded
[12:48:51] + 1003520 bytes downloaded
[12:48:51] + 1013760 bytes downloaded
[12:48:51] + 1024000 bytes downloaded
[12:48:51] + 1034240 bytes downloaded
[12:48:51] + 1044480 bytes downloaded
[12:48:51] + 1054720 bytes downloaded
[12:48:51] + 1064960 bytes downloaded
[12:48:51] + 1075200 bytes downloaded
[12:48:51] + 1085440 bytes downloaded
[12:48:51] + 1095680 bytes downloaded
[12:48:51] + 1105920 bytes downloaded
[12:48:51] + 1116160 bytes downloaded
[12:48:51] + 1126400 bytes downloaded
[12:48:51] + 1134407 bytes downloaded
[12:48:51] Verifying core Core_78.fah...
[12:48:52] Signature is VALID
[12:48:52]
[12:48:52] Trying to unzip core FahCore_78.exe
[12:48:53] Decompressed FahCore_78.exe (3435296 bytes) successfully
[12:48:53] + Core successfully engaged
[12:49:04] Deleting current work unit & continuing...
[12:50:18] - Preparing to get new work unit...
[12:50:18] + Attempting to get work packet
[12:50:18] - Connecting to assignment server
[12:50:24] - Successful: assigned to (171.67.108.53).
[12:50:24] + News From Folding@Home: Welcome to Folding@Home
[12:50:24] Loaded queue successfully.
[12:50:31] + Closed connections
[12:50:36]
[12:50:36] + Processing work unit
[12:50:36] Core required: FahCore_78.exe
[12:50:36] Core found.
[12:50:36] Working on Unit 04 [January 31 12:50:36]
[12:50:36] + Working ...
[12:50:36]
[12:50:36] *------------------------------*
[12:50:36] Folding@Home Gromacs Core
[12:50:36] Version 1.90 (March 8, 2006)
[12:50:36]
[12:50:36] Preparing to commence simulation
[12:50:36] - Looking at optimizations...
[12:50:36] - Created dyn
[12:50:36] - Files status OK
[12:50:37] - Expanded 661808 -> 3332352 (decompressed 503.5 percent)
[12:50:37] - Starting from initial work packet
[12:50:37]
[12:50:37] Project: 6892 (Run 616, Clone 1, Gen 79)
[12:50:37]
[12:50:37] Assembly optimizations on if available.
[12:50:37] Entering M.D.
[12:50:44] Protein: ALZHEIMER DISEASE AMYLOID
[12:50:44]
[12:50:44] Writing local files
[12:51:22] Extra SSE boost OK.
[12:51:24] Writing local files
[12:51:24] Completed 0 out of 250000 steps  (0%)
[13:46:07] Writing local files
[13:46:07] Completed 2500 out of 250000 steps  (1%)
[14:40:47] Writing local files
[14:40:47] Completed 5000 out of 250000 steps  (2%)
[15:35:26] Writing local files
[15:35:27] Completed 7500 out of 250000 steps  (3%)
[16:30:05] Writing local files
[16:30:05] Completed 10000 out of 250000 steps  (4%)
[17:24:41] Writing local files
[17:24:42] Completed 12500 out of 250000 steps  (5%)
[18:19:19] Writing local files
[18:19:20] Completed 15000 out of 250000 steps  (6%)
[19:13:55] Writing local files
[19:13:55] Completed 17500 out of 250000 steps  (7%)
[20:08:35] Writing local files
[20:08:35] Completed 20000 out of 250000 steps  (8%)
[21:03:10] Writing local files
[21:03:10] Completed 22500 out of 250000 steps  (9%)
[21:57:49] Writing local files
[21:57:49] Completed 25000 out of 250000 steps  (10%)
[22:56:27] Writing local files
[22:56:27] Completed 27500 out of 250000 steps  (11%)
[23:51:12] Writing local files
[23:51:12] Completed 30000 out of 250000 steps  (12%)
[00:45:48] Writing local files
[00:45:48] Completed 32500 out of 250000 steps  (13%)
[01:40:31] Writing local files
[01:40:31] Completed 35000 out of 250000 steps  (14%)
[02:35:09] Writing local files
[02:35:09] Completed 37500 out of 250000 steps  (15%)
[03:29:50] Writing local files
[03:29:50] Completed 40000 out of 250000 steps  (16%)
[04:24:29] Writing local files
[04:24:29] Completed 42500 out of 250000 steps  (17%)
[05:19:11] Writing local files
[05:19:11] Completed 45000 out of 250000 steps  (18%)
[06:13:52] Writing local files
[06:13:52] Completed 47500 out of 250000 steps  (19%)
[07:08:27] Writing local files
[07:08:27] Completed 50000 out of 250000 steps  (20%)
[08:03:04] Writing local files
[08:03:04] Completed 52500 out of 250000 steps  (21%)
[08:57:37] Writing local files
[08:57:37] Completed 55000 out of 250000 steps  (22%)
[09:52:15] Writing local files
[09:52:15] Completed 57500 out of 250000 steps  (23%)
[10:47:03] Writing local files
[10:47:04] Completed 60000 out of 250000 steps  (24%)
[11:41:44] Writing local files
[11:41:45] Completed 62500 out of 250000 steps  (25%)
[12:36:22] Writing local files
[12:36:22] Completed 65000 out of 250000 steps  (26%)
[13:31:01] Writing local files
[13:31:01] Completed 67500 out of 250000 steps  (27%)
[14:25:43] Writing local files
[14:25:44] Completed 70000 out of 250000 steps  (28%)
[15:20:20] Writing local files
[15:20:20] Completed 72500 out of 250000 steps  (29%)
[16:15:03] Writing local files
[16:15:03] Completed 75000 out of 250000 steps  (30%)
[16:53:17] CoreStatus = 0 (0)
[16:53:17] Client-core communications error: ERROR 0x0
[16:53:17] Deleting current work unit & continuing...
[16:54:32] - Preparing to get new work unit...
[16:54:32] + Attempting to get work packet
[16:54:32] - Connecting to assignment server
[16:54:32] - Successful: assigned to (171.67.108.53).
[16:54:32] + News From Folding@Home: Welcome to Folding@Home
[16:54:32] Loaded queue successfully.
[16:54:42] + Closed connections
[16:54:47]
[16:54:47] + Processing work unit
[16:54:47] Core required: FahCore_78.exe
[16:54:47] Core found.
[16:54:47] Working on Unit 05 [February 1 16:54:47]
[16:54:47] + Working ...
[16:54:47]
[16:54:47] *------------------------------*
[16:54:47] Folding@Home Gromacs Core
[16:54:47] Version 1.90 (March 8, 2006)
[16:54:47]
[16:54:47] Preparing to commence simulation
[16:54:47] - Looking at optimizations...
[16:54:47] - Created dyn
[16:54:47] - Files status OK
[16:54:48] - Expanded 661808 -> 3332352 (decompressed 503.5 percent)
[16:54:48] - Starting from initial work packet
[16:54:48]
[16:54:48] Project: 6892 (Run 616, Clone 1, Gen 79)
[16:54:48]
[16:54:48] Assembly optimizations on if available.
[16:54:48] Entering M.D.
[16:54:55] Protein: ALZHEIMER DISEASE AMYLOID
[16:54:55]
[16:54:55] Writing local files
[16:55:33] Extra SSE boost OK.
[16:55:34] Writing local files
[16:55:35] Completed 0 out of 250000 steps  (0%)
[17:49:28] Writing local files
[17:49:28] Completed 2500 out of 250000 steps  (1%)
[18:43:19] Writing local files
[18:43:19] Completed 5000 out of 250000 steps  (2%)
[19:37:12] Writing local files
[19:37:12] Completed 7500 out of 250000 steps  (3%)
[20:31:02] Writing local files
[20:31:02] Completed 10000 out of 250000 steps  (4%)
[21:24:50] Writing local files
[21:24:50] Completed 12500 out of 250000 steps  (5%)
[22:18:39] Writing local files
[22:18:39] Completed 15000 out of 250000 steps  (6%)
[23:12:27] Writing local files
[23:12:27] Completed 17500 out of 250000 steps  (7%)
[00:06:20] Writing local files
[00:06:20] Completed 20000 out of 250000 steps  (8%)
[01:00:06] Writing local files
[01:00:06] Completed 22500 out of 250000 steps  (9%)
[01:53:58] Writing local files
[01:53:59] Completed 25000 out of 250000 steps  (10%)
[02:47:54] Writing local files
[02:47:54] Completed 27500 out of 250000 steps  (11%)
[03:41:48] Writing local files
[03:41:48] Completed 30000 out of 250000 steps  (12%)
[04:35:36] Writing local files
[04:35:36] Completed 32500 out of 250000 steps  (13%)
[05:29:31] Writing local files
[05:29:31] Completed 35000 out of 250000 steps  (14%)
[06:23:20] Writing local files
[06:23:20] Completed 37500 out of 250000 steps  (15%)
[07:17:15] Writing local files
[07:17:15] Completed 40000 out of 250000 steps  (16%)
[08:11:06] Writing local files
[08:11:06] Completed 42500 out of 250000 steps  (17%)
[09:04:57] Writing local files
[09:04:57] Completed 45000 out of 250000 steps  (18%)
[09:58:51] Writing local files
[09:58:51] Completed 47500 out of 250000 steps  (19%)
[10:52:52] Writing local files
[10:52:53] Completed 50000 out of 250000 steps  (20%)
[11:46:42] Writing local files
[11:46:42] Completed 52500 out of 250000 steps  (21%)
[12:40:30] Writing local files
[12:40:30] Completed 55000 out of 250000 steps  (22%)
[13:34:19] Writing local files
[13:34:20] Completed 57500 out of 250000 steps  (23%)
[14:28:12] Writing local files
[14:28:13] Completed 60000 out of 250000 steps  (24%)
[15:22:08] Writing local files
[15:22:08] Completed 62500 out of 250000 steps  (25%)
[16:15:57] Writing local files
[16:15:58] Completed 65000 out of 250000 steps  (26%)
[17:09:49] Writing local files
[17:09:49] Completed 67500 out of 250000 steps  (27%)
[18:03:44] Writing local files
[18:03:45] Completed 70000 out of 250000 steps  (28%)
[18:57:37] Writing local files
[18:57:37] Completed 72500 out of 250000 steps  (29%)
[19:51:35] Writing local files
[19:51:36] Completed 75000 out of 250000 steps  (30%)
[20:29:18] CoreStatus = 0 (0)
[20:29:18] Client-core communications error: ERROR 0x0
[20:29:18] Deleting current work unit & continuing...
[20:30:32] - Preparing to get new work unit...
[20:30:32] + Attempting to get work packet
[20:30:32] - Connecting to assignment server
[20:30:33] - Successful: assigned to (171.67.108.53).
[20:30:33] + News From Folding@Home: Welcome to Folding@Home
[20:30:34] Loaded queue successfully.
[20:30:47] + Closed connections
[20:30:52]
[20:30:52] + Processing work unit
[20:30:52] Core required: FahCore_78.exe
[20:30:52] Core found.
[20:30:52] Working on Unit 06 [February 2 20:30:52]
[20:30:52] + Working ...
[20:30:52]
[20:30:52] *------------------------------*
[20:30:52] Folding@Home Gromacs Core
[20:30:52] Version 1.90 (March 8, 2006)
[20:30:52]
[20:30:52] Preparing to commence simulation
[20:30:52] - Looking at optimizations...
[20:30:52] - Created dyn
[20:30:52] - Files status OK
[20:30:53] - Expanded 661808 -> 3332352 (decompressed 503.5 percent)
[20:30:53] - Starting from initial work packet
[20:30:53]
[20:30:53] Project: 6892 (Run 616, Clone 1, Gen 79)
[20:30:53]
[20:30:53] Assembly optimizations on if available.
[20:30:53] Entering M.D.
[20:31:00] Protein: ALZHEIMER DISEASE AMYLOID
[20:31:00]
[20:31:00] Writing local files
[20:31:39] Extra SSE boost OK.
[20:31:40] Writing local files
[20:31:40] Completed 0 out of 250000 steps  (0%)
[21:25:15] Writing local files
[21:25:15] Completed 2500 out of 250000 steps  (1%)
[22:18:46] Writing local files
[22:18:46] Completed 5000 out of 250000 steps  (2%)
[23:12:18] Writing local files
[23:12:18] Completed 7500 out of 250000 steps  (3%)
[00:05:52] Writing local files
[00:05:53] Completed 10000 out of 250000 steps  (4%)
[00:59:22] Writing local files
[00:59:22] Completed 12500 out of 250000 steps  (5%)
[01:52:52] Writing local files
[01:52:52] Completed 15000 out of 250000 steps  (6%)
[02:46:21] Writing local files
[02:46:21] Completed 17500 out of 250000 steps  (7%)
[03:39:55] Writing local files
[03:39:55] Completed 20000 out of 250000 steps  (8%)
[04:33:25] Writing local files
[04:33:25] Completed 22500 out of 250000 steps  (9%)
[05:26:57] Writing local files
[05:26:57] Completed 25000 out of 250000 steps  (10%)
[06:20:32] Writing local files
[06:20:33] Completed 27500 out of 250000 steps  (11%)
[07:14:07] Writing local files
[07:14:07] Completed 30000 out of 250000 steps  (12%)
[08:07:36] Writing local files
[08:07:36] Completed 32500 out of 250000 steps  (13%)
[09:01:14] Writing local files
[09:01:15] Completed 35000 out of 250000 steps  (14%)
[09:54:46] Writing local files
[09:54:47] Completed 37500 out of 250000 steps  (15%)
[10:48:35] Writing local files
[10:48:36] Completed 40000 out of 250000 steps  (16%)
[11:42:12] Writing local files
[11:42:13] Completed 42500 out of 250000 steps  (17%)
[12:35:45] Writing local files
[12:35:45] Completed 45000 out of 250000 steps  (18%)
[13:29:17] Writing local files
[13:29:17] Completed 47500 out of 250000 steps  (19%)
[14:22:46] Writing local files
[14:22:46] Completed 50000 out of 250000 steps  (20%)
[15:16:15] Writing local files
[15:16:16] Completed 52500 out of 250000 steps  (21%)
[16:09:44] Writing local files
[16:09:44] Completed 55000 out of 250000 steps  (22%)
[17:03:19] Writing local files
[17:03:19] Completed 57500 out of 250000 steps  (23%)
[17:56:52] Writing local files
[17:56:52] Completed 60000 out of 250000 steps  (24%)
[18:50:30] Writing local files
[18:50:30] Completed 62500 out of 250000 steps  (25%)
[19:43:57] Writing local files
[19:43:58] Completed 65000 out of 250000 steps  (26%)
[20:37:27] Writing local files
[20:37:27] Completed 67500 out of 250000 steps  (27%)
[21:30:55] Writing local files
[21:30:55] Completed 70000 out of 250000 steps  (28%)
[22:24:24] Writing local files
[22:24:25] Completed 72500 out of 250000 steps  (29%)
[23:17:57] Writing local files
[23:17:57] Completed 75000 out of 250000 steps  (30%)
[23:55:23] CoreStatus = 0 (0)
[23:55:23] Client-core communications error: ERROR 0x0
[23:55:23]
Folding@Home will go to sleep for 1 day as there have been 5 consecutive Cores executed which failed to complete a work unit.
[23:55:23] (To wake it up early, quit the application and restart it.)
[23:55:23] If problems persist, please visit our website at http://folding.stanford.edu for help.
[23:55:23] + Sleeping...
[23:55:23] Waking.
[23:55:23] - Attempting to download new core...
[23:55:23] + Downloading new core: FahCore_78.exe
[23:55:25] + 10240 bytes downloaded
[23:55:25] + 20480 bytes downloaded
[23:55:25] + 30720 bytes downloaded
[23:55:25] + 40960 bytes downloaded
[23:55:25] + 51200 bytes downloaded
[23:55:25] + 61440 bytes downloaded
[23:55:25] + 71680 bytes downloaded
[23:55:25] + 81920 bytes downloaded
[23:55:25] + 92160 bytes downloaded
[23:55:25] + 102400 bytes downloaded
[23:55:29] + 112640 bytes downloaded
[23:55:29] + 122880 bytes downloaded
[23:55:29] + 133120 bytes downloaded
[23:55:30] + 143360 bytes downloaded
[23:55:30] + 153600 bytes downloaded
[23:55:30] + 163840 bytes downloaded
[23:55:30] + 174080 bytes downloaded
[23:55:30] + 184320 bytes downloaded
[23:55:30] + 194560 bytes downloaded
[23:55:30] + 204800 bytes downloaded
[23:55:30] + 215040 bytes downloaded
[23:55:30] + 225280 bytes downloaded
[23:55:30] + 235520 bytes downloaded
[23:55:30] + 245760 bytes downloaded
[23:55:30] + 256000 bytes downloaded
[23:55:30] + 266240 bytes downloaded
[23:55:30] + 276480 bytes downloaded
[23:55:31] + 286720 bytes downloaded
[23:55:31] + 296960 bytes downloaded
[23:55:31] + 307200 bytes downloaded
[23:55:31] + 317440 bytes downloaded
[23:55:31] + 327680 bytes downloaded
[23:55:31] + 337920 bytes downloaded
[23:55:31] + 348160 bytes downloaded
[23:55:31] + 358400 bytes downloaded
[23:55:31] + 368640 bytes downloaded
[23:55:31] + 378880 bytes downloaded
[23:55:31] + 389120 bytes downloaded
[23:55:31] + 399360 bytes downloaded
[23:55:31] + 409600 bytes downloaded
[23:55:31] + 419840 bytes downloaded
[23:55:31] + 430080 bytes downloaded
[23:55:31] + 440320 bytes downloaded
[23:55:31] + 450560 bytes downloaded
[23:55:31] + 460800 bytes downloaded
[23:55:31] + 471040 bytes downloaded
[23:55:31] + 481280 bytes downloaded
[23:55:31] + 491520 bytes downloaded
[23:55:32] + 501760 bytes downloaded
[23:55:32] + 512000 bytes downloaded
[23:55:32] + 522240 bytes downloaded
[23:55:32] + 532480 bytes downloaded
[23:55:32] + 542720 bytes downloaded
[23:55:32] + 552960 bytes downloaded
[23:55:32] + 563200 bytes downloaded
[23:55:32] + 573440 bytes downloaded
[23:55:32] + 583680 bytes downloaded
[23:55:32] + 593920 bytes downloaded
[23:55:32] + 604160 bytes downloaded
[23:55:32] + 614400 bytes downloaded
[23:55:32] + 624640 bytes downloaded
[23:55:32] + 634880 bytes downloaded
[23:55:32] + 645120 bytes downloaded
[23:55:32] + 655360 bytes downloaded
[23:55:32] + 665600 bytes downloaded
[23:55:32] + 675840 bytes downloaded
[23:55:32] + 686080 bytes downloaded
[23:55:32] + 696320 bytes downloaded
[23:55:32] + 706560 bytes downloaded
[23:55:32] + 716800 bytes downloaded
[23:55:32] + 727040 bytes downloaded
[23:55:32] + 737280 bytes downloaded
[23:55:32] + 747520 bytes downloaded
[23:55:32] + 757760 bytes downloaded
[23:55:32] + 768000 bytes downloaded
[23:55:32] + 778240 bytes downloaded
[23:55:32] + 788480 bytes downloaded
[23:55:32] + 798720 bytes downloaded
[23:55:32] + 808960 bytes downloaded
[23:55:32] + 819200 bytes downloaded
[23:55:32] + 829440 bytes downloaded
[23:55:32] + 839680 bytes downloaded
[23:55:33] + 849920 bytes downloaded
[23:55:33] + 860160 bytes downloaded
[23:55:33] + 870400 bytes downloaded
[23:55:33] + 880640 bytes downloaded
[23:55:33] + 890880 bytes downloaded
[23:55:33] + 901120 bytes downloaded
[23:55:33] + 911360 bytes downloaded
[23:55:33] + 921600 bytes downloaded
[23:55:33] + 931840 bytes downloaded
[23:55:33] + 942080 bytes downloaded
[23:55:33] + 952320 bytes downloaded
[23:55:33] + 962560 bytes downloaded
[23:55:33] + 972800 bytes downloaded
[23:55:33] + 983040 bytes downloaded
[23:55:33] + 993280 bytes downloaded
[23:55:33] + 1003520 bytes downloaded
[23:55:33] + 1013760 bytes downloaded
[23:55:33] + 1024000 bytes downloaded
[23:55:33] + 1034240 bytes downloaded
[23:55:33] + 1044480 bytes downloaded
[23:55:33] + 1054720 bytes downloaded
[23:55:33] + 1064960 bytes downloaded
[23:55:33] + 1075200 bytes downloaded
[23:55:33] + 1085440 bytes downloaded
[23:55:33] + 1095680 bytes downloaded
[23:55:33] + 1105920 bytes downloaded
[23:55:33] + 1116160 bytes downloaded
[23:55:33] + 1126400 bytes downloaded
[23:55:33] + 1134407 bytes downloaded
[23:55:33] Verifying core Core_78.fah...
[23:55:34] Signature is VALID
[23:55:34]
[23:55:34] Trying to unzip core FahCore_78.exe
[23:55:35] Decompressed FahCore_78.exe (3435296 bytes) successfully
[23:55:35] + Core successfully engaged
[23:55:46] Deleting current work unit & continuing...
[23:57:00] - Preparing to get new work unit...
[23:57:00] + Attempting to get work packet
[23:57:00] - Connecting to assignment server
[23:57:01] - Successful: assigned to (171.67.108.53).
[23:57:01] + News From Folding@Home: Welcome to Folding@Home
[23:57:01] Loaded queue successfully.
[23:57:07] + Closed connections
[23:57:12]
[23:57:12] + Processing work unit
[23:57:12] Core required: FahCore_78.exe
[23:57:12] Core found.
[23:57:12] Working on Unit 07 [February 4 23:57:12]
[23:57:12] + Working ...
[23:57:12]
[23:57:12] *------------------------------*
[23:57:12] Folding@Home Gromacs Core
[23:57:12] Version 1.90 (March 8, 2006)
[23:57:12]
[23:57:12] Preparing to commence simulation
[23:57:12] - Looking at optimizations...
[23:57:12] - Created dyn
[23:57:12] - Files status OK
[23:57:13] - Expanded 661808 -> 3332352 (decompressed 503.5 percent)
[23:57:13] - Starting from initial work packet
[23:57:13]
[23:57:13] Project: 6892 (Run 616, Clone 1, Gen 79)
[23:57:13]
[23:57:13] Assembly optimizations on if available.
[23:57:13] Entering M.D.
[23:57:20] Protein: ALZHEIMER DISEASE AMYLOID
[23:57:20]
[23:57:20] Writing local files
[23:57:58] Extra SSE boost OK.
[23:57:59] Writing local files
[23:58:00] Completed 0 out of 250000 steps  (0%)
[00:51:30] Writing local files
[00:51:30] Completed 2500 out of 250000 steps  (1%)
[01:45:00] Writing local files
[01:45:01] Completed 5000 out of 250000 steps  (2%)
[02:38:29] Writing local files
[02:38:29] Completed 7500 out of 250000 steps  (3%)
[03:31:57] Writing local files
[03:31:58] Completed 10000 out of 250000 steps  (4%)
[04:25:26] Writing local files
[04:25:26] Completed 12500 out of 250000 steps  (5%)
[05:18:55] Writing local files
[05:18:55] Completed 15000 out of 250000 steps  (6%)
[06:12:20] Writing local files
[06:12:21] Completed 17500 out of 250000 steps  (7%)
[07:05:50] Writing local files
[07:05:50] Completed 20000 out of 250000 steps  (8%)
[07:59:16] Writing local files
[07:59:16] Completed 22500 out of 250000 steps  (9%)
[08:52:44] Writing local files
[08:52:44] Completed 25000 out of 250000 steps  (10%)
[09:46:17] Writing local files
[09:46:17] Completed 27500 out of 250000 steps  (11%)
[10:41:55] Writing local files
[10:41:56] Completed 30000 out of 250000 steps  (12%)
[11:35:23] Writing local files
[11:35:23] Completed 32500 out of 250000 steps  (13%)
[12:28:56] Writing local files
[12:28:56] Completed 35000 out of 250000 steps  (14%)
[13:22:27] Writing local files
[13:22:27] Completed 37500 out of 250000 steps  (15%)
[14:16:03] Writing local files
[14:16:03] Completed 40000 out of 250000 steps  (16%)
[15:09:35] Writing local files
[15:09:36] Completed 42500 out of 250000 steps  (17%)
[16:03:07] Writing local files
[16:03:07] Completed 45000 out of 250000 steps  (18%)
[16:56:39] Writing local files
[16:56:39] Completed 47500 out of 250000 steps  (19%)
[17:50:06] Writing local files
[17:50:07] Completed 50000 out of 250000 steps  (20%)
[18:43:28] Writing local files
[18:43:28] Completed 52500 out of 250000 steps  (21%)
[19:36:52] Writing local files
[19:36:53] Completed 55000 out of 250000 steps  (22%)
[20:30:21] Writing local files
[20:30:21] Completed 57500 out of 250000 steps  (23%)
[21:23:49] Writing local files
[21:23:49] Completed 60000 out of 250000 steps  (24%)
[22:17:23] Writing local files
[22:17:23] Completed 62500 out of 250000 steps  (25%)
[23:10:52] Writing local files
[23:10:52] Completed 65000 out of 250000 steps  (26%)
[00:04:26] Writing local files
[00:04:26] Completed 67500 out of 250000 steps  (27%)
[00:57:58] Writing local files
[00:57:59] Completed 70000 out of 250000 steps  (28%)
[01:51:29] Writing local files
[01:51:29] Completed 72500 out of 250000 steps  (29%)
[02:45:03] Writing local files
[02:45:03] Completed 75000 out of 250000 steps  (30%)
[03:22:29] CoreStatus = 0 (0)
[03:22:29] Client-core communications error: ERROR 0x0
[03:22:29] Deleting current work unit & continuing...
[03:23:43] - Preparing to get new work unit...
[03:23:43] + Attempting to get work packet
[03:23:43] - Connecting to assignment server
[03:23:43] - Successful: assigned to (171.67.108.53).
[03:23:43] + News From Folding@Home: Welcome to Folding@Home
[03:23:43] Loaded queue successfully.
[03:23:50] + Closed connections
[03:23:55]
[03:23:55] + Processing work unit
[03:23:55] Core required: FahCore_78.exe
[03:23:55] Core found.
[03:23:55] Working on Unit 08 [February 6 03:23:55]
[03:23:55] + Working ...
[03:23:55]
[03:23:55] *------------------------------*
[03:23:55] Folding@Home Gromacs Core
[03:23:55] Version 1.90 (March 8, 2006)
[03:23:55]
[03:23:55] Preparing to commence simulation
[03:23:55] - Looking at optimizations...
[03:23:55] - Created dyn
[03:23:55] - Files status OK
[03:23:56] - Expanded 661808 -> 3332352 (decompressed 503.5 percent)
[03:23:56] - Starting from initial work packet
[03:23:56]
[03:23:56] Project: 6892 (Run 616, Clone 1, Gen 79)
[03:23:56]
[03:23:56] Assembly optimizations on if available.
[03:23:56] Entering M.D.
[03:24:03] Protein: ALZHEIMER DISEASE AMYLOID
[03:24:03]
[03:24:03] Writing local files
[03:24:42] Extra SSE boost OK.
[03:24:43] Writing local files
[03:24:43] Completed 0 out of 250000 steps  (0%)
[04:18:20] Writing local files
[04:18:20] Completed 2500 out of 250000 steps  (1%)
[05:11:57] Writing local files
[05:11:57] Completed 5000 out of 250000 steps  (2%)
[06:05:33] Writing local files
[06:05:34] Completed 7500 out of 250000 steps  (3%)
[06:59:10] Writing local files
[06:59:10] Completed 10000 out of 250000 steps  (4%)
[07:52:45] Writing local files
[07:52:45] Completed 12500 out of 250000 steps  (5%)
[08:46:22] Writing local files
[08:46:22] Completed 15000 out of 250000 steps  (6%)
[09:40:00] Writing local files
[09:40:00] Completed 17500 out of 250000 steps  (7%)
[10:33:52] Writing local files
[10:33:52] Completed 20000 out of 250000 steps  (8%)
[11:27:25] Completed 22500 out of 250000 steps  (9%)
[12:21:02] Writing local files
[12:21:02] Completed 25000 out of 250000 steps  (10%)
[13:14:43] Writing local files
[13:14:43] Completed 27500 out of 250000 steps  (11%)
[14:08:27] Writing local files
[14:08:27] Completed 30000 out of 250000 steps  (12%)
[15:02:00] Writing local files
[15:02:00] Completed 32500 out of 250000 steps  (13%)
[15:55:39] Writing local files
[15:55:39] Completed 35000 out of 250000 steps  (14%)
[16:49:14] Writing local files
[16:49:14] Completed 37500 out of 250000 steps  (15%)
[17:42:50] Writing local files
[17:42:50] Completed 40000 out of 250000 steps  (16%)
[18:36:25] Writing local files
[18:36:25] Completed 42500 out of 250000 steps  (17%)
[19:32:38] Writing local files
[19:32:39] Completed 45000 out of 250000 steps  (18%)
[20:26:17] Writing local files
[20:26:17] Completed 47500 out of 250000 steps  (19%)
[21:19:51] Writing local files
[21:19:51] Completed 50000 out of 250000 steps  (20%)
[22:13:26] Writing local files
[22:13:27] Completed 52500 out of 250000 steps  (21%)
[23:06:58] Writing local files
[23:06:58] Completed 55000 out of 250000 steps  (22%)
[00:00:36] Writing local files
[00:00:36] Completed 57500 out of 250000 steps  (23%)
[00:54:09] Writing local files
[00:54:09] Completed 60000 out of 250000 steps  (24%)
[01:47:51] Writing local files
[01:47:52] Completed 62500 out of 250000 steps  (25%)
[02:41:30] Writing local files
[02:41:30] Completed 65000 out of 250000 steps  (26%)
[03:35:10] Writing local files
[03:35:10] Completed 67500 out of 250000 steps  (27%)
[04:28:49] Writing local files
[04:28:49] Completed 70000 out of 250000 steps  (28%)
[05:22:26] Writing local files
[05:22:27] Completed 72500 out of 250000 steps  (29%)
[06:16:07] Writing local files
[06:16:07] Completed 75000 out of 250000 steps  (30%)
[06:53:38] CoreStatus = 0 (0)
[06:53:38] Client-core communications error: ERROR 0x0
[06:53:38] Deleting current work unit & continuing...
[06:54:51] - Preparing to get new work unit...
[06:54:51] + Attempting to get work packet
[06:54:51] - Connecting to assignment server
[06:54:52] - Successful: assigned to (171.67.108.53).
[06:54:52] + News From Folding@Home: Welcome to Folding@Home
[06:54:52] Loaded queue successfully.
[06:55:02] + Closed connections
[06:55:07]
[06:55:07] + Processing work unit
[06:55:07] Core required: FahCore_78.exe
[06:55:07] Core found.
[06:55:07] Working on Unit 09 [February 7 06:55:07]
[06:55:07] + Working ...
[06:55:07]
[06:55:07] *------------------------------*
[06:55:07] Folding@Home Gromacs Core
[06:55:07] Version 1.90 (March 8, 2006)
[06:55:07]
[06:55:07] Preparing to commence simulation
[06:55:07] - Looking at optimizations...
[06:55:07] - Created dyn
[06:55:07] - Files status OK
[06:55:08] - Expanded 661808 -> 3332352 (decompressed 503.5 percent)
[06:55:08] - Starting from initial work packet
[06:55:08]
[06:55:08] Project: 6892 (Run 616, Clone 1, Gen 79)
[06:55:08]
[06:55:08] Assembly optimizations on if available.
[06:55:08] Entering M.D.
[06:55:15] Protein: ALZHEIMER DISEASE AMYLOID
[06:55:15]
[06:55:15] Writing local files
[06:55:54] Extra SSE boost OK.
[06:55:55] Writing local files
[06:55:55] Completed 0 out of 250000 steps  (0%)
[07:49:38] Writing local files
[07:49:38] Completed 2500 out of 250000 steps  (1%)
[08:43:18] Writing local files
[08:43:18] Completed 5000 out of 250000 steps  (2%)
[09:36:58] Writing local files
[09:36:59] Completed 7500 out of 250000 steps  (3%)
[10:30:53] Writing local files
[10:30:53] Completed 10000 out of 250000 steps  (4%)
[11:24:33] Writing local files
[11:24:33] Completed 12500 out of 250000 steps  (5%)
[12:18:12] Writing local files
[12:18:12] Completed 15000 out of 250000 steps  (6%)
[13:11:50] Writing local files
[13:11:51] Completed 17500 out of 250000 steps  (7%)
[14:05:34] Writing local files
[14:05:34] Completed 20000 out of 250000 steps  (8%)
[14:59:10] Writing local files
[14:59:10] Completed 22500 out of 250000 steps  (9%)
[15:52:51] Writing local files
[15:52:51] Completed 25000 out of 250000 steps  (10%)
[16:46:35] Writing local files
[16:46:35] Completed 27500 out of 250000 steps  (11%)
[17:40:20] Writing local files
[17:40:20] Completed 30000 out of 250000 steps  (12%)
[18:33:56] Writing local files
[18:33:56] Completed 32500 out of 250000 steps  (13%)
[19:27:37] Writing local files
[19:27:37] Completed 35000 out of 250000 steps  (14%)
[20:21:12] Writing local files
[20:21:13] Completed 37500 out of 250000 steps  (15%)
[21:14:52] Writing local files
[21:14:52] Completed 40000 out of 250000 steps  (16%)
[22:08:30] Writing local files
[22:08:30] Completed 42500 out of 250000 steps  (17%)
[23:02:07] Writing local files
[23:02:08] Completed 45000 out of 250000 steps  (18%)
[23:55:47] Writing local files
[23:55:47] Completed 47500 out of 250000 steps  (19%)
[00:49:23] Writing local files
[00:49:23] Completed 50000 out of 250000 steps  (20%)
[01:42:59] Writing local files
[01:42:59] Completed 52500 out of 250000 steps  (21%)
[02:36:30] Writing local files
[02:36:31] Completed 55000 out of 250000 steps  (22%)
[03:30:04] Writing local files
[03:30:04] Completed 57500 out of 250000 steps  (23%)
[04:23:40] Writing local files
[04:23:41] Completed 60000 out of 250000 steps  (24%)
[05:17:20] Writing local files
[05:17:20] Completed 62500 out of 250000 steps  (25%)
[06:11:01] Writing local files
[06:11:01] Completed 65000 out of 250000 steps  (26%)
[07:04:44] Writing local files
[07:04:44] Completed 67500 out of 250000 steps  (27%)
[07:58:25] Writing local files
[07:58:25] Completed 70000 out of 250000 steps  (28%)
[08:52:04] Writing local files
[08:52:04] Completed 72500 out of 250000 steps  (29%)
[09:45:48] Writing local files
[09:45:49] Completed 75000 out of 250000 steps  (30%)
[10:23:35] CoreStatus = 0 (0)
[10:23:35] Client-core communications error: ERROR 0x0
[10:23:35]
[10:23:35] (To wake it up early, quit the application and restart it.)
[10:23:35] If problems persist, please visit our website at http://folding.stanford.edu for help.
[10:23:35] + Sleeping...
Folding@Home Client Shutdown.
Re: Project: 6892 (Run 616, Clone 1, Gen 79)
The WU is a bad one as there were multiple failures:
The WU (P6892,R616,C1,G79) has been reported as a bad WU.
Thanks for the report.
